View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46
  1. Valve Adjustment (WITH VIDEO TO MAKE SURE ITS THE VALVES!!!)
  2. Creative Compacts Short Shifter Questions
  3. Is This Possible? Dumb/Interesting Question
  4. Engine DEAD
  5. Gasket
  6. CEL issues, please help!
  7. Throw Out Bearing
  8. Warning lights come on during cornering / breaking
  9. AEM f/ic NA tune
  10. Problems with mmw/Weapon R header
  11. help me fix this!
  12. Header Question
  13. Injen CAI
  14. I HIT 50K MILES.
  15. Fujita CAI '08
  16. Exedy stage 2 with flywheel feed back
  17. How much does fifth gear cost?
  18. Need an alternative to Redline MT90
  19. rough idle, need help
  20. Alphawerks?
  21. Tanabe sale?
  22. Antifouler question
  23. Need some help poeple!
  24. Dual Exhaust on a tC?
  25. is 800cc to much for 12psi and meth kit
  26. Slight rumble for 1st mile or so
  27. What do you think about this intake
  28. S-Pipe with stock midpipe, and TRD exhaust
  29. Tanabe Concept G Group Buy
  30. GGP Engineering NEW PRODUCT RELEASE
  31. Car must of felt frisky today
  32. Best Short Shifters for the tC?
  33. Agency Power Light Weight Pulleys
  34. k&n cold air intake up on ebay
  35. Hrm. Exhaust Setup.
  36. Megan Drift Spec Catback Questions
  37. maybe a dumb question
  38. Whp
  39. What do you guys think i should get
  40. Injectors on N/A?
  41. Will a Stiffy touqe damper take away some of the backlash ?
  42. Wat do u guys think bout this...
  43. how much is an upstream o2 sensor?
  44. Built Shortblock
  45. CustomtC Short Ram
  46. stock header (exhaust manifold) question
  47. Question about Short Shifter
  48. Christmas gift choice help!!
  49. Transmission.. ****
  50. megan drift spec exhaust
  51. Help!
  52. Hydrolock with Injen CAI?
  53. Questions about all engine things
  54. car idles at 600 RPM?
  55. thinking about getting a mid pipe...
  56. Stock header bolt size
  57. Question about TRD Intake
  58. what make s more power?
  59. Front motor mount
  60. anyone have this exhaust?
  61. another P0420 CEL code question
  62. best cat back exhaust/intake for an 09' tC
  63. HKS Hi-Power AxleBack orrr Skunk 2 Full Cat Back
  64. Help with O gaskets?
  65. installed tsudo headers and em cold air intake 2 nights ago
  66. Trans Swap
  67. Header Help
  68. Fixing A CEL
  69. Throttle Body Failure
  70. Whats Your Fastest N/A Time in the 1/4 Mile
  71. EXHAUST KIT QUESTIONS???
  72. Size of radiator hose to install gauge
  73. reflash ecu?
  74. Twin turbo?
  75. Thermostats
  76. eBay Catback Midpipe
  77. CEL P0606 fault Code
  78. hks hi-power exhaust
  79. Broken Bolt Help :(
  80. engine swap 08 xb 2azfe into 05 tc
  81. hks hi powered with mid?
  82. Which Clutch?
  83. CEL Help
  84. exhaust emissions
  85. How to pass Emissions?
  86. Downshifting on Automatics
  87. I Need More HP.....What Are My Options? Any Help Is Great!!
  88. The customization of an ebay exhaust
  89. Emissions Question
  90. Are there any headers that does not cause CEL?
  91. Burning oil in an 08
  92. what size are stock tc injectors?
  93. Cable bushings question
  94. Does new clutch 'STAGE 5' require aftermarket fluid lines?
  95. Megan Racing Header
  96. tC Hard Cold Start problems..
  97. cel once again......
  98. Dropping tranny to change clutch and flywheel...questions
  99. help installing VTEC.
  100. help with exhaust
  101. p0137 cel code.... need advise please.........
  102. Is there A DIY TRD exhaust on here?
  103. New motor Ecu config???? HELP PLEASE!!!
  104. How Much HP Can The 2azfe Take Stock?
  105. close..
  106. "Official" Wire Tuck Thread.
  107. HKS Racing Suction Intake
  108. 07 midpipe vs 05 midpipe?
  109. P0301(misfire cylinder 1)
  110. What does everyone think of Competition Clutches?
  111. Pulley Belt Tensioner
  112. first time washing my filter/pics of my poorman CAI
  113. Fuel controller
  114. Rough idle....cause?
  115. Cat Converter Question
  116. Just installed new can
  117. Dezod n/a s pipe back exhaust
  118. Booster Pump, Zex inline or Kenne Bell Voltage Boost-a-Pump?
  119. Computer Chip for the tC
  120. UniChip
  121. greddy v-manage
  122. Axle Back vs Catback
  123. Brian crower n/a camshaft
  124. bumper rattle
  125. i want more horsepower on my scion tc. help
  126. Early Christmas to me...Or late. However you look at it
  127. valve cover aluminum type?
  128. serpentine belt or drive belt?
  129. how often should you change Mobil 1?
  130. Colder weather = less friendly shifts :(
  131. What do I need for a tranny swap?
  132. Megan header, Invidia S-Pipe, and Skunk2 exhaust
  133. throttle body q
  134. Install Strup Headers + Invidia S Pipe + Magnaflow Catback
  135. Hey guys!!
  136. rattle when decelerating
  137. Should I?
  138. 130psi in cylinder... is it okay to drive like this?
  139. Megan midpipe + TRD axleback anyone have this?
  140. Best Clutch / Flywheel combo??
  141. Best Headers?
  142. someone lease help me
  143. Borla axle back Question!!
  144. next mod
  145. Please Delete!
  146. Need Help
  147. Greddy Air Diversion Panels
  148. IPT Electro-Matic Manual Controller
  149. LSD for the Scion tC???
  150. Centerforce Clutches!!!
  151. Im looking for a Trd Exhaust or a megan oe-rs axleback,
  152. spark plugs
  153. going with dezod s-pipe back exhaust
  154. doc i cable bushings
  155. ALL MOTOR tC- looking for advice
  156. The COMPREHENSIVE thread on NST (NonStopTuning) Pulleys
  157. idle and driving issues
  158. greddy option connector?
  159. Weapon-R Headers w/ Jet-Hot Coat.
  160. motor is in pieces, the sotry....
  161. Cold air intake??
  162. Deep rumble with Burnt tip.. anyone?
  163. Anybody still have their stock midpipe???????
  164. Need help building a mid pipe?
  165. HOW MUCH TIMING?
  166. ok so im doing a sort of minor"tune up" on my car
  167. clutch adjustments question...?
  168. Pics of new installed 3in Doc I short shifter and TRD knob
  169. Full Complete Scion TC TURBO Engine For Sell
  170. HELP wit my megan setup
  171. Fujita Cai as a SR?
  172. WOTBox owners
  173. HELP PLEASE! Could all this be caused by the mass air flow??
  174. which clutch
  175. stock flywheel
  176. Teach Me
  177. Crankshaft!!!! HELP!!!!!
  178. Braille Lightweight Batteries... info/reviews...
  179. Tanabe Medalion Touring Exhaust for the 2005-2009 Scion TC
  180. clutch break in
  181. Tsudo header is coming BACK!
  182. IPT Trans valve body upgrade install DIY **3/19/09 update**
  183. DC HEADERS = no perfomance difference??
  184. Exhaust setup
  185. Pre Catalyist is bad What are my options? New header?
  186. Got a problem and need some advice from those in the know...
  187. Axle help!
  188. Built motor tc's chime in
  189. Cleaning Header?
  190. Quick Question
  191. hks hi power exhaust, help please
  192. After adding resonator to my setup
  193. Mazzuri 4-2-1 Race Header?
  194. SPARK PLUGS.
  195. PREMIUM FUEL?
  196. FS TC: GReddy tic, figure grill, ebay fogs
  197. Please Delete!
  198. Automatic with mods vs. Manual stock
  199. Help!
  200. Possible Headers
  201. can anyone give me an answer?
  202. PTUNING Time Attack tC in Modified Magazine
  203. DEL with Mass air flow adapter with filter
  204. CEL with Mass air flow adapter with filter
  205. Tsudo N1 Exhaust
  206. TC Intake Manifold Tester..
  207. How loud is your engine?
  208. Replacement header for my 05 scion tC
  209. clutch advice please
  210. Belt Tensioner Problem with NST Pulleys Help?!?!?!?
  211. any interest in a twm stage2 short shift?
  212. Smoother Idle w/ CEL??
  213. Dezod exhaust owners
  214. gear ratios
  215. P0335 (CKP Sensor Malfunction)
  216. wotbox
  217. What kind of spark plugs do you use?
  218. STRUP
  219. What kind of exhaust set up should i get?
  220. Changing differential fluid
  221. Fuel System Cleaners or Injector Cleaners?
  222. intake question
  223. Would it be beneficial to get my car tuned with these mods?
  224. looking to trade my HKS hi powered exhaust...
  225. Ptuning exhaust owners! what do you think?
  226. Supercharger or Turbo?
  227. Motor Pulling/Swapping
  228. Just a real quick question...
  229. Need a little bit of convincing...UPDATE 2/16/09
  230. I've been wondering..
  231. Post up pics of your *NITROUS*
  232. this might be a stupid question
  233. Which S-Pipe
  234. individual throttle bodies?
  235. govenor?
  236. Need exhaust help
  237. which sounds better a larger cone or a smaller cone on a AEM
  238. Question about Tune for N/A
  239. megan catback exhaust question...
  240. Heat Shield Temperature?
  241. Oxygen Sensor Wiring Help
  242. Cold Air Intake CAI Panel??? Would You Recommend Buying One
  243. Motor swap question
  244. hks hi power axleback
  245. stock intake pipe
  246. Best Brand of OIL?
  247. DYNO RESULTS WR INTAKE MANIFOLD FOR TC.
  248. valve train knock at idle
  249. Motor Pull HELP PLEASE
  250. Ok guys
