View Full Version : Scion xA/xB 1st-Gen Suspension & Handling
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15
  1. finally dropped the box!!! with pics that are fixed
  2. Best springs for stock shocks (long-term)- Suggestions?
  3. Need opinions on springs
  4. H&R springs on XB?? anyone?
  5. MEGAN SCION XA XB BB FRONT STRUT BAR
  6. Tanabe bump stops
  7. Anyone have Tein H-Techs ?
  8. Just ordered Tein S-techs...
  9. upgrade tires on xb?
  10. Fujiz review of the Tanabe DF210's
  11. Questions on air bags.
  12. Hotchkis Sport Coil Springs Installed. Before and After Pics
  13. long term effects of lowering
  14. anybody have the trd lowering springs + shocks?
  15. TRD shocks and sturts with Tanabe DF210s
  16. Install Direction of Tein Rear on XB
  17. Questions about TRD Springs
  18. Which air setup?
  19. anyone got fabulous coilovers?
  20. xA with TRD springs and 17's
  21. ??? difference on springs???
  22. Anyone with H-Techs...
  23. Do coil-overs creak like springs?
  24. suspenion ?
  25. suspencion
  26. if the front springs aren't seated right...
  27. I need some advise
  28. air suspension
  29. Tein H Tech installed - first impressions
  30. Aftermarket Suspension Question
  31. Front spring comes off strut!!!
  32. Airride (bag) systems, homemade, not kit
  33. How does the xB handle in the wet?
  34. Can I go any lower?
  35. To Drop or NOT to Drop
  36. Lowering Springs
  37. Scion Xa RS 1.0 Suspension Questions - Steering Feedback
  38. JIC Type 1 Frame brace
  39. Best price for TRD struts?
  40. Strut compatibility?
  41. OTG Shims installed ***Pics***
  42. What Springs? How Low?
  43. Goldlines and steelies (until next week) on RS 2.0
  44. Shaky steering with new springs
  45. Before and After spring pics - Stock, NF210's, DF210's!!!
  46. Bagged Xb owners need your help!!!
  47. Springs installed wrong?
  48. Wheels shims for rear only?
  49. Just got done with back bags
  50. metal to metal "clank" on new install of springs
  51. VIDEO xb in autocross
  52. TRD shock and strut set
  53. who has bags on there scion??
  54. who has bags on there scion.
  55. rear wheel spacers...
  56. lowering my xb
  57. strange "engagement" noise
  58. Tire Size Question
  59. ditching the bags and need ideas bad like!
  60. Hotchis stage one Suspension any good?
  61. I'm Stoked
  62. Which Rear Swaybar?
  63. Bump Stop Trimming on Spring Installation
  64. How to tighten top strut bolt?
  65. Any recommendations on lifting the box
  66. One Ton Garage Shims
  67. Progress Rear Anti-Sway Bar Install walkthrough
  68. Largest spacers you can run?
  69. xB Stock Spring Rates
  70. New rims
  71. $32 ebay coil-overs? any good?
  72. H-Tech problem..NEED HELP
  73. has any of yall ordered anyhting off airbagit.com?
  74. trd shocks help
  75. Progress Springs Good or Bad?
  76. I'm thinking about cutting my springs...
  77. Tein S.Tech vs. Tein High Tech springs...
  78. Should I buy these three things
  79. can anyone tell me...
  80. Coilover owners help
  81. everyone keeps sayin airbagit.com sucks
  82. xb springs
  83. coilovers
  84. draggin a Xb
  85. strut bars
  86. how to adjust rear camber
  87. Best things to do for handling?
  88. Anyone with these rims?
  89. Eibach Springs
  90. Ksport USA looking for xB owner for test fiters
  91. Koni Aftermarket Shocks - Soon!!!
  92. NEED STRUT BAR TODAY!
  93. I want HKS SF5 Springs...
  94. one ton garage
  95. Might loose the bags in favor or coilovers but need help
  96. Is this worth getting???
  97. H&R spacers or chassis tech spacers?
  98. Xb's with bags need your help! not the same question
  99. people told me it would happen and it did
  100. N-Brake NA-Performance Brake Pads Intalled! PIX! Update 5/5
  101. spacers
  102. loud rear wheels
  103. Big ___ sub box makes me wonder about springs.
  104. I just installed my TRD springs.
  105. performance suspension parts
  106. Tanabe DF210 Legit??
  107. Can you BAG the XA
  108. to put 20s on the xb
  109. wheel spacers in the parts review section
  110. airbag install question?
  111. Tein S Techs or Goldlines?
  112. .:Noise from front suspension
  113. JIC Magic Carbon Fiber Strut Bar
  114. whats more effective?
  115. be sure to check your lug nuts...
  116. aerospeed springs
  117. new pics of my box with H&R spacers
  118. Front Strut Tie Bar
  119. Wondering if this idea works...
  120. xB Spring installation PDF guide
  121. strut tower brace
  122. Springs and choppy ride
  123. hot springs
  124. Will I need camber correction for xB Goldlines?
  125. Goldlines vs. RS*R springs
  126. Scion Xb Wing
  127. Dont xA and xB use the same springs?
  128. Rear shock tower cross bar
  129. Anyone have these?
  130. What would be reasonable???
  131. Tein WAGON dampers
  132. Air Ride question?? Need help asap!
  133. Coil-overs vs. Springs Scion XB
  134. Sport Spring kits...
  135. Adj. Front Cambr Plates?
  136. Question regarding springs/coilovers? xB
  137. air ride question? first one.
  138. Spacer for XA.
  139. one ton garage spacers
  140. Question about rear sway bar
  141. Installing Tanabe DFz
  142. megan springs
  143. Hey xB owners with Goldlines installed...
  144. Steering Wheel question.....
  145. widetrack box
  146. Settling time?
  147. where i can buy the progress sway bar for cheap?
  148. xb :: Who's runnin the RS*Rs
  149. RS 2.0 looking for strut bar...
  150. Brake upgrade
  151. I want to lower my 05 XB
  152. Is it easy to lower the XB?
  153. How do I pick springs????
  154. "anti-sway bar"
  155. TRD springs...and shocks?
  156. Has any one used these spring kit ????
  157. Springs: To Tien or not to Tien
  158. Tein Springs with 18s?
  159. Anyone have Eibach sporlines?
  160. Tein Basic coilovers, camber kit needed?
  161. Tein H techs.. some ?'s
  162. Not sure if this is right - rear big brake kit?
  163. is tein basic coilover any good?
  164. One ton spacer effectiveness? <-Spelling?
  165. what is better eibach or hnr springs need help fast
  166. Your thoughts on XB Handling?
  167. xb on the ground
  168. people with airbags an compressors or tanks under the car..
  169. I want to see pics of XB's Lowered on Stock Rims
  170. Stay "in line"...
  171. Im looking for Springs for my XB???? Help!
  172. Drilled & Slotted rotos question
  173. XB with TRD struts/springs
  174. Anyone have the alignment specs for an '05 xB?
  175. so whats better to use??????????????
  176. Smoother ride found, and it's not the springs.......
  177. Will any line up shop have what I need after I lower my XB??
  178. Lowering My 2.0 XB !?
  179. Suspension help??
  180. Camber kit reliability?
  181. Cusco Camber kit
  182. The life span of springs - dumb ?
  183. Strut Tie Bar Help
  184. Camber Kit HELP!
  185. quick ratio?
  186. Alignment problems with the xA xB?
  187. is there a front sway walk thru?
  188. xA on goldline springs question
  189. Im getting my Tein S Springs Monday for my XB, Question????
  190. Strut
  191. how many of you guys and gals trimmed your bump stops??
  192. Front camber ?
  193. How many of you lowered your XB without Spring Compressors?
  194. torque specs for xb suspension?
  195. lowering
  196. Just got finish droping the XB!
  197. Recommendations for 18" Tire Sizes
  198. Man, you guys with the Tein S Springs make me...
  199. ACCESSORY EXPLAINATION PLEASE
  200. Tein S-Tech's or Eibach Sportlines
  201. Best first step to improve general road manners.
  202. Pic request from those on H-techs
  203. F1 tires look great on the xB! How much can i drop???
  204. is there something wrong with my suspension..??
  205. To dub or not to dub...
  206. Tein S. and Rims question
  207. OMG- How bad do I need to drop it
  208. Rear Disk Brakes
  209. Please help me decide.
  210. rear drums
  211. KYB GR-2 Shocks for xA/xB.
  212. why do people camber?
  213. TRD Shocks N Struts
  214. SCION bB "Bagged Box"
  215. Any one in GA or Near GA that wants there box lowered !!
  216. Strut or CV-J blown?
  217. How much can i drop my car w/out issues..
  218. What do you think?
  219. TRD vs Tein S Tech - springs reviewed
  220. Eibach questions?
  221. Anyone here?
  222. Need specific picz PLZ!
  223. Anyone install the front swaybar on an xB??
  224. rubber thing not pointing out
  225. TRD struts xB
  226. Rear shock measurements?
  227. EAI Air Cylinders
  228. Tein Super Wagon 2 inch in cockpit height adjustable suspens
  229. Had my H-Techs installed this weekend.
  230. HOW TO: Installing The DC Strut Bar In The xA (56K Warning)
  231. negative camber plates??
  232. help on xb drop springs with dj equipment
  233. Recommends for a drop!
  234. I Know This Has been Asked Alot Of Times.....
  235. How many different front sway bars for xb?
  236. Tein H-tech VS TRD springs
  237. H.Tech installation question.
  238. Finally dropped it. Some pics.
  239. PICS, just got GOLD ENDLESS BRAKES and Zeal coils
  240. ? about the Partshippers Progress Tech Basic Drop Kit
  241. Driver Side sturt spring noise?
  242. My Custom Strut Bar *Updated PICS*
  243. Best price for complete bag system (site sponsors?)
  244. ? on differences with LSDs
  245. Strut Problems
  246. Bbist Strut bar?
  247. Rear strut bar
  248. xB Alignment Problems
  249. Looking For Springs ASAP
  250. OK...So to my understanding.....
