View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48
  1. Megan M Spec 2 Muffler
  2. Changing Automatic tC Tranny Fluid! DIY!!
  3. re-installing METAL valve cover...
  4. Where did you buy your exhaust system.?
  5. F1 racing clutch
  6. Need help asap with CEL code P0172
  7. HELP slow acceleration under 4k rpm
  8. cobalt owner wants some #'s for full bolt on tc's
  9. TRD CAI self-install & warranty
  10. PO101 code, help
  11. stock header or after market header?
  12. My nitrous setup. UPDATED WITH TIMES
  13. So just installed a Megan Racing OE-RS axleback
  14. Second Generation tC 2.7Liter? :/
  15. CEL help please!
  16. OBX Super Coil Pack
  17. Factory keyless entry issue any ideas?
  18. Removing the exhaust manifold heat shield?
  19. performance
  20. Serpentine belt tensioner and Powertrain warranty
  21. trd filter
  22. exhaust help
  23. Stuck in the middle of an engine swap, need bolt torque specs.
  24. Injen Vibra mounts
  25. Weld on Muffler?
  26. check engine light after rain?
  27. exhaust mix and match!
  28. RPM on stock head question.
  29. Midpipe Time
  30. Why is website so cheap?
  31. exhaust/boost question
  32. How many of you SL members have the
  33. Unbiased Unichip Review
  34. Midpipes w/ TRD exhaust
  35. piggyback question. need help
  36. Trd intake ????
  37. I got Knock!!!
  38. Catback under car pics? Looking to install a tsudo n1
  39. Question about axleback exhaust
  40. Borla vs Magnaflow exhaust
  41. Rear wheel bearing out at 63,000 miles
  42. NEED HELP.....
  43. Cold air intake cause Check Engine Light
  44. Megan drift spec or tsudo????
  45. Cant Decide Help!!
  46. need some help with thermostat
  47. idea i came up with
  48. Hey Experts
  49. Monster Motorworks Header Problem
  50. Ark Exhaust
  51. wana get nos. but why does nos have a bad image?
  52. Cylinder Head
  53. CEL Came on
  54. Custom Nitrous kits.
  55. Anyone with 5spdl flush/fill their tranny fluid lately?
  56. 55 mph + night + racoon = cracked bumper and dented radiator
  57. Faint buzzing sound coming from the engine bay
  58. Tc sticks in first
  59. RASPPPPZZZ
  60. Manual Swap wiring harness question
  61. 2nd & 3rd gear gone
  62. Cai qquestion
  63. fuel injector help
  64. Bling Bling
  65. do you need to stick your head under car to install axleback/exhaust?
  66. How many of You SL member have
  67. Best Manual Transmissino Fluid.
  68. zmax?????
  69. hks hi power installation question
  70. Greddy Emanage Ultimate Help
  71. Greddy Emanage Ultimate Help
  72. best sounding axelback?
  73. Tsudo catback install Pics inside
  74. Midpipe question
  75. final exhaust thread!
  76. CAI or Short Throw Shifter????
  77. Clutch Dying at 45K...?
  78. help install alternator pulley
  79. tanabe
  80. New TC Owner, looking for some pointers
  81. Maintenance Light only for oil?
  82. Raceland EXHAUST?
  83. Axxtion STS SoCal Test Fit for FREE
  84. Brown smoke Pop
  85. Black smoke
  86. Maintaince Question?
  87. ECU piggy back and tune for N/A?
  88. Car Pulsing
  89. Installing/removal exhausts
  90. Transmission Problem, Car won't go into gear, What's the problem?
  91. Just won 400 bucks what should I buy :/
  92. Megan Short Shifter
  93. Please Help Me!?!?!?!?
  94. Exhaust rattle
  95. Good Deal?
  96. "Raceland" brand & Dr. I Cable Bushing questions
  97. Any good website to buy the TRD cold air intake?
  98. Motor Mounts and Motor Mount Inserts?
  99. Scion Tc manual trans
  100. trd axelback
  101. please help me with hks
  102. Alphawerk Header
  103. replacing battery cables?
  104. Tsudo/MMW Header Install
  105. Turbo or N/A
  106. TWM Stage 2 Qustion... INFO NEEDED!!!
  107. Broken Engine Cover Stud
  108. What belt size to use for running no AC
  109. Silly muffler shop
  110. Review: Axxtion underhood short shifter
  111. help! remove ecu
  112. Breaking in period.
  113. Timing Marks - Bolting Head to Block Cams Sprocket - How To
  114. what to get to accompany my trd muffler?
  115. is my tool good enough
  116. Clutch Replacement Charges
  117. Exhaust for Automatic tC
  118. DIY Clutch
  119. Fuel injector clip install?
  120. parking brake adjustment
  121. MAF sensor issues w/ CAI
  122. 05 K&N for 07 tC?
  123. rising shift point
  124. NA Dyno : 186.5 whp/ 190 tq...
  125. TRD question
  126. Short / warm air induction
  127. Belt tensioner shock, is this how it goes?
  128. port matching (gasket match) your intake manifold
  129. Underhood noise
  130. ARK PERFORMANCE INC: NEW REDESIGNED SCION tC FULL CATBACK SYSTEM.
  131. need some advice.
  132. Wheel bearings going out?
  133. Header + High flow cat
  134. INNOVATE LC-1 wideband pics added
  135. Greddy SE vs TRD which one
  136. Serpentine Belt Keeps Splitting
  137. question regarding fujita intake
  138. New Clutch & Flywheel Question. (Oem Clutch and Fidanza 9.5lb Flywheel) Guru's Needed
  139. Possible clutch fail? Need help please *Update* 12/18/08 *pics*
  140. DC Sports Axelback
  141. Tsudo Headers & Exhaust System
  142. new exhaust and header ideas
  143. Could use a little help....
  144. New clutch decisions?
  145. wideband bung location with supercharger?
  146. tsudo catback sound on cold start.
  147. List of Parts for Proper Installation (Whole Exhaust Setup)
  148. apexi afcII
  149. Cel p0101
  150. ***UPDATE***vac/gas leak???
  151. oil pan question
  152. ACT clutch disc question
  153. Damn, so close...
  154. What AEM Dryflow Filter Fits 05-06 Injen CAI??
  155. Help!
  156. s-pipe question
  157. transmission fluid and clutch recommendations
  158. alignment tool
  159. Rpm to Mph difference/issue
  160. Just so you know
  161. Anyone have this issue??
  162. Cannot Shift Automatic Transmission Selector Lever Issues
  163. SRI filter cleaning - what kit?
  164. uhh...what?
  165. M2 Headers
  166. Question for you guys
  167. Exhaust Leak that I CAN'T GET RID OF!!! (PICS ADDED FINALLY.....)
  168. Free stuff........Sweeeet!
  169. clutch master cylinder
  170. Clutch Plate
  171. need opinion on exhaust
  172. Need Help Deciding.
  173. Auto transmission issue
  174. Resonators-Suggestions/Help!
  175. manual trans noise
  176. TRD Exhaust fitment issue with Tsudo midpipe
  177. tc randomly doesnt start
  178. Official Raceland Intake/Exhaust
  179. Mixed opinions about changing ATF
  180. TRD performance clutch, short shifter
  181. TC Motor Mounts
  182. 2006 tC maybe bad gas?
  183. Alright Guys Im Swapping My Auto To A 5-Speed HELP
  184. Clutch and flywheel hate the cold.
  185. Megan Drift Spec
  186. side exhaust yes or no
  187. Since I'm Swapping My Tranny Should I Upgrade?
  188. help, stripped a header bolt
  189. Fujita Cold Air Intake Problem
  190. Safe Rev limit on stock bottom end?
  191. fujita for 06 tc
  192. Phenolic intake manifold spacer
  193. Are there catback exhausts for 09 tc's?
  194. obx helical lsd
  195. What short ram intake i should get for my 08 tc?
  196. Fujita cold air intake for sale!
  197. Precision Muffler Axelback
  198. Help!! Stripped Head Bolts 2.4 2AZFE engine
  199. Do anyone have the HPS short ram intake??
  200. losing 1qt every 3k oil change
  201. which has a better sound? injen or weapon R
  202. Ingalls "stiffy" ETD trouble
  203. Spark plugs
  204. I need a new clutch on a low budget
  205. polishing ceramic header
  206. Raceland intakes
  207. Coil-on-Plug failures
  208. Why dont we have aftermarket degreeable exhaust cam sprockets?
  209. Turbo Or 5-Speed
  210. ex-turbo engine idle problem
  211. Greddy Spectrum Elite
  212. Pulleys!!!!!!!
  213. 2006 TC w/41k miles, engine started fairly loud rattle at idle and the oil is ok
  214. HELP - Car Slips on Hill
  215. motor/tranny mount question
  216. header install
  217. Intake Question
  218. general warranty question
  219. Shifting Problems
  220. exhaust
  221. Injen CAI, TRD Axle-back setup
  222. New alternator and car revs up/down at idle
  223. Engine rebuild master kit with pistons?
  224. Intake Mount
  225. Drop in Filter
  226. 08 Manual tC - Jolty/Rough Shifting
  227. How come no one mentions Takeda Cai/Sri intake or Hps cai/sri intakes?
  228. TC radiator DIVERSION PLATE
  229. Phoenix Rainstorm possibly a factor? Help!
  230. 05-07 TRD Exhaust fit on 08+ ???
  231. in need of a primary o2 sensor but need help
  232. Pulley Question
  233. Power Steering Delete/Removal/Tuck
  234. weird noise need some advice
  235. this sinner, went to church
  236. P0606 after heavy rain (CEL) but car runs fine
  237. Sorry Guys
  238. 2007 AT Scion tc 90k miles...
  239. Idle is different...
  240. My new CARB Legal INtake..yay!
  241. Buying a new exhaust..don't want any rasp?
  242. Major gas mileage drop
  243. Custom Exhaust Setup Question
  244. Raceland Intake
  245. Redline Water Wetter?
  246. trd supercharger on a 07 camry
  247. Down Pipes/S-Pipes
  248. Uni-Chip and Decendant Intake Manifold
  249. 08 transmission in 05 tc
  250. CEL Help
