View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46
  1. To those with INJEN SES exhaust
  2. injen SRI - SO FREAKING BIG
  3. RACE FUEL?
  4. tC Radiator Fan Motor
  5. 08 work with 05?
  6. Clutch wont disengage
  7. MA state laws aftermarket exhaust?
  8. Replacing resonator that came with catback...
  9. 06 midpipe on 09?
  10. headers question.....
  11. Cat Back System Vs. Muffler
  12. **Edit**
  13. Spotting on my header???
  14. Does anyone know
  15. $159+shipping for DME headers. Good Deal?
  16. Trd exhaust without resonator
  17. tuning for N/A motor
  18. Shifter clip HELP
  19. Trying to install S-pipe what is needed?
  20. buying intake?????
  21. ClutchMasters FX400
  22. Pics and video of my Raceland catback and ZPI s-pipe
  23. Megan s pipe question
  24. car stalling/sputtering
  25. Tanabe exhaust installed!
  26. Instake resonator removal and power theory discussion
  27. ** EDIT **
  28. Stalling at idle
  29. intake help !!!!
  30. Have questions!! New engine, newer clutch from my old engine.
  31. engine temperature drop
  32. AEM CAI throwing CEL on 08 TC
  33. Dyno tuning auto 08 tc with intake/exhaust mods?
  34. The newest built all motor Scion tC.
  35. TRD Supercharger
  36. New: DC Sports Cold Air Intakes
  37. OEM Clutch question
  38. Header Question?
  39. megan s pipe would fit with stock header and stock mid pipe?
  40. ** EDIT **
  41. Injen exhuast
  42. tC throttle body questions-strange ?'s
  43. ** EDIT **
  44. Tanabe Concept G Fitment...
  45. loud engine sound? will synethic oil improve this situation?
  46. i lost my engine mounting bolts!!!!!
  47. CEL after LED swap?
  48. Exhaust Rattle
  49. Look what i discovered
  50. ** EDIT **
  51. will an aftermarket radiator and fan shroud help the A/C?
  52. air in the system
  53. 2AZFE MADE Without Balance Shafts? WIERD!
  54. Raceland, tsudu or Megan midpipe
  55. Problem with 2 OBD2 codes
  56. Engine Dead
  57. Pressure control solenoid
  58. Replacing MASTER CYLINDER!!!!
  59. Serpentine Belt & engine noise
  60. opening trunk
  61. Injen SES vs. Greddy Ti-C Exhaust
  62. First (known) PTuning Axle Back Review
  63. ** EDIT **
  64. FOrjworks TC Billet Coil Pack Cover
  65. hks hi power exhaust question
  66. Tsudo Mid pipe(s)
  67. jimmy's 195whp & 186wtq weaponr manifold DYNO RESULTS (12-6-2010)
  68. Street legal aftermarket exhaust parts
  69. No Compression: All Cylinders
  70. New Exhaust :)
  71. Problems with shipping CAI
  72. Question about catback exhaust and stock catalytic converter
  73. Installing s-pipe, will I need a new donut?
  74. '06 tC Harder than usual starting
  75. allmotor limits
  76. Tsudo Axleback
  77. How to make my automatic tC faster, and louder!
  78. Raceland Exhaust
  79. Changing Clutch Fluid
  80. built engine guys or techs if possible help..
  81. rx8 throttle body swap discussion
  82. LSD Install - How Much?
  83. Raceland Header and S Pipe for Scion tC 08
  84. Tranny swap advice
  85. possible bent lower control arm or strut
  86. WTT: Greddy SE exhaust for TRD exhaust+cash or Greddy sp2 exhasut
  87. Noise coming from new Injen intake?
  88. Free mods?
  89. tC Shifting problem
  90. power steering delete
  91. WTF? Do I have bad luck?
  92. Trans fluid for LSD transmission
  93. Anyone pulled over for aftermarket exhaust + no cat?
  94. Leaking coolant...Possible blown headgasket?
  95. 07 TC oxygen sensor
  96. Wehn Will We Be Able To Go Faster Than 129mph?!
  97. stroker kit?
  98. ARC intake box question
  99. Bypassing the ECU's gas cut off and etc.
  100. rough going into 2nd gear
  101. Overheating: Weird Issue
  102. Which is better? K&N/Aem Dryflow
  103. Scion tC 4-2-1 Race Header S-Pipe CEL Fix
  104. Coolant change
  105. LESS POWER?
  106. One tire spinning during burn out
  107. ACT Clutch and F1 Racing Flywheel?
  108. Appears to be rust on piston tops
  109. Would it be ok to go 91 octane in california?
  110. fuse that will cut spark
  111. any body have issues with header and s pipe
  112. Mini Cat O2 Sensor CEL Fix, any experience?
  113. [HELP NEEDED] Buying Exhaust
  114. NEW Yonaka Motorsports Alumunium Dual Core Radiator Review!
  115. removing motor
  116. Tsudo Midpipe question
  117. New head gasket
  118. p tuning short block
  119. Alternator swap??????? and AEM question
  120. ** EDIT **
  121. stock air intake rattles.
  122. Anyone recognize this header?
  123. Where to order HKS hi-power exhaust
  124. Dry Sump System.
  125. S-pipe made my car sound like as_
  126. HELP Trans swap
  127. Automatic Transmission Problem
  128. Clutch Pedal
  129. What part of The tc would you mod first?
  130. HELP removing head bolts
  131. Oil pressure Gauge Install Question
  132. Replacing Front Wheel Bearing Question!
  133. Anyone Heard of ScionTech
  134. New Scion Owner Help Tc Acting Strange
  135. HKS intake pics?
  136. MAF adapter
  137. ***Does Any One Know Yet***!!!
  138. *Should I get the catback or an axleback*
  139. Built NA / longevity factor
  140. Using a high flow cat as a resonator?
  141. *EDIT*
  142. TRD CAI installation >>> help me
  143. Exhaust leak!!!!HELP!!
  144. Battery Malfunction!! Help
  145. Exhaust and Intake help!!!!!
  146. To anyone who has done auto to manual * help
  147. Lock up please
  148. 2,000 miles over warranty... need new block??
  149. random intake bolt question
  150. Stage Axles?
  151. Dimensions for 850cc Dezod Fuel Injectors?
  152. New Clutch questions
  153. 3rd and 4th gear out
  154. 2009 tC o2 sensor will fit on a 2008?
  155. FS: Tc stock parts and ipod touch
  156. Threw cel p0137, engine knock, burning oil....help!
  157. No idea where I should post this..
  158. Just installed Megan header
  159. need help...
  160. Skunk2?
  161. NGK colder plugs
  162. VVTi Question
  163. a little question from a noob
  164. Timing chain replacment
  165. *HELP* leakin tranny oil
  166. Motor Mounts...
  167. 1st to 2nd Gear Grind?
  168. Megan Midpipe
  169. just a tease (WPN-R INTAKE MANIFOLD & RX8 TB) **pics**
  170. New Keys - Car Won't Start
  171. ecu question helpzz
  172. 3" S-Pipe-Stock Midpipe to 2.5" axelback..?
  173. Need help Remove and Replace Tc Engine
  174. Tuning ideas for Apexi Safc II
  175. yet another auto to manual question (ANOTHER ONE!)
  176. Spark Plugs
  177. Stock tC 05-06 intake: type of plastic?
  178. shifting issue after battery replacement
  179. P0441 Code?
  180. Need Maf. Connecter Pictures
  181. help asap anyone in nj, pa, philly
  182. keep blowing slave cylinder!
  183. what may be wrong?
  184. burning oil? or am I paranoid?
  185. Installing apexi safc 2 need help!!
  186. whining noises coming from power train
  187. Water Pump replacing
  188. Need help Quick please!
  189. new 2.5L engine in 2006 TC
  190. ECU Location in 05 / 09 tc
  191. mid pipe remvoal help
  192. Megan driftspec to HKS....
  193. Car wont start. PLz Help.
  194. Weapon R intake manifold Neo color
  195. Downstream o2 sensor?
  196. Need to tighten Serpentine Belt
  197. What Next need help !!!!
  198. UPDATE! HELP Manual Transmission Issues!!!
  199. Question on AFR's
  200. What's this ? Do I need it !!!
  201. Those With Intakes In New York
  202. obx cai question
  203. ADVICE!!!
  204. Mid Pipe Rattling
  205. replacing act heavy duty pressure plate back to exedy oem?
  206. Question about the Fujita CAI HELP!!!!
  207. Colder Spark plugs Nitrous
  208. How to check pcv valve operation?
  209. Water in Intake
  210. PO420 CEL..stumped
  211. Am I getting screwed?
  212. Dc sports header worth it?
  213. ecu chiiped
  214. reversing and turning produce squealing noise
  215. Change Oil Filter without draining oil?
  216. Removing the Head
  217. custom vs kit exhaust
  218. auto scion tc owners
  219. AEM FIC for N/A
  220. heater hose
  221. Running lean After Primary o2 Sensor Change
  222. Fuel Injector Cleaner
  223. check engine light annoying
  224. Help!! Advice!! Crankshaft key failure
  225. O2 sensor clip from wiring harness
  226. 05-06 clutch on 09 tc?
  227. Header install problems. Need advice.
  228. HELP CAI question..
  229. aftermarket cluch+drivetrain probs warranty Q's
  230. A/T Transmission Turbo
  231. NST Impact or Torque?
  232. TRD Cold Air Intake Install
  233. Auto/Manual Harness Question
  234. Tsudo Axle back for $150??
  235. CEL issues on new 2 me tC
  236. More suds for your N/A build...
  237. Engine & Transmission Removal
  238. Wire colors for clutch
  239. More CEL..
  240. NEED A NEW HEAD :{ head gasket blew and cracked head
  241. What is TRD CAI Intake Filter size for an 08 TC
  242. Coolant leaking/bubbling out of reservoir
  243. swap 5sp manual for automatic, need info
  244. Just did a compression test
  245. HKS exhaust install issue...
  246. CV Boots
  247. OEM Exhaust Gasket Part Number
  248. desperate for help
  249. Premium Gas in Your Scion tC - Good or Bad?
  250. Recieved OEM Shim Kit with free brake grease, need info..
