View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46
  1. PTUNING Billet Aluminum Vacuum Manifold
  2. What transmission should i get? I need help.
  3. Came across this on ebay and was surprised
  4. SUN Hyper Voltage Stabilizer Pocket (Hot Inazma Pocket)
  5. Vibrant catback??????
  6. Is this legit???? 50hp?
  7. do you own a NST ud pulley?.... please read
  8. What exhaust is this
  9. people who have shipped stock exhaust
  10. My insides hurt...
  11. Sticky Gas Pedal???
  12. V6 tC anybody?
  13. Raceland exhaustt
  14. shifting problem?? ( new to drive manual car )
  15. 2AZFE Fuel Rail //Dezod Motorsports//
  16. weapon-r headers?
  17. New Clutch problems
  18. *EDIT*
  19. Injectors
  20. O2 Sensor Issues
  21. JDM exhuast
  22. Looking For Advice
  23. power shifting .
  24. grinding into 4th
  25. cluth squeak after painting the calipers
  26. high compression pistons
  27. I'm addicted to rasp and don't care
  28. Steering Shaft!!
  29. Additives throw CEL?
  30. clutch pedal very heavy
  31. exhaust question
  32. AEM Electronically Tuned Cold Air Induction System
  33. What clutch kit for scion going on Turbo .
  34. pulley issue
  35. diagnostic reading (p0420)
  36. Need Horsepower
  37. header install problem
  38. Scion tC DESCENDANT Velocity Plenum?
  39. Aisin Seiki Co., Ltd.
  40. Query about adjusting TRD short-shifter for smoother shifts?
  41. ATF fluid leak!
  42. Clutch Replacement 2006 TC
  43. Mandrel Bend exhaust
  44. Twin discs clutches
  45. can i put a 09 manifold on my 05?
  46. lOOKING FOR A 3IN EXHAUST
  47. ABS Delete/Relocate How To:
  48. is this real TRD cai ???
  49. tC pops out of 5th gear while driving any ideas cause im gonna burn this car LOL
  50. Passenger Side Motor mount question EZ
  51. redline MT-90?
  52. Fujita Cold Air intake can be converted into a short ram?
  53. Bad Clutch Problem-HELP
  54. looking for exhaust
  55. trouble with CAI and being lowered
  56. spipe=deeper sound?
  57. Header emissions question?
  58. Need help CAI throws CEL
  59. Hydraulic chain tensioner
  60. Cost for a resonator and installation on mid-pipe on tC
  61. Battery Install. Now CEL, Car Stalls and Won't Give Gas? Help
  62. need a new clutch
  63. 5spd to auto swap?
  64. Cheap OBDII Scanner on Amazon Right Now
  65. Dyno Results
  66. Scion tC lower motor mount
  67. Whats needed for an 05 scion to upgrade to 09 motor...
  68. Tell me what you think
  69. need this n e ideas
  70. Proper ATF level?
  71. Re-using oem throw out bearing?
  72. **Need help for some research, fighting a ticket.
  73. ?Raceland CAI = Check Engine?
  74. Weapon r spipe + stock manifold?
  75. OEM exhaust manifold question
  76. Hawk HPS rear pads!!!!!
  77. valve cover bolts
  78. Need help
  79. Anyone have Tsudo headers AND N1 exhaust? Sound clips?
  80. AFE stage 2 intake review
  81. idle adjustment
  82. Good Valvetrain
  83. Raceland Header? Plus other related Q's
  84. cruise control not working?
  85. Possible drive train problem?
  86. Missing Threads? ▲▲ LOOK UP! ▲▲
  87. Changing Spark Plugs Fail Question.
  88. Exhaust ??
  89. clutch review
  90. Scion TC 'Chilton' Manual
  91. Raceland tC exhaust
  92. My 2006 tC died a mile away from my house, what could be wrong?(Throttle body broken)
  93. Engine Dress Up: Vac hoses
  94. Speed sensor?
  95. Help needed on clutch install
  96. Safe to switch between maps using unichip?
  97. Any thoughts on this?
  98. Exhaust, s-pipe?
  99. ARK V.2 TC Short Shifter Review *pics*
  100. Belt Size....(searched)
  101. Buying power steering fluid
  102. weird sounds after installing header and catback
  103. 75000 Miles Spark Plug Installation Questions
  104. sub install gone horribly wrong lol please help!
  105. 2007 MT totally gone
  106. Removing Valve Body
  107. need help finding a copper manfold gasket
  108. My car is bogging after cleaning battery terminals.
  109. Just a few questions???
  110. 83k miles on an '07
  111. Questions for those of you with INJEN SRI
  112. car shaking
  113. ScanGauge II Intake Air Temp
  114. TRD Exhaust Install Instructions 07 tC
  115. megans racing exhaust question
  116. Need advise on ecu upgrade for NA and future turbo set up
  117. please help!!!!windows wont work after installin cai
  118. Are gear oil and transmission fluid referring to the same thing?
  119. midpipe shaking hitting bottom of car
  120. OBDII OBD2 EVAP Monitor Readiness CEL for inspection
  121. TCPETE AIMS FOR 210whp NA... dyno tomorow!
  122. anyone experience p0011 trouble code??need help!!!
  123. midpipe hitting bottom of car
  124. URGENT...Will i pass the Smog check
  125. DC HEADERS ON A 2010 TC
  126. What is a good or the best exhaust for tc none turbo
  127. zpi head
  128. Help identify this header
  129. I need someone's help!
  130. Inconsistent Powerband
  131. Wonder how Megan Racing oe-rs Axleback Exhaust SOUND?
  132. Spipe/downpipe question.
  133. MAF sensor. what exactly are we supposed to be cleaning?
  134. Throttle Position & Scangauge
  135. Gasket help
  136. Has anybody done an 06-07+ engine swap?
  137. Exhaust Question????
  138. spec clutches
  139. Anyone actually have / had the eBay exhaust?
  140. how i got 400 whp
  141. electrical-water problems
  142. what's wrong??? :(
  143. Home Depot tC pulling a p2195, power cutting... Help!
  144. My Magnaflow Exhaust Story
  145. Transmission or Axel Boot??
  146. Megan Race Header Question TC
  147. Smog test with injen sri(CA)
  148. Where to buy Tsudo N1 Axleback from?
  149. Mid-Pipe
  150. HKS hi power exhaust on rs 4.0
  151. Does anyone know....
  152. pics of strup axle back?
  153. Thermostat Temperature Problems
  154. Seafoam and TC with supercharger ???
  155. Weapon R Header rattle noise? (not Rasp)
  156. leaking water pump at 18,500?
  157. PowerCard
  158. tC's: SRI w/ AEM filter size issues
  159. AEM Intake Install!!
  160. 07 redline problem
  161. Looking for suggestions!
  162. Save hundreds on dezod S1 turbo kit!
  163. Fuel pump wiring
  164. Clutch Problems
  165. Exhaust tip choice
  166. Bent rod????
  167. CF heat shield for the exhaust on a TC.
  168. 170k miles on a clutch....
  169. Megan Header/Drift Spec, looking for good resonator.
  170. 550cc Drop in Idle???
  171. Steering wheel clicking?
  172. Threw a CEL...
  173. Clutch Recommendations
  174. turbo mafia exhaust
  175. 750cc injectors
  176. Next step anyone?
  177. ** EDIT **
  178. Alternator installation
  179. transmission help!!
  180. best short ram brands injen or that fuji joint
  181. BEST Price on Weapon R Secret Weapon SRI
  182. new clutch click
  183. upgraded cams
  184. TRD vs. Aftermarket shortshifter
  185. Recommendation for new mod
  186. How can i bleed and change clutch line
  187. 2011 tC 6 speed Tranny Swap Discussion
  188. new tc
  189. Dual exhaust???
  190. coolant
  191. SPYDER Cold Air Intake
  192. 2ZZ-GE
  193. Poping noise when i take off (Problem solved)
  194. Need some feedback. (Turbo people,Or modified clutch people)
  195. How to extract a broken spark plug?
  196. Megan Mid Pipe w/ Stock Exhaust & Header
  197. oil pumps, whos got em?
  198. Guaging interest, porting throttle bodies
  199. Injen Cold Air Intake w/ heatsheild and engine cover painted.
  200. Car Wont Start
  201. flywheel and clutch ??????
  202. Header & overheating problem
  203. Engine after overheating. The Aftermath.
  204. Trans temperature sensor
  205. What items should I *not* replace if I plan to supercharge in the future?
  206. Knocking During Acceleration
  207. Exhaust question?
  208. Should I Delete Balance Shafts!
  209. Price check on Megan Axleback
  210. Engine and Trans Rebuild...
  211. ** EDIT **
  212. Exhaust opinions regarding midpipe/spipe/headers
  213. hks?
  214. max horsepower on injectors
  215. Possible TRD exhaust issue
  216. NRG Ground Wire Kit
  217. Minor issue
  218. tsudo midpipe v2?
  219. Canister length
  220. Intake, catback exaust, in, throttle body next?
  221. Easiest way to gain power for under 2k
  222. Turbo an automatic?
  223. any ideas?
  224. CEL
  225. #1 Choice of Intake FILTER?
  226. Wtb s/c
  227. Exhaust help
  228. Draxas Exhaust?
  229. injen intakes
  230. Intake Manifold Design
  231. building up the engine
  232. cel code p0136
  233. Help with Tsudo Header
  234. Whats the Perfect Dimensions if I Purchased a Universal Muffler??
  235. 2006 TC clutch has to pushed all the way to the floor
  236. Are radiator tie downs and radiator stay brackets the same thing?
  237. what clutch to get? TRD or ACT
  238. Real HP gains from a cat back on a tc??
  239. want to get a header...but dont want to deal with the police
  240. Oh lord I have rasp!!!
  241. did the mechanic F up the motor?
  242. Will I have clearance?
  243. trying to go back to quiet...
  244. comparing tanabe g concept vs HKS HiPower
  245. Custom TRD radiator panels
  246. Can radiator panels be bought in red?
  247. Oil coming out the oil dipstick area!
  248. *EDIT*
  249. Oil/ Tranny Cooler? Which One??
  250. how to clean engine bay?
