View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. my hydroshield
  2. intake sucked up water
  3. tanabe concept G
  4. Coolant Flush...
  5. silencer removal
  6. need some info on Injen exhaust
  7. bolt on power
  8. th body
  9. magnaflow
  10. Anyone do a all motor build?
  11. wierd problem, dont know wtf is going on please help
  12. TC LSD
  13. TC EXHAUST
  14. "Precision exhaust", or is it Magnaflow
  15. question on the hks high power exhaust
  16. UPDATE: CAI + WATER
  17. question on headers
  18. TRD LSD HELP!!!!!!!!
  19. Whos interested in an ESK ?
  20. cold air intake vibration mount
  21. 5th gear shift
  22. Went to the dyno today...
  23. Car takes 4 to 5 seconds to start!!!!
  24. TRD LSD
  25. crankshaft pully
  26. well its time for a new Clutch
  27. Megan Header
  28. Clutch choices
  29. Just installed the GearSwitcher, got a few questions
  30. Alphawerks Header question!
  31. Torque Converter for our cars??
  32. Stock Exhaust Weight
  33. Part number for the allen screws on the stock intake
  34. REV LIMITER WHERE IS IT!!!!?????........
  35. Is getting a Header worth it?
  36. Hi Flow Cat vs. Cat Delete down pipes
  37. NEW ENGINE
  38. 07 Scion tc ecu diagram
  39. exhaust hangers
  40. Greddy dt
  41. my slight header delemia
  42. question about interchanging parts from year to year
  43. Docs basic short shifter question
  44. Tanabe Medallion Touring Exhaust (Pics and Video)
  45. Intake systems
  46. --->(pics only) show off your engine compartment <----
  47. NEeDiNG SUGGEsTiONS ON eXHAUST!!
  48. does TRD shift knob fit CC short shifter?
  49. {Axle-back} Opinions please. TRD or Precision exhaust?
  50. Would the engine still run if I do this?
  51. DIY on AEM Cold Air Intake
  52. VVTI AND VTEC
  53. what size bolt is....
  54. injen exhaust question
  55. i/h/e help
  56. Bad things about headers???
  57. Sweetest exhaust tone?
  58. TRD Exhaust
  59. e manage
  60. Megan Racing headers for the tC
  61. my exhaust keeps rubbing!!
  62. Down Pipe's?
  63. Questions about ARK N2 Cat-Back exhaust
  64. cams,th body etc..
  65. Manifold Gasket for Cheap?
  66. weapon r header sound clip
  67. Just letting everyone kno..
  68. The "shortest"?
  69. big bore
  70. nonresponsive cable shifter
  71. n2o / o2 help
  72. short shifter help...
  73. Injen CAI
  74. Easy STS!
  75. my plan
  76. Ebay cable bushing and shifter
  77. Exhaust Problems! Help!!!!
  78. Headwork PICS!!!
  79. Changing transmission fluid... Help need bolt sizes plz
  80. Injen CAI and Alphawerks for 2008
  81. What are the differences between cat-back and rear section?
  82. tsudo n1 here in a week.....
  83. Where do I hook up a Fuel Sender for a Fuel Pressure gauge
  84. TRD Headers?
  85. Getting HEaders in Tuesday and...
  86. Stock Fuel Pump Flow Rate
  87. Noise getting off lower gears
  88. Full Exhaust question
  89. TC Passenger axle
  90. My DIY on the DC Sports Muffler install
  91. Quiet down Tsudo catback
  92. oponions needed
  93. Wanting to Buy a Cold Air
  94. Estimated 1/4 mile time Question
  95. CAI question...
  96. stay away from ebay cold air intakes, headers, crankpulleys?
  97. Exhaust that hangs to low....
  98. help with head removal
  99. question about lining up midpipe w/ stock oem axle
  100. AT Fluid high from factory
  101. Header Help
  102. injen cai and bypass valve
  103. injen intake and exhaust
  104. short ram
  105. Tanabe Tuner Medalion Exhaust
  106. Shifter has mind of its own?
  107. gas
  108. The CAI/Bypass Valve Info Thread
  109. Car having probs starting
  110. Crazy gauges - Help!
  111. ugh wtf is w my tc
  112. manual transmission question
  113. Custom mid pipe?
  114. automatic=slow???
  115. Another tC just got the bottle!
  116. Does the tc have a rev limiter?
  117. My gas mileage sucks now!! Why?
  118. Questions about aftermarket headers
  119. invidia downpipe problem: neeed help
  120. Need a Spacer between the axle back and midpipe
  121. Injen intake question!
  122. Exhaust
  123. Engine Warrinty
  124. Electric throttle
  125. Removed Balance Shafts. w/dyno
  126. which header to buy
  127. zpi lightweight crank pulley
  128. TRD Auto Tranny Reflash
  129. 07 Tc CAI for road trip?????
  130. HP suggestions!
  131. Where to begin on getting a Turbo???!!!
  132. what to believe?
  133. Clutch decision...
  134. COLD AIR INTAKE PROBLEM...HELP ME
  135. Anyone running header/s/midpipe Tanabe Touring exhaust?
  136. Unstreetable?
  137. Manually shifting in an automatic?
  138. Lightweight crank pulley
  139. Brotha needs help with his crazy baby
  140. ** EDIT **
  141. Completed stock intake modification
  142. My experience with the TRD Cold Air Intake (CAI) in a 2007tc
  143. sister put diesel in the tC...need some feedback
  144. Intake filter question
  145. Random ECU hiccup?
  146. New Injen CAI and DC Header
  147. Emanage without much mods???
  148. should i expect rasp?
  149. Damn, changing flywheel and clutch is ____'n hard!
  150. Apexi N1 catback exhaust
  151. odd woosh sound
  152. what kinda oil do you use and how often do you change it?
  153. Megan Midpipe Dilema...HELP!
  154. Sputtering..Need help
  155. New Sticky?
  156. Tsudo N1 problem HELP!!!!
  157. 18" res. on updated Tsudo Catback???
  158. What does Toyota use to install the oil filter?
  159. super noob question
  160. Question about Weapon R cold air box.....???
  161. Redline MT-90 Online Retailers
  162. Question about the polish on a Tsudo N1 catback???
  163. Better gas mileage with h/i/e?
  164. i was looking at the exhaust thread
  165. short shifters..
  166. Exhaust/Kaminari Question...
  167. wierd clutch
  168. Injen CAI problem
  169. Damage from racing headers
  170. For us Cali tC owners
  171. Mod Suggestions..
  172. Wont you lose HP.
  173. Ground Fusion Questions
  174. Unichip Tuners in chicago area
  175. Need Scion Tc exhaust help
  176. throwing code...P0139....
  177. What else is Possible!!
  178. Weirdest tranny i have ever driven
  179. Exhaust Difference: GReddy EVO2 vs SP2
  180. BMW owners has questions: Don't flame me!
  181. megan header ques ? ?
  182. Lightweight Crank Pulley
  183. Which is better???????????
  184. the car is lagging, help please??
  185. rattling/bumping noise.....help appreciated!!!!
  186. What does the mid & S-pipe really do???
  187. dc headers
  188. helppppppppppp
  189. Time To Change The Brakes
  190. Location of vacuum lines
  191. CEL on and off
  192. Redline...
  193. CEL won't turn off!!
  194. Throttle Body
  195. engine mounts or engine limiter?
  196. Finish installing the megan racing short shifter **Problem**
  197. MAF problems
  198. Weapon-R Help (Realllllly odd)
  199. I need INFO
  200. Short throw shifter
  201. eBay Intake on 2008 tC
  202. where did you get your header from ? ?
  203. Opinions: Strup header and exhaust?
  204. injen cai piping size???????
  205. Headers make the scion tc sound like a fart machine ?
  206. All motor / nitrous - connecting rod strength
  207. stock exhaust size?
  208. Tranny very notchy!
  209. Alphawerks Headers
  210. Hesitation from accel. between shifting quickly at high rpms
  211. Optimizing the Intake
  212. Rattling during acceleration
  213. Neeed Help!!
  214. Exhaust
  215. Limiter
  216. lightweight crank pully
  217. buyinga resonator
  218. Tsudo 4-2-1 Header installed!! on a Supercharged tC!!
  219. piston question
  220. nst pulleys
  221. How is this possible..
  222. Which motor oil are you guys using????
  223. CAI
  224. transmission swap
  225. oil pressure gauge
  226. Injen intake question!
  227. Oil pressure question
  228. Im Ordering Brakes... need help
  229. Paddle shifters kit or sequential manual kit for Scion tC
  230. E.C.U
  231. Headers and exhaust
  232. Q for Doc I's short shifter
  233. Best power gains in headers?
  234. How many clicks til parking brake engages?
  235. Turbo-Mafia.com
  236. DC sport ceramic race headers
  237. Trd LSD 1/4 mile times
  238. CEL returns!!!
  239. WHAT WILL A TC RUN IN THE 1/4 MILE?????
  240. Need Help With O2 Sensor!
  241. tranny problem: grinding 4th and 5th gear.
  242. Polishing My Head!!!
  243. WILL MY CHECK ENGINE LIGHT COME ON???
  244. 2ZZ Tranny Swap into a tC
  245. Question!!!!
  246. Question..
  247. Intake dyno test: Umnitza, Injen short ram and Injen CAI
  248. Whats going on ZPI?
  249. Megan Axelback or Cat back?
  250. ECU Program updates?
