- I'm lost and stuck with spacers :(
- my custom coilover build thread ;)
- question on rear shock removal
- should i be concerned about this?
- Tanabe Pro Sustec S0C Anyone?
- Air Bomber airride all done
- Air Ride Installing Question.
- Coilover "max height"...I need your opinion
- Any pics of Eibach Pro on 16's
- adjustable springs?
- Brake issue
- mystery problem need help.
- shock suggestions with S-techs.
- Left foot braking?
- How low can u go on coils ?
- RealCamber.com camber plate instal.
- Does energy suspension bushings kits for xB fits xA?
- Alignment or Rotors?
- Anyone with H&R sport spring on a xA?
- can you do your own alignment?
- Rear Passenger Side sticking out more than Driver's Side?
- Rear hub bolt size???
- Finally got some camber
- New Koni STR orange
- Kinda sucks to be an auto tech sometimes!
- best time to do sway bar end links?
- coilover vs springs
- are these coilovers even worth it getting?!?
- GTSPEC Type F Rear Strut Brace on ebay
- 05
- does any have EIBACH Sportline springs on 15's pictures!?!
- Improving suspension on a xA
- I need to read the rules
- Why am I not as low as some people?
- Help? Can't adjust dampening on front k Sport coilovers
- Installed D2 Coils but run into few problems.
- VSC and TRAC
- Need help with Strut Bar installation.
- anyone have pictures of an xa on eibach sportlines?
- I messed something up with suspension.
- F it, I'm done! Who wants to buy an xB?
- tanabe nf210 install with tokico blue's
- HELP!! wheel turns when stepping on brakes?
- Do the 1st gen xb and xa use the same springs?
- Rear Shoe Replacement
- 4 link suspension
- drivershaft!!!
- xA killing my back
- Sway bar and strut bar...
- OTG onetongarage.?
- What's better. Soft springs firm shocks or Vice versa
- Weird noise at 20-25mph
- Lease is up this month, Prob with suspension? clunk and wandering
- Help with slight rubbing.
- Ground Control coilovers..
- Rear discs
- Koni Struts Smooth?
- front strut bar: Aluminum, Steel, or titanium?
- Hard right turn = something rubs
- GT-Spec Suspension bars
- xB and xA engine bay
- Raceland doesn't make coilovers for the 1st gen xB so ...
- Broken ABS Sensor
- Brake Noise
- Weird noise coming from front driver's side?
- XA tanabe df210 and nf210
- How to put back shock in ?
- suspension spring bushing? anyone know where i can get some?
- Help install springs Chicago Area? Xa
- TEIN Basic Coilover noise
- Need Help, front suspension
- Smoothest/softest Shocks for 2006 Xa?
- Handles like its being wind buffetted?
- New Shocks and Struts
- trying to figure out thr rear and front lowering springs they came unmarked.
- megan racing
- Scion XA front rotor bolt size????
- Anyone used Hotchkis comp swaybar?
- 05xA DIY lowering springs
- New suspension, now issues
- Koni Shocks on Sale @ Tire Rack until 6/30/10
- Opinions on springs
- Alighnment angels
- FORJWORKS 2005-2007 5Deg Camber shims
- Which Coilover kit should i go with???
- Need to find brake pads/rotors....
- Shocks and Struts, part numbers please?
- Air shocks
- Hotchkis bumpstop broken
- Positive Camber After Coilovers
- pulling left only after turning left
- New Air for my Box
- I need M.O.R. slotted rotors for my 06xB...
- slammed on coilovers
- What are some quality brakes I can get?
- Need help on coilover camber plate replacement
- Help! Monroe rear shock install, pic included!
- xA Monroe Front Strut #s?
- Here is the supension setup I want, what do you think?
- Stiffer rear shocks
- difference between xa and xb trd shocks and struts
- More Weight in Back - Stiffer?
- Emergency brakes
- im buying from ptuning.. df210,, good or bad???
- eibach sportlines pro kit
- Which coilover (springs) are closest to stock ride?
- Question regarding lowering springs
- Megan Strut Tower Brace - Yea or Nay?
- Oh no! It's the darn ball joint again!
- Can't untie shock from coilover
- Best place to buy coils from?
- Camber bolt question please help
- xb coilovers on an xa?
- Big Problem
- DIY Rear Helper Bags
- Is anyone running a 2-way air setup?
- TRD Springs
- mounting nuts for shocks?
- Need coil overs
- Sway Bushings Question...This bad?
- Few questions on rotors/brakes/lines
- Looking for Rotors?
- Changing wheel hub and bearing...
- Removing hub spacers, what size are the factory bolts?
- Play in the steering
- Can I use the Echo rear shocks with stock springs?
- coilover Tein SS-P question
- Daily driver suspension question
- rear sway bare w/ air ride kit?
- New Type of Monroe Shock with Dust Cover
- Alignment problem. Makes me wanna cry.
- Monroe guides?
- Close up the wheel well.
- Monroe Bearing Plate - defects..or?
- Bagged gen1 xb looking for camber!
- I have some question on the Koni's I just bought.
- Flipping the hats?
- Gen 1 Air Stunner Elite Struts by Randode
- Lowering Springs Question
- Argh! Gen. 1 xB strut question
- Rear struts to hold more weight
- help guys!
- Steering wheel shimmy
- I want a Cushy Ride!
- how to lay bumper on an xB by Randode
- Creaking/groaning under front end
- what to do if rear shock bolt is just spinning?
- Best Coilovers for xA
- Opinions, coils ($665) or bags...Progress kit experiences?
- weird noise while driving
- Tenzo R springs
- Noise while cornering. Was told it's the rack and pinion--repair cost $1500. Input?
- Driver side suspension rattle..
- Good springs?
- How do I raise the rear height?
- Looking to lower my box. Which way Shud I go?
- DISCOUNTED monroe 71575 struts etc.
- Power steering problem
- TRD Lowering Spring issue..
- Sway Bar Link & Tie Rod End
- the Ultimate Air Ride Switch Box
- noise from front right wheel
- -3 an -5 camber shims (1st gen xb) -SOLD-
- Coilover kit help
- 2005 Xa RS1 Suspension
- traction control
- Cutting coilover springs
- Power Steering Issue
- KSport Coilovers on a 1st gen XB
- stock springs
- Will DF210's rub on 15x7 41et 185/65/15
- Planned suspension upgrade xB1, any forseeable issues?
- stationed in england and need rear shocks ASAP
- Boot Cover
- When to replace TRD springs..
- Has anyone gone back to stock springs recently?
- Looking to order rear coilover springs
- Need Suspension Advice!! I am an all stock, clean slate.
- rear frame brace or rear sway bar
- Rebuilding air lift strut?
- killed my Energy Suspension Endlink Polyurethane Bushings
- Echo front struts and bumpstops
- Smoother ride for 2006 xB - Monroe?
- Raceland coilover kits are now available for 1st generation scion xb's!
- TRD rear bar
- Suspension Repair After Crash
- best shocks for Scion Xa 2006 with eibach suspension?
- Does anyone have the contact info for Mike from M2 Motoring ?
- Clunking noise from front end when going over bumps
- Question about these coilovers
- Can I be directed to the energy suspension bushing post with all the part numbers
- need help on finding a single 06 scion xb trd rear shock
- Hydraulics?
- TRD shocks & springs for scion xA
- Please just a easy answer.....
- Results of my alignment check
- Edit
- You air baggers out there
- Scion XB AirREX Air Suspension
- 2005 XA Front Suspension Squeak
- rattling from the front driver side wheel area
- xA stabilizer pins?
- Removing front strut bar
- 100k end link change
- Struts and shocks at 85K?
- Input needed
- KSport Pros Clanking Sound
- power sterring belt hits when layed out
- Right Hand Drift?
- 2006 xb Rear alignment off. Any kit to fix this??
- XA rear camber question
- xB Rear spring Specs
- new shocks?
- Question about suspension setup
- swaybar or ?
- kyb
- simple coilover questions.
- K-Sport suspension
- Progress Coils on xA?
- Coilovers with ZERO drop
- Springs and spacers
- Tanabe Sustec Pro S-0C Street & Track Coilovers
- Raceland Coilovers on xA
- Let the mods begin
- want to go lower but can i take theses bars off ??????
