View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. Project 400WHP. Suggestions how to do it?!
  2. Tranny emergency...please help me. I don't have a lot oftime
  3. Tranny fluid, what kind?
  4. Stealership stripped the bolts on my oil pan
  5. Installed camcon and intake. Dyno inside. *W/ Time slips*
  6. to those with SpeedSource Motormounts...
  7. S-Pipe and Mid pipe. ZPI vs. Megan Racing
  8. 6 speed....XRs Tranny!?
  9. Bigger trottle Bodies
  10. quick question to peeps with megan exhaust
  11. zex nitrous dry kit
  12. Jet V-Force Controller
  13. NEED HELP FINDING NO RASP SETUP
  14. cant choose between injen and tanabe
  15. high flow cat.
  16. does anyone have...?
  17. Heat coated my header
  18. Oil Light
  19. Need quick help w/ SS install
  20. SCION tc HORSEPOWER INCREASE RECOMMENDATIONS
  21. Installed my Header!!!!
  22. Tsudo Cat Back Owners - Need Input
  23. Auto vs 5-speed
  24. WANTED quiet deep exhaust tone
  25. Tranny Cooler install question.
  26. Magnaflow Part #?
  27. Catback and headers??
  28. KillerGlass Radiator Hose Came Out!!
  29. TRD filters
  30. INJEN CAI slapping sound
  31. Problems after removing Nology Hotwires...HELP!!
  32. Ignition box
  33. TRD Exhaust + TRD Intake
  34. The tC exhaust explained
  35. header issue
  36. lsd
  37. S-pipe q's
  38. ZPI Cat Back or Precision Muff. Cat Back
  39. Need cherry bomb advice!
  40. Clutchmaster Stage3 - Flywheel - LSD Install - Props!
  41. What brake Fluid?
  42. Smoke!!
  43. AEM/TRD Hose and Tempature Question
  44. Crank pulley
  45. Greddy Evo2 Driver Side bracket
  46. P0103 MAF or VAF Circuit High Input
  47. about shift knobs...
  48. Cause for concern?
  49. Megan Drift Spec vs Injen Cat Back
  50. Dealer pricing for TRD exhaust install
  51. Tranny Question
  52. WHo wants a video how to for Intake?
  53. HKS HI power exhaust wanted
  54. ignition equalizer
  55. Good exhaust for tC stick???
  56. exhaust help quick!
  57. Tsudo Fireball axleback
  58. what is the best header conig for the tc
  59. hear a noise
  60. blowing smoke
  61. Injen Exhaust Help
  62. Tsudo N1 Catback install
  63. Spintech mufflers
  64. Invidia S pipe works with DC Header.
  65. Megan Racing HELP
  66. antifouler and turbo
  67. problems starting
  68. Apexi N1
  69. s/c full exhaust help
  70. valve cover
  71. Does The Injen SP - Speed Pro Intake Cause Any CEL??
  72. Valve Adjustments?
  73. Anti Foul Trick
  74. Maintenance RQD light came on
  75. Headers
  76. 07 ebay intake
  77. CIA TRD or INJEN?
  78. ECU pinout?
  79. For all you that have Alphawerk's......
  80. Rasp and Fitment Problems *fixed*
  81. Who needs an HKS Hi-Power exhaust
  82. Crank pulley purchase info?
  83. ARK N2
  84. Anyone have one of those quick drain oil valve things?
  85. best intake
  86. hks owners...help!
  87. XRS 6-speed tranny swap
  88. Need Allmotor specialist
  89. GROUP BUY Billet Engine Bay Accessories From Zeta Products
  90. When should one use a Fuel Controller (emanage)?
  91. Fuel Rail Test Port.... Question?
  92. Gasket help please
  93. Where can i buy Agency Power ti/ss exhaust
  94. :( im so stupid
  95. dirty maf sensor??
  96. Best bang for the buck with $250?
  97. Hp Yield
  98. !!!!Fujita Cold Air Intake...Please read!!!!
  99. power steering tsb
  100. Oxygen 02 Sensor
  101. Are there different ring and pinion gears available?
  102. quietest exhaust system?
  103. Brakes Suck.
  104. Full Megan Exhaust?
  105. spark plugs? worth it???
  106. A few pics of under the hood!
  107. sports muffler on automatic?
  108. what is back pressure
  109. HKS exhaust
  110. Megan or ZPI Mid-pipe
  111. Tsudo Exhaust Installation DIY
  112. APEXi NEO COUNTERFEIT
  113. Problem Tranny after new clutch installed
  114. Headers Megan or dc sport?
  115. Cold Air Intake
  116. What Brand Exhaust Is This????
  117. BOMZ INTAKE??? ANYONE USE IT BEFORE?????
  118. Jet V-Power
  119. Exhaust smell in oil?
  120. Clutch/Flywheel install?
  121. Pulley question?
  122. First Mods: Short Shifter
  123. Megan Axle Back Exhaust 05-07 tC - Low Price Found
  124. Help with clutches....
  125. Megan Midpipe question?
  126. clutches
  127. how much can the stock clutch handle?
  128. Flanges
  129. no axel back
  130. Short block or long block
  131. tc exhaust quick question
  132. Resonator with stock mid piping and axleback..is it possible
  133. Supercharger
  134. Help! New O2 and CEL back on!!!
  135. Clutch Squeaks
  136. getting the tC ripped for summer
  137. What nitrous system?
  138. What the HECK is "GFI"?
  139. my axle back got messed up
  140. 07 tC exhaust
  141. ARC intake box
  142. Pulley Help/Question
  143. catless midpipe and OEM axle
  144. Removing Belt
  145. Hard to start in the AM
  146. CEL but no codes?
  147. s-pipe /exhaust question
  148. CARB Exempt Legal SRI for 2005 2006 tC Short Ram Intake
  149. PM OR OEM MEGAN?
  150. the clutch
  151. Slight Rasp
  152. Header Coating? Is painting black do-able?
  153. dual side exhaust
  154. I need help!!!!!
  155. Kaminari kit with HKS Exhaust
  156. Headers? Legal? or Illegal?
  157. Has anyone tried this with a CAI
  158. stock intake upgrade
  159. Geddy EVO 2
  160. The Tc Tranny?
  161. Anyone know of?
  162. Looking for an Injen Intake
  163. Injen or AEM?
  164. any tc pushing no2
  165. CAI and MPG
  166. auto tranny
  167. K&N CAI installation
  168. water in the intake........
  169. lightweight crank pulley on an auto?
  170. Shaky Idle..?
  171. apexi neo cel
  172. cams
  173. precision muffler axleback
  174. HARD BRAKING noise HELP!! asap!
  175. Opinions on this setup for a 5-speed
  176. Injen cai BIG PROBLEM!
  177. TSUDO 4-2-1 Header test fit pics (56K bad)
  178. MPG boosting mods
  179. Anyone Know Where to get Chrome Engine Cover Nuts?
  180. All motor or turbo?
  181. OE-style aftermarket exhausts **Updated w/Video**
  182. tsudo n1 piping
  183. TRD Cold Air Intake
  184. need some speed...
  185. so i've learned my lesson...
  186. Dead Car... won't start
  187. Normal?
  188. Megan Racing S-Pipe
  189. Is my motor blown?
  190. Help with info on Limited Slip
  191. 2007 tc K&N intake
  192. Clutches???
  193. HKS Hi-Power Exhaust [tC] No 56k
  194. megan racing mid pipe
  195. HKS HI-POWER OR INJEN EXHAUST
  196. WTH...car won't go pass 118 mph*Update in org. post*
  197. K & N Air Filter?
  198. manual .
  199. Idle adjustment on a manual transmission tc
  200. InjenCai Broken? IDK need help
  201. 25000 mile service
  202. Heat Shield Removal Help!!
  203. DC Header, Megan Mid Pipe and TRD Exhaust
  204. High pitch wistle on Injen?
  205. Header?
  206. Does anyone have the Street Power exhaust?
  207. zpi exhaust
  208. hp? on weapon r headers
  209. Auto Innovation Downpipe????
  210. BEST CAT-BACK EXHAUST FOR tC
  211. Searched, now I need your thoughts "Droning in axleback
  212. Engine acting wierd
  213. Rear Wheel Drive TC
  214. Tanabe Concept G with TRD Supercharger???
  215. pictures of my new exhaust/rims/drop
  216. New headers and a question!
  217. Motor Mount!!!!
  218. motor mounts, header, turbo mani and eyelids
  219. Hide things in engine bay (battery, Washer fluid etc)
  220. So there is aftermarket tC cams now I guess...
  221. Twin turbo
  222. stock headers gutted?
  223. Weapon R header
  224. HKS Silent Hi-Power?
  225. Will this custom exhaust work?
  226. Scion Tc Hose Swap.
  227. Electronic Cut-off Valve for your exhaust?
  228. weird engine sound
  229. 2007 MAF Adapter
  230. 9.5 pulley
  231. Metal guard on headers
  232. Glass Header???
  233. Exhaust Leak?
  234. 02 sensor question
  235. Weapon- R TC Header picture
  236. brand of exhaust
  237. Wrong a/f sensor
  238. Is it true about the weapon r headers?
  239. K&N Air Intake
  240. Help!?! Tsudo n1 mid pipe - HKS Hi Power?
  241. ferrera and dezod springs+retainers the same?
  242. want less raspy exhaust
  243. Gas mileage?
  244. More power.
  245. fujita cai
  246. ECU - Yes or No
  247. How many cc are the stock injecters???
  248. Borla Exhaust
  249. Clutch Chatter
  250. o2 sensors, cel, & anti fouls
