- Quick Question
- 6 speed M trans
- engine internals work, pistons rods port and polished head
- Any pic of TRD muffler from the back?
- Fuel rail bolt size?
- Anyone else have this problem?
- Tune Up Recomendations?
- Iraggi Alternator
- Cheap Thorley Cat backs on ebay-I got one for $180
- NA power with a 2.7
- watch out for hidden shipping charges
- clutch noise
- Intake Manifold
- Max power on gen1 auto tranny?
- boosting the XB!! wha't have you done to it!!!to get the Wow
- Perrin Xa/Xb1 radiator hoses
- The Power List
- TRD Short Throw Shifter
- Clutch Replacement help.
- Car won't shift past 2nd gear (automatic)
- Custom Intake. $10 bucks...With Pics!
- Blitz Supercharger
- zomg look at this ebay header...unreal
- What is missing??????
- MPG's on my 06 scion XB
- What is this part called ?
- XB maintenance schedule
- Clutch Problems!
- Where can I find a perrin fuel rail?
- Shifter Assembly
- HELP! DIY for Lightweight Crank Pulley and Belts?
- Long Overdue, but performance is finally here!
- Valve timing/ A Lemon?
- Air Conditioner belt squealing
- JDM 1NZ-FE turbo Vitz RS rated at 161HP
- Water Pump bad at 45,000 miles
- TRANSMISSION drain PLUG size?
- Espilar Jgt500 ok to use with turbo?
- Aem bypass Valve BROKE!
- 1nzfe and 4age...
- Hesitation from stop.
- Amsoil/Injen Dry intake filter
- For people who want a low exhaust sound...
- intake install....a few problems
- '06 xb grinding problem, warranty question!
- '05 xB Transmission Mount
- Battery Tie Downs ?
- Knock (Ping) Sensor
- Block Coolant Drain
- Xa 6sp?
- Dead Scion by the Road--Mine
- my auto transmission, warranty story
- My cluster's lit up like an Xmas tree...
- What Kind of Engine Should I Get?
- Homemade Intake tube....Honest Opinions Needed
- New Owner
- RPM Needle Going Backwards?
- Replacement cruise control battery
- Misaligned Power Steering Pulley
- Replacement filter injen short ram
- Headers improved gas mileage
- TSB
- Cam shaft gear?
- 2005 xb manifold donut gasket life
- will it fit?
- Very Loud & Annoying Squeal
- Rattling under the hood when hot
- Upgrading your intake
- Flywheel bolt torque spec?
- O.E. Air Filter
- Anyone have this problem or have any ideas?
- 1nzfe internals
- Squeal when I turn on A/C?..
- Sluggish engine, low idle, and gurgling noise on xB
- In true FAIL, INC form-You got oil in my antifreeze, no, you got antifreeze in my oil
- Will this work
- GI: Custom Cams
- need some advice with exhaust
- Hard idle and Rev Limitor at 3000RPM
- Chirp with Throttle Blip
- alternator problems ???
- Anyone out there have had or heard of this issue????
- Scanguage 2: Why would my TPS read 11 at idle?
- voltage stabalizers ?
- tune up
- greddy header for XA??
- Torque LOSS!
- Ingalls stiffy woes....
- anyone modify and AEM to fit with fog lights?
- More TRAC VSC and engine lights :(
- xB Water Pump Replacement
- OBX Carbon Engine Cover
- Belts
- Coil Pack problem
- Service and Maitenance Schedule?
- Fastest naturally aspirated gen1 xB
- Sun Auto Scion
- my 2006 xA and engine noise in a 2008 Yaris
- Pls critique my noob performance mods.
- alternator belt.....
- Any ideas?
- Setting base/hard idle
- Obx Catback exhaust or Greddy Evo2 axelback?
- Horrible grind..
- Engine swap
- What is the quietest axle / cat back?
- What's the schedule on changing spark plugs?
- belt noise need help........
- Engine code 12. retard timing
- CEL Code P0020
- Torque Dampers are they worth it?
- CLUTCH RELATED QUESTIONS... 2005 xA
- smelly box
- xa limiter???
- camshaft position actuator circut removal
- Camcon vs AEM FIC
- EVAP codes/ fixed at dealer/ reimbursed by toyota
- Where to buy 1.75" V-band clamps?
- Axxtion STS SoCal Test Fit for FREE
- The Real 2ZZGE Injector capacity
- ** EDIT **
- Auto to manual transmission. What is required?
- brake questions
- For anyone who has strup headers
- Help needed! CEL P0505
- Power Steering Pulley/Pump/Belt Problems
- Just got a TRD exhaust for my XA FREE!! Need some help.
- indexing spark plugs
- Cleaning Intake ?
- Perrin fuel rail......
- Engine replacement question
- Brake light on dashboard
- Best intake for the xA
- Passenger front and back floors soaked
- Which echo ecu to buy
- Early O2 sensor failure
- Axxtion sts review
- Mid Pipe xB
- Valve Clearance check
- Head rebuild, any tips?
- zex safe shot
- battery or alternator
- excessive exhaust noise
- camshaft regrind
- 1-2 zz fit in xb Yes it does
- Vibration
- XB Check Engine Light, VSC, TRAC OFF and the Cat code
- Humming Sound
- Jet Performance Module on an xA???
- same charcoal filter problem, different girl....
- looking for headers
- nitrous
- Auto-Manual conversion
- Checking Auto Trans Fluid
- greddy turbo kit
- Need help: Removing transmission control Clips
- [Help] Changing Differential Fluid
- Gen1 xB Manual Trans swap with Echo?
- "Universal" Catalytic Converter?
- non-mechanical vibration at 2000 rpm
- tuning
- Need help identifying part
- switched from redline MT-90 to Eneos gear oil
- removing muffler?
- Scion XA Fuel Filter Help!!!
- Engine/auto trans install problem
- Oil Pressure Gauge
- So, here is my story with a header install...
- Where's the Crankshaft Position Sensor located?
- Are pulleys effective for automatic xBs?
- MSD DIS-4 or 2-step launch control
- does an Injen IS2100 need a new filter?
- cold weather battery drain?
- xB automatic trouble shifting into 5th gear
- Energy Suspension Motor Mounts
- HOOD BOLT SIZE?
- HOOD BOLT SIZE?
- Knocking noise from engine bay?
- asap help: leaking transmission fluid from passenger axle
- Clutch judder on wet days
- Engine Steaming
- Stage 2 clutch
- Replacing Injen Short Ram Filter
- xB idles fine, but stalls after giving it gas
- AEM cold air intake for xb
- Multiple idiot lights on.
- idling issues, need help!
- Anyone know why my car is making this weird noise?
- Borla vs. TRD
- Clutch replacement...trusted shop in San Diego
- 05 xa tranny
- Looking for a 07 tc MAF sensor
- dealer says 'its normal' to have to crank car couple times for starting..
- Couple noises, issues, any ideas?
- Lost power somehow
- PTUNING getting deep into xa/xb...
- Need Oil Filter Adapter for xa/xb
- Another P0500 thread please give me your input
- Opinions on the Aem F/IC
- Injen short ram intake help
- DIY: Auto Transmission Drain and Fill (1st gen xB)
- Power programmer?
- Do they make a Haynes repair manual for 1st gen xB?
- Nice throttle body spacer on ebay
- blitz sus intake installed today
- Put my JDM bB manifold on, along with reinstalling the rest of my goodies
- ** EDIT **
- oil leak (help)
- xA A/C Issues
- tubo toyotas turbo kit
- Custom Exhaut
- Please Help, Manual Transmision Fluid Change...
- Lets talk ITB
- Would anyone know if
- what brand is the trd exhaust ?
- Short ram/CA intake
- AFE Stage 2 Cold Air Intake
- Low coolant light
- Please lock/delete
- I just installed a transmission cooler in my xA
- What Happened?
- New here...questions..
- Anybody bypass heater core?
- Exhaust Help
- QQ: Injen IS2100
- Keyless remote and the horn??
- Need brake pads soon....
- Steering Wheel Shakes when turning L then straight and fixes turning R?
- ECU for 1st Gen
- Intake Question
- CEL "Small evap leak"
- No Start issue but have fuel and spark
- XA TO XB guage question
- cai and exhaust
- HELP: Vsc, Trac cont., Engine check----
- 180,000 Miles AutoTran Oil/Filter Change
- 100+k miles and beyond.
- Down Shifting
- Transmission flush and fill.
- Changing 2nd O2 sensor
- Looking to give my xB a little more power
- Camshaft position sensor questions!
- Clutch Decision Help
- xB is a possible buy for me
- Whats our LSD options?
- front wheel bearings
- anyone have an emanage blue n/a tune?
- Checking Valve Clearance(s)
- Idle air control problem
- Where 2 Buy O2 Sensor @ a good price.
