View Full Version : Scion xA/xB 1st-Gen Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19
  1. Steel braided lines
  2. TICK TICK SOUND WHEN SHIFTING FRM PARK
  3. How much would a new transmission and clutch (and labor) be?
  4. 06 xb reset my ec and now no start,cranks,cranks
  5. AEM cold air intake filter question.
  6. Vibration in gaspedal and grabby clutch?
  7. Power steering moaning
  8. Anyone familiar with this header?
  9. I didn't know Weapon-R finished this..
  10. what is Air Breather
  11. TRD performance clutch
  12. P0302 trouble code
  13. thinkin about a trany swap, need some help!
  14. supercharger vs turbo
  15. AE101/111 4A-G engine swap...?
  16. You've got your aftermrket filter, your SRI, your CAI, and..
  17. need opinions and suggestions
  18. Squeaky Clutch..anyone else having this?
  19. About engine oil
  20. XB drift box
  21. what other colors would you like to see???
  22. C60 Celica GTS trany xB swap
  23. What Is This OEM Connector For?
  24. question on sri
  25. OH SNAP! Top Fuel Zero1000 exhaust on xA [Pics]
  26. Fender Flares.
  27. High Flow Cat
  28. Where Are The AC Fuses on my '06 xA??? (Pics)
  29. squeeky sound from.... what?
  30. cravenspeed wants to know what you have done 2 your XB
  31. Anyone know about R1WURKS pulleys?
  32. billet aluminum lifetime oil filers
  33. motor mounts going bad?
  34. the jdm exhaust
  35. another exhaust question
  36. Engine problems need help please
  37. Issue with Strup exhaust
  38. Exhaust Axleback Sounds
  39. Axle removal??
  40. New problem need help
  41. Exhausted!!! V2.0
  42. power
  43. Anyone installed block heater for xB?
  44. Tranny oil change in XB
  45. Auto tranny shifting hard
  46. Mounts and other things
  47. my car won't shift into 4th on the highway !
  48. 125 mph!!!
  49. What size bolt needed 4 megan haeders? concern abt cell leak
  50. Dual Exhaust AxleBack ?
  51. exhaust shops
  52. AWD possibilities?
  53. First Oil Change
  54. Are the Xa and Xb power steering pumps interchangeable?
  55. Auto stuck in 4th up hill
  56. PLEASE HELP
  57. echo ecu swap
  58. Buying a USED xA.. can someone help
  59. Electric power steering pump?
  60. Engine bay paint and stuff...
  61. anyone used Royal Purple Auto Trans Fluid?
  62. Looking for some added power (Need advice)
  63. Magnaflow muffler (none kit)
  64. Where's the Power?
  65. A/C Problem..Freon Leak caused by another Hose
  66. Winterization tips for xB--
  67. Drive Shaft Bolt - Xa
  68. Best shifter mod?
  69. check eng vsc and track light stays on,lost power ????
  70. aftermarket intake pipe diameter?
  71. Xb OEM Clutch
  72. eBay headers?
  73. HONEST NOS NITROUS POWER IN AN XB and forced insuction
  74. Radiator fan not working, gurgling sound from engine
  75. OBX Short Shifter
  76. injen is2100 carb question/california legalities???
  77. Plastic intake question
  78. who knows tires?
  79. dumb body shop
  80. Any ideas?
  81. Oil Cooler.. ??
  82. Cold Air/Short Ram Intake Performance???
  83. fixing electrical connector
  84. Whats the best motor oil for xb???
  85. 8 gauge ring terminals????
  86. good performance shop?
  87. What's the name of the part on exhaust.
  88. So... bored/honed out throttle body anyone?
  89. anybody got pics of the Injen rd2105 as a short ram?
  90. Header
  91. Catalistic
  92. First gear syncro weak?
  93. I'm ready to buy a cold air intake but...
  94. SPUTTERING AFTER INSTALLING INJEN SRI
  95. VSC, Trac Off, CEL
  96. DIY: xB block heater install
  97. Torque specs on clutch and flywheel?
  98. Auto or Stick? Which is quicker?
  99. yes, another exhaust thread
  100. Short ram with throttle/body/spacer help?
  101. N/A & F/I build parts availibility.
  102. You guys want an upgraded Intake Manifold & Throttle bod
  103. LSD for XA
  104. Nytrex
  105. OEM Exhaust flanges
  106. Shortshifter question
  107. lighter crank pulley??
  108. "MAINT REQ'D"
  109. YARIS h.b. , XA , XB :same engine and manual transmission ?
  110. Over Heating and then some.......
  111. Platinum sparkplug gapping
  112. is there a spark plug cover to replace the engine cover?
  113. synthetic gear oil change : new xb : soon as 1,500 miles ?
  114. What happened to the ITB's? SEMA's over.
  115. Topping off current brake fluid with Synthetic???
  116. how much weight can you put inside the car
  117. Auto Tranny Cooler
  118. Drive belt
  119. gear oil change:o.k. to reuse gaskets for filler/drain plug?
  120. Problem with XB. Any Ideas?
  121. What's The Farthest You've Ever Coasted???
  122. Trouble codes list and what they mean?,
  123. New audio system and Batterey dies? What can i do?
  124. Vibration in Gas and Clutch Pedal
  125. Low Octane Gasoline
  126. Engine Reset without pulling battery terminal???
  127. TRD Header
  128. air filter for AEM Cold Air intake
  129. My exhasut got louder...WHY?
  130. For those who use K&N Air Filters, look at this test
  131. Clutch action seems high up the pedal?
  132. XA engine humm @75+mph....help
  133. Headers
  134. Need a new intake and...
  135. What's the best catback exhaust for XB
  136. exhaust leak
  137. motor work
  138. new xB dyno numbers
  139. where is emission inlet?
  140. // Slick aFe Intake just installed PICS \\
  141. FREE intake mod
  142. 06 xB: bad air flow meter?
  143. Anyone know how to wire wideband O2 in 2006 xa?
  144. AEM F/IC and 2006 xA
  145. adjustable clutch cable??
  146. Radiator Diffustion Panel?
  147. Has anyone else experience this.....
  148. NGK Iridium plugs and the Proper Gap?
  149. Need link help for extended warranty.
  150. TRD exhaust weight?
  151. Scion XB Rough Idle
  152. help with my o4 xA
  153. XB - catalytic converter >
  154. injen cold air intake?
  155. what causes this?
  156. Tanabe Super Medallion Hyper Axle Back
  157. Need suggestions on Intake
  158. Megan racing Headers
  159. Cold Weather shut down,...
  160. 0-60 Whats your best time?
  161. Intake, exhaust, header, pulley.. what other engine mods?
  162. Seat Height Adjustment?
  163. xA owners, we've waited long enough.... a new supercharger!
  164. rough/slow start
  165. apexi neo question
  166. Oil Diffusing Filter On Intake Replace?
  167. Headers: Ceramic Coat or Stainless Steel???
  168. Auto Trans Delay after Car Sits for awhile
  169. now heres an idea...
  170. Turbo or supercharge for an auto xa
  171. just installed Tanabe Super Medallion Hyper Axle Back on xa
  172. A/T fluid filter?
  173. A/T fluid filter?
  174. Installed Engine damper
  175. Turbo/Supercharge AT XB 05 ?
  176. REAR L.E.D. TURNS
  177. Question about TRD shifter knob
  178. Gas Mileage
  179. What is this for?
  180. XB will not start
  181. The lean code battle is over...
  182. headlights dimming
  183. Anyone looking for a AEM Battery Tie Down??
  184. maintenance light flashes when car first starts
  185. Cold Air Intake?
  186. Has anyone upgraded their coil packs?
  187. Suggestions? Squeaking when starting up and accelerating...
  188. Transmission Woes...
  189. Electronic Control Moduel?
  190. need forged rods for 1nzfe
  191. suggestions on exhaust... invida catback?
  192. fujitsubo power getter exhaust for xA
  193. Squealing serpentine under boost.
  194. Free oil changes
  195. need to order custom pistons and rods 1nz-fe
  196. Header installation gripes
  197. OIL FILTER SANDWICH ADAPTER
  198. 2007 Scion Tc 5spd Redline Question
  199. Manufacturer buyback, purchase?
  200. NGK Iridium spark plugs installed today
  201. My stock 06 xB on the dyno Video!
  202. transmission help
  203. trd lsd
  204. Revving with no power?
  205. Wheel to wheel measurements
  206. universal high flow cat?
  207. valves and valve springs for 1nzfe
  208. which intake to choose..
  209. Tranny fluid and filter change Question
  210. sparkplugs
  211. Engine swap??? 4 banger vs V8!!!!!
  212. pulstar plug = waste of money
  213. RWD V8 Scion xB
  214. SCION-PARTS.COM xB RUNS 12.97
  215. a REAL project
  216. more cooling
  217. looking for new exhaust ideas
  218. Performance upgrade question
  219. SCION XB ELECTRIC ENGINE = EBOX !!
  220. ac removal
  221. which SILENCER fit greddy evo2
  222. 06 to 04 1NZ-FE swap, any differences besides ECU?
  223. best engine damper
  224. Changing out clutch. What to change?
  225. wiseco 10:1 75.5mm forged pistons
  226. 2003 - 2005 celica 310cc fuel injectors
  227. 1nzfe valve and valve spring specs
  228. Likes and Dislikes of the Xa
  229. Matrix/Celica 6speed tranny in xa/xb?
  230. Header Question?
  231. 1nz-fe connecting rods specs
  232. E-Bay Headers
  233. Battery holds hot out of the oven
  234. perrin fuel rail with tc injectors
  235. Performance stuff, TB spacer, header, head work, cat back ex
  236. xB Spark Plugs
  237. Camshaft Actuator Stuck Open (variable timing system)
  238. injen RD2105 filter size
  239. performance chips
  240. tear down and build up (vids pg2)
  241. Beefing up my 1nz-fe project started
  242. Kelvar belts
  243. drive belt question
  244. Warning light help PLEASE!
  245. ingalls damper question
  246. OBD-II Error Code help
  247. Clean oil - yellow dipstick. Can't read level
  248. Denso Injector Help
  249. custom cams and valves: is it worth the $$$?
  250. vibration @75?
