View Full Version : Scion tC 1G Suspension & Handling
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22
  1. Powergrid Adjustable Endlinks??
  2. koni shock questions
  3. Hotchkis sway settins for 250-300whp?
  4. installed tien h techs....now hear a knocking
  5. POLL: Are you dropped or stock (dont be ashamed)
  6. ???
  7. EBC Green Stuff...
  8. I want Coilovers with dampening adj for under 1000 options?
  9. TRD drop requires new Struts?
  10. curious question
  11. suspension question
  12. strut help-need to know by monday
  13. Coilover Suggestions
  14. Goin with Hawk HPS pads for front, but what about rear?
  15. NEW Suspension Set-UP!..HeHe
  16. Hotchkis or Tanabe?
  17. Noise While Driving....HELPPP
  18. '05 w/ TRD Lowering Springs having Rear Camber Issue
  19. Front Caster Adjustment?
  20. Another uneven lowering story...
  21. K-Sport Coilovers
  22. installation trd springs
  23. Tein SS-P w/ Pillowball Mounts with EDFC???
  24. rear left brake makes squealing sound. HELP~
  25. trd vs progress vs tein
  26. Anyone with Eibach sportlines springs
  27. teins or trd's
  28. Anyone have pics of their TC with OEM Lips and TRD springs~
  29. camber adjusting
  30. TRD or Tokico Shocks
  31. tein basic from spectuned.com?
  32. 1 year later...
  33. tein s techs, new struts?
  34. most beneficial (performance) suspension mods ~$500
  35. 2005 TC Front Brake Pad Question
  36. Stainless Steel Brake Lines
  37. Please post your TC with ground effects kit and trd springs!
  38. torque steer
  39. Ok I Need Help Again :)
  40. Just ordered TRD springs
  41. need help, tein s techs!!!
  42. tie rod right?
  43. coilovers issue
  44. what kind of tool is it called to tighten the strut bar...
  45. Whats next?
  46. tokico shocks installed
  47. Why no love for..
  48. air ride or air suspension kit for the tC????
  49. trd springs white?
  50. Carbon-Metallic Rear Brake Pads
  51. springs and bars
  52. Tein SS+P Problems
  53. Hotchkis vs TRD
  54. Simple ? About TRD Springs?
  55. tein basic
  56. those god damn endlink!
  57. Dezod X-Rated Brake Pads, Temp Range & Coefficient
  58. skunk2 springs
  59. Very Weird handling issue, Rear breaks loose downshifting
  60. Just lowered tc so I decided to have a photoshoot
  61. alignment settings for autoX or track days
  62. Help reguarding jacked up bolt on tie rod
  63. Who Has The Progress Rear Sway bar?
  64. Drivers side inner tie rod end
  65. Scion Tc / Toyota Matrix TRD Shock Coilover Kit
  66. Creaking sound from the back
  67. Suspension Upgrades
  68. Tein Basic Coilovers
  69. H-Techs or S-techs? Will exhaust be to Low *Pics* Updated
  70. H&R sport springs, what color are they?
  71. About to order TRD Springs/Tokico Shocks
  72. shake rattle and roll (not very well)
  73. stoptech sportstop rotors and porterfield brake pads
  74. problem bleeding/adjusting brakes
  75. Megan Racing Coilovers
  76. Megan Racing Race Spec Tower Bar vs DCSports Front Strut Bar
  77. Rear Brake Help
  78. Alignment after lowering springs
  79. coilover ????/
  80. Hotchikis Tuning strut tie bar
  81. Hit a curb baad now axle or suspension is messed up. pics!
  82. tC camber plates?
  83. TRD coilover!?!?!??!?!?!
  84. Where can I get some Brembo Rotors?
  85. Recommendation for Drilled Slotted Rotors?
  86. H&R SAWEEEEET!
  87. ARK looking for TEST FITTER !! ARK Ft. Strut Bar
  88. Custom C-pillar set up
  89. del
  90. Dropped my car on Tein S-techs Today *More Pics Updated*
  91. aftermarket calipers?
  92. Changing the brakes!
  93. h-tecs on stock struts???
  94. h-techs or trd's need pics
  95. do i really need a camber kit?
  96. progress
  97. AFTERMARKET CONTROL ARMS...
  98. smoothest most comfortable riding coilovers
  99. PowerSlot Plus rear rotor help please.
  100. Hotchkis sway set, best settings ?
  101. Replacing back to stock springs?
  102. TRD Spring write up?
  103. Buddy Club N+ Spec coilovers/damper "Who has this On?
  104. finally got my HOTCHKIS springs and TOKICO HP SHOCKS..but
  105. New pads with rotors?
  106. st suspension sway bars?
  107. 08 tc springs and warranty info
  108. Alignments
  109. Newbie Suspension Help!
  110. Help cant deceide..
  111. h-tech gap
  112. Wilwood brake kits
  113. brake fluid
  114. Air Ride
  115. clunking noise?
  116. coilover springs
  117. Post Pics of Brake Upgrades
  118. Think my driver side front shock is going out
  119. New hotchkis springs and sways in! now what do i do?
  120. Front Lowering Spring settling question!
  121. Powergrid endlinks
  122. installing springs
  123. Brake question
  124. christams suspension set up
  125. Vogtland? Adjustable shocks?
  126. promotion tuning coilovers for 400 dollars?
  127. alignment????
  128. anyone have a c-pillar bar?
  129. TRD rear sway bar installed!
  130. This is ridiculous
  131. RS1 Lip + Tein H.Techs?
  132. Camber Alignment Bolt? Chicago Alignment shop?
  133. HELP?! Hotchkis Camber Link
  134. Rear Suspension Knock.....
  135. celica skunk2 coilover kit for the celica fit a tc.
  136. Progress Vs. Hotchkis
  137. DIY lowering springs
  138. will trd struts work with tein h springs?
  139. softest springs
  140. BRAKE ROTORS and PADS Brand?
  141. Strut bar vs Sway bars
  142. rotor opinions please
  143. Tc bags
  144. What do I need to lower?
  145. H&R question (no no problems :P) (Oh Bryannnn)
  146. what strut combo for s-techs???
  147. alignment after 3 days?
  148. coilovers with edfc (wierd sound)
  149. Trd install
  150. About to do the TRD Spring/Sway install...MOST DETAILED DIY?
  151. Need help upgrading suspension (Handling)
  152. coilover owners, what have u done to make ur drop lower?
  153. camry on a tc?
  154. TRD Struts Question........
  155. Pops, Creaks, and Clunks
  156. Eibach Camber Bolts or Hotchkis Camber Links w/ Tein S Tech
  157. Hotchkis Sway Bars VS. Suspension Techniques Sway Bars??????
  158. quick pad question
  159. S tech's -vs- Skunk2's
  160. Scion tC alignment still a lbut off after its been align..
  161. Dezod brake bonanza!
  162. TEIN S-TECHS
  163. Question about brake pads...Celica vs tC.
  164. Front Sway Bar
  165. sway bar question
  166. stoopid quesjun?
  167. Best Price on Koni Yellows?
  168. ABS/BRAKE/TIRE PRESSURE lights on after brake pad change
  169. tokico shock question...
  170. Springtime Suspension Plans...
  171. Lowering spring recomendations for stock whhels
  172. greddy rear strut bar?
  173. Sway Bar Help!
  174. traction bars
  175. new shocks and struts vs coilovers
  176. What type of springs and how much should I lower my TC....
  177. Will tein s techs rub with my setup? Please Help
  178. are the springs the same for 2008?
  179. FS:tC FULL TRD SUSPENSION~
  180. Lowering
  181. Are strut bars worth it?
  182. can some1 explain wheels offsets and bbk's
  183. What do you replace to get a smoother ride? noob
  184. handle and ride decent?
  185. i hit a curb in the snow.... now what?
  186. Tien S techs
  187. Just installed a rear sway (Thanks Matt)
  188. Shocks
  189. TEIN S-TECHS!
  190. 40K miles, about to install TRD Springs......
  191. New to a lowered car.....need advice.
  192. lowering springs
  193. Need some suspension help.
  194. lowering car
  195. suspension setup - would like opinions
  196. Anyone in New Jersey...
  197. Suspension PDFs or Breakdowns
  198. Best place other then the dealer to get alignment...........
  199. WHITE VS RED TRD SPRINGS
  200. Tanabe lowering springs...
  201. Tein Basic Coilovers
  202. I wonder what this could be for?
  203. Dezod Front End Links DONE AND IN STOCK!
  204. Screeching sound a certainspeed
  205. Rotora rotors..
  206. Rear Sway Bar Problem
  207. tC camber
  208. which struts?
  209. scion tc lowering springs
  210. suspension setup
  211. hotchkis sways question
  212. Lowered + Express Car Wash?
  213. Spring install help
  214. ***Tein Lowering springs***
  215. Going from stechs to something else.....worth it?
  216. New Function and Form coilovers available for the Scion tC!
  217. Good struts for Sportline springs
  218. pics of TC sittin on trd's
  219. More new suspension products at Dezod!
  220. Low???
  221. Alright Hit Me, What Would I Need????
  222. how long will my stock struts last on trd springs?
  223. question about stock struts
  224. Lowering Springs + Stock Shocks???
  225. SPC rear camber links
  226. KSPORT ?S KSPORT OWNERS HELP!
  227. daily driver suspension
  228. tein coilovers for tc
  229. Anyone have this setup?
  230. TRD or Ksport Coilovers?
  231. Eibach Pro or TRD Springs
  232. What do your lowering springs taste like?
  233. is this true
  234. progress coilovers need help
  235. Turning noise?
  236. Can a TRD Suspension TC handle as well as a Honda si?
  237. Any problems with Hotchkis springs mixed with TRD rear sway?
  238. Help with my suspension decision
  239. KSPORTS ?????
  240. POLYURETHANE BUSHINGS...
  241. suspension for my daily drive?
  242. Question about TRD vs OEM Shocks.
  243. question about lowering
  244. Tanabe df210 and Tokicos FTW!!!!
  245. TRD Lowering Springs question
  246. I HAVE TEIN S TECHS WILL THEY WORK TRD SHOCKS/DAMPERS
  247. reducing body roll
  248. engine paint for calipers ? ? ?
  249. Strut bar and sway?
  250. Tein SS-P Coilovers + EDFC
