View Full Version : Scion tC 1G Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48
  1. under the hood shifter bushings
  2. Premium Gas In My Scions Give Me Better MPG
  3. obx L.S.D installed **pics**
  4. p0300
  5. Oil Change Question
  6. brake booster vacuum hose
  7. Descendant or PTuning Turboback Exhaust
  8. TRD Exhaust ticket CA [Update]
  9. Weapon R SW intake owners help.
  10. Fuel injectors
  11. Is getting a TB spacer good y or y not......how about the crank pulley y or y not.
  12. DC Sports Header worth the money?
  13. Failll :(
  14. Sorry But I Need Help NST
  15. aryana159 build auto to 5 speed (all work done by Ethan @ Track Star in arlington)
  16. *EDIT*
  17. OEM Clutch Suggestions
  18. So what should i do?
  19. Help with ecu part number
  20. 201WHP n/a UPDATE 4/23/11**bc cams installed**
  21. ????Engine Swap????
  22. Clutch Master Stage 2 and 3
  23. Pulsed negative lead
  24. HELP!!! SOS!!!! (save our scion!) Air box mount.
  25. 2011 Scion TC AEM Cold Air Intake
  26. Spark Plugs
  27. Spark Plugs
  28. lightweight flywheel
  29. Another AWD thread
  30. e management ultimate
  31. question about 2007 versus 2005 engines, or manual versus auto
  32. Scion Tc or STI
  33. Anyone try those eBay s-pipes?
  34. Need help for gaining 1gen tc horsepower!
  35. Question?
  36. ??
  37. p-tuning axle back Idle noise
  38. engine in cold winter!!
  39. clutch or slave cylinder???
  40. OEM spark plugs
  41. CEL for dying battery?
  42. DECENDANT intake manifold
  43. Any way to richen a/f mixtures w/o fic???
  44. S Pipe question
  45. question about transmission drain and fill plugs
  46. Cylinder 4 location
  47. Getting around this whole CARB thing?
  48. Replacement Cold Air Intake filter recommendations
  49. Heres a fun one to diagnose...check it..
  50. Headers
  51. Lost Gas Mileage
  52. ODB II
  53. 07+ injen filter replacement????
  54. troubleshooting 05 Scion tc Misfire! any takers?
  55. Intake???
  56. just hit 100k - what now? (maintenance questions)
  57. Raceland intake problem?
  58. Check Engine Light Just Come On
  59. Jerking during acceleration
  60. compression test gave me weird results..
  61. K & n filter system, Anyone have it ?
  62. Clutch problem
  63. Sprint booster?
  64. Question on driveshaft?
  65. Power Stabilizer
  66. tired of check engine light
  67. How will my car sound with Tsudo header/midpipe combo and stock axleback?
  68. Clutch problem
  69. ark n2 with header
  70. Shifting issues. Please reply
  71. HKS Hi-Power Exhaust or GReddy Exhaust Racing Ti-C
  72. radiator movement
  73. Oil pan question
  74. TWM stage 2 shifter installed!!!!
  75. install safcII on 07 tc
  76. Spark plug help
  77. 2005 tC won't start.
  78. CEL suggestion
  79. Difference from arc intake and others?
  80. weapon r intake without mount
  81. Mid-pipe question
  82. New Clutch
  83. sudden jerks at high MPH
  84. Megans Mid-pipe Full review
  85. Need help car idiling rough!!
  86. srs exhaust help.......
  87. Differences between the megan midpipe and tsudo midpipe?
  88. CAI/SRI...
  89. Leaking Tranny Fluid from CV Axle/Transmission
  90. Midpipe
  91. Best clutch for the money..?
  92. Tanabe Concept G VS TRD exhaust.
  93. 2nd gen auto transmission in 1st gen tc??
  94. I/H/E + Pulley ... now what??
  95. Saikou Michi Oil Catch Cans Review
  96. Need help deciding what cold air intake to get or any advise what to do
  97. name a good 12lb flywheel
  98. Ummm help!
  99. Weapon R intake Owners question
  100. Header & Exhaust Suggestions.
  101. Built motor w/ turbo need clutch!
  102. Clutch & Flywheel Boost
  103. scion tc po171 QUESTION
  104. HPS Cold Air Intake or Weapon-R Secret Ram Intake?
  105. Evap system ???
  106. fix check engine light.
  107. Clutch and Flywheel Combo
  108. Intake heat shields
  109. F1 10.3 Flywheel
  110. ok... rx8 throttle body!?!?
  111. Auto TC upgrades
  112. Raceland Exhaust System
  113. *EDIT*
  114. When Replacing Cold Air Intake Filter Should I Disconnect My Battery?
  115. Engine Weight
  116. Anybody Have???
  117. Problem solved
  118. Burning smell while in reverse
  119. Need Your Opinion
  120. Whats wrong with my car
  121. Stock Intake on 2005 tc
  122. re: trd s/c problamo
  123. New Clutch
  124. Idle issue
  125. NGK plugs for tC?
  126. Clutch Flywheel Install
  127. Exchanging muffler/tip of my raceland catback
  128. A/T Mishimoto Radiator ?
  129. Transmission Flush/Change Questions
  130. OEM replacement radiator?
  131. pulled my snorkel to the airbox, definitely feels a bit faster
  132. Clutch slipping...please help!
  133. Need some help on an issue.
  134. ftw ebay cable bushings lol
  135. Simple DESCENDANT / WORLD Racing bolt-on mod for under $35!
  136. Oil Question..
  137. trd axelback or magnaflow catback exhaust
  138. Shifter Stuck Between Gears
  139. got my tranny fixed!!! warranty!
  140. 2006 Scion tC horsepower/torque just died! Help!
  141. gain power! help
  142. No "noise" with CAI?
  143. Hks exhaust
  144. Clutch Install Question
  145. Tsudo's new exhaust system?
  146. Whats wrong with my 05 tC? video inside
  147. TRD-Magnaflow-3rd Party?
  148. Please Help...Strange Buzzing sound
  149. Straight pipe axle back
  150. help!!!!!!!!!!!!!!!!!!!
  151. How can I make an '08 tC faster than an '04 RX8?
  152. Woodard Racing N/A build! Updated Video 7/26/11 on pg.10!
  153. Exedy Stage 2 Clutch FAIL!!! Suggestions?
  154. Car wont start *help*
  155. 09 tc Sticks in first gear
  156. Another Losing oil problem
  157. Tc tune up troubles
  158. need serious help
  159. e manage problems
  160. NEED HELP- '05 Scion engine swap
  161. Will other vehicles fuel injectors work in the tC?
  162. will a 05 manuanl trans work on a 07 tc
  163. adjusting the clutch
  164. planning to turbo....
  165. Car starting Problem *help*
  166. Tunning/maintenance
  167. help need to roll up window
  168. Don't hate....
  169. Cleaning AEM Dryflow Filter Help
  170. Adding Power
  171. Quafie install questions
  172. squeak sound
  173. Difference with Injen SES2110 and SES2115 exhausts?
  174. Removing the WATER PUMP
  175. Headers and exhaust question
  176. Should I tranny swap or go boost? Plz help!
  177. Mass air flow sensor problem
  178. 5th Gear Clunking Noise (Vid Inside)
  179. Stuck Oil Filter
  180. tranny tq spec questions
  181. act street clutch question
  182. Measurement?
  183. Alternator Bearing...?
  184. 00 rav4 2.0L exhaust manifold interchangeable?
  185. weapon R header problem
  186. Turbonetics problem
  187. i need to find a good tune shop in so cal
  188. clutch wont disenguage after upgrade
  189. Exhuast wrapping header and intake...
  190. FWD/RWD/AWD + about 350-400 HP?
  191. E351 Transmission
  192. Random Spill in the Engine
  193. 05 tc- can get in gear/clutch issues
  194. BIG FIREWORKS!!!
  195. Custom tranny gears?
  196. clutch pedal problem
  197. HKS or Agency Exhaust
  198. 2008 Scion tC - used Lucas for 5,000 miles - any harm?
  199. *EDIT*
  200. new engine
  201. injen (lower cai) intake
  202. Shift noise...
  203. Head bolts loose - symptoms?
  204. Descendant Exhaust on my N/A?
  205. Help...my tc is 09...and i want to get an exhaust...
  206. PCV Valve Swap
  207. Greddy exhaust....
  208. WORLD-Motorsports Selling DC SPORT HEADERS NOW!!!
  209. Had Tsudo Header and Spipe installed...Now CEL and running in limp mode.
  210. Battery install
  211. Tsudo Mid-pipe with TRD Exhaust Problem
  212. head gasket
  213. ECM ECU Computer Help. Do I have a rare computer?
  214. nuts for plastic motor cover
  215. suggestions on upgrades
  216. Rx-8 tb???
  217. power steering pump replacement
  218. jolt when accelerating
  219. Axle power lvls
  220. radiator fan problems
  221. 4-2-1 header/exhaust/heat wrap
  222. Clutch noise
  223. Just bought tC and have some questions
  224. Tsudo V3 catback exhaust
  225. low idle, knocking noise from underneath
  226. ECU Quest
  227. tsudo products. any one have any trouble?
  228. Speedo not reading speed...
  229. No Gears After Accident
  230. Just Got My Exhaust Done
  231. Which OBD 2 Scan tool Should i get ?
  232. Master/Slave Cylinder
  233. Headers and cat?
  234. will 07 motor and tranny fit my 06?
  235. Some clutch questions
  236. any guesses as whats wrong with my car?
  237. Greddy Evo 2!!
  238. which axel back would you prefer?
  239. i need your help
  240. motor and tranny mounts question
  241. Need some opinions: Should I bother doing any tranny work for 127k miles?
  242. Help...having problems with my clutch
  243. Emissions/Evap error code
  244. p2716 code on 2AZSC M/T ecu Manual with S/C
  245. new to stick
  246. P0031 On a new Bank 1 Need Help
  247. Clutch Engagement Adjustment
  248. need another clutch!
  249. Megan Drift Spec melting bumper..
  250. In serious need of help with Tranmission
