View Full Version : Scion tC 1G Suspension & Handling
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22
  1. Rethinking the Front Strut Tower Brace
  2. E-brake light comes on periodically when handle is down..
  3. Think it will Rub?
  4. Side by side pics of dropped vs. non-dropped tC
  5. Tire Wear Problem
  6. tanabe nf210s
  7. Tokico + Hotchkis springs?/now with ingalls front camber kit
  8. people with s-techs
  9. OUT NOW!! FUNCTION & FORM TYPE II COILOVERS for TC
  10. Brakes too tight after new brake pads!
  11. Bigger rotors?
  12. ground control coil over kit
  13. thump when going over speed bump
  14. Cut Stock Springs ?
  15. Finallyyy
  16. Espelir Lowering Springs
  17. Alignment question
  18. tanabe NF210
  19. NEED TORQUE SPECS
  20. Woo hoo Christmas finally came...
  21. Dezod Motorsports Scion tC Brake Package
  22. trd vs. tokico struts/shocks
  23. Brake pads?
  24. Anyone in North Houston/Katy/Cypress area...
  25. so im thinking about goldlines...
  26. Ksport Coil-over Question
  27. Ksport Owners, Question
  28. HKS Coilovers Question
  29. Help! car is pulling to the right.
  30. Energy Suspension master bushing kit
  31. h&r sport springs questions...
  32. pads for big brake kits
  33. name of the a-frame
  34. squeaky brakes without brake pressure
  35. Car's F***ed... cv boot torn and joints may be shot.. :(
  36. Which coilovers have upper mounts built in/included?
  37. Birthday Present
  38. Odd question about springs....
  39. my front drivers tire is getting eat up.....HELP!
  40. Tanabe DF210 Lowering Springs for The Scion TC!
  41. Brake and ABS lights on. please help.
  42. TRD Coilovers- Worth It????
  43. Christmas continued, the coils are in..
  44. 2 Brake Questions?
  45. Zeals for sale
  46. Rear Brake Shoe Rubbing to Rotor.
  47. Im So confused how this helps
  48. powerslot plus questions
  49. Aiite i got a problem... help me out homies.. ksport owners!
  50. How bad are my alignment check results?
  51. trying to go low.. help.
  52. daily driven/track coilovers
  53. Tanabe DF210s on Tokicos Struts
  54. ICHIBA VS H&R SPACERS
  55. lowered on TRD's
  56. Coilover Tuning Info.
  57. NRG Coilovers?
  58. strut bars
  59. The Mysterious Sqweak..Continues....
  60. rubbing noise ?
  61. B&G or Function & Form
  62. best non-performance brake pads to replace worn stock ones?
  63. where to buy hotchkis version 2 springs?
  64. Ksport Kontrol Coilovers info needed.
  65. trd's had me at first, now not so sure
  66. Tanabe Sustec Pro S-0C Coilovers for the Scion TC!
  67. scion tc white TRD springs
  68. Posji Tech Coilovers?
  69. 02 celica brake pads???
  70. please help a new one out!!
  71. thinking about getting trd struts/shocks with hotchkis sprin
  72. TC Brakes
  73. Odd Spring Question!
  74. wilwood bbk
  75. cheap alignment shops in LA
  76. Scraping sound when turning right *fixed i think*
  77. Ebay strut bars any good?
  78. Does a Strut Bar really make a noticable difference?
  79. I need some info : sways, rear strut, c pillar, bushings...
  80. TRD Struts Rough Ride ??
  81. Pictures- Stock height vs. TRD - as requested
  82. SWAY BARS.
  83. tein tech springs
  84. coilovers help
  85. Front Sway, Suspension Tech., Eibach,? Which is best?
  86. does anyone know a good suspension specialist near LA
  87. Do i need a Camber Kit
  88. Whats your experience with Airbag Recall?
  89. Blown Strut Help
  90. question bout front brake pads and ordering them
  91. Resurface Brake Rotors each time? -- Debate
  92. Drilled slotted rotors
  93. stiffer handling
  94. Brakes Set up suggestions / opinions
  95. goldline springs
  96. EBAY Lowering Springs - Skunk2 Any good?
  97. Spring Rate for lowering Springs- Which is ideal
  98. Tightening front strut?
  99. anyone in socal want to install my trd springs?$?
  100. FRONT CAMBER BOLTS!!!
  101. TRD Lowering Springs - Spring Rate
  102. 40,000 miles and TRD springs
  103. Uneven, Even with coilovers?
  104. tein ss-p camber plate question
  105. Measured - 0.98 Lateral G's
  106. Have question and need help about brakes and suspension.
  107. my first feature!
  108. Rotors
  109. rough ride
  110. Disconected sway bar
  111. oven paint for calipers ?
  112. Lookie what I got in the mail!
  113. lowered now weird noise around 70mph....
  114. Can I adjust rear camber with the stock parts?
  115. lowering springs
  116. Black Hotchkis Spring?
  117. do i need a new module for my airbags... plz help me!
  118. slotted and drilled rotors
  119. sprint springs
  120. I need some help!!!!!
  121. swindled? need help on spring purchase?
  122. tein s techs or h techs? with 18 inch rims
  123. Hotchkis Sway Bars?
  124. Trd struts or Tokico HP Struts with s tein
  125. need some more help!
  126. New Mods and Speeding Tickets
  127. ** EDIT **
  128. trd spring users
  129. alignment and camber adjustment questions
  130. Bumpy Ride problem
  131. to confirm, wilwood bbk
  132. H&R or TRD's on 18's
  133. Easystreet tC Air Ride kit
  134. Where at!!!!!!!!!!!!!!!!
  135. Overspray on the rotors....How to remove it?
  136. d2 or ksport
  137. Goldline Springs
  138. TEIN basic SS
  139. Ingalls Rear Strut Brace?
  140. E BRAKE QUESTION
  141. What setting do you have on your TRD Sway Bar?
  142. why are Tein H-techs so expensive?
  143. will 05 to 08 lowering springs fit an 09??
  144. i really want hotchkis springs buut......
  145. Buddyclub coilovers?
  146. ** EDIT **
  147. Hotchkis springs and tokico shock install
  148. SWAY BAR: TRD, Progress, or Hotchkis?
  149. i lowered my car today
  150. Wierd Noises
  151. SPRINGS VOTEE!!
  152. question guys...coilover sleeves
  153. Front Camber question
  154. HOW TO REMOVE Front brake rotors!!!!
  155. Quest for better handling.... with boost..
  156. need brake help asap
  157. Best Site to Order Coilovers? (Price Wise)
  158. Krazy's Project cont... UPDATED W/ PICS!! 03/20/09
  159. questions about lowering springs settling and alignment
  160. rotor?/Pad? noise
  161. TRD Springs on XB
  162. Camber!!!!!!...going H&R coilover
  163. brake help
  164. coilsss
  165. trd shocks/springs install
  166. RSB help!
  167. who would you get to install your springs?
  168. custom struts
  169. What rear strut bar is this?
  170. Installing Front Strut Bar
  171. Lowering springs with stock tires
  172. Which struts?
  173. So i Screawed my friend! ( H Tech Springs)
  174. adjusting front strut preload
  175. knocking noice?
  176. skunk2 vs. tein vs. h&r race
  177. Tein H-Tech lowering springs instal???
  178. JIC Magic FLT-TAR coilovers
  179. What is the best rotors/pads combo for the tC?
  180. EDFC Controller..I Need Some Advice Please
  181. Coilover
  182. which rotors for the tc??
  183. Squeaking in the rear rim area drives side. Question.
  184. need help asap??? (c pillar)
  185. Acceleration Steering Problems
  186. Which one is it? Multi-link or Double wishbone?
  187. what is a good spring/strut setup?
  188. ground control
  189. Squeeling Brake Pads?
  190. Possible Strut / Shock Problem
  191. ball bearing issues
  192. Lost brake pressure
  193. To low in front compared 2 back?
  194. So I finally took my car in for an alignment
  195. TCSportline coilovers?
  196. Road magnet 1.5" drop do I need camber bolts and arms?
  197. Lowering Spring Specs and Drop
  198. Stock shocks are gone
  199. Too Extreme for Dezod Endlinks?
  200. If its done right... please dont flame
  201. No more 4x4 tC.....
  202. Caster adjustable top/upper suspension mounts?
  203. Tragedy! need help
  204. lowered tc and front strut bar question???
  205. Tanabe NF210 for tC
  206. HELP! Quick question on coilovers
  207. New master bushing kit 4 sale($165 shipped, firm)
  208. brake replacement questions
  209. help with suspension on my tc
  210. Best Coilover for tC, opinions please?
  211. Tein H Tech or Eibach Sportline ?
  212. Tokico shocks + Cold weather = ?
  213. Fender Braces
  214. drop kits
  215. Tokico or Koni Shock/Struts w/lowering springs
  216. Perfect Drop for Daily Driver & Track
  217. suspension
  218. new suspension ( few pics )
  219. I'm too bouncy!!!!
  220. How much to install TRD Springs at toyota.
  221. TRD shocks good with H&R springs
  222. will it get lower?
  223. Just installed new brake pads and rotors.
  224. D2 RACING TYPE RS COILOVERS
  225. does it work? ingalls 4 point and rear strut bar
  226. anybody with a full trd setup?(shocks,springs/rear sway)
  227. new
  228. what's lowest price anyone found for tokico shocks/strut?
  229. S-tech Help!
  230. H&R vs Tein vs TRD
  231. TRD spring question
  232. Progress rear sway bar
  233. Progress Sway $175 Shipped?
  234. Caliper Defect
  235. weird problem when braking
  236. Brakes/Tires when hot - vibration (UPDATED:see last post)
  237. Help getting this bolt off for spring install?
  238. pics of TRD springs
  239. Just installed rotors, Rear passenger side squealing LOUD
  240. rotor question
  241. Quick Question - getting bolt off of front strut?
  242. Coating the springs.
  243. Callin all TRD Coilover owners.. Need parts help!
  244. Change stock wheels??? or suspension???
  245. Problems with springs installation... Need feedback
  246. Wilwood owners ..need some help
  247. traction control
  248. stoptech baby!!
  249. Please help!? Ground Control spring owners?
  250. are trd springs low enough
