- put 2'' tein springs passenger side is higher
- need help with my 2'' tien lowering springs one sides higher
- whats better
- trd
- hotchkis bar?
- help please
- Brake Issue - Premature Wear
- Interested in Coilovers, need Scionlife's opinion.....
- TRD springs and rubbing!! WTF? updated w/pics
- Hotchkiss Sways + Tein SSP???
- TC SUSPENSION!!!!
- Dezod Brake pads (come inside!!)
- Hotchkis Sway Bar Problem
- possible to bottom out?
- Ingalls Stiffy questions
- Snow
- trd front strut bar?
- Understanding offset, lowering and wheels/tire size
- 08 tC suspension question
- cutting front TRD springs???
- Could these be fake TEIN SS-P?
- DIY Article on Hotchkis Springs in a Scion tC!
- My suspension plan:to be implemented this week...
- H&R coilovers....best price?
- which will give me the smoothest ride? springs or coil?
- Any Tein SS-P DIY?
- (PICS 56killer) Rotors, Pads, G2 Painted Calipers
- powerslot plus
- Strange Knocking Noise?!?!?!
- Anyone install the Progress F/R Camber Kit for tC?
- Poll:lowered car with stock struts?
- TRD, Tein H-Tech, Tein S-Tech
- Hawk vs Axxis vs Dezod Pads
- SUSPENSION ALMOST COMPLETE WEEE!
- Tein S-Tech *clunk*
- Suspension... butterflyed !?
- ? on camber kits
- messed up suspension
- Lowering Springs
- Alignment question
- Help with Springs
- where is the best place to get tein s-tech?
- $100 for a DC Strut Bar...where to find?
- Megan Racing springs
- Non TRD lowering springs and the warranty
- CENTRIC HIGH PERFORMANCE BRAKE ROTORS
- Attention TRD Spring Owners !!!!
- How much performance do you gain from getting new rotors?
- rotora bbk and stock wheel ?
- Brake problem
- Just installed Tein Coilovers (No 56k)
- ** EDIT **
- megan c-piller bar?
- Smoothest Ride
- Tein S-techs and TRD Shocks... VERY NICE!!! (pics)
- best spring rate for tC
- Help w/ front cambers please!
- Worth putting stock springs back on for winter?
- TRD Springs & Shocks Installed
- Noisy creaky springs - FIX!
- Phila Area - Tranny/engine torque limiter test oppotunity
- Anyone with Cusco Zero-1 coilovers
- where to get goldline springs?
- Road Racing Suspension Questions
- Scion tc 08 Lowering Car Help
- daily driver
- torque damper for the zpi limiter
- remove shocks?
- goldline springs now need lowering struts recommedations
- Track day video
- Question and suggestions on Coil Overs / TRD Struts & sp
- Need Coil adjustment advice
- goldline or Eibach Sport springs? INPUT
- Popping Sound After Front Hotchkis Swaybar Installation
- To all who have S.Tech's
- New Coilover Release
- Spring Rates tC *Input Needed*
- corner balanced ya!
- Lowering Springs Opinion
- Tein H-techs or Tein S-techs?
- CRAZY SUSPENSION!!!
- Tein Suspension
- Any Tein SS-P Out there
- Trd rear sway bar not doing its job?
- Coilover question???
- Camber Kit install
- Question about installation of TRD Rear Sway Bar on TC
- Brake Bed-In Discrepancies
- Worried about a "hole" I had to go through today
- anyone ever corner balance their tC ?
- Tein S-Tech Problems
- tein s-tech with hotchkis sways?
- Just lowered my tC with Hotchkis springs *PICS*
- Dropped her today on Htechs
- Good cheap place for Spring Install..
- TRD STRUT PERSUASION?
- Shocks Blown what to do!?
- suspension problem
- [*]HELP[*] Ingalls "stiffy" tuning
- wheel spacer ?
- Tokico make shocks for tC???
- race TC
- Tein S Tech Springs For tC But what Shock or struts?
- Tein Basic Coilovers. Pics? Opinion?
- LoweringSprings & 4 people in the car without bottoming
- TRD springs for TC have different ride heights??
- Installing springs at Toyota Center with aftermarket rims
- TRD Springs & Rear Swaybar Installed!!!!!!!
- After I lower my car...
- What can happen if overtorquing sway bar bits and pieces?
- Can anyone Put people in the backseat with TeinSTechs?
- Before and After: 4 wheel alignment
- big brake kits
- SPring type
- Hotchkis Springs Baby.
- You know your low when....
- TRD Struts and Springs
- Air Ride...on ebay....
- engine dampner and strut bar
- Re-installed rear springs. Question for all hotchkis owners
- s.techs squeaking.. anyone else notice this?
- where is the trd spring diy?
- Front brakes squealing while driving?
- ** EDIT **
- How bad is my alignment?
- Sweet...
- I want my car lower! any recommendations and side pics?
- Finally Fixed annoying noise.....
- question about bump stop
- Setting Ride Height with Coilovers
- pictures of my car on b&G rs2 coilovers ;X
- Air ride for tC, read here
- Installed DME Rear Strut bar today.
- GOOD SITE TO FIND TRD SPRINGS AND STRUTS?!?!
- springs...
- OEM rear sway bar squeaking? HELP!!
- Best springs for this setup???
- tein s-tech installation question
- quick strut assebly question
- help my brakes
- Are my Calipers Frozen??
- When did u change your brakes????
- Pic request: Eibach Pro-Kit on 18"
- trd springs
- ETD?
- Progress Rear Sway Bar (Anyone use this site?)
- TRD OR DC?
- Horrid Griding Noise...
- Quick ?
- I need info on coilovers...
- sacramento cali tc people attentiion!!!!!!
- perfect black rings on rotors? what's going on
- Anyone wanna make 200 dollars?
- Brake question, is this the right forum?
- Dezod Competition Spec endlinks (Fronts almost done! 1/22)
- Hotchkis lower springs with camber links
- 18's with s-techs ???
- Rear Sway Bar on Stock Non-TRD Suspension?
- TRD Coilovers
- Ingalls Stiffy question...
- . . .Power Slot Plus Rotors. . .
- Tein H. Tech
- TRD vs Koni vs Tokico shocks+lowering springs = HELP!
- people with TRD drop + GEK
- brake light
- Rear Strut Tower Brace for 2008 tC
- HELP!!!! I only have one spring on!!
- springs
- If I lower the front suspension only.
- coilover conversion
- Wierd Noise
- Springs+Body Kit+18's = ??Help??
- 08 suspension
- coilovers
- For sale Brand New TRD Struts
- Does TRD Struts lowers your car even more?
- Scion TRD swaybars DIY?
- auto-x
- new car?
- How low on stock shocks?
- tein
- eibach sportline lowering springs for tc
- TRD coilover adjusting ride height question
- weird noise from rear brakes.
- tc lowering springs help
- Tein S-Tech + Kaminari Body Kit
- question about sway bars
- dealing with a lower drivers side
- Can someone post pic of TRD struts with tein springs???
- Lower Tie Bar and glass roof replacement
- How Much $$$$ to lower my tc
- Alignment Questions
- Whica one is better? Tein S-Tech or Hi-Tech??
- Lower Spring installation around Austin TX area
- What has changed since 06
- Lowered with TRD springs... Wheels angled strangely.
- Coilovers......... most comfortalbe ride?
- Anyone lowered on 19's?
- RUBBING ON TRD'S
- got a problem need help!!
- hotchkis springs
- suspension decision......... VERY difficult!
- Shocks and Struts with Hotchkis Springs?
- Who Else Touge's their tC??
- Please define spring rate
- how long have you had your stock suspension?
- TRD or Eibach Lowering Springs
- HELP!! Missing Sway Bar Bracket
- Re: Alignment
- sale oem springs, oem intake, oem 17" wheels
- scion tc rear greddy strut bar?????????????
- H-Techs or Hotchkis????
- blown struts
- curious question
- Lowering my tC
- Question regarding brakes
- want to see my scion slammed on tein s-techs? cant now...,
- springs
- Do i have to redo my suspension
- new front struts
- ok ok ok one question about brakes upgrade!!!!!
- how big of an improvement from trd sways to hotchkis sways?
- KONI Yellows Question!
- deleted
- ok so heres the deal...it is decision time
- suspension techniques...
- Really Stiff "frozen" like struts
- Trd Sway
- Low Speed Brake Grind noise....Hmm
- Help Needed!
- Larger Gap in front with Trd springs/struts, is this normal?
- Rear lower tie bar
- Smashed sideways into a curb... (pics, price, parts added)
- best bang for the buck in handling
- Coilovers Question
- Pics of my tc with my new tein s-tchs and trd struts
- ABS warning light....wtf!?
- noise with s-tech
- dumb body shop
- S-techs with a lip kit
- Springs!
- Just some brain storming
- STechs Installed
- Broken Hotchkis Front Sway Bar *Move to TC*
- suspension problems
- Brake rotor resurfacing.
- ATE Slotted Rotor
- Suggestions on Sway Bar/Suspension Setup
- new brakes new problem
- suspension diet
