View Full Version : Scion xA/xB 1st-Gen Suspension & Handling
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15
  1. Anyone try these spacers off Ebay?
  2. Need help collecting strut bar pictures
  3. airbags and max wheel size
  4. one ton garage spacer = _____in' mod!
  5. Finally this day has come!
  6. -5 camber plates installed
  7. Lowest drop on springs for 1st gen xb
  8. Bagged Scion Videos ( 56k No No)
  9. xb --> yaris
  10. 4 wheel alignment on xb?
  11. Steering wheel shakes like mad at 70+ MPH
  12. Tanabe Sustec Under Braces Installed (Pics & Review)
  13. air ride lower on one side
  14. Springs... Tein, TRD, Tanabe? Please help
  15. Yes, another rear disc brake post!
  16. Skunk 2's need help camber kit? Struts?
  17. ksport kontrol pro coilovers question?
  18. Any one have pics of their car with lower suspension. {xA}
  19. xB Suspension Issues
  20. Looking to Bag Scion, need the Pros and Cons
  21. Flashers for LED turn signals
  22. Help, my car is falling apart at the seems!!
  23. Air bagged Kit
  24. i want more info on 1st gen xb lifts.. anyone?
  25. Tanabe DF210 on stock strut shock
  26. xB Brake pad installation
  27. looking for a complete kit to bag my xb
  28. astroJR got some air
  29. hey does the xb front struts the same as
  30. Defective (OE) brake pad
  31. New Monroe Shocks N Struts
  32. Easy street dampening adjustment??
  33. need advice/help on ksport coilover install
  34. ATTN PHOTOSHOPPERS: I need help with somethin...
  35. Rear camber?
  36. tien or eibach??
  37. floating front end huh what???
  38. Rear shock tower stiffner install????
  39. TRD rear shocks and Koni Front struts-Will this be OK?
  40. New Heavy Duty Hotchkis Sway's Sale for 1st Gen xB and xA
  41. brand new box set up on ksport coilovers
  42. Beatrush Front Performance bar ( with pics)
  43. tanabe df 210 on 18'' rims?? need answers please
  44. Strut brace bar installation?
  45. A Question for xB1 suspension gurus
  46. o the sexiness of tein ss+p's
  47. SHOCKS/STRUTS for xb
  48. 15 offset or 0 offset??? Sitting on DF210's
  49. Coilovers Question
  50. How much?
  51. k2 motor tc springs on the box
  52. front strut top nut tightening problem...........HELP
  53. front sway bar
  54. rear drum brake pads ?
  55. eibach front alignment bolts--- need help
  56. 1st Gen xB. Springs. TRD or Tein
  57. brake pad for xb 2005
  58. xB Brake Rotor help pls...
  59. lump...lump...lump...
  60. air suspension and low offset wheels + fender pulling?
  61. Post up pics of your air suspension in-trunk tank setups
  62. TC springs on XB
  63. lowering really make difference
  64. Coilovers?!?!?!
  65. Turn Rotors?
  66. Echo Struts
  67. instructions for changing 2006 xB brakes
  68. 1st gen xB brake life?
  69. Tein S Tech Springs-Sag???
  70. Need suspension help
  71. Anyone have the Weapon R "trunk cage" on their box
  72. Koni adjustable shocks/struts and Goldline springs.
  73. BEATRUSH STRUT BAR!!!
  74. gettin springs need few help
  75. so has anyone come out with a shock for this car yet?
  76. Sensa-Tracs 71575 vs. KYB GT-2 333258
  77. write up on parts for air ride.
  78. BEATRUSH front support bar
  79. Sensatracs for 06 XA?
  80. xA easy street bag setup?
  81. Post pics of how you ran your front air-lines.
  82. finished Koni Yellows w/ Sportline
  83. What shocks to use.....
  84. Bracing questions
  85. Strange frontend noise
  86. Bushings (Poly)
  87. need help finding big brake (front and rear) kit for xB
  88. Will Eibach camber kit work on Sensatrac front struts?
  89. noob here. want to lower my xb...
  90. another noobie question...
  91. Parking brake light in dash comes on...
  92. Question for those of you with Air setups.
  93. Tanabe Pro S-OC Type II vs. Tanabe Pro S-OC
  94. steering prob
  95. Can a 5gal tank EXPLODE???? (air suspension)
  96. Air Runner
  97. Tring to decide between springs...
  98. Drivers side slop
  99. Front sway bar question
  100. xb1 and xd suspension...?
  101. wanted: detailed pics
  102. Weapon-R front strut bar
  103. tein coilovers basic / SS
  104. Strut nuts
  105. Show Ur Pix
  106. Question about putting in springs
  107. which springs are right for me?
  108. Rotordisc
  109. new goodie
  110. Front Underbody Chassis Brace Comparison
  111. Where 2 Buy Sensatrac's???
  112. Finally dropped!!!
  113. coilover srping rates
  114. Lowering an '05 xB
  115. Smoother ride, new shocks and struts?
  116. Air ride?
  117. Spacer Help
  118. Suspension
  119. Show me your bagged xB
  120. Question on shocks and springs!
  121. Whats the stiffest rear shocks we can get?
  122. I Need a set of springs....Can Anyone help....
  123. Tein Springs?
  124. Tanabe Strut Bar?
  125. OEM hub bolt size?
  126. rear camber shimms
  127. i seem to be having an issue...
  128. Randode camber fix
  129. Looking for pictures of lowered cars
  130. Monroes with Eibach Prokit
  131. raising the thing a few inches
  132. Chassis reinforcement
  133. SCORE!!!!!!!!!!!
  134. HELP HELP! can decide between TEIN basic or Tein ss
  135. Tein basic Vs Tein Super Street
  136. HELP HELP HELP! downfall to Tein basic
  137. Quick Struts from Monroe on XB???
  138. COILOVER Ride, Height, Suggestions.
  139. just bought tein h techs for my 05 xb...
  140. Form and Function Coilovers for XB/XA installed.
  141. painting/powder coating springs
  142. Tein S-tech - Load capacity before bottoming/rubbing?
  143. KMW Performance Bag setup???
  144. Tanabe DF210 or Tein S-Tech for 215/45/17s
  145. SHOCKS AND STRUTS
  146. Do I have a camber problem after drop?
  147. wilwood bbk = bada$$
  148. lowering springs
  149. anyone using tein basics?
  150. any pics of a drop of 2.5 inches on coilovers?
  151. xA Struts/Shocks on xB??
  152. Source wanted/needed for the bB strut bar?
  153. How come no H Techs on ebay?
  154. Rear sway bar Xa...which one?
  155. xb trd spring part# 00602-48130-150 vs PTR11-52031-50 ?
  156. Need suggestions on suspension setup
  157. DIY strut tower brace
  158. Shaving the stock springs?
  159. Monroe Sensa-trac front struts with lowering springs...
  160. do i need a camber kit?
  161. kw coilovers vs. tein coilovers...
  162. High Performance Brake Pads and Shoes
  163. bb strut bar
  164. Scion xA Tanabe Rear 4-Point Under Brace
  165. xB strut mounts-Where to buy?
  166. show me your air bag setup
  167. Front poly bushings
  168. which coilovers to get?
  169. For all of you daily drivers and drive in hills...
  170. xB tool box!
  171. Hotchkis rear sway bar on EBAY steal of a deal....
  172. coilover question.
  173. swapping back to stock springs for winter?
  174. air ride: best bang for the buck?
  175. d2 coilovers min and max drop?
  176. Alignment problems??
  177. tein spring question on xa and echo
  178. H & R coilover help??
  179. D2 Coilover Questions
  180. noise after S-Tech install
  181. GI Camber and rear wheel spacers.
  182. Early xB and xA front disk brake shim installation.
  183. Project Mu Big Brake Kit for xA
  184. Front vs Rear springs
  185. help with front sway bar removal
  186. Air ride fitting Question
  187. break question
  188. Warining Lights
  189. Time to drop it
  190. suspension, shocks, struts, etc question
  191. any insight on these bags??
  192. Airbags and Fender rolling??
  193. fornt air strut leaking
  194. Bump stops question
  195. machineing cusco plates
  196. Suspension V6.0
  197. New wheels , fender rolling bumb stop saga
  198. Level?
  199. New air compressors on the market
  200. MONROE 5870 INSTALL
  201. Misc Brake Pad and Rotor Information
  202. Traction Control
  203. Any experience with front camber kit on xb?
  204. Easystreet front strut question. . .
  205. CAMBER? WHATS THAT?
  206. Weapon-R trunk cage
  207. Front Strut Choices?
  208. Questions about dropping my scion xb
  209. Tein S-Techs or Skunk2 Springs ?????????
  210. Air Ride blah blah blah.........
  211. Are these springs worth it?
  212. stock struts and shocks question.
  213. help: coilover problem
  214. nex coilovers?
  215. ROTORA GROUP BUY XA, XB
  216. Any tricks to make my back end drop a little lower
  217. Quiet and Strong air compressors???
  218. i want my xB to tuck on 17's w/ 205/ 40/ 17 what springs
  219. just lowered my xb with df 210s what shocks should i put on
  220. D2 Coilovers, PROBLEM!
  221. Finally New Wheels but know want Springs...
  222. Lowering My Car...In Need Of Advice
  223. Pulling to right under acceleration
  224. infamous pop sound from XBs EDIT: FOUND ISSUE.
  225. xA/xB have any camber probs?
  226. GReddy Lower Arm Bars
  227. Brakes 2006 xb has clunking sound when first put into dirve
  228. Edit.
  229. Springs? Coliovers?
  230. Monroe shocks/struts -- Buy 3, Get 1 Free!
  231. Clunk/Rattle in front end over slow speed bumps.
  232. Tein S Techs v Tanabe NF210's
  233. Air bags+fun = oops
  234. Finally did my springs....
  235. brushed caliper black
  236. After a long wait, finally got my progress coilovers.
  237. Strut-mount question
  238. Eibach springs
  239. Air bag questions
  240. Spacer Help
  241. Wheel studs??
  242. Newbie: What's used to smooth out ride for xB?
  243. KONI Shocks - Sport Yellows
  244. help, I installed 5601 Monroes in the rear, now I've noise
  245. Which Eibach Springs are better.
  246. air ride easystreet
  247. H Techs Rock! xB Before and After pics included
  248. New Drop, From TRDs to DF210....Much Happier
  249. Tein SS-P w/EDFC or S-techs & Koni
  250. Which strut tower bar? (installed pics for comparison)
