View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46
  1. Buzzing in engine bay!!
  2. Gauging Interest: Adjustable Throttle Controller Group Buy
  3. Shifter linkage near transmission.
  4. CAMCON vvti controller + a/f controller
  5. ** EDIT **
  6. Clutch..Shifter..Linkages trouble?...help!!!
  7. HELP HELP HELP car wont start
  8. Were to get good
  9. weapon-r header donut gasket size plz?
  10. Help with borla exhaust and header
  11. Loud noise when slowing down!
  12. Megan Drift Spec Exhaust on RS 4
  13. Clicking noise during acceleration
  14. Exhaust piping question
  15. HELP!!!
  16. Question about gear oil's
  17. tc header rasp
  18. Lets talk about Custom Midpipes.
  19. Killerglass...
  20. Custom Mid pipe
  21. Raceland CAI
  22. A/T Supercharger Fit Kit
  23. TRD Intake
  24. My boring scion
  25. scion tc clutch problem.
  26. ECU reflash
  27. cant put it in gear.
  28. TRD exhaust
  29. Installed Energy Suspension Motor Mounts! Side Mount DIY!
  30. no speedometer, throwing p0500 code, multiple lights
  31. Need a Clutch Recommendation? NOT COMPETITION CLUTCH
  32. Tc mt w/trd limited slip diff installed $750.00 low miles
  33. ** EDIT **
  34. Anyone has the megan drift spec exhaust with custom piping to the cat?
  35. New Greddy Evo2
  36. Magnaflo cat back exhaust
  37. unichip question
  38. Raceland header with stock exhaust
  39. throttle body cleaning
  40. Need help with Injen SES Install
  41. Header and Spipe advise
  42. car shaking for a while after start
  43. DG-Spec Centerforce Flywheel
  44. AT-205 Re-Seal
  45. datalogging help
  46. Where is the starter????
  47. Stock or lightweight flywheel?
  48. Megan SS
  49. tC motor swap
  50. ECU Help
  51. Clutch kicking back
  52. Injen CAI or short ram
  53. Best way to take off exhaust
  54. Age old question
  55. need help
  56. Quetsion on DC Headers for anyone who might know
  57. Need help with megan short shifter install.
  58. NST Crank Pulley... HELP!!!
  59. tC engine capability for hauling heavy loads
  60. Question for 5 speed manual guys
  61. TICKing sound
  62. nylon or copper?
  63. Odd rattle in front end
  64. are you serious..... major problem
  65. gearing
  66. NST Pulleys
  67. Anti-Fouler
  68. How to increase throttle in Park?
  69. drinking oil...
  70. How many quarts for ATF in drain?
  71. P0420 Code 2005 TC-Help!!!!
  72. ** EDIT **
  73. oem exhaust.
  74. 11lb Flywheel = better accelleration?
  75. Vacuum Leak?
  76. Part Number
  77. these headers fit?
  78. How 'hard' is it supposed to be to shift gears
  79. Weird Noise from Engine after replacing the PCV Valve
  80. RADIATOR FANS QUESTION
  81. Hill assist ???
  82. half size radiator?
  83. Clicking Noise?
  84. Reverse signal wire - 07??
  85. needles dont jump
  86. advice
  87. bc stroker kit
  88. DIY radiator flush?
  89. Can low power steering fluid cause a CEL to come on???
  90. PTUNING Competition Front Billet Motor Mount (w/ Pic & Pricing)
  91. Intake Filters
  92. AC removal belt size?
  93. Looking for Exhaust Tip
  94. Ingalls Engine Damper
  95. please help
  96. my 40k POLISHED exhaust
  97. edited
  98. Wheel hop after installing Motor Mounts?
  99. From a reliability standpoint: Nitrous or Turbo?
  100. grinding
  101. Anyone running the Raceland Catback on their tC?
  102. Question on AEM ems and Greddy Ultimate
  103. Noise Post-Pulley Install
  104. Magnaflow Universal?
  105. Liquid coming out of header ??
  106. Apexi N1 Axleback?
  107. Raising Rev Limit...
  108. Air Intake Bypass Valve
  109. s-pipe or high-flow cat?
  110. Legal power mods in cali?
  111. The inside of my valves are white, WHY?
  112. Engine squeak when press gas pedal?
  113. WTB : 06 tC throw out berring and pilot berring
  114. 08 scion tc pressure plate specs
  115. shift kit?
  116. HKS Hi-Power vs Greddy Ti-C Axleback Exhaust (CARB OK)
  117. Aftermarket Clutch Problems PLEASE READ!!!
  118. between header and axelback
  119. Five Axis Custom Fabricated Center Exhaust
  120. Tsudo midpipe or Megan midipipe
  121. camry sensors on my tc?
  122. Blank mid pipe?
  123. best oil for 07 TC
  124. oil and tranny fluid
  125. S/C Replacement Parts
  126. Aero AR25 resonator. Will it fit on stock midpipe?
  127. After how many miles do I change my spark plugs?
  128. Whistling noise
  129. Changed tail light/Brake light won't work/Can't move the car out of Park! Stuck!
  130. a/c needs help
  131. removing intake manifold?
  132. Car stuck in park - ABS - Ebrake - (!) = On
  133. alphawerks - Where to buy?
  134. K&N Drop in filter - Review
  135. no trd catback?
  136. apexi neo automatic?
  137. Thread Pitch
  138. What header to Buy?
  139. Nitrous advice
  140. High mileage engine but want to go turbo?
  141. antifouler for Invidia S-pipe?
  142. Which CAI/SRI would you prefer?
  143. 2006 stock intake on 2007 tc
  144. Modified Emissions Tickets
  145. Short Air Vs CAI
  146. mmw header rattling on under carraige
  147. Shifter help!!!!!!
  148. Need Some Advice
  149. Cheapest NST pulley dealer?
  150. CV Joint Going Bad After 3k-4k Miles
  151. ACT clutch slipping
  152. xD CAI modification port to tC
  153. Low Oil Issue...
  154. Cold Air Intake - AEM ETI
  155. PTUNING: Scion tC Axle-Back Exhaust System (Pics & Sound Clip) - GROUP BUY!
  156. Best full exhaust from header back?
  157. Can i install the 05-06 S/C kit on my 08 Auto TC?
  158. CAI question...
  159. My car sounds like crap
  160. A/C Compressor
  161. need help asap....
  162. Introduction and a story about our TC
  163. Starter Replacemnet
  164. Key buttons stopped working??
  165. Got a CEL (Codes are P0138 and P0606)
  166. Help, Possible AC Problem
  167. headers cover bolt size?
  168. Question about aftermarket exhaust install
  169. M/T Fluid Change??
  170. Damaged driver side axle seal!!!
  171. Valve cover gasket - how to?
  172. talked to trans shop about using non-oem fluid....
  173. NEED To Change coilpacks
  174. any one have this combine exhaust setup
  175. what exhaust on the tc sounds the most like a subaru?
  176. S-pipe install question
  177. exedy stage 1 or clutchmasters?
  178. Twin Plate noise
  179. Need help from ARC Induction Box owners!
  180. mishimoto air diversion plate doesnt fit rite : (
  181. Tore CV Boot, possible bearing damage
  182. Any Suggestions?
  183. replacing rear mount
  184. horrible sound in front end
  185. HOW DO YOU MAKE A TC RWD
  186. please read. need help ANYTHING!
  187. LAS VEGAS TC OWNERS $$
  188. if you live in vegas and have a scion tc...
  189. Motor Replacement
  190. 07 engine into an 05
  191. ACT should give out a jar of vaseline with every clutch order(UPDATE)8/12
  192. weapon r intake manifold?
  193. looking for auto fit kit asap
  194. dual exhaust
  195. question for tc owners
  196. Low coolant Level - got a small question to ask.
  197. trd intake
  198. weird noise coming from engine **VIDEO ADDED**
  199. For those with AEM DryFlow Air Filter...
  200. clutch disengagement problems.
  201. Check Engine Light car Die after 4000 rpm
  202. exhaust help.
  203. probably a dumb question but..
  204. hks hi power = loss lower end torque?
  205. Which mid-pipe would you get?
  206. AEM 21-680P Cold Air Intake Systems for $107
  207. how to install injen intake
  208. INTAKES
  209. MAF sensor not sitting flush with intake
  210. Any Good?
  211. Rotor/Axle/ maybe CV joint?
  212. Which Header would you prefer?
  213. Pretty sure I made a big mistake... Opinions?
  214. stock clutch replacement
  215. Where/How much for used 2azfe engine
  216. tC injen CAI/SRI for $150 obo! ebay
  217. HEADERS
  218. HEADERS
  219. Greddy exhaust
  220. anything else
  221. Trd Supercharger for $300??
  222. New alternator after 4 years?
  223. TRD Intake
  224. Trans Whin
  225. Need help with CEL
  226. injen CAI shipped for $150!
  227. Chunk missing on top bolt of front motor mount.
  228. Stock oil pressure sender (dummy light) oops!
  229. Nearing the end of replacing my motor!
  230. Help
  231. Problems with 02 Sensor/CEL
  232. TWP Electronic Throttle Controller - Long term review
  233. ECU Flash or FIC?
  234. Stroker kit
  235. Electric Water pump
  236. 2010 Stock air box compatibility with 07
  237. 6 speed
  238. Broke engine block bolt need help
  239. Worth the money?
  240. Which IEH Piece would you get first
  241. Help!!! Bolt going in circles
  242. Spot the busted O2 sensor
  243. Possibly going turbo or...
  244. Spare TRD CAI/SCI filter
  245. does it matter which brand mid pipe i get?
  246. possible power steering issue?
  247. ENEOS Gear Oil Question (Manaul Transmission)
  248. ** EDIT **
  249. Short throw shifter installation???
  250. E85 Stock Engine Stock Ecu
