View Full Version : Scion tC 1G Suspension & Handling
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22
  1. Replacing stock struts
  2. 18x8.5 +40 can i drop 2"
  3. Coilovers suggestions
  4. lowering springs
  5. Stock sway bar
  6. Sway bar options..
  7. Squealing breaks: I think I messed up on changing them.
  8. Contrast: Coilovers Vs. Full Suspension
  9. strut noise
  10. Lowering Springs..Camber Kit..Struts?
  11. New to Dezod! Vogtland comes to the lineup
  12. ?lubricate front suspension?
  13. has anyone seen this? oni camber
  14. Custom Brembo Brake kit
  15. need some input.. stock traded for trd
  16. Suspension squeaking?
  17. Right rear tire cupping?
  18. KYB Shocks or something else?
  19. Alignment question
  20. Older tC needs help
  21. Clunky noise in rear of car
  22. Irritating Noise from Stance Coilovers, need advice.
  23. TRD coilovers
  24. Someone please help.. Whats the name of this???
  25. all four struts blown out
  26. Eibach Ground Control
  27. Stance GR+ or B&G Rs2??
  28. New Clutch and Alignment...Now very squeaky when turning
  29. interest in custom brackets to fit porsche calipers
  30. delete
  31. Chopped stechs with trd struts/shocks?
  32. Questions about sprint springs...
  33. Weird knocking noise.. Plz Help
  34. Any brake recommendations?
  35. trial and error
  36. Pics of TRD coil overs please
  37. Suspension question. Please help?
  38. camber/toe correction with Eibach/Tanabe springs
  39. Time to replace rotors/pads?
  40. Anyone know the Tow hook width/size
  41. ABS Relocate - New Brake Line ?
  42. Camber Bolt
  43. Need help choosing new shocks
  44. Alignment Report
  45. anybody know where....?
  46. Camber kit needed?
  47. Question about the TRD brake pad and break-in (bed-in) procedure ?
  48. Raceland or Rokkor Tuning
  49. stance
  50. DIY Rear Camber Adjustment???
  51. Mr coilovers lowering measurements
  52. Coilover Owners help me out!..Thanks
  53. REVIEW: C8sport SSD Coilover (UPDATE: last page- removed 1 perch ring)
  54. Parking Brake/ Hand Brake
  55. best coilover 1000 and under
  56. Warped rotors
  57. Another pad and rotor question
  58. Looking to buy Htechs
  59. Wheel Width/Fender Rolling Help
  60. Suspension install in Brooklyn?
  61. Thoughts about Megan Coil's???
  62. Blown front struts, what should it cost to replace?
  63. HELP MEGAN OR TEIN?!?
  64. Brake pads
  65. Tokico HP + HTechs OR Cheap Coilovers (Rokkor or RL)
  66. tC suspension noises and pulling. Help please?
  67. Poking more on one side than the other?
  68. Passanger Side Front Wheel Vibration and Uneven Brake Pad Wear
  69. eibach sportline springs
  70. Help: E-Break
  71. Rattle in front left wheel
  72. Vogtland Spring & Shock Combos (Tokico & Koni)
  73. Suspension help and questions
  74. Buying HTechs on ebay
  75. Function and Form Front End Links
  76. lowering spring help
  77. Alignment price????
  78. Coilover Recomendation
  79. Brakes creaking sound when pressed...
  80. Tein Basics Coilover help!
  81. tein's
  82. Air in the lines ...
  83. Where to Buy Coilovers?
  84. How low can i go in front?
  85. SUSPENSION TECHNIQUES
  86. ????????getting new Font Rear Brake Rotors and pads????????
  87. TRD pads or Hawk pads???
  88. strut hole measurement
  89. Help
  90. TRD Struts/Springs/Sway bar .. now what??
  91. Need help w/ tranny mount part #!!!
  92. Buddyclub N+ Coilovers
  93. Ball Joints and testing
  94. First Post: Just bought stagg struts (guinea pig?)
  95. Hotchkis springs sagging?
  96. HELP..ANY ideas??
  97. monotube vs. Twin Tube??
  98. Progress sway bar issue
  99. Hotchkis spare parts
  100. Is it possible to ugrade ones rotors to that of a toyota truck or toyota supra.
  101. Disable Scion tC ABS
  102. recomendations
  103. raceland coilover
  104. coilovers
  105. Opinions and Help. (sway bars & bump stop)
  106. TRDs on 100k tC?
  107. Question on TRD Lowering Springs.
  108. Installing dme front/rear strut bars
  109. No brake power after pad replacement
  110. Eibach Pro System
  111. scion tc with hotchkis lowering spring runs 225/45R18 ok?
  112. Am I getting worked over or just REALLY unlucky?
  113. top mounts
  114. b&g coilover owners.
  115. Wanna Go Lower
  116. BlackWorks SS Coilovers
  117. Creaking Coilovers
  118. What Sway Bars to Buy. . .
  119. Question regarding life span of S-Techs
  120. Coilover Help
  121. Suspension mods and insurance
  122. camber kit
  123. Alignment issues after raceland coilover install
  124. B&G Coilover thread!
  125. Coilovers d2 or function & form type ii?
  126. Rip off or not?
  127. Teins for sale in Northern VA
  128. lowering springs advise
  129. Buddy Club Coilovers
  130. shocks and struts
  131. please lock
  132. racelands or rokkers?
  133. Pros and Cons Strut Bars (Ingalls vs Greddy)
  134. TRD performance brakes
  135. Installed S-tech / airbag light is on
  136. trd lowering spring! only 0.5” in front and 1.5” in rear??
  137. 05+ Scion Tc Tein Basic Coilover Question
  138. BC RAM Coilovers...
  139. Coilover Little Help
  140. Stechs horrible ride
  141. Cut bump stops too much?
  142. Which to choose...
  143. rota grids and racelands
  144. Rear strut top nut
  145. Tein Basic Coilover Replacement Question
  146. Group buy offer by Password:JDM (Rotors)
  147. Firestone Alignment
  148. Front Sway bar questions.
  149. trd or raceland front strut tie bar and rear sway bar
  150. Cusco ZERO1 Coilover (Introduction)
  151. what coils to buy, here r some suggestions.
  152. TRD Rear Sway Bar
  153. cutting wheel studs?
  154. rear upper strut bar or rear sway bar
  155. D2 RS Coilover Review
  156. Raceland and/or Rokkors on 18x7.5 +42
  157. Trd springs
  158. Function and form/ coilover help
  159. Front sway bar bushing dimensions
  160. New Big Brake Kit available at Dezod!
  161. How to increase Payload Capacity of Scion tC 2007?
  162. Quick question about adjusting height...
  163. delte please
  164. CUSCO Strut Bar Type AS Review
  165. Offset Question
  166. camber kit
  167. Anyone have installed pictures of the 4pot wilwood 11" BBK
  168. i think im ready for some summer autox!
  169. Brakes!?
  170. Better handling possible for a 2011 tC NOW lowered?
  171. Eibach Pro Alignment Kit / Hotchkis Rear Camber Kit
  172. Ground Control Coilover kits -any good?
  173. So Im Uprgrading to the TRD Suspension Setup
  174. brakes
  175. Alignment...Did I get shafted?
  176. Uneven poke?
  177. Dezod Stainless Steel Brake and Clutch Lines: HOW TO and REVIEW
  178. BC BR Coilovers Vs. Raceland Coilovers
  179. horrible squeal while driving
  180. Adjustable Rear Control Arms
  181. knocking noise, is it balljoints?
  182. Skunk 2 Springs
  183. need parts for cheap
  184. Koni, Tokico, or KYB???....
  185. Brake Line Fitting Size
  186. uneven brake wear
  187. DIY Inner CV Boot replacement (w/pics)
  188. wheel spacers
  189. Problem with New Rear Shocks
  190. ABS, BRAKE and tire pressure (!) flashing
  191. Just got my alignment
  192. buying USED coilovers?
  193. Cracked rotor?
  194. Brake pads slipping? 08' TC
  195. STANCE custom valved coilovers !
  196. TRD struts & springs
  197. Rubbing issues
  198. Tightening topmount of coilover (h&r)
  199. Removing Spring from broken Strut
  200. Alignment at Midas
  201. lowering springs off a Subaru
  202. Coils or springs?
  203. Lowering spring help
  204. Lowering 08 tC
  205. Rokkor Coilover?
  206. Front swaybar shifted?
  207. Coilovers??
  208. Brake creaking fix
  209. Front sway bar position question
  210. Rear Springs
  211. TRD lowering springs
  212. New rotors/discs w/old pads
  213. Power Steering Rack I Think!
  214. Popping while turning?
  215. Installing longer studs on the rear - instructions?
  216. Vogtland springs
  217. how low for DD?
  218. needs some threads that explain how to choose damping + spring rate for ride
  219. Need your opinion skunk2 or tein s tech springs
  220. Tire Poll -Opinion needed
  221. Rear caliper issue
  222. weird clicking noise
  223. Energy suspension motor & tranny mounts
  224. HELPPP>! :(
  225. Question Regarding Camber
  226. sway bars
  227. Rear Strut "EYE" bushings?
  228. e-brake possibly sticking?
  229. Torn boot solutions?
  230. These the real deal? Trd lowering springs
  231. megan coilovers installed!!! no drop :(
  232. Is this normal?!
  233. Need Help Deciding!! Plss
  234. Thinking about lowering my tC with 163k miles
  235. Help on Shocks and Spring
  236. Struts Going Out..?
  237. Grinding noise.
  238. H&R Coilover Wrench Size
  239. Hybrid Spring Setup Hotchkis Rears / H-Tech fronts
  240. Pillowball Mount Question
  241. teins
  242. Suspension upgrade with NO DROP???
  243. Rear Spindle Replacement
  244. Battery Relocation?
  245. front camber bolts and swaybars
  246. tein s-tech problem
  247. Abs light/speedo not working
  248. *EDIT*
  249. Help! HKS Coilover Rebuild
  250. Koni yellow adjustments?
