- New owner needs advice - Typical tune up issues with the XB
- Best Tuner in Socal?
- magnaflow full catback exhaust system
- injen intake mounts?
- Engine statered bucking yesterday, suggestions?
- horsepower gains?
- vehicle speed sensor question / location
- caliper noise?
- Spare motor packaging, suggestions?
- please help asap
- 9400mi xB - Needs New Rear Oil Seal!
- exhaust manifold specs
- CAI Vs. SR
- Non-threaded header-what size are the bolts????
- Auto Transmission Drain Hole? help..
- Whats the best header for the 1st gen xb?
- xb clutch
- 2006 XB - Need details on check and add auto trans fluid
- Maybe a stupid question
- Exhaust help.
- What SHORT SHIFTER IS THE BEST
- Question about the injen rd2105 filter
- TRD Intake warranty issue, need help
- Power steeing belt replacement; how to?
- GI...billet battery hold
- Lazy steering and Hard to brake???
- Consistent clatter during acceleration on 04 Xb
- Does anybody have a transmission fluid cooler?
- Odd noises coming from my xB
- HP 103.63, TQ 104.18
- CAI Install help on '06 xB
- CAI Intake/Exhaust questions...
- Put on my K&N Filter this past week......
- Royal Purple Max Gear
- Read my Plugs Please (pics*)
- 1nz-fe flywheel bolts
- Installed: Fidanza Wheel, Spec 2 and AP line...
- Transmission builds?
- Speedometer Quit 05xB
- Nitrous?
- 06 Xa change to 6 speed?
- Air filter
- YDR intake?
- need help my xb the engine was choking and shaking
- Lightest Lightweight Crank Pulley
- Distance to exhaust valve?
- poor mpg with k&n typhoon
- Perrin Pulley Discontinued
- Odd Grinding type sound 05 xb 66,000 miles
- OEM Air Filter to K&N Filter DIY w/Pics
- First time on my own
- This thing has got to get quicker.
- fugita f5 ?s
- coil pack...
- Last word on tranny oil please?
- Weapon-R, worth the price? need feedback on several products
- Bosch spark plugs
- oil question
- Solvent for cleaning MAF
- 2nd gear, 4th gear, r gear All gone~~??~~???
- Apex WS2 Exhaust System for xB
- greddy tic silencer...
- Weird stalling problem...
- 5spd trans drain gasket part #?
- injectors throwing codes..in need of some assistance....
- Possible Future Battery Leak???
- !!!!!!!!!!!HELP PLEASE!!!!!!!!!!!STUTTERING AT 3k RPMS
- Throtle body spacer.
- Should I Dual?
- Cold air intake concern/ question
- AFE Stage 2 Intake
- TRD Quickshifter Boot Issue
- how do you remove the stock exhaust
- Ground Wire Kit Question???
- Reading error codes w/o scangauge
- Big mileage increae
- any tranismission gooroos?
- Can anyone recomend this exhaust
- how to remove the silencer
- CAI or SRI
- Alternator adjustment?
- Antifreeze question
- belt squeal, and some other woes, please help !
- Xb 2zz motor and 6sp swap
- Best Aftermarket Clutch for xA
- COLD AIR INTAKE SYSTEM FOR SCION XB 06"
- Odd Rattling Sound when engine cool
- Engine teardown and inspection, any tips?
- Question about emissions (CA)
- Pic of OEM/stock xA exhaust and piping?
- Any good places to pick up an exhaust?
- Bogging down when I idel?
- Emanage Piggyback with Greddy O2 Sensor Adaptor.
- 2004 xB - Runs like crap!
- OBX throttle body spacers?
- mufflers
- How do I clean intake valve deposits?
- Rough Idle
- stock parts
- spark plugs
- where to purchase RS-Type shifter inexpensively?
- 06 xa condenser and radiator fit xb?
- Beware Walmart FRAM Air Filters for xB
- Nastos squeeze box
- Excessive Clutch Noise
- GReddy xB Header (with pictures)
- which exhaust system is best?
- Rattle coming from front end
- any muffler/exhaust that's quieter than stock?
- auto transmission performance
- Air filters
- Anyone know how to get Injen to respond to emails?
- just installed an echo ecu...
- Xb/Xa Cylinder Head Pics
- uh oh problem!
- exhaust for scion xa?
- Just got a Scan Gauge, I got some Questions
- My xB is quick, but not fast....I cured that.
- Installed Intake, Header, Exhaust. With video links
- LSD's for the XB/XA!
- ac issue 06 xb
- need some info on this header
- Need help on convincing my dad to let me get CAI
- Warrenty Questions on an 06 xB (Intake)
- Shifter & Shifter Base Bushings?
- Need help with ignition problem....
- Rough Shifts
- Got my Fujita SR Today (Now Updated With Pics!)
- magnaflow cat back fit with after market axle back for xa
- Weapon-R Secret Weapon versus F5, also 4-2-1 Header Dyno....
- cheap=best axle back exhaust
- electric fan + a/c = ???
- High-performance, oiled air filter
- CAI really works!!
- What Should I Do Next?
- 05' PCV Valve
- 26/28 mpg? WTF!...help?!
- koyo radiator help
- headers for 06 xB
- safe on lucus transission oil
- GXR1000 XB (SARTUKI)/Possibly my next project(saving now!!!)
- Crazy idea of the day....
- manifold donut gasket
- xB engine is Spread Bore or Square Bore?
- 1st Gen XB AC Power
- Weapon R Header with Heatshield
- K&N typhoon intake and TWM shortshifters are awesome FS!
- All of the people with headers and full exhaust
- Transmission Flushed
- CB Radio and PO351 code
- Does anyone know the manufacturer's spec for EGT for xb?
- HOW TO: manual tranny fluid change
- XB Tranny Removal (Crossmember? Engine Hooks?)
- Change transmission from manual to automatic ?
- Competition Clutch Stage 1 & 2 in stock!
- 1nz-fe motor removal/installation pics and/or instructions
- replacing intake.....
- speculation about untuned scions
- Newbie wants more power and speed, help please!
- Warranty syncro problems
- xa air diversion panel
- new exhaust came today. 56k-100k goodluck.
- xB OBX Billet Throttle Body
- --- Won't Start! Alternator Apparently Over Charging---
- RS2 Exhaust Question -- OBX Exhaust Tip???
- 1ND-TV Diesel/Hydrogen-powered xB1
- ok i'm fed up, need some opinions for exhaust!
- Buyers Guide Header(get it started)
- Clutch question
- Low idle (I think), any suggestions?
- overheating?
- What constitutes emissions control systems??
- Fidanza Clutch Kits?
- loss of power/ fuel economy after jumpstarting a Buick
- Speedo / Odometer Variation on xB 1 (stock tires/wheels)
- Power Lag Off-Idle
- scion xA. turbo, surpercharged or?
- xA exhaust question
- guess who's retarded?
- HP numbers experiment.
- HOW LONG OF BREAK IN ON AFTERMARKT CLUTCH
- Lightened (accessory ) Pulleys
- Which intake is CARB legal for 06 xB in California?
- Rattle at low RPM under load
- Shredded Drivebelt
- High Flow Cat = WTF?
- nitrous
- Espelir JGT500 axle back. sound clip
- Pulley options
- Help, Help...Weird Engine Noise from 3000 revs - 4000 revs
- What should I get next for horsepower and CARB Legality?
- 4 wheel drive
- Trouble Codes
- HKS Intake?
- Scion xB engine work
- REPLACING AIR FILTER ON YOUR CAI
- 05 xb injector upgrade and ECU questions.....Nooob
- How often to change the 5-speed tranny fluid?
- Having issues with my box. Help!
- noob exhaust question, for a noob just like me
- VCS-Trac OFF- Check Engine Light ON
- I'm torn on whether to buy this or not
- Nosie Belts
- Perrin Code???
- crank/rod knock?
- Need Help Bad PLS!!!! all who can help pls do. 05' xB
- Installed my tsudo exhaust...
- Pulstar "Pulse" Plugs
- Is it possible at all??
- Need help asap
- does weapon r cold air shield work?
- HELP!!!stock intake tube mounts?
- How do you change your coils to spark plug wires?
- megan headers leakage
- whistling noise 55-65 mph
- Fitch Fuel Catalysts-- Any noticable differences in MPG?
- Got My New Top Fuel Intake In and On The Car (Pics Up!)
- Exhaust: xB vs tC
- Used Muffler Disposal / Recycling
- Clutch or Transmission problem?
- 1zz throttle body swap, work in progress (with pics)
- A'PEXi Power Air Intake Kit
- SCIONLIFE EXCLUSIVE
- ALL FLUIDS CHANGE HELP!!!
- AEM cold ait intake
- DIY: Changing your own oil
- this might be a dumb question but reducing weight inside
- Suggestions on painting the block?
- Shhhhhh Noise durring accell about 2000k rpms
- how hot is to hot?
- Really need some help with my header install. Question!!!
- NST CRANK PULLEY & NST OVERDRIVE ALTERNATOR PULLEY
- Gude News!
- Air filters.........
- Weird starting problem
- Muffler Flange
- pullie arangement for super charger
- Cluth issues........so it seems?
- Goodbye Mobil 1 "Synthetic"... HELLO ROYAL PURPLE
- my brand new custom catback exhaust now w/video/sound clip
- just ordered the perrin axle back
- Yaris Intake Manifold
- Valve cover studs
- Alternator grinding.
- really quick question about header
- compression test how to? doing this right now..
- doing a tune up
- Flex Fuel Ethanol Conversion Kit
- What guyz think about under drive pulley?
- fuel injector(S) ? problem.
