View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. Clutch Pedal falling
  2. nitrous setup reviews
  3. Guys with TRD CAI, please read
  4. JVT racing header
  5. odd engine behavior
  6. Leaking exhaust = rasp?
  7. my 05 RS1 tC is making a whistling engine noise
  8. Question....scraping noise?
  9. question about intake
  10. Plasma Ignition and Chip
  11. SR*S Catback Exhaust
  12. need help with my unichip
  13. alphawerks header question..
  14. Would any of this void my warranty/
  15. Pic Request: Battery Negative Cable?
  16. tC keeps dying when it drives
  17. NRG Weighted Toyota Threaded Shift Knob for $12.07!!
  18. rpm's too high in 5th gear on freeway?
  19. Testing the water...A/T LSD? *UPDATED PG 2*
  20. Injen question.
  21. K20R swap
  22. Help Please
  23. Am I restricting my exhaust airflow?
  24. Best clutch to use with dezod turbo kit?
  25. turbo exhaust question
  26. Highest RPM on N/A tC???
  27. eshaust passing emissions?
  28. Ignition Coil Resistance ?
  29. Pleaseeeeee Help
  30. project long in the making
  31. header and exhaust set up
  32. Good Sounding Automatic Setups
  33. My 2005 tC engine blown - what do i do im desperate
  34. possible solution the fix TC throttle delay
  35. full exhaust system
  36. Why does my BRAKE sign come up sometimes?
  37. clutch
  38. whats a good height reduction on a short throw??
  39. Minor problem...
  40. Anyone have the Cold air from Vertex?
  41. Still got the alaphawerks header noise!!!!
  42. best CEL eliminator
  43. injen exhuast
  44. headers
  45. warranty, ugh
  46. 06 vs 07 intake
  47. Is there a difference between "D" and "3"
  48. my 06 tC needs a little more
  49. headers... question
  50. Iridium plugs....
  51. Other N/A internal tuning vendors?
  52. Who else LOVES their "Stiffy"???
  53. Light Weight Crank pully
  54. anyone in Masachusetts been pulled over for their exhaust?
  55. Black Box
  56. Short Ram Intakes?
  57. Intakes
  58. Power Help
  59. Does anybody have a ZPI S-Pipe & Mid-Pipe & HKS Setu
  60. Air flow ratio controller help needed
  61. Dumb question..?
  62. ARK exhaust
  63. OBX headers and S-pipe
  64. rod knock?
  65. DOES THE 05-06 MEGAN headers fit on the 07?
  66. Resonator Cost and Where to Find?
  67. 2007 5 speed tC dyno!!
  68. Antifouler
  69. short ram or cold air intake???
  70. Tanabe Medallion comment
  71. 08' tc scion catback
  72. Sprint Booster
  73. Really nasty clutch noise
  74. any problems with MMW Headers?
  75. Do I really need it?
  76. NEWS: Tanabe Concept G Exhaust Arriving Early Next Week.
  77. JVT Racing Header *Updated w/ Dyno*
  78. Exhaust help
  79. Any problems with 2007 Injen CAI????
  80. Does anybody can help me with CEL for the header
  81. Greddy evo 2 or sp2 ?
  82. shell gas....not shell gas
  83. MMW HEADER DYNO
  84. Lightened Crank Pulley from Cravenspeed
  85. Camcon Vvti Controller
  86. Type of Coolant for tC?
  87. A Header, Naked, Wrapped, or OEM Heat sheild...?
  88. Spring Bolt connection
  89. TRD exhaust on Craigslist- good deal?
  90. possible new injector from usrt
  91. Which CAI sits lower?
  92. n
  93. high flow cat question...
  94. cam con question
  95. Best intake?
  96. Where to buy 08 tails
  97. just wondering
  98. Your Tc's TOP SPEED?
  99. Agency Power Pulley..Will it Work????
  100. trouble going into reverse
  101. Coolant Level Low
  102. Day after the Drag (weird noise)
  103. Header that fits under cover?
  104. TRD Or Tanabe
  105. Think I have a Problem.
  106. TRD Intake
  107. Exhaust Port diameter?
  108. Megan S-Pipe
  109. will this fit?
  110. Grinding noise....
  111. swaps on a tC??
  112. Pic of stock midpipe
  113. Is this normal?
  114. weird smoke...
  115. 4GR-FSE / Transverse 2JZ
  116. Cheapest website for Injen COA
  117. SR-S Cat back exhaust
  118. Quick question about TRD Axle Back Exhaust
  119. short or long?
  120. meagan racing headers
  121. megan short shifter question
  122. The Breaks Are Rubbing??? Help!!
  123. flywheel
  124. What Kind of Header 2008 Tc
  125. flywheel and clutch
  126. i bought the wrong CAI :(
  127. What Next?
  128. TRDSparks and McGeorgeparts.com Pricing
  129. megan headers and my cel
  130. Injen SES Axleback Pics and Video (no56k)
  131. s-pipe question
  132. Idle issues
  133. question on intakes
  134. mt-90 or reg castrol 75w-90
  135. Exhaust (couldn't find it with search function)
  136. injen cai
  137. ETD and AC help.. ... .
  138. Need Quick ez advice
  139. 08 vs 07 tC
  140. Injen CAI Question
  141. need help, got in trouble with popo
  142. TRD / Quaife LSD install pics
  143. hydrolock? need some help!
  144. shifting from 4th to 5th.
  145. dealing with megan racing is a bust.....
  146. Apexi exhausts
  147. mods questions!
  148. what to do next?????
  149. Base bushing in short shifter
  150. Header = rasp
  151. SRI with new header .... sucking in warmer air?
  152. Plug question
  153. Full Exhaust
  154. S-Pipes....so many to choose from...
  155. DC Headers
  156. New Intake from K&N for the tC
  157. CEL/O2 sensor help
  158. hks hi power exhaust
  159. anyone fall for this
  160. signal wire for 02 sensor
  161. Sound clip anyone?
  162. how to install stock intake..
  163. TRD COLD AIR INTAKE VERSUS WEAPON R SECRET WEAPON
  164. Afetrmarket downpipe
  165. SORRY, FIX TO THE "ANYONE FALL FOR THIS"
  166. 1st gear snap?
  167. Black Smoke
  168. Strup Race Headers
  169. E-BRAKE,CHECKENGINE,TIREPRESSURELIGHTALLON!!HELP!!
  170. What happens when you hit Redline?
  171. Injen intake installation?
  172. NST pulley help ASAP!
  173. Stock flywheel?
  174. A few sounds I never noticed before (clicking accel pedal)
  175. ~ 200hp w/o F/I?
  176. Are these short shifters too good too be true??
  177. TRD Exhuast or Tsudeo N1
  178. Used Clutch?
  179. Do i need a CEL eliminator?? HELP!!
  180. headers
  181. i/h/e
  182. quick question about HKS hi power exhaust
  183. best high compression pistons?
  184. need help with my megan short shifter
  185. 6 speed
  186. is there a CAI eval thread compairing all makes and models
  187. help me decide between borla and magnaflow
  188. Intake install Help
  189. what you think???
  190. making my own intake
  191. how will it sound?
  192. exhaust?
  193. clacking?
  194. Possible engine swaps?
  195. engine rattle and whistle
  196. Cat back or full exhasut help me out
  197. HKS HiPower Exhaust help!
  198. 2006 scion tc ball joint
  199. throttle body spacers...goood or baaad?
  200. Ebay
  201. megan drift spec catback exhaust
  202. Dealership gives me a headache...
  203. Auto Trans Cooler
  204. JUST ORDERED!!! VERY EXCITED
  205. JVT Racing S-Pipe
  206. TC idleing problems?!?!
  207. mid pipe question
  208. nology
  209. Hey have anybody heard of these before?
  210. My problem (Relates to dc sports headers)
  211. HELP. Tanabe Exhaust off Ebay
  212. Tanabe exhaust instilation
  213. f/s - weapon-r intake/agencypower lightweight crank pulley
  214. TRD rad cap
  215. need trd exhaust and injen intake
  216. Scion TC TRD exhaust!
  217. Video - Another one of those "I was bored" threads
  218. Void Warranty
  219. Intake questons and poll(Injen or AEM)
  220. Muffler
  221. Plain and simple answer to?
  222. I've got a quick/cheap/easy way to rememdy CAI vibrations
  223. megan oe-rs
  224. radiator leak poor toyota quality?
  225. MAF Conversion
  226. Buschur Racing Midpipe?
  227. Alright i admit it i cant drive manual
  228. Resonator
  229. inake/heatsoak
  230. Tanabe Concept G angled?
  231. GI: TC AGENCY CRANK PULLEY
  232. Good place to buy Injen CAI
  233. tuning my car
  234. 05/06 intake whistles. 07 doesnt???
  235. short ram air intake
  236. Quiet exhaust
  237. AMSOIL 75W-90 Gear Oil Poll
  238. ARP studs help
  239. headers
  240. ARC vs Injen
  241. ticking noise?
  242. Temperature gauge making weird sound?
  243. exhaust dounut
  244. after installing headers now have ticking noise
  245. Double Clutching?
  246. need help guys dont know what to do
  247. what size are the headbolts?
  248. Finally a TRD CAI that's CARB-approved for the Tc???
  249. Smaller Injen CAI Filter...
  250. Good Powerful Exhaust??
