- TRD exhaust. Relabled Borla?????
- Fujita CAI or Weapon R Short Ram?
- CEL with Fujita CAI
- oh so, RICE.
- Everyone with Magnaflow Resonator - leak problem!
- Exhaust Rattling Question
- Low/rough/knocking idle
- My oil pressure need feedback
- Just received my poly motor mount bushings :)
- Does anyone have this set up?
- 1-step colder plugs
- tsudo n1 Exhaust
- Header?? Yes or No??
- ** EDIT **
- Intake??
- Anyone seen tc with side exhaust ?
- power hour!
- Intake manifold vacuum line Question
- how to clean a dry filter?
- s pipe or mid pipe?
- HKS,Megan,Tsudo.. I need some input. *UPDATE* pics
- need help with some bearings
- intake + exhaust
- How to take off the stock exhaust?
- TRD CAI
- Weird Engine Noise
- Mistery Rattle.........
- catalytic converter
- Car dies after supercharger removal
- scion parts fit 09 vibe ?
- Nitrous
- Weapon r intake manifold problems
- Gude Head package
- exhaust combo
- Transmission grinding...
- APEXI WS2
- Can You Run A Fujita Intake As Short-ram
- Manual Trans
- Putting cams in help please
- DME Axelback?!?
- S pipe?
- Nitrous express fly by the wire
- Exhaust system Question
- random rasp out of no where
- Replacing throwout bearring
- All Motor 200 WHP
- CALI LEGAL HEADERS?
- looking for a full exhaust with cats
- N/A Fic Tune
- Intake & Exhaust ??
- CF exhaust heatshield
- Header Question
- Header Question
- A/F Ratio 15.9 .... HELP!
- Performance Chips?
- help with exhaust
- hard start, spark knock?
- Is there a difference between cams???
- gearing for 5-speed tc's to save gas
- o2 sim questions
- Short Ram Intake or CAI for the tc
- Where to get Gaskets for s-pipe?????????????????????
- Tsudo N1 Exhaust
- mass air flow sensor screw
- looking for opinions
- CEL issue after intake installation
- Official DIY for Energy Suspenion Motor mount install
- Will an aftermarket S pipe bolt onto the stock mid pipe?
- Trading the scion in need some advice
- installing e-manage
- thee Anti Fouler, does it work??
- I'm set on exhaust
- Royal Purple Gear oil
- Anyone Using A Blitz Throttle Controller?
- Throttle Problems
- FYI underdrive pulleys
- air cond.
- replacing clutch
- someone please explain air/fuel ratios to me
- AEM F/IC stock map file
- Official: Engine Bay/Cover Picture Thread
- What do you gies think about this Performace Chip
- fujita cold air intake
- rough idle
- WEAON R HEADERS questing
- jimmy's tc N/A 181whp - 167wtq Dyno inside (update)
- removing the thermostat
- Zpi S-pipe question
- Header?
- Throttle Body Problem
- Flat radiator hose??
- 07-08 MAF Interchangable with 05-06 MAF?
- custom TRD short shift
- installing megan midpipe
- Building A Junkyard Engine?
- tC MAF & Other sensor questions or issues
- TRD Exhaust Hanger Question?
- 2azfe engine internal ?s
- HKS hi power, tsudo mid, am I pushing it *FL Law*
- Megan Racing OE-RS vs. Drift Spec
- my car is leaking oil
- MOTOR!!!
- 80w90 for differential
- P0420
- megan mid pipe recall?
- HKS HI-Power vs Megan Drift Spec
- Anyone ever use seafoam?
- This might be a serious problem for my tC..please help!!!
- help. potential engine problems
- question exhaust and power...?
- Whats best to get rid of rasp?
- *please lock*
- which way does the enigine come out
- Regular Gas is Recommended. Use it!
- BUDDY CLUB E-THROTTLE BOOSTER
- Throttle body spacer
- Greddy Spectrum Elite SE Exhaust
- Horrible noise coming from under the car :/
- How is it??
- Engine Performance\Build Part Summary
- best spark plugs for the tc
- My New Toy :-)
- tc owners with the megans drift spec exhasut
- what do you think?
- what exhaust do i want thats cheap read why----
- 500+WHP tC, what it took, lots of *PICS*
- throtle body spacer???
- most worthless part people buy for our car, wat do u think?
- the most horespower?
- Power Steering Reroute?
- magnaflow exhaust?
- I need a PULLEY!!!
- Donut gasket from header -> s pipe
- Megan S-Pipe and Mid-Pipe owners!?
- Exedy Clutch Kit and F1 Racing Flywheel
- resonator
- My New Toy.....Installed :-)
- timing!!!
- possible to restore the header??
- Stick Feels loose
- Header question
- how to clean your throttle body
- Megan Racing Short Shifter
- 181whp n/a TC VIDEOS
- does anybody have the apexi WS2 exhaust?
- Looking for imputs on motor swap idea and Thats all!!!
- Need Help 02 sensor replacement
- looking to boost 2009 TC
- Just got car back from replacing clutch... help
- Thinking of going full exhaust, What pipes for injen ses?
- Wierd Tranny issue... should i bring my car in? plz help
- clutch and flywheel issues
- Looking to Buy the megans Drift spec catback
- Motor tick!!!! AWWWHHHH HELP PLEASE
- where can I find this??
- Motor mount bolts? help
- Machining Stock Shifter Into Short Throw
- Header, Intake, Nitrous
- Six Speed Transmission
- CLUTCH BLEW! PIC UPDATE PG5!
- Battery relocation
- Secret Weapon R intake Carb legal?
- Shift light install
- Header Wrap
- Refabricate Factory Heat Shield with Aftermarket Header?
- Ive seen this on a few engines and was wondering what it was
- bee r rev limiter
- Does anybody else
- engine swap ?
- pulley? cut groves in Tensor?
- quick question
- Fogs killed my car
- just a little question about my exhaust
- No Powersteering Help
- Fuel injectors
- warrenty question??
- Quietly tuned car?
- i have axle questions help
- Do I have a bad maf
- Is Megans Catback(drift spec) backordered
- Question about 9lb. flywheel VS. 12lb.
- Clutch Delay Valve
- biggest slim line fans on stock radiator?
- how much power loss? ill be driving with lower compression
- Cabin noise
- taking out silencer from the megans catback
- engine/piston bore
- which exhaust to get???
- my rear rotors are looking lil funny
- 2AZ-FXE
- brakes loud as all hell
- How can I get a deep tone on Idle!
- Finally!!! Apexi world sport 2 exhaust pics/videoclip
- Short Ram intake ?
- always count your tools when you finish your engine work
- Speedo ABS BRAKE LIGHT LOW TIRE LIGHT HELLPP!!!
- Gauges w nitrous
- A little stuck on installing TRD CAI
- Coolant Flush/Change and Power Steering Change
- How are the Brian Cower N/A Cams!
- no axelback!
- ECU
- question with headers/intake
- what do you think about this N/A setup?
- need sum opinions in strup header + strup exhaust setup!!
- 35 shot Jet size for nitrous
- Gotta problem...
- Car Troubles while deployed HELP!!!!!!!
- Oil leak? Oil light Help.... Anti freeze? not fuild OUCH!!!
- dezod N/A s-pipe exhaust with aftermarket (strup) header???
- Going from A/T to M/T
- Engine swap advice, and a eulogy
- ptuning 3 inch exhaust!
- Type of oil/leak
- This may be a stupid question!!!
- any suggestions for headers?!
- A/C Compressor oil
- magnet???
- For any thats interested in an Apexi WS2 Axleback. Here u Go
- Fujuita
- BENT VALVES WTF. / engine clicking
- valve and lifters!!!
- Having the engine run without a heatshield
- Scion extreme turbo kit
- Polished OEM Exhaust Manifold with pics.
- trd cai warranty
- B&M Short Shifter
- DC sport headers?!?
- Unknown Motor noise
- Head bolts
- 5w20 vs 10w30
- problems with my auto shifter
- Problem with knocking sound???
- The best exhaust going with Dc Headers and Injen CAI
- Wire harness
- Anyone keep there recepit for there TRD exhaust?
- i have dc headers and my thread broke for O2 sensor pls help
- how many cats does out tc's have
- Drivetrain Swap Ideas
- looking for exhaust opinions
- polished my valve cover!
- tC exhaust from header to muffler what do I need
- Will a 08 spipe fit a 07?
- hks axleback w/ megan mid? anyone?
- intake vacuum hoses
- trd exhaust
- Help with leaking from passenger side axle
- Getting The TRD Exhaust Soon....
