- need help reg 18" x 8"...is rubbiiinnnggg! why?
- Hotchki's vs Progress Sway Bars
- Best set of springs??
- To those who have Hotchkis Sways...
- city lights
- TRD Rear Sway Bar any good?
- Please Help! Need a how to for spring install
- TRD rear sway parts list
- Looking for a shop in Sacramento
- Could be repost but im too lazy...
- diff b/t tein ss and tein ss-p
- hotchkis sway bar
- how long will the stock struts last with hotchskis springs?
- Installed my Hotchkis springs this weekend...
- Tein s-techs....
- Who installed Hotchkis Rear Camber Kit?
- WHAT TEIN COILOVERS SHOULD I GET???
- What dampers are there out for the tC?
- is this spring any good? Its pretty cheap
- Hotchkis Sway Problem
- For those doing your own installs
- Need help & opinions on installing TRD rear sway bar
- is dropping my ride with only springs really that bad?
- TRD knock offs??
- suggestion on where to go for Hotchkis Stage 1 TVS install?
- FRONT SWAY BAR QUESTIONS
- anybody paint thier stock Tc rims gunmetal?
- Strut bar and sway bar difference?
- eibach pro kit/trds/hotchkis/h&r???
- Tein or TRD
- TRD Springs
- sidewall height
- nitto neo-gen
- Tanabe SOC Type II vs. Tein Basic
- Would a BBK fit under the stock tC rims?
- rear hotchkiss sway bars installed.
- Ksport Coilovers for the TC
- Crap...Ive got too much info...swaybar dilemna
- Coilover DIY newbie questions
- where to buy trd lowering springs for a good deal
- Brake upgrade question
- Scion.com strutbar??
- TRD vs. Eibach springs...in need of help
- REAR STRUT BAR!!!
- tire pressure warning light after TRD spring installation.
- Which springs/shocks to go for?
- Need really good suspension advice.
- camber kit required on H&R springs??
- Hotchkins Springs, Sways, Struts!
- will 19's fit right with Tein s-tech? pls post pics..
- Tein Basics....need feedback
- Best support stand position
- FWD Cars on canyons??? uh
- Ordered my TRD springs!
- New Springs and Struts... Tokico!!!
- Who installed the Hotchkis front Sway bars themselves?
- Upgrading sway bar endlinks
- improving BRAKES without going Big Brake Kit?
- DIY Suggestions
- Eibach Pro-Sport Lowering Springs CHEAP!!!
- Enkei RSV 18x7.5 Offset?
- just installed TRD sway bar
- Tanabe NF210s installed *PICS* Updated with Settled PICS
- C Pillar Bar. Keep your back seats!!! (updated 9/29)
- spring question
- Need help.. What are the best spring?
- How much does the Eibach Pro-Kit really lower?
- My BCP dropped with Hotchkis Springs
- Any TEIN H-Techs in Stock?
- trd springs
- Anybody with Tanabe DF210...
- Dealer installation charge... is this good?
- Need Some Help Picking What Kind Of Coilovers To Buy!!!!!
- TANABE Sustec Pro S-0C Type II COILOVERS * PRICES? RETAILER?
- some questions about the TRD springs.
- Common Brake Issues Answered
- HELP! Scion tC front strut bar installation
- Cutting your bumbstops.
- TRD spring install w/ before and after pics
- How serious are you about handling? Dropped, roll center...
- Question about tein basics
- stock spring/sway bar sitting on my living room...
- TRD Spring and struts?
- Goldline or Tanabe DF210 or any other for tc
- i need to see ur short shifer with pix ??
- Not sure about lowering w/o rubbing. Need advice.
- what type of Lowering springs should i purchase
- passenger side higher than the other!
- Celica Wheels
- what online site to order from?
- How long would TRD SHOCKS last with TIEN-S?
- Camber Kit or not?
- Progress sway bar question
- weight of stock wheel
- Attention owners of Hotchkis Sways--re:company investigation
- lowering question, tried search.
- looking to buy Greddy Strut bars, any reputable stores?
- Tein Super Street Coilovers *PICS*
- Photoshop help
- trd springs w/pics on TC
- Needed, Tein SS coilover spring rates.
- New tires for tC... ALREADY SEARCHED!!!
- TRD Shock and Sway Bar... DIY?
- how hard do you take your corners?
- tanabe front strut bar question
- Tein EDFC: How did you run the wires?
- trd spring/tire combo
- 17x8.5 w/ 245 Toyos. Anyone with better grip?
- best price on TRD springs and sway bar combo?
- Which BBK- Wilwood or Rotora?
- Trd Springs/Shocks
- Unstable at higher speeds...
- finally got the tc dropped on 20s (56k be patient)
- Tighten up the tC's steering? Steering rack bushings?
- Camber and Wheel spacer questions.....
- Who else makes hub centric wheel spacers for the TC?
- Tanabe Strut Bar Opinions
- Do Your need a spring compression?
- problem with my tanabe springs
- compliments to tein basic coilovers
- TRD Springs - Visible?
- TRD Springs! Before and After. With measurements!
- Anyone have Hotchkis Sway Bars without lowering???
- Jacking up car to install springs?
- droppin on TRD with 18" what offset and width?
- Building a Catalog...Please contribute
- hub centric spacers..?
- springs and shocks
- tein s tech negative camber problem
- TANABE or H&R SPRINGS ????
- Going to paint my calipers, any tips or suggestions?
- SPRING COMPRESSORS
- 5Zigen wheels on TC.
- CAI
- How far can I lower?
- tC Roll Bars, Roll Cages, now available!!!!!!
- tC Tein coilover owners..need a pix of your ride slammmed
- big brake kits
- spec torque
- trd big brake kits?
- Need instruction booklet for Factory Ground FX kit
- Improving my brake system
- CF/Kevlar roof now installed, in Corner Carvers...
- 1.8" drop on stock struts/shocks ??
- want hotckis sway bars, trd shocks/springs, what do i need?
- PICS UPDATED-->Hotchkins Coils Installed! (10-10-05)
- Setups.
- Post Tein SS-P install: "chug chug" noise from eng
- Importancd of torquing suspension components when replaced?
- Lowering my TC...Question?
- POST PICS OF YOUR RIMS
- Cheapest TRD or H tech Tein springs?
- Ground Control Coil Overs
- Tire Pressure Light
- Those with S-Techs what shocks/struts you running?
- TRD Springs and Sway Bar Installed!! *Pics*
- Lowering Spring Dealer Install
- anyone have a tc with the ROJA 7 rims?
- s-techs or h-techs?
- Im looking for a smoother, more comfortable ride, help!
- TRD springs alignment spec
- Hotchkis Coils.....neg. camber!
- Update w/ Tein H-techs **Pics**
- S-Techs or H-Techs with 18"s?
- Cheapest place to buy Tein basics?
- Hotchkis TVS kit installed
- check out these ss brake lines
- Wheelsnext.com - the cheapo tires they give you...defective?
- my suspension is making annoying squeaking noises!!!
- Tein S techs
- TRD springs....Cheapest price around?????????????
- Light below tuner question
- Coilovers, Spings and Won Tons
- adjusting hotchkis
- S-Techs on 18's...56k=no
- Best Coilovers ??... that already exist
- Look what I got myself into this weekend-with bad phone pics
- Spring Rates and Personal Performance Opinions!
- Look fast or be fast, not always mutually compatible.
- TC max offset?
- Autopower SCCA approved roll bar arrived today:)
- Buyers Guide: Scion tC Suspension
- Disadvantages of 18 Inch Rims on a tC.
- shocks to go with the hotchkis springs....
- where did you get your springs from?
- 24 way adjustable coilovers.. springs
- Will 18x8.5 rub?
- A spring set that does not lower the rear more than front?
- let's guess the problem
- Scared to lower my tC
- New Strut Tower bar?? TRD?
- Megan Racing Coilovers??????
- TRD brakes
- TRD Spring Dimensions? (not spring rate)
- springs drop
- Tein Basic problem/question
- All TC strut bars are not very good
- Tail light covers
- Rear shock tower brace (strut tower)
- Prices on TRDUSA website
- Tein-S springs and issues with camber/shocks?
- Lowering springs and twichy handling !!!!!
- hmm, trd springs or hotchkis?? lol, just a thought :)
- tein-h on 17"s (need pix)
- Hotchkis Sway Bars.....
- TEIN S-TECH LOWERING SPRINGS
- anyone have the ground control coilovers?
- Show off your BIG BRAKE KIT......
- How-to install Tein H Techs (or any springs) UPDATED Nov9
- Trading my 05 for an 06 TC, What to do differently?
- Coilovers or Lowering Springs????
- 18's on a tC with trd springs
- TC brake lines
- lowering tc..
- DC Sports CS-2 Bar........Notice any change?
- Cheapest place for greddy strut tower braces..?
- Tein Superstreets!?
- Alignment, how long should you wait after you lower your car
- Installing TRD Brake Pads
- Im Pulling My Hair Out!!!!!!
- scratching underneath the car
- new brake
- Lowering Springs, Camber Kit
- Megan Coilover Sping Rate Poll
- trd springs pics?
- Scion TC big brake kit questions/answers
- TRD Springs are in!
- align it...
- Similar to TRD 19"s but better...I want them soo BAD!!!
- Progress Rear Sway bar parts check
- tein ssp with edfc
- StopTech BBK finally installed! Pics on PG 4
- question about tien s springs on tc
- Anyone know of an alternate strut bar??
- thinking of getting some springs. need advice
- This slightly makes me angry
- Can't decide on wheels for my tc....please post pics
- just got trd sway bar installed and i love it.
- Anybody w/ DC Sports or Cusco strut bar...please tell me...
- anybody blown their OEM shocks on aftermarket springs yet?
- Need COMPARISION pics
- TRD Suspension On Track Review now w/ PICS
- coilovers
- Anyone have Hotchkis springs?
- tC on H-Techs--pictures
- TRD sways vs. Hotchkins Sways
- Just a warning.. my Tein Superstreet Coilover broke
- Cheapest Performance Tires!
- Cool "autocross" video, not sure if anybody here h
- Questions on stock shocks and lowering springs...
