View Full Version : Scion xA/xB 1st-Gen Drivetrain & Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19
  1. Xb rough idle question
  2. ughhh.. exhaust discontinued..
  3. Fuel Heater? / Intake Manifold Heater?
  4. 05 Xb ECU Replacement?
  5. supercharger vs turbocharger
  6. Transmission problem?
  7. The ULITIMATE MOD.... The eBox :-)
  8. the strup v2 is ON!
  9. random jerkiness/bogging and VSC + TRAC OFF lights
  10. Power mods for 1st gen. xb that won't void warranty
  11. E-Brake Light Comes On At High RPMs
  12. would the greddy header fit xa's??
  13. New Exhaust For The Box!!!
  14. is this header good?
  15. New Axel Back or Custom Midpipe?
  16. Fujita Filter
  17. bleeding clutch line after SS line install
  18. need help. strange noise, thinking it maybe my clutch.
  19. cold clutch studdering
  20. Spark plugs and Spark Plug Gap
  21. Question on resonator delete???
  22. looking to buy stock exhuast
  23. Needs HELP... Xb won't start.....IT tries but no luck thankz
  24. First power mod for my xB?
  25. Replacing clutch in 05 xB
  26. XB 2004 DYNO TUNED WITH APEXi
  27. 05 Xb, muffler/exhaust pipe making horrible noise
  28. Perrin pulley=belt squeak?
  29. skipping bad! help!
  30. DC header question..... HELP
  31. head or crank swap
  32. Gude Dyno Results!
  33. Ram Air setup? Hood + Intake
  34. K & N filter wont fit 06?
  35. Greddy Emanage tune question.
  36. VVTi Intake Cam Gear Replacement questions
  37. just purchased the perrin short ram.
  38. optima yellow top?
  39. Interest on Intake Manifold for the 1st gen xB and xA
  40. ReBirth Weapon-R intake Manifold PRE SALE NOW!
  41. aem twinfire edit help
  42. Writeup for xB brake job?
  43. Scion xB Tune Up
  44. melted shifter cable/linkage
  45. K&N Intake - 8hp on stock Scion xB
  46. p0012 covered by 100,000 plan?
  47. video of perrin intake and strup exhaust
  48. I had a bad water pump & here is why
  49. wiseco piston spec sheet for 9:1 and 10:1 compression
  50. reset light
  51. ackward noise when pressing clutch pedal?
  52. Engine will not crank PLS HELP! Scion Xa 2005
  53. Blitz vs TRD exhaust ?
  54. What do you guys think? +42hp???
  55. Pulstar pulse plugs
  56. squealy alternator
  57. eBay short shifter
  58. high shifting points on A.T.
  59. Engine Cuts Off while running?
  60. GOING TO BUY A NEW CLUTCH SUGGESTIONS
  61. 2006 Scion XA - need to replace blown engine
  62. 2006 Scion XA - need to replace blown engine
  63. another code throwing thread
  64. RPM at 60 with a five speed manual
  65. '04 xB 1st Gen and excessive engine oil use
  66. EXEDY STAGE 1 CLUTCH KIT
  67. Humming buzzing sound from engine
  68. Need A/FR Gauge help!
  69. Best way to cut the fuel
  70. Fuel system depressurizing but with a twist
  71. Buddy Club Voltage Stabilizer & Grounding Kit
  72. Sudden Drop in MPG..... 2005xb 56k miles
  73. Touqe Damper will it take away some of the back lash?
  74. xB 2006 rough idle, clattering, STRONG gas smell
  75. OBX Exhaist
  76. P0171 - updated, new problems, need help!
  77. HHHEELLPP!!! TOO MUCH OIL!
  78. Tanabe Concept g Exhaust feels NIIICCEEE!
  79. New clutch suggestions
  80. Xb shakes too much at times
  81. HELP!(again) Studder/hesitate/choking feeling from car
  82. Header Question....
  83. TRD short shifter
  84. For those of you with the DC Sports Header
  85. Exhaust Tip
  86. Stock intake - K&N filter and mod idea - opinions?
  87. Stock intake mounting bolts - sizes/lengths?
  88. bad water pump
  89. clutch flywheel combination
  90. Oil change, changed car?
  91. ecu open loop 2006 xa manual
  92. Do I have a coolant issue?
  93. Help with Perrin Intake
  94. What is this part?
  95. Weapon-R Intake Manifold Poll!
  96. HELP roll pin sheared and the dealership is screwing me over
  97. N/A horsepower help
  98. greddy sp2 exhaust
  99. manual transmission
  100. What do you guys think of Competition Clutch?
  101. What would you do first?
  102. OEM shifter bushing part numbers
  103. NST Feeler Thread ... Now turned Group Buy Thread!
  104. OBX 4-2-1 header
  105. Loud Exhaust Help!
  106. Perrin fuel rail removal? Testing fuel pressure?
  107. 06 xa swap for a 2005 toyota corolla xrs 2ZZ-GE
  108. Shifter bushing install question
  109. Look whats under my hood...
  110. New Weapon-R Neo coating....
  111. Exhaust
  112. 06 xB RPM Idling and Power Problem
  113. HKS Intake
  114. Overheating after water pump/belt change
  115. Looking at upgrading a few things...
  116. NEED HELP FINDING A PART ASAP!!!!
  117. Is there a dude with the lic plate "LUNABOY" on he
  118. DME Header, DME Exhaust, Anyone?
  119. DeLabel battery & some SPECS DIE HARD OPTIMA
  120. Bad Valve, DIY Repair of it... Ideas?
  121. TRD exhaust has scuffed sides on muffler. Normal?
  122. strup exhaust silencer
  123. Weapon R manifold results thread
  124. who has NGK G-Power Spark Plugs?
  125. throttle body
  126. i/h/e what combo do you have?
  127. Injectors tapping
  128. No codes- What is the truth? Yes, Ive searched the forums.
  129. Aftermarket Drive Axles?
  130. Gude Performance Cylinder Head Package for the Scion xA / xB
  131. Running lean. suggestions?
  132. smallest bigger?
  133. Need help finding pistons
  134. 1/4 mile time, HP ??
  135. strup axle back installed today with tons of clips
  136. Actual bolt on dyno results?
  137. RALCO PULLY
  138. After Market Header DIY POSSIBLE??
  139. Fuel Pressure
  140. feels like my 5spd is on downers...
  141. auto to 5spd?
  142. TRD quick shifter
  143. 1st gen scion xb cat-back
  144. You wont believe my warranty story
  145. any gearing options 4k rpm going 80 on the fwy is killing me
  146. used engine prices
  147. Tranny Fluid on XB
  148. Header?
  149. Bend Over and take it like a man..........
  150. Reservoir covers
  151. quick intake question,
  152. It's peanut butter jelly time!
  153. how to properly store an engine for several years
  154. AEM ebay outlet store
  155. TRD Helical Diff for sale
  156. Scion XB Weapon R 4-2-1 Header NEW on ebay! $150!
  157. Anybody tried/using one of these?
  158. Fuel injectors Good or Bad idea
  159. My Weapon R Intake Manifold Pics
  160. Exhaust
  161. speedometer recalibration
  162. Someone Please help!! P0500 code, can't figure it out!
  163. 1NZ-FE sleeve wall thickness
  164. Perrin Parts?
  165. Ceramic or Stainless
  166. xd engine to xb 1st gen swap
  167. rpm's went down to 450, whats going on?
  168. loss of torque
  169. fuel filler pipe
  170. pinging/ rough idle only when car is stopped
  171. Need help on a flexplate problem.
  172. Sounds like my clutch is falling a part! O_O
  173. Drive axle replacement
  174. HEAD GASKET
  175. Weapon-R XB manifold limited edition Neo-Titanium TReatment!
  176. Fuel Rail Pressure
  177. Noise when shifting into 1st from N at a dead stop.
  178. Any one have the DC Sports Headers for the xb?
  179. Which to choose to clear o2 sensor code?
  180. Order of power mods to do
  181. Automatic xB with Throttle Body Spacer???????
  182. throttle body coolant line bypass - whats up?
  183. Is It Possible?
  184. 2AZFE head swap
  185. VVTI controller?
  186. is it okay to run Tc plugs on Xa
  187. Oxygen Sensor (0438) code comes on when raining
  188. Cylinder 3 & 4 Misfire Codes
  189. Catch Can Install
  190. screeching noise some help please
  191. fujita CAI
  192. 05' Xa Increased Throttle Response
  193. xB Crew's WR Intake Manifold Installed
  194. JVTR Radiator does anybody have one of these on there Box?
  195. Anybody in SoCal have a stock muffler???
  196. wire tucking
  197. OBX Header
  198. fifth gear grind
  199. CV Boot replacement
  200. Engine Removal
  201. Spark Plug Gap and ING Timing
  202. eBay xB header, what bolts should I buy to install with?
  203. Alternator Issue?
  204. CEL on, codes pulled, need help
  205. Scion XA check engine light codes P0441 P0442 P0446
  206. re-power 2006 XA
  207. I want a REAL answer... Header Install... What bolts locally
  208. Beware of cold air intakes
  209. Header install... Heat concerns?
  210. putting in a set of gauges 06 xb
  211. is a xB Manual Trans. different from a Manual tC trans.
  212. xB exhaust fit an xA?
  213. eBay header review. No pictures but some insight.
  214. How much AT fluid for a change?
  215. AEM cold air intake for '05 xA
  216. Does Autozone sell Denso plugs under the Autolite namebrand?
  217. Give me your opinion?
  218. Free rad from Mishimoto
  219. Anyone running a clutchmasters stage 4?
  220. Did DC Sports go out of business?
  221. MAF value range
  222. Rostra cruise control install questions
  223. engine noise at 4500k RPM's???
  224. What is this?
  225. Perrin xB exhaust
  226. energy suspension motor mount inserts?
  227. Turbine powered XB
  228. A/C Cooling. Trying to get colder
  229. Clutch: Hydro reinstall how hard is it? can it be done solo?
  230. 2006 XB Radiator Leak - 56K miles.
  231. FAZE GAUGES oil temp, water temp, boost, oil pressure, volt
  232. 2nd transaxle replacement after 60k!?!?
  233. M2 header on stock muffler, how loud?
  234. Two problems
  235. need help with clutchmasters stage 4 install
  236. shorty arm spark plug??
  237. foam v/s cotton....discuss
  238. yet another engine swap thread that has a lotta research
  239. squeaking from engine in drive and reverse
  240. Cherry Bomb Glasspack
  241. stock RESONATOR length????
  242. New pics of my boosted xA!
  243. What filter is it?
  244. Diffrence between Cold Air and Short Ram?
  245. 2004 XB tune-up how to
  246. MSD ignition
  247. release series cold air intakes
  248. New clutch problems?
  249. - Vibration in Gas and Cluth Pedal
  250. E85 tune with E-manage?
