View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. short shifter install
  2. How much are everone's welding jobs?
  3. Where can I buy the AEM Blue Battery Tie Down?
  4. the check engine light
  5. Help Needed. Something went wrong... CEL on!
  6. supra engine in tc
  7. cheapest place for the TRD exhaust?
  8. TRD Quickshifter
  9. Header question
  10. Unorthodox lightweight crank pully
  11. question about tC cats.
  12. fried my pre-cat
  13. hmmm headers
  14. Got that exhaust on........finally
  15. Does anyone have hks exhaust in-car videoclip?
  16. Question
  17. good deal?
  18. 2006 tC Automatic Dyno ?
  19. full cat back
  20. MMW CEL Eliminator vs Antifouler vs EManage
  21. header or intake
  22. Header Question
  23. Need help deciding...
  24. Greddy Evo2 axle-back exhaust video clip
  25. WHATS A SAFE AIR TO FUEL RATIO?????
  26. '06 OEM header on an '07
  27. B&M question
  28. TRD LSD on an automatic 2005
  29. AEM carb legal intake for tC?
  30. Highest N/A Dyno Graph on Scion Life
  31. Alternatives to E Manage Ult
  32. Time for a resonator.. Need Advice!
  33. tsudo n1 install help........
  34. weapon-r vs. ingalls ETD
  35. Megan Mid Pipe
  36. Gear and Axle Ratio for Automatic Trans
  37. So what happened to my clutch?
  38. PNP harness.
  39. 2 Brief Intake Questions
  40. I WANT THE MEGAN CATBACK! BUT I GOT 1 QUESTION!!!!PLS HELP!!
  41. Datalogging Software
  42. Megan Drift-Spec Axle back, need some input
  43. Intake Advice
  44. Tanabe Medallion Concept G Vs. HKS Hi-Power
  45. how much belt dressing to apply?
  46. automatic turbo issues
  47. burning smell
  48. I find it impossible to check the dip stick oil level...
  49. anyone daily driving with a stage 3 clutch?
  50. How to set Jumpers into Greddy Ultimate
  51. Best way to downshift?
  52. How bad is this for my engine?
  53. 2005 TC engine problems- might void warrenty
  54. Megan short shifter installed...
  55. Will any company make a damn 02 sim that works!?
  56. Injen Short Ram Noise
  57. w/c is better??GREDDY EVO@ or DRIFT spec?
  58. new gear noise im hearing - going slow
  59. Need a clutch, where to buy?
  60. Ok... so I want this to be my next project...
  61. Recommendations on headers for TRD Exhaust?
  62. headers and cat back exhaust
  63. Dimensions of S pipe
  64. S pipe
  65. HEY GUYS...NEW TO THE FORUMS SO...
  66. exhaust
  67. Opinions needed
  68. vibrating sound???
  69. Header and S-pipe installation.
  70. MAINT REQD
  71. Third ground today - with the clutch down??
  72. headers and cooling plate
  73. Engine Idle RPM...too low?
  74. Anyone interested in a Stealth Cat back by TSUDO
  75. Which clutch is best for my s/c TC???
  76. Need Advice Badly!!!
  77. '07 Tc CAI
  78. Can the stock ECU get wise to sneaky tricks?
  79. New TRD short shifter
  80. Cold Air v.s. Ram Air
  81. ignition coil
  82. New Headers and more?
  83. Agency Power Exhaust
  84. Limited-Production Aluminum Intake Manifold
  85. Pulley Advice
  86. TRD Quaife install by a Honda guy.........
  87. i/h/e help
  88. removal of stock exhaust
  89. fortified axle > anyone have one yet?
  90. Exhaust....So many choices
  91. RX-8 THROTTLE BODY ON A TC?
  92. MMW Specials..
  93. Problems shifting
  94. Donut gaskets
  95. Injen Hydroshield
  96. 07 Injen CAI
  97. Need some suggestions.
  98. megan drift spec for 07 tc
  99. which exhaust??? NEED help!
  100. Tsudo N1 w/ Headers?
  101. Cold Air intake
  102. Benefits of the Emanage
  103. tsudo catback
  104. Fidanza flywheel+clutch masters installed(updated) 56k nooo!
  105. Ain't this about a @#*!!
  106. Injen CAI installed!
  107. Scion and the "Free" Oil changes
  108. what should i do??
  109. Damn Intake systems... *for cali only*
  110. zpi exhaust and stechs
  111. RASP
  112. just ordered my greddy evo2
  113. Header/downpipe question
  114. Fujita CAI for 2007 Scion tC
  115. ZPI Exhaust Installation?
  116. Help Multiple Engine CEL codes, O2 sensor, Misfires, MMW
  117. TWM Shifter, base and shift cable bushings install (2007)
  118. Agency Power Pully vs. ZPI V.2
  119. 2007 CEL need HELP
  120. how many miles for full synthetic?
  121. Breaking in the tc
  122. I'm confused! Help me make up my mind!
  123. automatic to a manual trans help
  124. INJEN HYDRO-BOOT
  125. bring back the dead: Weapon R air ram kit
  126. NOS questions
  127. TRD Intake?
  128. Quickfix CEL!
  129. Megan Racing @ Dezod
  130. nst lite crank pulley
  131. Powdercoat or high temp store paint?
  132. tsudo N1 installed (56k careful
  133. tC Proformance?
  134. I need a LOUD exhaust (shut up. lol)
  135. Borla exhaust
  136. How does this line up?
  137. mid pipe
  138. just installed my pulleys...
  139. would this set up work? Header + Exhaust Combo
  140. Why so cheap (Megan Header?)
  141. tC Clutch Sucks???
  142. Borla Dual tip Exhaust for the TC? Take a look.
  143. Okada Projects ignition coils???
  144. ZPI catback exhaust = LOUD?
  145. Where is the ss clutch line DIY?
  146. quick pulley question
  147. what should i do next?
  148. DC STB and INJEN CAI
  149. question about top speed
  150. CC short shifter bushings
  151. resonator in the megan drift spec. cat.back.
  152. Header Removal Tool
  153. Tanabe conjcept g...
  154. what size (diameter) is the TC's fuel supply line?
  155. fujita cold air intake for automatic?
  156. slooooooooooooooooooooooow
  157. I NEED HELP!!!!
  158. throttle body spacer
  159. Driveable tC Exhaust <$250.00
  160. Three things I want to do... would appreciate some input...
  161. Spring bolts...
  162. UPDATED: My current set-up, no CAT CONVERTERS!!!!
  163. Greddy SP2 tip size?
  164. Help!
  165. will this cause a problem?
  166. Just got my valve cover/spark cover in..
  167. Exhaust Gains?
  168. Thing connected to the MAF ticking ... kinda loud???
  169. dual exhaust?
  170. which is better megan short shifter or cc
  171. Clutch slip? Please help...
  172. k&n CAI filter specs
  173. vvti problems?
  174. plugging the intake resonator
  175. Anyone know anything about this exhaust system????
  176. Would this be obnoxious
  177. Parts of the exhaust system...help with new scion!
  178. generic ebay 4-2-1 headers...help?
  179. Mid-pipes?
  180. exhaust questions
  181. Creative Compacts Exhaust sound clip anyone?
  182. 2007 Fitment: Intake, Header, Exhaust
  183. Pro-motion/Creative Compacts exhaust?
  184. K&N drop in filter review
  185. Crank Pully Question!
  186. bad gas mileage? could this possibly solve the problem?
  187. Maintenance 101 --Understanding your tCs' engine--
  188. intake
  189. TUNERZINE.COM AND NST COME TOGETHER FOR TZ PROJECT TC..
  190. HKS...good to go!
  191. Help Please~~
  192. Methanol Kit
  193. cant get silencer off megan drift spec ! heLP!!!! :cry:
  194. compression loss
  195. aem cai, dc header, resonator, trd axle back exhaust(video)
  196. Humming/Whistling Noise
  197. Header/ CEL Questions
  198. Fitting AEM CAI to a 2007 TC
  199. Doc + King = CAI Fender Mount! *UPDATE 2/4* (pics inside)
  200. NEED Help installing camcon and setting i need
  201. I NEED YOUR SUGGESTION!!!
  202. Ingalls Engine Damper Review w/ added intall details
  203. people w/ megan drift spec
  204. Thermostat
  205. OBX Header and S-Pipe w/ TRD Exhaust **VIDEOS**
  206. Pulley install
  207. California Emissions: Issues w/ headers and some ?'s
  208. bypass TB for hp......?!?
  209. My Powder Coated Valve/Spark Plug Cover!!!!!!!!!!!!
  210. Greddy SP2 installed...have some questions
  211. SOFTWARE UPGRADE
  212. Who makes a TRUE cat-back exhaust?
  213. Tsudo fireball axleback hell + bad fit + leaks
  214. Stuck: Antifouler and CEL Eliminator dont work
  215. emanage for NON-turbo car?!?!?!!
  216. brand new gt-r exhaust
  217. Best Header for tC? Opinions?
  218. Header CEL Situation Round-Up
  219. Problem with tranny at startup
  220. Anybody ever heard of SR-S?
  221. Air Bypass
  222. HKS Hi Power HELP!
  223. The risks of headers.
  224. 35k miles 05 TC with a lemon transmission
  225. thoughts on injen CAI. with mods.
  226. torque of horsepower? which do you prefer?
  227. Anyone have ZPI pulley on an auto?
  228. Agency Power full cat back exhaust????
  229. Scion tC N/A Stage 1 & 2 Kits
  230. S Pipe Benefits
  231. Cold start up!
  232. ARK Exhaust ROLL CALL ~ DT-S / N2
  233. fortified axles are here!
  234. my grounding kit + voltage stabilizer review (madd JDMZ yO~)
  235. Authorized TRD LSD Installer
  236. Auto tranny sticking?
  237. best place to get TRD exhaust
  238. Injen CAI question.
  239. Question About Resonators
  240. lil help shiftin tC
  241. belt for pulley?
  242. Exhaust leak?
  243. New midpipe or mod mine?
  244. Anybody have a Dezod Exhaust sound clip?
  245. What Headers are the Best for a 2007 Scion TC
  246. trd exhaust
  247. megan drift spec in cabin video
  248. Emanage or other power chips on NA?
  249. replacing a clutch, version 2 questions
  250. DC Sports Header = really loud buzzing noise!
