View Full Version : Scion xA/xB 1st-Gen Suspension & Handling
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15
  1. Front sway bar endlinks?
  2. lowering xb's
  3. Post pics of 18" and 19" wheels, with a 2" dr
  4. Lowering issues
  5. Toyota Echo Shocks and Struts in a XB HELP!
  6. axxis pads & brakes in general
  7. what are one ton garage rear spacer shims?
  8. Torque spec for mid chassis brace / rear arm bar?
  9. Popping Noise in Front Suspension When Turning Hard 2 Park
  10. will i need camber plates with hotchkis springs?
  11. please help
  12. Getting Springs, get Struts too??
  13. Springs/suspension mods "ruin" suspension?
  14. Changed my Springs they look nice, but pulled my Axel!
  15. Rear disk?
  16. installed new suspension
  17. Who manufactures the lowest springs for an xb?
  18. Doing coils on my friends xA...
  19. looking for goldlines?
  20. wiring chart for asv 7 perwired box
  21. xB + Drop= Winter Woes?
  22. cut it up some more!
  23. Eibach opinions???
  24. powersteering pump pulley?
  25. hey i got a question!?!?!
  26. Noise in front strut...only 18xxx miles
  27. rear strut bars...
  28. Springs Real or Fakes?
  29. xA: Have Tanabe DF210's...Update!Installed Progress with pix
  30. Monroe 71575 Strut
  31. Issue with steering vibration at high speeds...
  32. Options to prevent scraping...
  33. ABS, TRAC Off, and VSC lights are on
  34. Can you stretch springs?
  35. TEDSBOX gets down first pics
  36. How long till it drops?
  37. Springs...?
  38. TRD Rear Frame Brace
  39. Goodbye Wheelgap, Hello Tanabes 56k: Maybe
  40. Shocks covered under warrenty?
  41. Question about air suspension...
  42. How much does the stock Scion xA front rotors weigh?
  43. Castor question (w/ solution now)
  44. Need info on shorter shocks
  45. Bagged our xB this weekend
  46. Need rear shock support in Orange County area
  47. XB ON AIR BAGS AND SUPERCHARGER
  48. check this out... Good handling xA!!
  49. Question aboyt the HKS SPF 5 spring
  50. air ride tank size question
  51. Problem if just getting Rear Koni's?
  52. Anyone have this???
  53. Coilovers: Biggest Drop
  54. cusco camber plates / ground control camber,castor plates
  55. Wheel Clicking on xB at 30 MPH +
  56. powdercoating shocks and struts
  57. Oh, what a feeling!!
  58. Turning Radius
  59. Vibration turning left
  60. check it out vented drum brakes!!!
  61. Tanabe Sustec Pro Air Cobra Coilover....anyone have them?
  62. SoCal xB with Hydro's!!!!
  63. Vogtland springs on xB? Anyone?
  64. Is a strut tower brace worth the $$$?
  65. shock/strut suggestions
  66. hyrdraulic system
  67. Koni Rear struts VS KYB front and rears
  68. rear tower brace?
  69. combining the hotchkis add-on rear sway bar?
  70. Spring Squeaks
  71. Best coilovers for your buck?
  72. gas mileage on different sizes
  73. KYO Coilover Springs - Anyone have experience with these?
  74. Power brake bleeder
  75. Stock wheels 2" drop any pics???
  76. Spring Question
  77. Anyone who has autocrossed thier xb PLEASE HELP
  78. Real Monroe Shocks SCION XB Part #
  79. Spring Installers in Bergen/Pasaic NJ area???
  80. NEW shock+struts VS coilovers?
  81. Anyone have the DC Sports Bar & Injen SRI?
  82. tein h-tech
  83. xb that are lowered
  84. xB Four Wheel Wilwood Discs...
  85. F*** Coilovers, im waiting for these!
  86. KSport coilovers: Softer Springs?
  87. Progress tech springs, suspension tech sway and
  88. custom rear camber plates in the works!
  89. Eibach or TRD with Monroes
  90. Anyone running HKS SF5s?
  91. koni shocks on sale
  92. air ride compressors
  93. newbie will this fit ?
  94. How many close calls have you had?
  95. HELP! Xb is acting very odd when at high speeds.
  96. xB rear air ride suspension.......which kit?
  97. K sport coil over!! Rear travel adjustment available??
  98. get'n the air ride on
  99. A few Questions About Tower Strut Bar
  100. VSC, TRACK OFF, CEL, light came on.
  101. Great price on Tein S Techs
  102. Front strut rubber boot replacement?
  103. DEAL FROM MMW to SL Xb Members on Stress Bar Sets !
  104. E-brake light on!!
  105. Front Drivers Disk Brake... help!
  106. I just lowered my xB with the Tenzo springs...what next?
  107. Videos of 2 xBs bagged by randode
  108. Tanabe df210's vs Progress coilovers
  109. REAR SHOCKS
  110. Monroe 5601
  111. best place to get TRD stuff inexpensive ???
  112. strut bar?
  113. What a differance!!!!!!(Pics)
  114. Whats wrong with my ride? Suspension feels so bad
  115. which valves for air supension
  116. xB autocross video
  117. 5601 follow up
  118. Lowering spring install
  119. Cambering and alignment shops
  120. Koni struts.... best place to buy them(service + price) ??
  121. tanabe sustec front strut bar?
  122. Coilovers that deliver a drop of 3.5" or greater
  123. my bagged RS 4.0 xB
  124. 2003 Echo w/ Tein Coilovers HELP!
  125. air lift rear bag brackets
  126. Monroe Sensatrac 5870
  127. does anyone have h&r race springs
  128. 1.5" or 2" drop w/ 15" wheels ? Pros/Cons ??
  129. Goldlines on stock xA
  130. pressure switch
  131. negative camber ?
  132. Megan Springs
  133. Sway Bars
  134. ground control coil overs???
  135. Hearing clattering noises after springs installation
  136. Tanabe DF-210 130 shipped
  137. does anyone have the APR 4 point frame brace
  138. Calling All Bagged Scions!!!!!!!!!!!
  139. Strut Studs
  140. Which Compressor
  141. Lowest Xb???
  142. Tein Springs
  143. Wheel spacers?
  144. how much drop. please help
  145. Hotchkis strut tiebar with Injen intake
  146. Hotchkis strut tiebar with Injen intake
  147. TRD Rear Frame Brace
  148. any quality riding 2" drop springs available ?
  149. xB Brake Hesitation?
  150. Coilovers + Sway bars
  151. How to remove calipers?
  152. For all the DF210 Peeps out there
  153. tokico hp struts for the xB?
  154. I need help from air ride/suspension gurus
  155. Tein H.Tech Installed. Before & After Pics
  156. Life BEFORE & AFTER Ksport ***PICS***
  157. TRACTION CONTROL /VSC LIGHT AND ENGINE LIGHT ON
  158. Scraping sound in front wheel???
  159. i need help on my xb
  160. cusco camber plate pros help with insight please
  161. trd spring questions
  162. air bag suspension...
  163. My df210 and medalion touring axel back install
  164. JIC vs. Tanabe
  165. Love my new 2007 SR4...but the seat is killing my legs! HELP
  166. Calling all Tein Basics!
  167. Old easy street Brackets
  168. clunking sound from rear air bags
  169. JIC lower arm bar
  170. worth lowering,again....
  171. pros & cons HKS C compact coilovers?
  172. opinions on cheap springs
  173. anyone using Eibach's?
  174. Which Spring? PLZ help!!
  175. Q for the peeps hittin switches...
  176. coilovers??
  177. Crappier ride?
  178. Review: APR 4-point frame brace and rear lower tie bar
  179. Just lowered my PW xb
  180. decent/cheap coilovers....
  181. does the yaris use the same parts?
  182. Just ordered H&R Sport Cup Kit and Progress Rear sway...
  183. 15 min. and rollin lower
  184. rear sway
  185. coilovers.....to cheap
  186. nvm
  187. Fender rolling on an xb???
  188. TRD spring quality? and combo with monroes
  189. Whistling noise from steering wheel.
  190. #1 Number one Sleeve and Spring Coil-Overs
  191. Tenzo R Springs... Good or Dont Waste The Money
  192. the sarcophabox get adrop!!!!!
  193. Wilwood Big Brake Upgrade for the rear.
  194. how does rear sway bar works( add on )
  195. Front air bag inquiry
  196. would progress anti sway bar fit 2003 echo 4 speed coupe?
  197. In search of more negative camber.
  198. lowest coilovers available
  199. What the hell???!!!
  200. Question regarding Air suspension install
  201. New rotor design?
  202. handling quesiton?
  203. Failed VA State Inspection
  204. Buying Tein-S spring, but shock question
  205. Just recently bought an xB. Question on lowering
  206. time to change my brakes..couple questions??
  207. air zenith mounting question
  208. Finally finished the air system...
  209. Air Management Valve Fill Controls
  210. replacing brake shoes
  211. ??? on Rear Upper Strut Bar
  212. rear chassis brace
  213. 03 fit 06
  214. H-brace arm ? on ebay
  215. Suspension Guru's in here!!!
  216. Axle problem
  217. Any luck with cheap ebay springs?
  218. Hotchkis vs. DC Sports
  219. Show me Xa's on Bags
  220. Which shocks when lowering?
  221. Lifted xbs?
  222. FBI Rides.com Promotion Code?
  223. before and after suspension mods
  224. Tokico D-Spec (HTS) + Road Magnet springs on xB
  225. Turbo and airbags??
  226. pros and cons of air bag suspension
  227. Looking for Springs!
  228. problem...the rear springs are lower than the front! HELP!
  229. s-tecs with stock struts question
  230. xA TRD Strut/Shock Part # Question
  231. drop ?????
  232. Oh crap, is this really bad? (knocking sound)
  233. Ready for the rear disc xB swap...but
  234. Front Anti-sway bar .... is it really needed ??
  235. new easystreet front struts
  236. Newly Lowered ( 56k I don't think so, big pics)
  237. OneTon Garage Rear Shim Alternatives?
  238. Jic front underbrace
  239. looking for all chassis pieces out there...
  240. does anyone set their suspension up for autocrossing?
  241. NRG Carbon Fiber Strut Bar [PICS]
  242. Smoother ride - what to do, how much & where to get them
  243. SRP xB on Tanabe NF210's
  244. need help on replacing control arm
  245. Has anyone DYI rolling fenders?
  246. Who found S-Techs cheap?
  247. post pics of your edfc controller!!
  248. C-One Strut Bar Installed ( Update 4-24 with three new pics)
  249. Slotted vs Drilled & Slotted
  250. Rear Toe!
