- Factory cruise control works intermittently
- Test-Pipe or New Cat???
- 2006 xA battery issue / question
- Any improvement for auto tranny?
- Manual tranny fluid change ?'s
- vvti selenoid replacement
- Dipstick length?
- Coil packs
- 2005 Scion Xa Motor Swap!?!?!?
- So I know there's lots of cam gear threads...
- 04-05-06 xb manual tranny are they the same?
- Battery draining. Unsure where the problem is.
- Toyota Coolant Oem: Red or Pink?
- 2005 XB Exhaust Cam Sprocket Explained
- Upper Radiator Hose
- camshaft position sensor
- Rotors ?
- 2 problems: Vacuum Leak and Noise. Seeking advice and input.
- looking for a/c wiring diagram
- Transmission filter/strainer replacement, necessary?
- Cylinder 1 Misfire
- 2004 Scion xB - replaced starter yesterday, now it will not start again.
- When should I change my timing belt
- xA New Motor Build
- OBD2 - PID's for XA
- Modifying signal from rear O2 sensor
