- New Blitz ehaust on Ebay right now !!CHEAP!!
- CV Joints or Axles?
- squicking noise when turning LEFT
- ( Help) theres no way i paying the stealership $1200 to replace a cat
- please help scion xa power loss
- Alternator/Electrical Problems...long story, need help!
- Motor Swap 1.5L to 1.8L possible?
- SLR motorsports PERFORMANCE CHIP
- Brake pedal drops
- Pressure in crankcase?
- Engine Code query
- MPG's
- Anyone paint their dipsticks???
- Engine build RANT!
- Ingen CARB legal ?
- Help with a transmission problem? Please?
- Exhaust Leak or..?
- new warning light help
- K&N Intake for scion xB
- Performance chip
- HELP! - High Idle
- ** EDIT **
- Need Help Finding Catalytic Converter 2004 Scion xB
- need help scion Xa, wont move momentarily
- adjust p/s belt
- abs vsc trac off no check engine
- abs vsc trac off no checkengine
- Echo engine into xB??
- Heard a knock
- P0012 - could it be OCV and not cam?
- Apexi S-AFC...
- 2005 XB a/c clutch and compressor testing
- Do I need to worry about the blue temp warning light?
- xB belt replacement problems need help.
- car shudders under acceleration. :(
- How to remove stock exhaust off Scion xA?
- Auto Transmission Change Help
- What is the best header for the money...
- 60,000 Mile Maintenance
- A/c compressor/fan cycling off and on
- 2006 xA with a 35 shot dry dyno results
- Just curious
- 05 xb with P0012 - fix it or not?
- Leaking Radiator on an XB
- need help please.......
- Oil pressure ports
- XA Air Conditioner won't turn off
- Quick Thermostat question 2005 XB
- 2005 xA vs. 2008 Yaris Engine Transmission Swap questions
- Starter Issue
- cleaning engine question
- Camshaft Oil sensor for vvti...Me needs one!
- 05 XB wierd noise
- fuel injectors keep clogging
- I have a funky exhaust smell...
- Have an idea wanna run it by everyone(btw new to forum)
- Converting a column mounted shifter to a floor mounted
- Is this a Common Issue or just me(i put it in the wrong section)
- dealer manual transmission swap
- 05 XB Cold Air Intake Filter: How do I get to it?
- My Box Is Vibrating :( Help!
- Strange sound from up front
- bad #4 injector 06 xb
- Possible lemon :(
- Catalytic converter exchange from Tercel to XB.???. possible?????
- exhaust leak
- rolling road
- 120k on my car, what belts need to be replaced?
- clutch problem?
- transmission temperature gauge.
- toaster is toast
- Supercharge
- Scion turned off & wont start VCS, check engine light,trac off light came on
- scion xa has oil in my air filter?
- Transmission bad?
- Head rebuilt, now excessive valve noise
- HELP! Coolant system flushed and replaced with....
- v8 engine swap/ RWD under construction
- my v8 swap....
- Shift cable
- my car is running colder then mornal
- new CAI, boggs bad only in 1st?
- Does the 1NZ-FE have automatic engine shut down with high temperature or low oil?
- Xb electrical strange behavior
- Need referral to a good clutch replacement shop or at home mechanic
- Blitz supercharger belt Help!!
- Jumped Time???
- Engine/tranny revs harder? Lower mpg
- App. cost to replace engine?
- just want my box to go faster
- What to replace stock clutch with and who should do the work?
- transmission removal
- trans locked up
- the dreaded vsc/trac off/check engine light.
- intake hissing sound?
- Xb just doesn't start like it used to??
- Code P0511
- Overdrive temperature lockout.
- Check eninge, VSC, and Trac Off light are all on, any ideas?
- spark plug removal
- Dropped Bolt Into Engine
- idle problem
- Ultrasonic Injector cleaning
- help have code po172
- Please help! ABS + Charging + Check engine lighs on!
- XB Automatic 1/4 Mile Times Thread
- Options with the AEM 'dealer' CAI
- 60k miles on the XA, what needs work?
- dinghy towing my XA
- Still having running Problems, code P0511
- Bigger Oil Filter?
- replacement AEM filter ruined by dealer
- 100K so what about a new engine?
- Intake noise
- Mass Airflow Sensor getting too much air ?!?!?
- 1NZ-FE engine specification and operation manual
- catback exhaust?
- swapping a 1NZFE into a 1976 Mini
- 1st - 2nd Grind. Gearbox Noes! GM synchromesh helps?
- Diagnose These Plugs
- Carnage
- Celica headers?
- knock sensor problom
- intake question
- Injen IS2100 SRI with no Defuser - Safe?
- Engine revs up while in park. Any suggestions?
- Power Steering Vanished
- Fujita ram intake upgrade-Done.. but now I have rattles
- Maintainance Indicator ?
- Over-rev
- 04 xb wont start
- Header & Exhaust Suggestions.
- upgraded my electric fan today on a budget
- MPG DROPPING.... :(
- Axxtion Short Throw Shifter Beware
- Thermostat
- Optima Yellowtop in xA????
- xA Cat/Axel back + tuner parts
- Engine oil question
- HELP - Strange Power Loss
- Getting car out of emergency mode?
- Auto tC- Turbo?
- A/C not working need help
- Engine air filter, does anyone have a good non-OEM recommendation?
- Brake bleeding with ABS
- 3SGTE
- Mixed 10w-30 and 15w40, will I be ok?
- NX install RPM limit?
- Check Engine
- Replacing 2004 xB engine
- Just bought a Scion xA, need to make sure its in tip shape!
- Have Repair Manual still ??
- power steering belt flips over ??? need help
- Valve spring compressor tool
- xb overheated
- Exhaust for my XA
- Gear Oil Refill Plug broken and stripped and other sh*% :(
- Exhaust moves & rubs rear gound effects
- Engine braking effect on fuel economy?
- XB New Battery and Oil Change Reminder - settle argument please!
- Replacing 2006 xB transmission
- 2004 xB misfire and low compression
- 2006 XB suffers from detonation at 1600 to 1900 RPM's
- Read a lot but don't know what to do !
- xB Auto to Manual conversion, parts needed?
- poor gas milage '04 xA 5- speed
- 2006 xA won't start
- Hydro-lock ?
- Thunk !?
- Resonator Removal ??
- When you have a cheap muffler and a drill
- 3 Lights came on !! HELP !!
- What part is this....
- 05 XA 70K
- Axel back pipe broke - go without muffler?
- Cylinder Order
- New
- BTU rating?
- Spark Plug Gap 05 xa 1.5L
- 2004 xB vibration?
- Speed Element EVO2 copy exhaust - run for your life.
- New Pulleys
- Manual Transmission Fluid Change
- my car won't start at all
- car starts and won't let me actually drive it
- Clutch adjust ?
- Mr. Cruise Cruise Control ?
- Question about misfire cylinder 2
- shifter cables
- xB Manual Transmission Grinding
- ebay exhaust
- DIY:Fix for P0442
- Driver door power lock does not work
- EBC Redstuff - tons of dust...
- Vibration above 70mph
- New to ScionLife.com
- Injen's xA/xB intake system
- Scion xA ULTIMATE Short Shifter KIT --- TWM Performance Short Shifters
- Exhaust leak
- Rattle at low speed ?? Xa 05
- electric fan not working
- Check Engine Issue (please help)
- Exhaust Leak
- Radiator Removal 05 xB Auto
- FWD: does one tire consistently wear faster than the other?
- Spark Plug change, help!
- auto trans
- what do you think this noise is...(video included)
- Exhaust leak
- First gear locked out down as low as 4 mph, is this normal?
- transaxle interchage
- Info on thermostats for anybody interested...
- DC ram Air
- Mind Boggler
- What are standard increase HP/performance in my XA?
- Blitz supercharger should I for the price?
- Code P0420
- New catback
- TWM Performance 10% Discount Code --- USE IT BEFORE IT'S GONE!
- I'm about to replace the clutch...
- Automatic shifter conversion completed
- 2ZZ-GE swap
- Good swap?
- 2010 XB problems with rodents under hood
- 2006 scion xb rough idle??? HELP!
- Transaxle vs Transmission Fluid
- Clutch replacement
- Lost power to instrument panel fuse box under dash
- Bushing Kits???
- Chronic Ignition Coil Failures/Problems - Almost Crashed
- cel code P0505 and P0511
- NGK or Denso O2 sensor
- Rattling Noise from Under Hood
- How to replace the serpentine belt on the 2006 xa?
- Damaged transmission part - what is it?
- manifold leaks
- 2005 xb wont hold charge..help?!?!
- Motor Mounts
- 2006 xa clutch replacement
- all warning lights on
- xB1 ECU swap/chip tuning
- took me 20 seconds to start my car O_O
- 2004 Xb didn't want to start Thursday
- Spark plug change fixes vibration issue
- Misfire cylinder 2, coilpack or spark plug?
- Where is the Engine Coolant Temp Sensor on 06 xA?
- Spark Plug Suggestions?!?!?!?!
- Evap Sensor causing sluggish start?
- 1NZ-FE Rebuild / overhaul kit - where to buy
- Scion xA/xB Short Shifter Install DIY
