- Horrible day at replacing OEM struts to Monroe struts
- Any suggestions for getting front strut dust caps off????
- Shocks
- Monroe 72245 and 5601 = Horribly Jarring Ride
- RS 4.0 PAINT NIGHTMARES
- anyone running Progress Technology coil overs
- need help for a serious problem w/ my Air bags
- Help please with 2005 XB balljoints/control arm!!!
- KSport Coilovers buy from 12/2006?
- Repainting my Wilwood BBK
- A question for those with airride...
- Anyone with TRD shocks/struts and Tein lowering springs
- Smooth Ride
- Used lowering springs on stock shocks.
- DF210's, still the lowest Springs?
- Front Brake Rotor for 2006 xA
- First time lowerering my car.
- Alignment
- xB: WOW! New Shocks and RSB
- xA ride height question
- |Dezod Motorsports| Axxis Ultimate & Deluxe pads in STOC
- springs finally
- greddy strut bar
- do replacement shocks come with the bump stop?
- Lowering Springs?
- eibach or tanabe?
- My Performance Suspension build (with reviews of parts)
- why rough? trd springs and monroe all around
- The good, the bad, and the ugly - Coilovers
- traction control/VSC question.....
- 215/40/17 With Tein S lowering spring help/question.
- need some help with lowered box
- OFFICIAL: Tanabe Sustec Under Brace for Scion XA!
- Rear Trailing Arm Bushing anyone?
- opinion on springs/shocks
- help with stocks strut assembly?
- Help finding driverside lower control arm
- Project MU Type NS vs. Endless Vita Nuova ?
- WARNING!!! Airlift Struts could be dangerous
- K Sport Coilover adjustment issue -please help!
- Need a shorter shock than 5870
- Brake Rotor suggestions, where did you buy yours? xD
- Tein Springs
- Rear shocks xB 1st gen.........
- Wheel Bearing Help Please
- DF210s vs. TRD
- Best place to buy/get lowering springs installed???
- h-tech or Eibach P kit- Any PIcs or Suggestions
- I need pics of New ES Struts
- my s-tech spring install (Pics inside)
- Ride Height Balance?
- anybody tried these springs or know anything about them??
- KEOKI shims contact?
- suspension help!!!!
- dropped on H&R sports and Bilsteins (+ new control arms)
- removing rear springs
- Could I of messed anything up?
- HELP!! Mystery rattle after suspension install.
- Question on Energy Suspension Bushings installation
- Yaris Springs
- Very Sloppy Steering - Please Help!!!
- sigh.....
- Looking to get your box stiff? Look no more!
- alignment gauge
- Tanabe Coilovers Install
- Cheapest place for Monroe shocks/struts??
- Noise in the back.
- Quick advice, 1 inch drop/quality springs for around $200
- K-sport OR Tein basic for a Low Comfortable Ride.
- Power Steering Flush
- Brake Pad And Rotor installation help!
- Gen 1 Eibach Sportline springs...rears Binding...
- Price for Sensetracs all around shockwarehouse.com
- lowering and air struts
- Dumb Question, Just need to be sure before I spend the money
- Camber Shims and alignment
- Rough Ride, Smoother ideas?
- Firestone Lifetime Alignment
- alignment gauge direction how?
- quick question about the front strut top hat
- my review of the NEW new Easy street struts
- Should I finally do it? (Sensatrac)
- Group buy for Swift Springs
- jbt 6-piston brake kit review
- adjusting coilovers?
- Plug&Play Air Suspension!?!?
- B&G Coilovers or springs?
- HELP WITH SUSPENSION PLEASE READ IM DESPERATE
- is it bad to cut the springs??
- birthday coming up, getting springs and strut bar..
- going susp, need some good suggestions.
- xB1 rear wheel bearings.
- How Low Can I Drop Before I Cant Turn?
- ok another suspension question
- new look after new suspension
- My new custom top plate for the new Easy Street struts by EZ
- slowing down airride suspension
- Tein Basic Coilover question xA=xB?
- DIY on how to take apart the new Easy Street struts.
- anyone running koni sports?
- "STD" Coilovers ("STANDARD") for gen1 xB
- Air suspension help!
- strut bar question
- HELP. STD 1st Gen xB wheel alignement, toe, camber data.
- Hub Help
- get down.
- Megan Springs
- Torn Between DF210s and Prgress Tech Springs
- NEED HELP!!!
- looking for in-expensive coilover kit any suggestions?
- Springs Settling In???
- Air suspension installation
- Xb spring question
- R1 Concepts Rotors
- cheep frame brace
- front and rear sway bars
- What to look for in Coilovers
- shocks/softer ride
- D2 coilovers or Tein Basics. about the same price
- Air suspension problems in cold weather
- Anyone have a source for the old spy springs
- Tanabe Sustec Pro S-0C Type II
- GTSPEC Mid Chassis Brace for me on ebay
- shocks and struts...
- A few suspension questions
- Replacing Front Wheel Bearings
- Lovin' the Greddy FWD Brace
- Guess Who's Dropped!
- softest / most comfortable coilovers
- Stock height, better handling shock
- "Good Handling" Air Suspension
- Shock Q
- Part number help?
- what brand of coilovers do i choose??
- Anyone with a TRD red front strut bar?
- Tein S-Techs with stock wheels and tires will it work?
- Please post a pic of xa TRD or DC Strut bar installed!!!!!!`
- Hotchkis Sway, Eibach Pro Kit, Monroe Sensa Tracs install
- Brake Question....
- FREE used Spy engineering springs if you install oem springs
- NF210 owners please help
- i was curious to know!?!?!?
- TRD struts and shocks with other brand drop springs
- photo needed from under the xB
- tein ss-p or ksports gt pro
- Where to grease/lube front suspension?
- Changing brake pads and rotors on '04 XB
- NEW $100 TRD REAR SWAY BAR shipped
- Front Sway Bar--Pros and Cons?
- anyone with nf210s?
- can anyone help me out?
- Roof bar and trunk cage kit?
- Cheap TRD's for bid on Ebay right now
- EZ's 1st air install all done
- what coilovers are the lowest
- VSC and TRAC OFF light came on..........
- auto-x and track pics!
- StopTech Slotted & Drilled Rotors
- okay.SuGGestion and HELP.wiGGLy.
- Shock Blown
- how to reduce or NOT rub at all.
- are these safe to EVEN USE.!?!?
- 15 mm rear shims
- Good deals on spings
- spacers
- lowered with new rims :)
- So New To This...
- so is it my suspension or my wheels?
- any brake upgades out there rear disc? larger fronts?
- done alot of reading here and want some opinions
- Edit...
- 1st gen TRD springs with the echo struts
- ~365Motorwerks Now has SS Brake Lines for your xB!~
- help with rotors
- removing front calipers on 1st gen xb
- tech help with alignment problem - think I broke my XA
- When to change your rear brakes...
- HELP!!! VIOLENT SHAKING
- Rear camber shims
- Easystreet air ride components made in the USA again.
- What shock do you use when u bag xb
- Need Help
- New Suspension Mod(Pic Inside)
- Need suspension help
- Xa Caliper Bolts
- C pillar Bar?
- day 1 airride install
- Is Evolved Concepts & One Ton Garage Out of Business?
- JDM TRD Rear Suspension Brace for VItz/Platz
- Starting to make air ride struts and manifolds.
- Front Control Arm and Rear trail arm bushings
- woud front camber bolts help me?
- Trouble Choosing
- springs pinking and clanking ?
- 06 xb vs 07 fit for auto x
- air tanks
- -3 for me! With steelies :(
- What springs to go with
- Need Help!
- I was recommended D2 Coilovers.....
- GT Spec front under brace installed
- quick spring question
- Best dampers/shocks?
- Monroe Rebate Now.
- ebay quick release? help!
- ksport coilover question
- what the difference between??
- tanabe df210 + __________?
- Rear sway bar is a must have!
- will you rub on 185/ 60/ 15 with df210s
- Squeezing Sound In Rear Shocks.
- Ksport Coilover Prices???
- huge wheel gap + air shocks = much better
- Decision made...
- Loud break pedal
- First Gen xB brake pad replacement
- Need info on Shocks,Dampers, springs for my Box.
- which strut/shocks?
- EZ-Baked Rear billet bag mounts now availiable
- I need help with my rear suspension set up
- With DF210 would i still be okay???
- has anyone use these before???
- Monroe 5870 or MA815?
- Soft ride / taut handling?
- Getting rdy to buy coils, but which ?
- Bad wheel bearing- replacement under warranty?
- Tein S-techs shot after 15000 miles?
- Need Help Troubleshooting!!- AIRBAGS
- Lowering springs with too much rust?
- Quick Q about Evolved Concepts camber shims
- Help me decide....
- koni rear length?
- Anybody on Eibach Sportline lowering springs?
- What springs for my needs and my xb1??
- H&R race springs
- '04 xB front sway bar worn bushings
- 10 mm spacer shim whos selling/making these?
- Driver Side Thump/Clunk Noise?
- General question on shock absorbers
- Rotors and Pads - Which Ones?!?!
- progress coilovers for the gen 1 xb
- trying to achieve dumptness on my xa.
- air ride question. for bagged xbs.
- question for all who have airride
- xa on coilovers.
- Energy Coil Spring Isolators?
- Tanabe S-0C coils or springs
- Can I go with anything Smoother?
- KONI FRONT Struts Alter TOP HATS??
- *edit*
