View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. My $75 Ebay Intake Review...
  2. Help Please... Bogging and Rough Idle
  3. injen exhaust, no i am not asking where to get one.
  4. Governor?
  5. urgent help needed.
  6. car randomly sputters when stopped...help plz
  7. Installed TWM Cable and Base Bushings
  8. Clutch Chatter?
  9. custom CAI.....what problems might I run into
  10. radiator fluid leaked on tranny
  11. Megan S and Mid Pipes
  12. Anyone know the size/thread of the OEM axleback exhaust nut?
  13. shiftkit!
  14. AEM Bypass valve
  15. Dezod exhaust pics?
  16. ARK looking for FIRST product volunteer installer.
  17. Which cat-back exhaust system should I go for?
  18. selling extended warranty back to dealer?
  19. GAUGING INTREST: DEZOD EXHAUST GB!
  20. Header rasp?
  21. TRD Limited Slip Differential
  22. I NEED A RACING HEADER
  23. tC Oil Cooler? Will it work? Does it?
  24. Air Filter / MAF Sensor Problem?
  25. Give Me reasons not to get rid of my tC!!!
  26. midpipe question
  27. Which cat-back exhaust system should I go for?
  28. Personal Opinons for Choice of Headers
  29. Draxas Exhausts and S-Pipes, Nearly out of Stock
  30. Draxas is for Sale
  31. How do i install an a/f ratio gauge on the scion tc
  32. Injen Intake....Black or Polished on the BSP?
  33. Transmission question??
  34. Are there any carb legal intakes? exhaust? headers?
  35. Confused...
  36. 07 Injen Intake M/T A/T difference?
  37. Mechanical RPM Limit of 2z (not ECU Rev Limit)
  38. TC Connecting Rod Length?
  39. good deal on tC s-pipe
  40. ZPI Clutch Information
  41. Tsudo N1 Catback Installed
  42. Any audio clips of what a tC sounds like with just intake?
  43. Megan midpipe and spipe problem
  44. Trouble going into reverse?
  45. YES! Excellent
  46. Cat-back Dual Exhaust
  47. What does this part do?
  48. Anyone know where i can get cheap spark plug coils?
  49. Header suggestions
  50. Engine tranny combos
  51. INJEN CAI & axle-back Exhaust, anyone???
  52. Please Lock
  53. Proformance Chip for the TC
  54. New Clutch Available for tC (Competitionclutch.com)
  55. VOIDING THE CARS WARRANTY
  56. injen cai, question.
  57. V6 tC?
  58. SECOND GEAR GRIND when cold outside
  59. 2JZ-FE vs 2AZ-FE
  60. 70 dollar axle back!!!
  61. Maintence Required Light!!!
  62. Apex Specific Prob?
  63. Scottsdaletc and Competition Clutch Stage 4 *pics*
  64. Resale value?
  65. Tc Charcoal Canister Cel light check engine ANYONE?
  66. best headers?
  67. Throttle Lag/Delay
  68. WTF!? Advise to dump oil cans on road!??
  69. Camshafts, Heads, pulley's etc.
  70. the ULTIMATE compliment..
  71. Cheapest place for Borla axel-back???
  72. Quick question...Do S-pipes throw a CEL?
  73. silver spark plugs
  74. radiator hose leakage
  75. Exhaust Set up question
  76. NST shifter bushings
  77. S-Pipe Install
  78. trd exhaust install question
  79. HELP: 1 Week Old Megan Cat Exhaust: not that loud anymore
  80. EBAY how good can this stuff really be??
  81. Heavier flywheel in 07 tCs?
  82. Borla
  83. 2007 tC, open, LSD or Viscus???????
  84. throttle body
  85. HKS angle
  86. DC Header
  87. Opinions Please
  88. Stock Trans Cooler
  89. 07 tc dyno chart/video's anyone?
  90. Burnt Bearings
  91. High-Flow Catalytic Converter for the tC
  92. FOR SALE!!!!!!!!!!!!!!!!!!!!!!
  93. Power Potential of Bolt-Ons
  94. Parking brake light keeps coming on after pulley install
  95. NST Pullies... Good Info!
  96. Not again.... Engine Number 3?????
  97. Weapon R Intake!?
  98. Phantom Grip
  99. Dyno Simulator
  100. Craven Speed shifter
  101. i need your help with wat to buy.
  102. HKS or Injen Intake?!
  103. intake filter
  104. *HELP!* Crank Pulley Install
  105. Possible ZPI Pulley damage?
  106. My New Heat Shield+Diversion Panel PiX
  107. a lil help about cat backs...
  108. Anyone dyno a 2007 tC yet?
  109. so my injen intake is finally arriving... last questions...
  110. Which Exhaust do you prefer?
  111. ticking/tapping noise
  112. PICS OF MEGAN RACING EXHAUST INSTALLED ONA 05 TC
  113. Short Shifter FYI
  114. 07 Intake
  115. Long tem header usage problems?
  116. 6 speed w/LSD?
  117. Dyno tune NA
  118. AEM oil cap question
  119. custom intake, anyone use this piece for the sensor mount?
  120. greddy evo 2 catback
  121. '07 tC Cold Start Issue (Automatic) **UPDATE on Pg. 2**
  122. Coolant levels recomendations?
  123. just a simple noob question.
  124. hi flow cat
  125. where the hell is the parking light fuse???
  126. Widebands on tC?!
  127. Header/HighFlow Cat/Resonator Set-up?
  128. Wats the Best Intake?
  129. Injen short ram Air Filter Heat Shield...
  130. HEADERS!
  131. quick & short shifter...
  132. HELP
  133. Zpi exhaust!! HELP ME!!!
  134. Swapping engines
  135. Question about the Alpha Werks Header.
  136. HELP ME!!!!!
  137. **edit**
  138. How much power are you laying to the ground Post numbers
  139. when or where can i get cams for the tc
  140. Exhaust leak
  141. Getting to 185 whp N/A
  142. a/c removal
  143. Anyone running straight pipe?
  144. Exhaust?
  145. swapping MAF sensor
  146. OE Injector and Fuel Pump Specs
  147. Making TC 4 wheel drive
  148. High Performance N/A ECU Reflash
  149. Shifting is very slow!!!
  150. Switching Over
  151. Anyone buy the Samco products from Optionimports.com?
  152. please reply to a/c removal question
  153. **edit**
  154. cold air intake questions
  155. Castrol Syntec or Mobil 1 full synthetic?
  156. Slow AT shifts during Nitrous
  157. Quick shift = no power? Anyone have this problem?
  158. Does anyone have this exhaust?
  159. Whats your opinion?
  160. super quiet resonators?
  161. hey nitrous questions need help pls look i want to buy a kit
  162. Tsudo N1 - About to pick up!
  163. tore my intake lil help..pls
  164. Injen Cat-back exhaust?
  165. valve cover torque specs??
  166. Question: CF Engine Cover and CF Air Diversion Panel
  167. Megan OE exhaust
  168. People have been asking me about my intake so here it is...
  169. Power mods, noise free?
  170. when do you use?
  171. Injen intake for 07 tC
  172. Injen Cold Air Intake filters??
  173. What do you think about the sound of this exhaust?
  174. size of filter for injen filter..help
  175. Ticking coming from engine on passenger side
  176. Fluctuating RPM's at idle?
  177. FLYWHEEL
  178. With the e-manage...
  179. New Strup Axle Back
  180. K2 motor short shifter for 07?
  181. Greddy Emanage Help
  182. programmers
  183. N/A Auto Dyno - Umnitza Intake (w/ Spectre GFI), TRD Exhaust
  184. brake light malfunction!!!
  185. HKS Exhaust
  186. Tsudo N1 Catback Exhaust Installed (Review/Pic/Vid)
  187. Squeaky noise driving at high speeds.
  188. ENGINE KNOCK.. after warmup
  189. HELP ME PLEASE!!!!
  190. CAMS for a 2AZ?
  191. Fining for Engine mods...questions Full Exhaust
  192. GTech timer
  193. extended my MMW intake..
  194. HKS Hi Power Exhaust?
  195. Turbo Tc W/ Dual Exhaust setup
  196. tranny
  197. Can I combine these?
  198. TOP FUEL EXHAUST? or ANY exhaust Pics?
  199. Headers and S-Pipe or Dezod Full Catback Exhaust?
  200. FEED BACK PLEASE!!! WHATS THE BEST INTAKE/EXHAUST SETUP?
  201. Injen CAI installation HELP!!!!
  202. New E-Manage coming from GReddy!!!
  203. recomended exhaust size
  204. megan racing s-pipe
  205. 07 tC Header?
  206. Question for everyone.
  207. What you guys think "short shifter"
  208. dyno question
  209. Upgrading Clutch....need some advice!
  210. what happened to the draxas exhaust
  211. any problems.......
  212. Can I adjust my ACT clutch?
  213. ingalls dampener sound when cold?
  214. Best places to buy tC parts?
  215. Engine Reving by its self when cold
  216. MEGAN DRIFT cat back !!!
  217. TRD Performance Parts
  218. Thinkin' about a baby bottle (N2O)
  219. MMW vs. Strup header
  220. Megan R. header problem. Polish the steinless steel?
  221. My 07 feels way slower than my gf's 06..
  222. The GREAT HEADER TEST..
  223. injen cai internal ticking..
  224. Driveshaft Issue
  225. Bore/Polish
  226. ebay intake
  227. best pulleys?
  228. Which clutch would handle more tq?
  229. N/A=Pig Rich at WOT?
  230. Auto Tranny Fitting Size?
  231. This sounds BAD!!!!
  232. HELP PLEASE!
  233. CA cops... goddd
  234. Scion tC CAI from K2.....inquiry
  235. Emanage Ultimate MAPS • MAPS • MAPS
  236. What’s the Stock Belt size?
  237. N/A Tuning Project //DONE FOR
  238. EGR Valve?
  239. I need another exhaust!! Something with tone!
  240. Hydrolock with Injen CAI
  241. Exhaust options?
  242. Alternator question
  243. Angle of HKS Hi-Power exhaust?
  244. CAI / Exhaust Combo
  245. First Oil Change!
  246. I need Injen CAI Clamp
  247. Dezod Exhaust
  248. Question?
  249. MMW / WR Engine Damper on Sale.
  250. ugh cheap drift spec...anyone has pics of Greddy EVO II?
