View Full Version : Scion xA/xB 1st-Gen Suspension & Handling
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15
  1. We need an xB strut sticky.
  2. bodydrop.... on 20's.... this is for real..!
  3. KYB G2R strange noise
  4. No one will fix the my xB
  5. Any Xa rideing on TRD Springs and TRD shocks ??
  6. Pics of Roll Cages
  7. DIY brake pad change?
  8. the package fariy dressed in brown came to town
  9. Another redundant shock/springs question...
  10. hotchkis drop?
  11. HKS Springs***Pics***
  12. Stock Drop...
  13. Spring Orientation Question
  14. 06 xA with H&R Touring Cup kit installed.
  15. The Hotchkiss Clunk?
  16. So many choices please help me....
  17. Are my rear springs crooked?
  18. Another xB with air suspension
  19. Pics of xB's on H-Techs/TRD's! Any SLIGHT drop!!
  20. Need specific information about df210s and adjustable struts
  21. Some Simple Mathmatics
  22. tein spring and wheelsize ?'s and pics
  23. Brake ?'s
  24. Randode's Bagged xB (New Video pg7)
  25. R1 Concepts' E-Line Performance Brake Rotors-Drilled/Slotted
  26. question on strippin my fenders
  27. my 2006 pw xb
  28. porformance shocks?
  29. 225/40/18
  30. pics of my zenn springs installed
  31. Trd spring coilovers
  32. Questions about H&R Sport Cup Suspension Kit.
  33. worth it?
  34. VSC and TRAC Lights On
  35. NF210's or S tech's??
  36. Traction control??
  37. **Edited**
  38. Springs
  39. Purchased S Techs (Tein) and am getting sensatrac 9870....
  40. Monroe Sensatrac 5987 install. Xb on ground? Xb on air?
  41. toyota prius
  42. Making xA ride smoother
  43. TRD Rear Spring Placement On XA?
  44. In Japan now and things are a little diff tein JDM
  45. jdm tein coilovers"low down spec light weight master Su
  46. Looking for advice for a smoother ride?
  47. front struts
  48. Interesting Alignment/Handling Issue in the xB
  49. Xa with TRD shocks/struts?
  50. XB running underground autocross track
  51. 916 NEED HELP
  52. suspension
  53. How do "BAGS" work?
  54. Advice is this correct? Hotchkis Springs (PIC)
  55. FBI complete kit for $1320
  56. Grinding, Vibration or Rubbing noise
  57. Eibach rear camber bolts?
  58. TANABE DF210'S
  59. the best suspension upgrade for performance is.....?
  60. Tein S Tech Springs
  61. What spring has the "highest" drop for xB rear???
  62. xA drop with no body kit??
  63. controll arm issue???
  64. new here, question about lowering
  65. Need Coil-Over Install Advice (JIC FLTA2)
  66. Need Better Handling In Bad Weather...Help?
  67. Air bag gurus please chime in......
  68. springs?!?
  69. Quick TRD Spring question
  70. bB Strut Bar
  71. Monroe Install Question
  72. trd rear sway bar & strut tie bar
  73. Suspansion problems?
  74. I'm buying an xA. Need coilover help (progress tech?)
  75. SPRING INSTALLATION UNDER $250 in LA????????
  76. COILOVERS OR AIR BAGS.?? WHATS BETTER ??
  77. Where can I buy White line sway bar
  78. Any springs that would lift the box?
  79. Coilovers and Rim Restrictions!!
  80. Blitz wagon damper W's are they worth it?
  81. What do you recommend?
  82. xB springs question??
  83. which springs are better
  84. megan racing springs
  85. Springtech camber shims...
  86. Quick Shock/Strut Question
  87. Greddy lower arm bars
  88. WHERE DO I FIND GOOD AIR BAGS?? BUT FOR CHEAP
  89. goldline springs blow... need help
  90. Smoothest riding suspension without giving up handling
  91. Suggestions Needed for Raising xA an Inch or so.
  92. Help Selecting new springs (xA)
  93. XA w/springs
  94. lowering???
  95. coilover rates
  96. Shocks/Struts Performance Upgrade!
  97. Complete poly bushing set for xB
  98. jic magic coilovers help
  99. Good quality of ride
  100. rear strut bar
  101. Blowin Strut??
  102. new steel braided brake lines shielded in colors
  103. Eibach Springs?
  104. new xb steel braided brake lines in colors
  105. HKS Spring***UPDATED PHOTO***
  106. Serious alignment problems...
  107. which coilovers?
  108. newbie sus. question/request......
  109. Question for the Daily Driven Dumped xB's
  110. problem with suspention
  111. KW-SUSPENSION
  112. what would be the difference?
  113. progressive rate springs
  114. Frame Brace Indecisiveness
  115. One Ton Garage (OTG) camber/spacer shims QUESTION
  116. Got my whiteline sway bar!
  117. some pics of my pw box
  118. Stock shocks and struts
  119. Air Suspension
  120. I'M SO HAPPY! DF-210's ON TODAY!!!
  121. The egg's air ride setup
  122. Front Sway Bar Bushings (OEM)
  123. Thoughts on coilovers?
  124. Engine lights
  125. best place to buy Tanabe DF210's ???
  126. Lowering spring question
  127. Can a XA take/use XB rear stock shocks?
  128. What about this strut bar - good or something else?
  129. spring question....Tanabe xa vs. xb
  130. I think my Xb handles better than my Mustang GT did!
  131. What shocks does everyone run with their DF210's?
  132. Shocks/Springs Questions
  133. Dumb Question From New Xb Owner
  134. From Air to Coilovers
  135. bent strut question
  136. Hearing a grinding/clunky noise when turning the wheel
  137. Full suspension rundown
  138. bam bam bam, slide slide slide
  139. Suspension for XA
  140. a little lucky if you like it...
  141. Still Pulls Left/Alignment Problems... Please Advise
  142. any good sleeve over coilovers
  143. Race Alignment from the Suspension Guru
  144. Wanna see my drop?
  145. On the monroes how many of the bump stops are you to use?
  146. Are coilovers THAT much better?
  147. Anyone tried these springs
  148. Monroe owner's opinions
  149. Are You Bagged And Drive Daily?
  150. New Springs
  151. Steering is very sloppy and loose feeling all of a sudden.
  152. spring
  153. Wheels Trimming
  154. Question: Is Tein pronounced teen or tine?
  155. Rear strut bar with quick release?
  156. need picts ro prove a point
  157. Ordered my S-techs today. Need advice now.
  158. Who sells a TRD Whiteline rear sway bar?
  159. Springs,Struts, and Shocks??????
  160. Ceramic or Semi Metallic Brakes?
  161. Does anyone know where I can get KW coilovers from???
  162. Slight lean
  163. Will these Monroe Shocks fit the XB?
  164. Where to buy springs, suspension parts?
  165. best bang for the buck?
  166. Adjustable Shocks! Which is the best ones to buy!
  167. question...? tein S techs and tire alignment
  168. HELP!! WHAT ARE THE DIFERENTS AIR SUSPENSION KIT ??
  169. need front brake help
  170. TEIN Coilovers
  171. D2 coilovers or Tein SS?
  172. racing seats
  173. How to improve ride
  174. rubbing!!! help!!!
  175. (xa specific) any experience with jic coilovers/hks
  176. **Edited***
  177. Lowest CoilOvers
  178. Coilovers for $34.00!! GO EBAY LOL!!
  179. so I rotated my tires the other day...
  180. Will stock tC springs fit xB?
  181. Who has the best $$$$ on Goldlines????
  182. Progress coilovers??worth it???
  183. Just Installed my new Goldlines and I am Flabergasted
  184. I put on lowering springs but.....
  185. Rotor Removal
  186. Clearance: 1 set of Tein S-Tech Springs for the xB at NAM
  187. Effects of rear swaybar in conjuction with....
  188. Best/Smoothest drop coils
  189. How often do you have to rebuild coilovers
  190. Hotchkis Front & Rear Bars Installed (pics)
  191. Is anyone running Koni Yellows and Tein S-Techs?
  192. strut bar question
  193. TRD SPRINGS $$$ Installed
  194. who's got the lowest xB?
  195. D2 owners.
  196. I Think My Breaks
  197. can someone find me D2 coilover pics
  198. Los Angeles/San Fernando Valley spring installl? Today?
  199. FBI airbags?
  200. Just got my Tanabe Df210s
  201. Springs
  202. pics of my drop. daily driven
  203. how do i install sway bars?
  204. Spring installation in Northern NJ?
  205. clearance issue with sway bar and subframe
  206. HELP!Monroe Sensatrak to Koni Adjustable...Is it worth it???
  207. DF210's Settling question W/Pics
  208. sloppy rear e brakes
  209. Great prices for KYB GR2 struts
  210. tanabe bf210
  211. New Monster Motorworks XB front strut bar
  212. All Pics of Tanabe Nf210's on xB
  213. Brake upgrades
  214. easy to install springs on xa?
  215. New Monster Motorworks XB rear bars
  216. New Monster Motorworks XB Roof bar
  217. Dropped my RS1 a bit...
  218. Scion/TRD springs vs. Tein vs. Eibach, etc.?
  219. universal air suspension
  220. Down - Down -Down
  221. Rear brake pad/shoe replacement?
  222. quick suspension question
  223. xa trd springs
  224. Strut Bars
  225. Buying a salvaged title car?
  226. a few questions that im sure you can find the answer too
  227. Leaning to the left
  228. underbody braces
  229. front camber
  230. S-tech's in front and stock in rear?
  231. steering stabilizers
  232. Anyone Have this?
  233. Removed Interior In Rear. I LIKE IT =0)
  234. need some shocks
  235. GT-Spec rear strut brace
  236. Coilover for 06 XB
  237. Insurance Lowered
  238. Stainless steel brake lines
  239. trd spring/shock for xa... bumpstops?
  240. rear airbag question
  241. F5FUJITA CAI + FRONT STRUT???
  242. Tein H tech vs. S Tech for xB's...
  243. 06 xB 30,000 miles brake noise problem rotors trim now what?
  244. xb bagged?
  245. options besides TRD shocks/struts
  246. lifted xB
  247. Feel every bump?
  248. air shocks for the rear of an xB
  249. c-one rear brace
  250. finally got my xb bagged
