- Building motor
- Header Question
- Injen SES no resonator??
- HELP NEEDED: valve lifters!!!!!
- It's here Tsudo Scion TC 2011 Catback exhaust
- full exhaust
- Rough idle finally gone (dirty t/b)
- Fujita intake
- Exhaust Fumes
- Tc running rich
- What size bolts hold on heat sheild and plastic engine cover??
- Make Me Faster for <$1000
- HHow too. Aam fuel rail . Looking for installation
- Non-CEL throwing Intakes for 07 tC
- Tanabe Concept G
- AEM FIC, Greddy Ultimate or Greddy Emanage Blue??
- High Mileage Engine Vibration
- Goin Back to stock help...
- What clutch should I get for turbo?
- ** Camry trans vs. tC trans ratio talk **
- 06 tC w/189,000+miles tranny problems
- Unichip possible on non turbo
- Clutch problem
- whirring noise 35mph+
- Stuck spark plugs
- 2005 Scion Tc Exhaust Manifold and O2 Sensor Issue
- Scion Tc Oil Change via Dipstick Tube
- bad 5th gear keeps popping out found problem (pics included)
- supercharger to turbo
- MT wont go into any gear.
- '10 Scion tC HQ TRD exhaust sound.
- nst 9.5 pulley
- TRD Supercharger Tune
- Aftermarket / Reman MAF sensor
- Will I pass CA smog check with these mods?
- LOW IDLE/ENGINE STALL~~HELP!
- Problems with temp gauge after jump starting
- removing stock oil pan
- New to Scionlife.com
- Injen's tC cold air intake system
- s/c cai?
- O2 Sensors
- Looking for a similar exhaust...
- power squeeze not forced induction question
- Starting Issues
- Cylinder 4 Misfire cause?
- Got a problem need help quick
- Charging system trouble
- idle/shake problem EDIT: Video/Possible problem found!
- simple cai questions i couldnt find.
- Spec Stage 2 Clutch and Spec Aluminum Flywheel
- 07 + engine on 05-06 tC????
- My car has gone mad, someone please help me target the issue!
- NST underdrive pulley install
- Clutch Problem
- R2C Performance (prototype) Intake dyno
- 2006 TC Loosing Oil?
- WTB Scion tC Short Block or Girdle
- Repeated Master Cyl Failure
- Stage 2 camshaft ideas?
- Timing chain and water pump replacement
- Headers + OBX resonator + HKS Hi Power
- Help! Throwing CEL Codes P0113,P0441,P0455
- Anyone try BG44K?
- Intake/Exhaust Questions
- WORLD-Motorsports Now has DeatschWerks 300 series in-tank fuel pump Kit!!!
- HEADER HELP
- Need help on how to drain trans
- automatic to manual swap walkthru
- Shifting is hard at high rpms..
- Winter storage
- Resetting ECU?
- K&N Air Filter
- size exhaust question on s/c?
- Need opinions on the Fidanza Clutch kit
- scion tc with e351 transmission driving video (shows speedo and rpm)
- oil in coolant
- exhaust got quieter?
- Transmission fluid change cost
- S/C Piggyback
- noise in timing chain area
- A/C dead
- Engine Rebuild @185,000 miles...
- power help
- Can an S pipe cause a CEL P2238?
- Which Pulley
- major oil filter problem
- Dealership Possibly Sold Me Wrong Oil Filter?
- Immobilizer reprogram???
- Idling at 650rpm ish??
- HP/TRQ estimate?
- Welded Spider Gears - Anyone?
- OBX Crank Pulley - Only 5 Ribs?
- TWM Performance 10% Discount Code --- USE IT BEFORE IT'S GONE!
- blew 3rd n 4th gear questions bout e351
- Cable Throttle Body
- wideband sensor question
- 05 MAF on 08??
- 1az-fe swap (yes 1az)
- *EDIT*
- crank pulley? New to modding=)
- Changing plugs, white residue
- ENEOS 75W90 = Trans noise at 20k miles
- Help with clutch problems
- Weapon-R Header now here for 1G tC!
- PLEASE HELP
- How to fix/prevent oil line leaks?
- Help Please! 05 TC Fresh Rebuild Will Not Start
- GReddy Spectrum Elite Group Buy
- Lightweight flywheel chatter?
- Catted N/A Header (S/C results in! Page 8)
- Cruise control not working
- Autotragic to Manual DIY w/ pics
- Feeler: OS Giken LSD Group Buy?
- new owner
- Rough Idle
- New to scion and imports
- Advice On Power
- Transmission Fluid, is it to late ?
- jerking to the right!!
- intake question
- BC Cam Shafts help...
- power. going for that power
- Header Cell eliminator
- Manual Swap? Cruise control not working? Read me.
- strange whine from the clutch
- Thank you Kareem at Descendant Motorsports/world racing
- PISTONS oem(9;8@1) VS 2azfxehybrid(12;5@1) PICS!!!
- Energy Suspension inserts not sold mounts
- Greddy SE on my bumper
- Torque Convertor
- Intake Install Question
- TRD EXHAUST!
- Problem with steering
- The P0010 Fault Code Also Known As The Camshaft Position Actuator Curcuit
- 3sgte plus driveline in the tc?
- Won't start after engine build
- Should I replace some part in the engine? (advice & Ideas welcome)
- megan exhaust
- NY state Inspection woes
- ss clutch line!!
- throw out bearing
- New to the whole exhaust thing ?? =/
- Injen Air Filter Question
- What are some good exhausts?
- Passenger Motor Mount
- Stock intake help ASAP (RESOLVED THANKS)
- Has anyone tried this "new" tsudo exhaust?
- Help with pulleys and headers ?
- Universal Muffler Possible for 2011 Scion Tc?
- 5th gear swap project
- scion tc header info
- Bottom end motor builds
- New Strup Axelback + Tsudo mid
- 2009 tC auto. ?atf?
- anyone have video sound clip of....
- Transmission?
- slipping?
- Throttle Body Changeout
- Decendant exhaust for tc1
- tb spacer
- OBX ?
- OEM 05 ECU WHERE!!!!?!?!?!?
- any unichip users?
- Excessive engine vibration
- Tsudo n1 cat and mid-pipe with axel back
- P0304 & P0300 Code....Need Advice
- Header or tune up?
- Rattle coming from engine area passenger side
- Auto to Manual Swap, a slightly different case.
- *EDIT*
- Mtec Industries 'New Product' Review
- Oil light flickers after engine build
- Fuel Pressure?
- 2007 & up synthetic automatic trans fluid swap?
- Ram to CAI
- HELP!!! My clutch is BROKEN!!!!!
- Knocking: Bent rod or spun bearing?
- Front Crank Seal?
- Cold Start ticking from Belts?
- ARK NII Exhaust
- CEL Code
- greddy evo2 missing mounting bracket
- Not working!!!
- Megan midpipes
- Megan midpipes
- Crankcase/Upper Oil Pan Removal
- Cluster switch out
- only speedelement sells tsudo header?
- 2AZ-FE removal steps and my build
- Blown head gasket?
- Please Help w/ Clutch Kit
- emanage blue
- 5th Gear slip out, ANSWERS!!!!
- Help a noob gain a little hp
- Clutch out
- HELP...burning serious oil!
- Clutch Going in and out
- Help with TRD CAI !!
- OBD2 Test Results Scion Tc 2007
- EXHAUST HELP!!!!!
- Dezod Catted Header Group Buy Interest?
- 2 Different SES codes in 2 days (KS) search no help
- Performance engine for TC?
- *EDIT*
- TRD Exhaust + Magnaflow 22" Glasspack
- *EDIT*
- tuner shops in AZ!
- ruh-roh. i might have some trans problems
- $4000 repair?!?! WHAT!
- Vibrant ultra quiet resonator.
- Hks exhaust w/ oem rear lip?!
- 05 tC installing CAI
- plz someone help!!
- Vehicle Speed Sensor "A" Code P0500
- 06 tC running rich
- Nut size needed
- Clutch issue I just need some feedback please
- IS THIS THE RIGHT WAY?
- Tsudo N1 catback or custom exhaust?
- 06 tc shut off on the way home
- AEM Bypass with Injen CAI?
- Tc Trans Q's
- Injen CAI Performance?
- Need clutch help
- Trd Exhaust Question
- fram filter=new rebuild
- Can't accelerate quickly
- Car having trouble starting. Not an engine guru so any help would be cool
- clutch help
- Performance help!
- Oil leak, what is this part???
- Engine block!!!
- What are your opinions on the Tanabe Medalion Touring Cat Back Exhaust System?
- Borla exhaust VS Tsudo VS taname exhaust
- Fitment Question
- Pulling the head
- Any tips on removing manual transmission seal?
- noise from tranny
- Tsudo install
- 2009 corolla alternator on 2005 scion tc?
- 2007 intake to 2005
- bad oil drain plug?
- code 2238 ?
- How have you shipped a motor?
- tilton pedal assembly
- stock Panasonic battery question
- *EDIT*
- Checking manual transmission fluid level
- how long do aftermarket clutches last?
