- Just bought Scion Xb, 3 speakers not working...
- 04 Xb FACTORY cd player mounting bracket...
- Replacing the rivets in front mids?
- trip meter #2 going very fast
- xB Car PC ***56K WARNING***
- Does my Xb have keyless entry ?
- HELP! sub isnt working(fixed)
- racing seats!
- Has anyone seen these seats or seat covers?
- New front Seat
- My new dash speaker grills bt EZ Baked
- remote starter + alarm wiring diagram 05 xb
- Speaker size for 2006 Zion XB
- Found the perfect use for my factory radio
- new dash 85%
- Painted dash 1st gen XB pics
- Interior Map Light / Dome Light pics...
- I Need A Box For My 10w7
- HELP! OEM gauge backlight problems...
- New Interior Bike Rack Setup(Pic Inside)
- installing 2nd amp
- Scion stock unit fitting 03 tundra?
- Pillar gauge pod on eBay, any good?
- Where did you wire this Shifter Base thing...
- Painting the Inside SCION XA
- 6 disc CD stuck
- Stock Air Box Tool Box
- Where Did You Get You Suede?
- Removing silver interior peices
- xB Cargo Bed Conversion
- rear passenger window problem
- mp3 volume problem
- Looking for Car PC ideas....
- extra bettery or more caps? burring out amps...
- interior cloth question
- Shift Knob for people with a shorter reach
- Anyone have a PDF or link to the manual for a Pioneer T1804?
- headliner cloth question.
- stock speaker wiring
- power side mirrors not working!!
- Need Help
- how can i remove the clear plastic "door" piece?
- AVIC-F700BT install???
- question on 2005 xb wire under rear bumper.
- Connect a USB Thumb Drive To My Ipod Connector?
- having problem using AUX connector 2006 XB
- what should I replace my stock 6 disc with?
- Projection headlights, compatible with HID's?
- About those Silver interior pieces... HelP?
- sub hits with no music?
- left dash light keeps going out
- AT shifter mod
- what's a good price for clazzio seat covers?
- Passenger power door knob not working
- Aftermarket Head Unit Question; HELP!
- 06 Xb and the IPOD Touch
- Clarion FB275BT Discreetly Installed in the Oven
- The accessory switch locations under the oven
- Need help finding an Ipod adapter for a 2005 xb
- how to keep orig h/u and add dvd player w/aux sound??
- Seat recovering
- RS3 Headunit "Secrets"
- my sub stopped, help plz!! (fixed)
- Ok dont laugh too hard at this, but help....... UPDATE!!!
- DEI/Clifford Alarm Install Help
- Autometer Tach install on 06 Scion xB
- Scion carbon fiber dash appliques
- Heel rest/floor mat protector?
- How many LED Illumination modes
- Tc steering wheel for Xb 2006
- replacing all speakers in car. please help
- Scion Bazooka bass tube with aftermarket radio...
- xA and xB front seat bolts, are they the same?
- New HVAC lighting. 5 minute mod for only $7!
- Happy Birthday to My Interior & Myself......
- Adjustable Snake Map Lights
- 08 radio help...
- Is the Bazooka Subwoofer worth $96?
- Stock car alarm goes off when starter assist connected??
- Looking to wire some LEDs under speaker grills....
- Speedometer problems
- Toyota Air Bag Swap
- cold+speakers=pop
- Head Unit
- Ipod jack cover
- Factory upgrade ALPINE DVD w/ DUAL 7" MONITORS need hel
- aftermarket headunit ??????'s
- Oven Light Bulb
- New quick release setup =)
- Since I've had good luck recently with responses...
- It pulls you in and you want to do more!
- Wiring help from someone who may know
- 2005 xb keyless remote
- Overhead Console
- Airbag light on.. location of sensors/wiring?!
- Need HVAC or GAUGE LED swap? DE or MD area..
- Horn
- Need HVAC or GAUGE LED swap? DE or MD area..REDO
- VCS, TRAC OFF and CEL all came on.
- batery power
- Carpet Padding
- BooBoo's
- Bazooka EL
- No Dash Turn Signal Indicators...
- Who has a Blaupunkt Gtt-1200 bass tube?
- ** EDIT **
- ** EDIT **
- Anyone with a Kenwood DNX5120:
- Double Din Mounts
- Wife's new sub box
- All great ideas come from the shower.
- Go BIG or go home.
- Just had an idea.
- Cruise Control
- Door Panel Inserts
- Dome light
- New Carpet?!
- rear speaker size
- Amp = fuse question
- how to change SCION greeting for 06 Radio's???
- is it my interface that's affecting my Greeting?!?
- Stock XB1 fog lights
- score!!!!
- Gauge Pod Question......
- ground cable getting hot for fogs
- Stereo Display Suddenly Stops Changing Colors!
- Vistoso Curtain Rails
- Will this Double Din fit?
- Seat Cleaner *Please Help*
- Sound deadening for road noise
- PAC controllers
- Door Lock Actuator
- I found these speedo glow gauges on ebay CHEAP
- My new interior fabric...
- Speaking of LED mods....
- Citizen Band...
- speaker size's
- 05 xB radio does not work any thoughts?
- Shifter knob ?
- Does 2008 XB's stereo work in 1st gen XB?
- stealth box inspiration
- How do you make a relay
- Alarm LED question
- Dome light
- 05 xA making wierd noise when i turn on a/c fan
- 2005 Scion xA vss wire location/color?
- problem with stereo, sudden drop in volume.
- New Custom extended shift knob
- Spec me speakers with an amp pls....
- Cigarette Lighter power always on?
- Factory XM radio install
- Does anyone make a steering wheel extender?
- 06.5 xB with Racing Seats, Air Bag Sensor Question
- xA Radio question
- Replacing xB1 front door lock actuator motor
- Bazooka mounting bracket for xB
- Question about wrapping door panels
- subwoofer question....
- New Box Design
- Automatic shifter P R N D illuminated lighting bulb...
- Audiopipe
- Scratches on interior panels
- Reverse Gauges for scion xA - Cheapest I've seen..
- Viper 5901 + Defroster hook up. HOW?
- Where do you install underglow for 04 XB?
- Bazooka - easy to remove? As opposed to hidden sub
- Trunk size
- Phantom II gauges too bright
- Ozonium Scion Rocker Switches... On/Off/On question
- How to paint the inside of XA
- Interior Storage Capability
- Scion xA ,dome light does not come on when driver door open
- "Top of the line" subs?
- Tweeter Short Help?
- Avh-p3100dvd installed.
- XB interior light mod. 18 LEDs BRIGHT!!!!
- new fabric
- Needing help with a system
- Dome light "door" setting issues
- anyone still make a full carbon dash?
- Audio ????
- 06 xB with 05 radio? Aux jack help.
- Error 3 and Error 4 Message on 6-Disk Player
- will this work???????
- Hasepro magical carbon???
- Shift knob tread pitch?
- just got some mtx subwoofers
- What size is the Bulb In the Dome Light?
- Anyone know where i can get the crystal ac control knobs
- Alpine ida-x305 - anyone else using CD-less technology?
- Dash Tray for xb?
- New Headunit Installed in the Box
- anyone tried this? Archos 7 on dash
- Window resetting
- Any Suggestions ?
- Wring question for Rockford Amp?
- Adding extra Cig plug on dash?
- Back Right Door Lock Actuator
- Ipod Touch Charging?
- Good Amp(s) to power 6 eD Sq10's
- Troubleshooting OEM Illumination Switch
- 09 xb radio desk question
- How many subs do you have?
- Aftermarket Steering Wheel Hub Questions
- Locks
- a new and freash idea...
- Help me! Think I might have blown a fuse in my 1st Gen. xB
- amp attached to front seat?
- HELP!!! removal of anti-theft device
- more powerful alternator.
- xB Use #132: Motorcycle trailer
- JDM Shift Knob Question
- I need your help
- Need help w radio upgrade for scion xa
- Panasonic CQ-VW100
- automatic door locks
- Which wire to tap for dimmer light near radio or hvac?
- Can u check the list ?
- iPhone users come in.
- New headunit choices
- Info on Pioneer AVH-4100DVD?
- Pioneer Slim fit sub
- Sirius Factory Box Gets Stuck on Channels?
- Do more dome Lights mean new fuse?
- replace 2004 xA factory stereo with newer one with aux?
- what kind of damp is this?
- paint or no paint?
- What percent window tint should I get?
- Some of the interior done...
- will this headunit fit?
- rs3200 problem
- will this soundsystem work?
- Replacement Mirror
- no aux mode on 06 xb head unit?
- ALL-NEW 04-07 XA/XB ARMREST FROM ZETA PRODUCTS
- no jute avail?
- Stronger lift gate struts?
- Will my 06 pioneer head unit work in a 2004 celica?
- xA pillars
- Help with somewhat confusing subwoofer wiring
- iPod Interface cable, with 05 6-disc?
- Installed (2) SQ10's & a NINe.2X amp....question!!!
- need HID help!!!
- INSTRUMENT PANEL TRAY?
- 0db vs 3db....
- My alarm doesn't like my dog
- Finalllly, pix of amp attached to seat
- Installed LED's in the Hvac Vents - Now with Crappy pics!
- I Haz Bass Now! lol
- xA passenger door speaker ratlle (yes i searched =)
