- Arm fic or other?
- *EDIT*
- Air Conditioning crapped out.. 05' w/78k
- coolant temperature sensor? or thermostat?
- 05 tC auto trans oil level / change
- *EDIT*
- Cylinder Compression
- (VIDEO) WORLD Racing Presents: Descendant Engine Build
- Belt size for power steering delete
- tc pushing 108k, questions about maintenance
- 2005 tc in Calif How Many catalytic converters do I need? Just one up front only ?
- Endless Exhaust question...
- Header installed
- Judge the sound of my Srs catback on a a/t Tc
- OEM Exhaust Manifold Temperature, What should it be, and should I be worried.
- weapon r dragon filter?
- **LOCK**
- Tips or Advice on Removing Stock Manifold Studs
- coolant flush
- Best option for bad Tranny: Rebuild or replace?
- automatic fuel cut launch?
- Oil below MAF w/ Photos.
- (Please move to FI Thread)Map Please! Car studders/ missing.
- p0441 and p0445 error code. check engine light
- Thicker oil to help silence noisy valvetrain??
- Strange RPMs, Help Please
- Coolent reservior
- oil plug gasket??? aka washer
- TC1 MAF code after installing Intke pipe
- Going from supercharged to stock engine
- Help with AC problem
- Transmission fluid change/add question??
- Exhaust?
- Need opinion's on pulley's?
- 07 tc Fujita Cai installation
- Attention anyone who was thinking of buying a spec clutch [read]
- Need a couple opinions on exhaust products.
- SOLVED! Fresh Manual Swap Power to Car/ Fuel Pump no crank?
- Randomly re-occuring low idle/stall problem (with video)
- Transmission/Clutch/Flywheel issue
- e351 on my tc
- need help cylinder heads
- I need help picking out an Exhaust!
- 2006 scion tc will not start, please help
- high rpms in 5th
- Strange sound from front end
- Used ECU install
- Agency Power Exhaust?
- auto tranny holding power
- VSV Mounting Bracket Part Number?
- Trying to seafoam but cant get a vacuum leak??
- Alternator not Charging my Battery, please help?
- Car not going into any gear when on (M/T)
- Rod Knock? (Cold and Warm Engine)
- *EDIT*
- XTR stage 3 6-puck sprung, any good???
- HELP
- Engine Light after O2 Sensor Install, and ECU Reset.
- DIY clutch went wrong
- Having trouble with my supercharged scion tc
- Slight on/off clunking noise..
- What's a good Stage 2 Clutch?
- Will Not Stay In 2nd Gear Kicks To Neutral M/T
- Weapon r intake manifold
- Which clutch is best for the money?
- 06 Air box retaining clips
- Pulling the head...
- Passenger Side CV Axle Support Failure
- TC1 AEM ETI issues potential recall
- Clutch sticks to the floor
- smoke
- 05-06 Head vs 07+ Head
- Auto Transmission Question
- Where can I buy transmission parts??? HELP
- Possible Vacuum Leak?
- Ever had a s pipe become loose and make a strange noise?
- 2007 tC CAI installation
- 08 Head bolts
- P0606 & P0456 Codes
- air Conditioning question?
- 2007 tC exhaust install
- I'm thinking about putting an xb2 trans in a tc1?
- Hopefully this is how you cure rasp for us tC header guys
- No acceleration from a stop, while passing??
- P301 on a built motor
- scion tc shirfter cables
- k&n typhoon 69... on an 07 tc?
- Raceland catback exhaust video inside...
- Catalytic converter bad at 80k miles? p0420
- what brand of 02 sensors recommended? 2005 scion tC
- Uh.. HELP!?!
- Burning Lots of Oil
- tc has fuel and spark cranks but does not fire help!!!
- delete
- Throttle actuator control stuck closed?
- Exhaust leak, need some help please
- Balance shaft delete instructions?
- What is it and where can I buy one?!?!
- loud chirp/squak noise
- Hissing noise
- n00b with a few questions
- Passing Inspection...
- Broken Crank Pulley & Gear
- Check Engine P0301 Code - Help
- clutch pedal start disable?
- *EDIT*
- Header Wrap Question
- ACT Clutch Installed: Need Help
- Necessary 100k Coolant flush?
- full exhaust header to tailpipe????
- exhaust idea, need help
- Throttle Body Cleaning
- What is a fair price for a clutch install?
- Coming for help. Engine Code P0447, Evap System. How to Fix?
- MAF question
- Megan Drift-Spec Exhaust
- 2azfxe Pistons Installed
- Radiator Flush Question
- Catback midpipe same as OEM???
- Hey FS dc sports headers!
- UNICHIP???
- Help! Whirling noise and not boosted
- oil leak
- Vacuum hose replacement
- CEL light blinking
- Greddy tic axle back question.
- p0300 p0301 p0302 p0303 p0304
- Idling issues..
- need help/advise with trd supercharger
- Radiator leaking - replace just frame or fan unit as well?
- Time for a timing belt?
- looking for info on timing chain tensioner pulley
- In the shop with a dead engine
- Looking for Parts
- Muffler too close to Rear Bumper problem
- Scion TC Engine Fan/Overheat problem
- Exhaust Gasket replacement
- Blue smoke...help
- 05 tC Cranks - Won't Start
- CAI Injen Question
- Black smoke
- ignition coils
- HELP! Where can I get my cold intake Air Filter cleaned?
- Scion Tc engine Diagnois and Help-misfire
- Pulley brands?
- Shift linkage problem
- Terrible gas mileage after a/c compressor install
- cylinder order scion tc
- Some Exhaust Questions
- Oil Pressure Drop = Spun Bearing or Gas in Oil?
- tc lags in power problem
- Intake question
- Noise like a cv shaft is grinding/blow
- How Should I Beef up My Scion? I Need Advice!
- Oil Light Flickering...Problem Solved (worn Rod Bearing)
- New wheel bearings installed and some noise?
- How to elminate the rasp!!!!
- Engine Rebuild Help
- Megan Racing Drift Spec Mileage Decrease
- Need some Serious Solid Engine Advice Please!!!
- factory exhaust hangers
- FS: 05/06 AEM Cold Air Intake
- 09 2az-fe
- oil consumption
- Best online aftermarket parts source?
- MT fluid
- Engine Light Problem -- Camshaft
- Experienced Troubleshooters Needed,, Did I blow my engine/hydrolock. read more. P2195
- toyota box intake
- 06 OEM Intake
- N/A Tunning tips/Ideas (engine management )
- Trouble Turning Over
- **08 5 speed trans problems**
- Windshield Wipers Wont Work!!!
- Hi Flow Cat and resonator?
- Hight temp after header install?
- need help engine wont start
- Rattle in Drivetrain Area
- Clutch/flywheel recommendations
- Automatic transmission removal.
- delete
- Stupid PNP harness question
- Compression
- Bad Water Pump??
- Megan Racing Drift Spec Cat-back exhaust with blue tip now available
- 130,000 on original clutch
- Tranny swap
- Flywheel dimensions
- Plugged 07 unichip to 06 tc lmao help
- custom bent mid pipe VS megan mid pipe
- Auto Engine Swap?
- Overdrive??
- can fuel injector cleaner clear CEL misfire code?
- Throttle hesitation while decelerating?
- *Edit
- Scion tC 06' P0741 transmission or torque converter problems. HELPPPP
- Trying to buy exhaust, need help
- Need some help??????
- Where to get s/c pulleys
- Disappointed with Deatschwerks
- Review: Competition Clutch Stage 4 Clutch Kit
- Dr isotope short shifter
- Scion TC OEM intake, NEED ASAP
- Mods please verify
- throw out bearing?
- Throw out bearing problem???
- 2009 - Blown engine
- TRD exhaust for 2010 tC
- Frs rear diff into 06 scion Tc to make it rwd
- Megan racing header questions?!
- DC headers and inividia vs. Tsudo headers and tsudo s pipe
- Looking for parts help!!
- So my engine is totalted and idn what to do lol
- diameter of crank pulley?
- Serpentine Belt suggestions?
- 2GR-FE swap
- my car is making a clunking sound
- MAF O-Ring Size?
- 2008 Scion tC will not START!!!
- Weapon R Throttle Controller, thoughts?
- *EDIT*
- Magnetic engine heater
- *EDIT*
- 2009 Scion TC.. What to upgrade??
- water pump problem?
- Raceland Exhaust
- Dealership says head Gasket is bad?
- Review: Exedy Twin Disc
- Oil consumption problems
- electric water pump conversion!?!
- possible clutch pedal issue (new clutch)
- n00b Needs some help
- Swaps?
- unichip
- Custom intake
- 250HP!!!
- Low car idle problem
- Low Idle Problem
- Hawk HP Plus pads
- S/C Tune w/o S/C?
- Loud Squealing and start-up issue.
- Balance Shafts removed review
- ACT Stage 2 Clutch Review
- Removing 2AZ FE head
- E351 trans Updated Question #### see post 16####
- Apexi SAFC Neo
- Poly exhaust hangers question
- Please help!! Grinding when I down shift on a stock clutch...(I think)
- RASP @ 6-8k RPM's
