View Full Version : Maintenance & Car Care
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. Hatch Door Not Opening
  2. What's best for cleaning xB interior???
  3. Air vent Question???
  4. Anyone know how to siphon gas out?
  5. Water buildup in foglight wiring harness
  6. Rotten egg smell from exhaust??
  7. Got sandwiched between a black Honda Accord and a Ford F-250
  8. xA rear window air buffetting
  9. Constant water buildup whenever engine is running?
  10. Very Embarrassing
  11. Abysmal MPG
  12. Turn upon start/stop?
  13. Fuel gauge incorrect?
  14. best car buffer
  15. So I finally got my xB but something unexpected happened...
  16. Check gas prices
  17. XB Hard to Start Sometimes
  18. Blue Light stays on for a couple of minutes...
  19. Who has had problems which required warrenty service?
  20. Factory car alarm chirping?
  21. Anyones XB overheat?
  22. trac warning light and buzzer??
  23. LOUD thump in hard acceration, engine mounts?
  24. problems getting in to second gear
  25. xA A/C Problem!
  26. REAR DOOR HEIGHT
  27. attaching license plate
  28. front dash virbrates...
  29. AMP Installation Question?
  30. Air Compressor
  31. Does anything really happen when you complain?
  32. Idle...
  33. MAF sensor
  34. Steering Wheel off center issue?
  35. Clicks when im driving
  36. A/C Insulation
  37. smokin xb...
  38. under the hood.....
  39. rear hatch
  40. DGTLLVRs experience so far...
  41. Engine light on?
  42. windows cracked=funny noise.
  43. XB electronics gone!
  44. Mexican Box
  45. Steering Wheel Scratch
  46. sometimes hard to put in reverse...
  47. Air bag light/ beeping on hard turns????
  48. Water problem spots when washing
  49. Vibration found
  50. whistling noise when gasing it
  51. Engine Warming
  52. oh boy...problem with the clutch?????
  53. New to proper washing - have swirls, need help...
  54. silencing the traction/stability control beep?
  55. Glove Box rattle found =)
  56. High mileage ?
  57. Interior problem (underdash)
  58. maintenance/service light
  59. smells like burning rubber
  60. Stalling Problem - Cause Found!
  61. Driver's Side Fog Light
  62. what's wrong with the windshield?
  63. Speed sensor....
  64. Ugh - Door ding Questions
  65. VSC / TRAC OFF problem
  66. bugged by buggy windshield
  67. Scratches on interior plastic
  68. Automatic shift handle...keep bumping O/D switch
  69. Got a Rattle
  70. Touchup paint & sanding
  71. Engine problem! Please Help!
  72. window not working
  73. bumper in the back of your....
  74. Oil block adapter
  75. Noise with window down
  76. Chang Oil?
  77. The Right Foot
  78. Learn From My Mistake
  79. OBD-II protocol
  80. Clean windshield !!
  81. TRD/Aftermarket exhaust moving 56K warning
  82. Bad ticking noise from engine, pls help
  83. Scion/Toyota Security System Sucks and Scion/Toyota wont
  84. When to change Injen filter...
  85. Oil change at dealer with 2" drop springs
  86. BROKEN MOTOR MOUNT!!!!
  87. VSC ABS Traction Off
  88. Hot Lava- no badge
  89. Keyed door
  90. my XA Joined the ranks of the vandalized.
  91. Polar White XB stained by road grime
  92. free tires for life
  93. Randode takes out a tire at 90 mph!
  94. TRD exhaust problem (muffler burns exhaust cutout)
  95. windshield $291 installed
  96. CAI filter rubbing on plastic wheel well?
  97. New car smell fading
  98. rattle from rear
  99. My xA has spots!
  100. Badgeless Hot Lava #503 (i think)
  101. It happened again!
  102. Keeping your dark colored xB clean...
  103. power locks failed
  104. how to clean the interior?
  105. how long until first wax?
  106. How many quarts of oil?
  107. Gouged skirt/bumper
  108. Have you used your warrenty lately?
  109. instrument cluster ????
  110. airbag curtain cover?
  111. AEM intake
  112. How to maintain a showroom shine between shows with no wax
  113. Warranty work by Toyota on Scion
  114. windex
  115. When To Get The First Oil Change???
  116. Modifying the turn signal stalk
  117. 15,000 Mile Maintainence
  118. Cruise Control Rattle and getting stuff fixed
  119. Alternator Rated output?
  120. Source of Metallic Dash Rattling Sound Found
  121. Shift linkage JUMPED, nothing but 5th gear!
  122. Do your doors stay open?
  123. black cherry paint
  124. Engine Issues or Paranoia?
  125. AEM cold air induction air filter cleaning
  126. Dustless Brake Pads???
  127. Cracked Windshield
  128. Changing the color of the Luxaura light tubes
  129. Any mechanical Questions!
  130. Xb engine shakes a little and slight exaust leak sound help
  131. Waxing help
  132. Warranty
  133. CD ERROR 4
  134. Chattering Throwout Bearing
  135. "Cheap" floormats
  136. Hotchkis Front Sway Installation Problem
  137. MPG on Xb
  138. anyone try the mr. clean auto dry?
  139. prob with my xa
  140. Clunking from Coilover
  141. Inside Tailight access panel??
  142. Update to my problem with the security systems
  143. To the people whove had cracked windshiels
  144. Overheating/Not.Driving Xa Hard-Work School, lots of Traffic
  145. OVERHEAT- Engine - Unknown- Please Read- Let me Know
  146. Allignment Issues???
  147. Rubbber Plugs
  148. what's the proper way to dry a car?
  149. Zaino Question
  150. Why does my XB get only 18.5 MPG?
  151. hubCRAPS
  152. How to program the keyless remote
  153. Rain-X Question
  154. Zaino Bros #1
  155. Spedometer calibration with 19's (bad mileage)
  156. getting really annoyed with 2nd gear
  157. Cracked windshield
  158. california blade
  159. FYI on dealer installed cold air induction system.
  160. timing belt???
  161. Rear Door Window Moves
  162. axle is hitting the exhaust pipe
  163. oil pressure question
  164. Lava Intake chipping and bubbling
  165. Quality of stock windshield wipers?
  166. Maintiance Req. Light
  167. clunk sound when put into reverse from park
  168. I hate 16 year old truck driving kids!!
  169. Better paint?
  170. Lifter Noise
  171. Max RPM for Break-in
  172. Scratch on the Bumper
  173. Question for camo green guys?
  174. VSC, TRAC and Check Engine light all at once?
  175. Tips For Rear Bumper Applique Install???
  176. steelies bolts
  177. Cracked rear side window trim
  178. $200 15k service bill?!
  179. Pre-Possession Inspection Checklist
  180. Oil Change(s) - Which Brand used ?
  181. xB 10,000 mile fuel mileage data
  182. brake wear
  183. Mait recd light
  184. Guage Cluster Vibration
  185. my XB died beware engine horror story
  186. Rear Wiper Removal
  187. Smashed up rim
  188. synthetic gear oil
  189. Service Manuals
  190. Weird Rattle?!
  191. Damn Kids! Damn.Damn.Damn
  192. for those of you with a stock intake....
  193. xB Automatic + 4700 miles = Transmission Leak = Fun?
  194. Recommend wax for new car?
  195. swirl marks in my paint
  196. water driping from under the car
  197. Lifters making noise? Let's see some stats!
  198. Engine break in secret? What i have recently found
  199. Thin paint
  200. roof rain/water gutter loose?
  201. Radio went kaput
  202. Water wetter in a 2005
  203. Precision Axle back help!
  204. What Tire pressure?
  205. Guages
  206. Full Sized Car Bra?
  207. Electrical and Clutch issues
  208. Vehicle Cleaning
  209. Energy Conserving Oil???
  210. Grandmoms baby white 2k5 xB has a bo bo
  211. Zaino Distributor?
  212. Bigger OEM toyota filter found,but may not be the best
  213. Which Grade of Gas
  214. Check Engine Light on
  215. Problem W/Injen cold air intake
  216. HELP!!! Intake Problem
  217. B12 Chemtool
  218. xB Popping Noise on Trailing Throttle
  219. PaintScratch Paint Pens?
  220. Waxed 4 first time. Help...
  221. SLOW SHIFTING xB AUTOMATIC
  222. XB Odometer 4.5% Too Low
  223. reverse noise
  224. Howd you break in your engine
  225. New Seat Track
  226. how many of you bough the extended warranty?
  227. Windshield help!!
  228. Sideskirt removal
  229. Noise from CD Cover
  230. FogX Questions
  231. Is everyone getting their first oil change at 1000 miles?
  232. Wheel spacer install?
  233. Uh oh... oil change...
  234. Dealer Bull____
  235. Needing some advice, please!
  236. Fire Glaze?!?
  237. Problems with automatic xB Transmission??
  238. PLEASE HELP ME, SCION TC TROUBLE!!!
  239. What to use to clean WHEELS and car for the tC?
  240. when is the first oil change due?
  241. Back Badge
  242. UPDATE to accident: I REALLY NEED ADVICE!!!!
  243. faint squeak during acceleration?
  244. xB WINDSHIELD TIP! U BETTER READ!
  245. blue temperature light on startup
  246. Removing scuff marks from rocker panels?
  247. oil filter Part #
  248. STRANGE NOISE o(*_*)o
  249. What should I use to clean my dash?
  250. Recurring Check Engine Light! Anyone else?
