- Weight Reduction
- Transmission lag from 2nd to 3rd at startup. Is this normal?
- TRD Gears
- Pulley troubles*Update*
- staright pipe in xb?
- best bang for the buck ?
- looking for a new clutch.
- Oil sending unit adapter plate
- Port And Polish Pros And Cons
- xa transmission
- Look what i just bought!
- MOST QUIET EXHAUST FOR XB?????
- clutch smell???????? Cluth going out?????
- Idle Adjustment Question
- Timing Adjustment
- transmission swap
- exhaust opinons
- Stronger axles for xA
- 06 xb dead like a piece of lumber
- CHEAP PRICES ON INTAKES
- Am I crazy? Engine Swap
- 06 xB acting funny in cold
- 1NZ-FE: Stock sensor types? Crank position, MAF, etc.
- Optima Battery Question
- B&M or TWM Short Throw Shifter???
- Where's the vacuum line on the xb's
- Fuel Delivery and Management
- What motor oil do you use?
- Greddy CAI anyone have it and if so opinions!!!
- OBX 4-2-1 Header / Bracket Issue
- 06 xa/xb ecu diagram HELP.
- HEADERS
- Engine Rattle due to Engine Vibrations or low idle Scion XA
- Crappy Miles Per Gallon! WHY?
- Engine features
- Installed Fujita SRI
- 06 xB auto will not upshift into 4th when cold
- Strup axleback LOUD!
- Intake...Out B-4 Seing Dealer?
- Q: about injen's xB SRI CARB legality
- Strup Exhaust AND Header setup
- Crank Pulley for an xA!?!?
- any one try a SuperTrapp?
- how many have a 50 shot of nitrous?
- Best intake filter?
- AEM O2 sensor tubing
- K&N Make Me Angry
- Fujita xB CAI foglight clearance **it fits, pics inside**
- Zero1000 Exhaust
- Tanabe Project XB GTS
- OBX headers on ebay any good?
- anybody using SPINTECH mufflers for their xB auto trans?
- Pulleys can you tell me about them?
- what to do witht he short ram?
- Still torn on getting a lighened flywheel
- How to get 160 hp from a box...
- Exedy vs Clutchmasters
- Exhaust Tip Recommendation
- Anyone go with a Test pipe on the Xa yet? also a couple ?'s
- Clutch if I's
- Need Pics of xA or xB or Yaris 5spd Transmission
- Nitrous or 2008 xB?
- Injen filter cleaning
- New Header Back System!!! NEW PICS POSTED!!!!
- Does anyone have the Greedy headers???
- DYNO DEAL FROM MMW to SL Xb / Xa Members.
- does the xb ESPELIR JGT500 EXHAUST SYSTEM fit in the xa?
- has anyone thought of individual throttle bodies?
- Quickie
- Thanks to new Exhaust SPONSOR-Econo Lube N' Tune(PICS)
- Question about Over Drive
- MMW engine damper instruction on how to install?
- Don't buy an intake here... (Edited)
- Loose throttle cable
- New intake=more horsepower?
- IDIOT TOYOTA TECHS
- installing performance intake/headers/exhaust - worth it?
- Update: STi Xb
- Melted shift cable question.
- I/H/E/P how much WHP?
- help with choosing air filter for AEM cold air intake
- check out this filter!
- TRD CAI CARB LEGAL FOR 2006 SCION XB
- AEM dryflow filters
- adjustable cam pulley
- fuel filter location
- Need Pics of NRG engine damper
- Exhaust getting really loud overnight?
- Toyota prius bottom end question
- 06 clutch
- CEL, VSC, TO Nightmare
- scion chip/module
- GReddy or DC Sports?
- water sender adapter size
- How do you take off the engine cover on an xb?
- Bought a Fujita SRI on ebay
- Crank Pulley
- need power for my xb axleback exhaust or cold air intake
- I NEED HELP FAST ON A XA
- Exhaust Tips?
- xB Belt Question, Belts or engine making sqeaking noise
- what the heck is this for?
- The xB autocross thread
- OBX Racing ( who are they )
- STRAIGHT PIPE!!
- Observation of a just installed K&N Typhoon
- How long does it take the car's computer to reset itself
- staight pipe too
- NEED CASH UNORTHodox pulley for practicly free with new belt
- K&N Typhoon intake?
- 1NZ-FE WANT MOD AND NEED PRO MEMBER COMMENTS
- just out of curiousity...
- M2 Billet Battery Cover
- Exhausts - Highway Drone
- TUNING FOR XB IN ORANGE COUNTY CA?????
- Alphawerks Header
- Yet another hydrolock thread.
- pulley question not your average question
- TRD Cold Air Intake 05 - 06 models
- BOSCH IRIDIUM FUSION SPARK PLUGS
- Ignition Equalizer
- Clutch noise
- GREDDY EVO 2 OR TANABE CONCEPT G
- 04 XB, 25,000 miles......transmission dead
- Cquence Rotors****PICTURES****
- AUTO TRANNY INFO
- Magnaflow Exhaust is Too Loud!!!
- question for you auto tranny guys.
- A MUST mod for manual tranny - Redline MT-90
- alternator ????
- moded xb vs stock Tc who wins?
- CAI Filter change
- engine coolant tempature sensor
- my exhaust suddenly sounds ricey and i don't like it.
- SRI problem? maybe, not sure.
- NEED HELP!!!!!
- TRACTION CONTROL PROBLEM
- Msd ignition xa
- Check out these new pullys
- SOS,ANY GUYS USE THIS MUFFLER IN YOUR xA???
- Undesided on a shifter
- Does ne one know what size battery the xB is ???
- i jus bought my fujita intake and i love it!!!
- exhaust....
- wishfull thinking? or am i right?
- whats a good battery to run in xb with a system in it???????
- I'm now part of the I/H/E club!!! PICS 56K, you can try
- Header Damage... Will this be a problem?
- ODD pedal vibrations
- quick exuahst question (greddy)
- Where did it go??
- Oil filter - OEM VS OEM
- TSUDO xB Fireball Axleback
- engine swaps possible for the box? (edited: need help)
- TRD Final Drive 4.0 or 3.77
- Anyone have pictures of Greddy sp2 installed on xA?
- Filling NOS Bottle with Co2... ...Any Experience???
- New air filter, need opinions...
- Serious question...NEED HELP PLEASE!!!!!!
- Volant Cold Air Intake
- Chrome engine cover
- intake breather hose size
- Unorthodox pulley owners
- EXHAUST PIPING
- do you want solid motor mounts for xbs
- blue loctite for aftermarket pulley
- 1/4 mile times for xb/xa?
- TO Bearing?
- View/Post dyno results here!
- xb transmission swap possible?
- Clutch Install Can anyone help me (all done flix inside)
- Warm up your Engines ?
- Auto Transmission Question
- VVT-i Vs VTEC
- Short duration trips
- Rust under the hood ?
- bah..time for a new transmission
- Borla Exhaust
- Exhaust Backpressure - Fact or Fiction with Scions?
- Random Activation of CEL, VSC, and Trac Cont lights
- OBX Exhaust
- AEM cai with K&N filter?
- Quick question
- Fujita CAI Intake (CA 3100)- not a good deal, A GREAT! Deal!
- Ground Wire kits
- is there any motor swaps
- help w/ my evo2 exhaust
- Flowmaster Hushpower sound suppression?
- REALLY NEED HELP,,,my car won't go over 83mph ?????
- Is my clutch grabby!
- New Shifter Cable?
- Wondering if I should buy this Greddy exhaust evo2??
- a xB's/xA's Upper Radiator Hose size?
- exhaust pipes and flanges
- Exhaust System
- Question on brakes?
- Cheap exhaust... What makes it cheap?
- E-85
- free up power?
- warranty almost up- what is the best header to get?
- Port and Pollish Heads
- aftermarket auto trans fluid
- Pulled over for illegal exhaust....Got some questions
- auto trans pan, where to buy.
- improved my lower end torque
- Best Price for a drop-in K&N 33-2211
- broken trans
- Question for HKS exhaust owners
- New AFE intake kit?
- which Grounding Kit
- Just installed the bosh infusium spark plugs!
- Perrin or Unorthodox racing pulley?
- Camcon
- howdy freinds =] i need your guys help on something
- WR New Header Pics and Website.
- Perrin Pulley install question?
- DC SPORTS Axle Back or Greddy EVO2 Exhaust?
- stainless steel wire mesh for hoses
- 86 rolla lsd in xb?
- Strup v2.0 Axleback Installed Today... My thoughts so far.
- tC Motor in an xB (NO NOT 2nd GEN)
- question on xa exhaust
- Transmission Problem...
- Whats the best intake to but in my xB????
- Short Ram Intake....Give me your opinions....
- just put on my f5 fujita sri
- GReddy SP2 or EVO2
- How to buy the YDR short ram intake?
- internals...
- What is the outter measurement of the throttle body opening?
- Problem starting lately?
- Has anyone fabbed there own exhaust?
- JGT ESPELIR Exhaust from Ebay...anyone have this?
- INSTALLED my Perrin exhaust today! Tired of evoII **PICS**
- Exhaust Gasket
- Which exhaust is the loudest one??
- Installed, GReddy, Tein, Perrin... Pics
- Intake manifold!?
- Magnaflow popping, burbling, etc?
- xb codes 22222222222222222222222222222222
- Randode short shifter - a must have
- Problem w/ Perrin Pulley - apparently
- lost the key for scion xb!!!! please help!!!
- pics of Injen dress up kit for engine??
- CA legal--Cold Air Intake or RAM Air for 2006 XB
- Need Help, Vehicle Speed Sensor...
- ok so i wana see about gettin torque back
- What kind of air intake would you recommend???
- Axle Upgrade for both xA and xB
