View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46
  1. A Long Time Ago...
  2. no a/c
  3. Will TRD CAI pass inspection in nj?
  4. Injen CAI with what exhaust system?
  5. Quick Seaform Question
  6. CEL after throttle body cleanining. Help
  7. quick question about 2azfe block
  8. Mass Air Flow Sensor
  9. tsudo midpipe and injen ses axleback?
  10. ECU
  11. Keep getting the bad ECM code P0606
  12. engine stutter
  13. Oil Draining Fast But No Leaks Anywhere????
  14. Low idle and near stall when stopping
  15. Car won't go over 20 and stalls when rpms are high update code P0103
  16. Clutch and Flywheel Replacement Brands, Ratings, Reviews?
  17. transmission warranty question
  18. Timing question
  19. Samco mm ?
  20. Part number request
  21. sand paper?
  22. Best Ways to Gain HP
  23. Tranny Swaps Questions
  24. Weird Ish Going on with my fan
  25. How much WHP do i have?
  26. new poster
  27. Tsudo N1 exhaust, hanging low?
  28. New weapon R Neo Titanium Treatment 07-09 Scion TC intake
  29. We now Stock eapon R Neo Intake Manifold 2005-09 SCION TC
  30. small issue
  31. New Injen Intake w/ Exhaust Video
  32. How to Increase WHP?
  33. N/A tC and power parts/tuning
  34. F5 Fujita cold air intake 06 tc
  35. motor oil
  36. Denso Iridium Power Plugs
  37. Intake pipe in fender lining help!
  38. A/C delete
  39. Weapon-R or Injen SRI?
  40. new Idea
  41. Nitrous vs. Turbo vs. Supercharger + My Situation
  42. Anyone ever remove this fuel line?
  43. HELP! Rusted Bolt stripped!!!
  44. tc valve lifters
  45. exhaust question?
  46. Stock Intake
  47. Need help... O2 sensor part #
  48. nitrous and sparkplugs?
  49. Brand New 2AZFE....Anyone know where to get one??
  50. Motor work quick question
  51. trans cooler for auto question
  52. Wilwood BBK Install
  53. P-Tuning clutch RAFFLE 5.00 TICKET
  54. Throw-out Bearing?
  55. intake question
  56. Upgrading the brakes . . .
  57. Quicker vs. Faster
  58. header gasket...need fast help!
  59. What To Do? (exhaust question)
  60. HELP! Car turns off.. :(
  61. alternator died
  62. Starts Rough w/ noises.
  63. cars acting funny
  64. Help! Airbag light came on-horn and cruise control will NOT work!!
  65. Jet V-Force
  66. Control Cable Replacement
  67. I have had enough with this Clutch!!!!
  68. Success or Failll!?
  69. Stock Muffler Question.
  70. tc fuel pressure
  71. POS CC stage 4 and 9.5lb flywheel
  72. Installing magnaflow exhaust, instead of cutting behind the cat, get an s pipe?
  73. Known cures for throttle delay?
  74. question on exhaust install....?
  75. megan mid & trd axleback... will they match up?
  76. Aesthetic engine mods
  77. Horsepower ratings for TRD intake and exhaust?
  78. Exhaust uninstall fail...
  79. Identify the Exhaust!
  80. Concept G vs TRD exhaust
  81. Weapon r intake selling on eBay? Should I go for it?
  82. Header doughnut Gasket Won't come off
  83. Mishimoto Radiator problem
  84. Dezod Motorsports N/A Stainless Steel S-Pipe-Back Exhaust System
  85. Looking for Flexible couplings? Where to Buy?
  86. Question about warranty
  87. Please Help, Need Conformation
  88. Cleaner for Injen Intake filter
  89. Header cover won't come off
  90. Looking For a Intake
  91. 2010 Scion TC with Injen Intake and Exhaust
  92. Will An 05 Oil Pan Fit On An 07??
  93. Intake mount stuck!
  94. Whistling sound with slight acceleration
  95. Adjusting clutch engagement point
  96. E:85
  97. Clutch Replacement Link, Please!
  98. cleaning my filter
  99. less power? vacuum leak? please give info
  100. WeaponR Race Header
  101. Is this an 05-06, or 07+ intake?
  102. Header rattle not rasp. Help.
  103. Cant Engage Gears in 5speed
  104. how i got rid of my rasp...
  105. 06' TRD Shifter on 08'?
  106. Custom midpipe question?
  107. Parking brake light is stuck on
  108. little startup issue
  109. unichip at trdsparks?
  110. Comp Clutch: SECOND TIME BREAKING IN UNDER 1 YEAR AND 1 MONTH!
  111. Anyone use Royal Purple?
  112. ARC Intake Owner w/ Strut Bar Question
  113. TC highest REV
  114. CC stage 5 clutch
  115. Broken Motor Mounts?
  116. DESCENDANT Fuel Rail & pnp RC Injectors
  117. megan S pipe
  118. Throttle Body Cleaning
  119. Is it worth changing my TRD exhaust?
  120. n00b has engine problems
  121. UPDATE:In need of some help..badly...again.
  122. help with major problem
  123. Help with my header problem
  124. HKS "Brita" Knockoff
  125. stock exhaust.
  126. auto to manual qestion in need of anserew ASAP!
  127. Help Me decide...
  128. Improve 0-60 stock TC
  129. Crankshaft issue...help please
  130. Any recommendation for custom shortblock/fullblock
  131. Need Confirmation about this weapon r intake in ebay.
  132. exhaust help
  133. Avoiding "spirited" driving consequences
  134. clutch issues...squeaks and whines... need some diagnosis help
  135. bomz intake on ebay/ questions
  136. Co2/No2 Intected Throttle Body? Coolant Lines?
  137. skunk2 w/ Tsudo?
  138. Clutch Help!
  139. my car doesn't start - no response at all
  140. scion tc fujita intake install ?
  141. oil and filter
  142. Modified N/A Scion Tc video – loads of bolts on check it out
  143. question about CAI !
  144. AEM fuel/ignition controller and 2009 tC?
  145. NSS on a auto trans??
  146. spark plugs????????
  147. Need real pic of engine
  148. 2007-2008 tc engine on a 2005-2006 questions
  149. Clogged Cat or NO?
  150. header help
  151. Which shifter bushings?
  152. Finally got an Injen CAI/SR intake!
  153. intakes
  154. K&N Filter Cleaning Kit, Will it work on a Injen CAI Filter?
  155. ebay oil catch can?
  156. Stealership not wanting to cover tranny Problem!
  157. energy suspension motor mounts
  158. tC throttlebody info/comparison
  159. no axleback?
  160. spark plug replacement
  161. Scangauge A/F Ratio Code
  162. ZPI or NTS pulley?!?!?
  163. sputtering problems
  164. megan oers colbalt?
  165. Megan drift spec exhaust question?
  166. 2AZFE - Boring
  167. TRD exhaust cut question
  168. converting CAI to SRI
  169. Engine dies when cooling fan turns on at idle
  170. Check Engine Light!! Please Help!!
  171. Radiator for Auto and Manual? WHAT?
  172. Having Clutch Issues, Need help Diagnosing/Pin Pointing Problem. PLZ HELP ME!
  173. Engine Noise ?
  174. More Power!!
  175. Axle Clunking....FML
  176. What do you guys think
  177. ptuning + header/spipe?
  178. funny noise
  179. CEL?
  180. Amsoil EA dry filter size
  181. Best option to keep me dry...?
  182. transmissoin acts wierd sometimes
  183. Injen Filter
  184. Need help with some things!!
  185. transmission oil ???
  186. Redline MT90 vs Royal Purple Synchromax
  187. Drilled a hole in muffler,LOTS OF WATER !
  188. Vibration around 3k RPM.
  189. Unichip Q Software
  190. Custom 3" Exhaust
  191. weird exhaust setup
  192. Sucking in cold air
  193. tsudo n1 erz...
  194. Exhaust question???
  195. Exaust width
  196. Bad gas mileage.. aahhhh! Anyone else??
  197. which spark plug??? NGK laser? or ngk IX?
  198. DC header, tsudo N1 axleback, and the boy who fell in love with his tC again
  199. tranny noise 5th gear only
  200. e-brake light under harder acceleration
  201. Car jerks after i let of the gas
  202. how to make tc faster when cant afford boost :(
  203. Will a cold air intake give my tC the extra kick to win...check out the vid
  204. Oxygen Sensor Help
  205. Calling All High Powered Autos
  206. TRD exhaust or Borla ?
  207. Sweet
  208. Cold climate tranny fluid?
  209. tc hard start
  210. 2008 Transmission Problems
  211. Programmer; Tuner
  212. Stock exhaust pipe size
  213. air box question
  214. Installing NOS SNIPER WET KIT (10 NITROUS QUESTIONS)
  215. Rough idle, tach at almost zero even when smooth
  216. Help! Car running slow
  217. short shifter size
  218. Alternator, starter, or battery?
  219. weapon R filter help plz
  220. Advice From The Pros!
  221. Whining from clutch (not squeaking)
  222. question about short shifter
  223. Exhaust leakage
  224. Weapon R Vs. Injen
  225. Tranny Fluid for a Manual
  226. Tenzo CAI
  227. replace synchros
  228. Motor Mount Replacment? How?
  229. Custom Midpipe
  230. big exhaust problem
  231. Competiton clutch flywheel?
  232. Where to buy MAF adapter
  233. fic problem?turbo guys help!!!
  234. Calling all engine guys! Help engine run smooth. Cel!
  235. More speed?
  236. CAI P0101 CEL fixed...
  237. ** EDIT **
  238. Axxtion STS's - OR too many brands Already??
  239. Problem with my clutch....
  240. Weird squeaking sound during cold start?
  241. Which one would you prefer?
  242. ok i give up
  243. stock clutch limit
  244. HELP!! Tsudo Header/ Spipe install!?
  245. Clutch Squeal. (Not the Pedal Squeak)
  246. Tsudo?
  247. What silicone hose brand for tc radiator would you pick ?turbo or stock
  248. UNICHIP Q
  249. Scion TC oil change
  250. Stick with MT-90 or try Mobil 1 gear oil?
