- Lets Talk ITB's Yes? No? Maybe?
- Buying USED intake?
- Monstermotorworks stage 1 xb kit?
- Any headers (4-2-1) for xA that work w/ stock heat-sheild?
- ebay ground wire kit
- $100 exhaust, To good to be true?
- VOLANT CAI BOX ??????????
- goodyear gator belts coming for the xa and xb
- Couple Questions....Tint,Springs,Crank?
- exhaust piping size
- Exhaust System?
- Install nology hotwires or not?
- Injen Catback Dual Exhaust for XB
- another k and n question?
- Compatible Parts List?
- Custom Quad Exhuast on XB
- Injen intake caused problems with my HVAC?
- Questions about SRI
- Greddy Evo II Review, Pics and Video! [56k No]
- Perrin pulley / stock pulley bolt torque spec
- 2004-2005 Xb Pinout Colors...What do they mean?
- worried rough shifting from 2nd to 3rd.
- quick Q
- Fujita CAI w/ Strut Bar?
- Magnaflow Full Cat Back Exhaust Installation
- is it really worth it!?!
- jic spartan type 1 exhaust
- Where's the Oil Pressure Sender Located on the xB engine?
- Intake install problems. MAF sensor related
- dc sport axle back exhaust
- Has anybody had the dealership install a new clutch?
- Looking for opinions on the cat for xB header-back prototype
- ugh!!
- Will AEM intake work on my 2006 XB.
- Supercharger!
- custom Magnaflow cat-back DNX tip pictures!!!
- Noticed Rattling in my engine, WHAT IS THIS??! HELP!!!
- draglinejt xA/xB pulleys from Ebay
- home made
- Bosch Platinum +4 Spark Plugs... better performance or not?
- Help! 06 xB auto---metallic click in park to reverse shift.
- eBay Carbon Cold Air Intake anyone try?
- help on ecu
- eBay MUFFLER?
- stillen exhaust?
- ZPI pistons
- Toyota Fuel Sub-Systems (OPEN/CLOSED LOOP) Feedback Control
- Intake Manifold
- TRD short shifter???
- has any body else noticed this
- 3rd gear grinding or linkagegrinding? **STORY INSIDE...
- Short Ram VS CAI
- header
- Wideband on xA/xB?!
- greddy sp2...
- More Horsies for Less $$$$
- Cat Back or Axel Back
- dc sports or strup?
- Write-up on transmission fluid change?
- Scion XA
- **edit**
- nitrious with super or turbo?
- AudioVox CCS100 Cruise Control on XB?
- my dyno Results
- Pedal Travel and Clutch Engagement
- Tick on brake pedal
- Throttle body and header questions.
- installing headers
- CLUTCH LINE HELP
- *Manual- Backing up on a slope
- celica throttle body swap
- Nippon Denso oil filters
- Creativity!
- Pulley xA
- CEL- Crankshaft position sensor HELP!!!
- What are my options for a short-ram intake on an xA?
- Exhaust system comparison Xa V. Echo
- Anyone know a way to quiet down the magnaflow on a RS2.0 ?
- Stock Oil Pressure Sender/Switch Markings
- Adjusting throtle Cable
- what would happen if you drove your car with no oil in it?
- 2006 aem cold air intake/dc sports header
- hoses and lines
- Scion xB Overdrive Switch
- I need some knowledgable help!
- AEM CAI for RS 2.0 (solar yellow)
- exhaust
- Rough clutch and gas Pedal
- Questions for the nitrous Guru's....
- turbo or supercharge?
- my xa is purring?
- TRD rattle
- VSC/TRAC/ENGINE LIGHTS ON
- DC Headers for XB
- Who has replaced their clutch? What did you get?
- undecided about my Fujita SRI
- cricket noise coming from engine????? Any clues?
- MMW Xb/Xa Header Blow out.
- does anybody have this kit???
- exposed cold air intake
- 1ZZ-FE swap
- highest top speed for box
- Air intakes...?
- Gorilla working at the Factory?
- Wanna add more HP?
- still which one? turbo or super
- Aftermarket Gears? Final Drive? 6 Speed?
- hey
- Try to figure this one out...
- MMW / WR Engine Damper on Sale.
- MMW Xb / Xa Header on SALE..
- Wont go into Park
- Look What Came in the Mail Today
- Warranty Issues
- cel, vsc, trac off going off only when low on gas
- My Engine Blew Up!
- Will tC radiator cap fit xB/xA?
- Need help
- Best value for intake/header/exhaust combo?
- What do you think?
- Slapstick shifter
- TRD axle back making sounds when im shifting
- Maint light blinking
- Engine Bay dress up
- New Greddy toy!! Will it work for xb's?
- stock exhaust and shifter assembly
- how is the FX-1 cold air intake?
- Headers
- Has anyone installed an Apexi ITC
- MONSTER M-WORKS Intake Manifold
- What's the best deal going for the xB TRD ehxaust?
- chips
- Kill Switch?
- loss of power between 3000 to 4000?
- xA downpipe?
- flame thrower exhaust question
- CLUNK! on downshift
- Injen CAI problem
- Best Value? Short ram intake
- MMW header - First impressions and install tips
- Carbon fiber mufflers
- HP question....
- Most H.P.gain on all intakes
- Free GReddy exhaust!!
- TB Coolant Bypass?
- auto tranny woes
- Brake Light Out, But Not The Bulb... :(
- Cold Air Intake Question
- Rough Gas Pedal Feel
- new fuel rail on the market... Craven Speed
- headers
- what is this good for?
- Got my DC Sports axle back installed *PICS*
- Balancer Shafts
- Nitrous Pressure Gauge Location Question
- is the xb for racin' or not?
- Need help locating a manual shift shifter boot. Please read
- Pillar gauges...what do you use and why?
- cheapest place for RS*R exhaust
- Have cold air, what exhaust should I get??
- HOW TO: Remove and paint engine valve cover (TONS of pics)
- Greddy catch can= warranty void?
- Tanabe Medallion Touring exhaust installed - (pics and vid)
- Has anyone tried freezing the intake air?
- Any success with NOS?
- Test Pipes, High Flow Cats, and Glass Pack
- Any decent headers for xA 06 model?
- Transmissions
- header install
- need help! APEXI AFC NEO
- shop in so cal wanna swap an engine in? i have plenty ideas
- engine swap???
- Monster Motorworks M2 Aluminum Oil Catch Tank for Scion XA
- xb 5th gear.....
- Paint chiped
- Weapon-R Damper
- Need an opinion on this chip...eBay Bid ends in 7 minutes
- another xb owner with p0103 code
- xb head swap
- How To Buy: YDR chrome CAI w/K&N filter???
- Weapon-R are they legal yet..?
- I wanna paint my Valve cover
- Anyone got dual exhaust on their toaster?
- Help with dyno.
- popped my clutch from first to second
- Automatic tranny problems arising... HELP!
- Tanabe SM Hyper Exhaust, can I do a Self Install or??
- exhaust and intake
- HOLY HEADERS BATMAN!
- best intake for xB?
- Injen short ram install problems on xB...anyone else?
- anyone got weapon-r ram air?
- AEM Intake Rubber Mount Bracket
- Big problems Help!
- afr with a 50 shot.
- Anyone have a fujita cai??
- throw out bearng again!!!
- Got Great deal on DC Sports Ex rather than e-bay unknown ex.
- Removing the silencer
- How to install MM2 Aluminum Oil Catch Tank for Scion XA ??
- Need help fst with ground wires
- invidia axle back exhaust
- Exhaust Header with heat shield mounts. Who makes one?
- Ebay Intake
- DC Sports Exhaust People?? Silencer question??
- anyone running a proper piggyback like eManage ultimate?
- Exhaust Clamp Part #
- tranny cooler
- Horsepower increases for the automatic crowd
- Any Install manuals online on installing headers on an xA??
- TRD exhaust pix, sound clips, opinions welcome
- No start???from time to time???
- PCV VA;ve
- ENGINE/MOTOR SWAPS?????
- FASTEST XB IN THE WORLD????
- Clutch slipping, need recommendations please
- K&N TYPHOON CAI modification???
- LSD for xb diff
- xA CEL light and M2 Stainless Steel Race Headers??
- Forced induction intake??
- my new dual exhaust setup *pics* UPDATE: videos
- NRG engine damper?
- What temp the engine runs on????
- Bassani Aft-Cat Exhaust System
- Dumb question about cold air intake
- Strup exhaust question
- wwoohoo dc headers came in
- xB Exhausts -- How do they sound?
- ECU Programming?
- ANYONE, CAI MOUNT BROKEN ! NEED HELP
- oops! p0103..time to battle the dealer
- Installed my short throw
- MY ENGINE IS SICK
- Exedy Flyweel
- VCS TRACK AND CHECK ENGINE LIGHT
- Could this be the CAI of the future????
- Where can i find high flow cats for the xb
- TRD Q
- 5th gear cruising speed
- exhausts
- MR2 engine swap?
- Throttle body
- engine shakes at idle, any suggestions?
- found me some ebay headers...woot
- xB clutch question.
- really annoying beeping?
- Please help all advice welcomed.
- 2 1/4 cat back flowmaster on my box!
- cat back exhausts for the xA
- XB Engine Rattle Help!!!
