- Driver is what counts
- Greddy Oil Catch Can issue (ZPI Stage 1.5)
- Walbro Fuel pump install Help!
- 06 Supercharger on 07 TC
- anyone have an emanage map for i/h/e setup?
- Supercharger???
- Scion tC race Radiator **Update with exatust mani pics**PG3
- What the he*l?!
- Supercharger leak
- Basics of Tuning
- Spark Question For Turbo Setup
- Dezod stuff...
- Add me to the boosted TC list!
- blown head gasket
- intercooler question..
- Best Place to Buy Blocks???
- Turbo Toyotas BASIK KIT w/ PICS 314whp 300wtq
- New Tsudo 3'' Turbo Exhaust: Need your input
- BLOWN SUPERCHARGER Video/sound clip inside
- missing bolt on s/c?
- aaem fi/c
- Fastest S/C tC Here?
- need help
- Quick S/C Question.
- Turbo on tc
- exhaust manifold gasket???
- should i get a BIKE or TURBO??
- NEW TWIN TURBO MOTOR SWAP & OTHER NEW ITEMS WOOHOO!
- Supercharged tC running emanage blue
- Automatic Turbo Questions.
- CAI: someone give me a push in the right direction!
- Is twincharge possible on the tC??
- Tuner in the Tampa/Orlando Area
- ** EDIT **
- Slave cylinder bleeder valve pitch
- GReddy Emanage Blue
- central jersey
- Custom Turbo Kit: Doggy Style! **3/18/08 Dyno/Pics Inside!**
- TRD Supercharger
- 16g help
- Turbo Ball park
- how tough
- Planned Turbo kit custom! input welcome
- tC supercharger
- BOOST
- megan drift spec + supercharger
- "The leak"
- Looking for a base map for a unichip
- and she is down again
- 08 tc turbo kit
- Turbonetics?
- ScionGT35R' new numbers +500 on pump gas
- Turbo Toyotas: No Style!
- ZPI Stage 0-Installed!
- check it out
- shopping for a turbo or s/c?
- gas milage turbo vs s/c
- NEW HYUNDAI COUPE UNVEILED!
- from S/C to turbo
- ptuning exhaust exterior video. wide open throttle
- jumping AFR reading question?
- ZPI stage 0 intake help
- Supercharger Rebuilding Kits!
- have s/c and wanting to go turbo!!
- Compression Test
- Ptuning exhaust installed and re-tuned!
- suggestions for the big 3...
- oil pressure fuel sandwich adapter
- Passing NYS inspection with Turbo?
- Need help mounting Oil Catch Can!
- Manifold help and intercooler help... Thanks
- Squeaky Belot on S/C
- Got Sputtering?
- Project
- What TURBO to go with
- NEW to F/I and need some advice please
- Crank sensor
- PTUNING: Project RedLine Time Attack tC (updated pics pg 16)
- Top Mount in a Yaris???? TT Yaris setup
- Florida Shop and Tuners??
- -supercharger-
- scion tc Supercharger Injectors?
- Texas Shops and Tuners
- Question about ZPI 16G set up
- Where can i find...
- Dezod: Update for Fri 3/21
- MN Dezod S1 tune
- How can this POSSIBLY sound normal?(S/C) ***UPDATE 11/01***
- turbo kit
- 9.5 psi S/C pulleys on stock internals..
- Hey Todd...any news on this??
- sr intake
- Solid Copper exhaust manifold gasket for TC. "Pics"
- Custom 3" exhaust?
- Engine builders PLEASE ENTER HERE!Oil pressure system.2AZ-FE
- after installing turbo
- Removal of the tC head
- need help
- "SL curse".....
- Electronic Boost Gauge question
- try not to let this happen to your car 222222222222video
- Dezod S1 w/street tuned AEM Standalone on 7LBS!!!
- Base Map needed
- TPS question and compatibility with AEM F/IC
- Quick question...and no i couldnt find it in the Search
- Dimming Gauges?
- Air Research Turbo
- Will an 05 Greddy Turbo Kit fit an 07 TC.
- Dezod/TT Hybrid Plans
- Goin Stock Again HELP!!
- pwr liquid to air kit
- 550cc injector greddy emanage ultimate map?
- How to remove trd supercharger ?
- supercharger diy installation questions
- How much did you spend on you supercharger?
- VA,MD,NC i need your help
- Need a wibeband kit...!
- The legality of it all...
- I need expert help....again lol
- s/c ques. about racing
- turbo question
- Should i get spark plugs?
- Ptuning scionlife discount?
- sound clips hiflo cat turbo setup
- Turbonetics turbo kit on AEM EMS! 323hp and 336ft/lbs....
- Greddy turbo kit with 550cc injectors tuned?
- Next round of mods for the trd tc - gimmie some help!
- oil pan?
- Get on the Dezod West mailing list!!!
- What kind of cam profile is good for a supercharged scion tc
- Can a vortech trim supercharger head be swapped for the v5f
- Has anyone been able to tune an 07 with a piggyback??
- Blueish..whitish smoke...
- I need s/c cams. I don't think I'm alone. Join me
- help with CEL codes
- trd supercharger
- Pricing Help?
- a few questions
- another s/c question
- question for anyone with a zex nitrous kit
- Gauge Pods?
- 300whp auto tc
- ok now im scared???
- TRD S/C Gotten any better?
- Mechanical boost gauge vs electrical
- how to stop wheel hopping when you have partial slicks
- intercolor and piping
- Who's running the Forge SPLT-R
- Bell Intercoolers
- emanage ignition help
- Whats your fav BOV for TC?
- time to buy my turbo!!!
- 9 Sec AEM Tc
- megan mid pipe and s/c
- Turbotoyotas TX Style!! broked axle!
- trd injectors with custom turbo kit also need map
- 625cc vs 550cc injectors
- DTC P0121
- Question about fuel injectors
- BPV . sc help
- how true is this
- looking for a good tuner in NE PA
- turbo exhaust
- Boom
- DEZOD STAGE 1 DYNO RESULTS*pics*
- What gauges do you need for a Turbo Kit?
- greddy turbo help
- Building my turbo setup for 300whp
- turbocharger
- New f/ic update version 3.01
- Could i use this for my new oil pan when installing kit?
- help plz...no haters
- help ......Apex'i turbo timer
- BETA sets of intercooler pipes...looking for some goodness?
- GREDDY TURBO KIT TUNE WITH 550 INJECTORS
- Where to read up on AEM f/ic?
- 2006 ECU IN 2005 SCION TC
- going turbo 101
- S1 kit cut
- Installing piggyback
- Megan Racing Turbo Manifold and Down Pipe Fittment
- A reliable team of 300 horses
- What did you do with your turbo guages? (Pics plz)
- |Dezod| Limited Slip Differential
- Reworked Treadstone IC piping.
- For all the ZPI lovers out there!!!
- welding of the oil pan?
- NST 65mm pulley
- Can Camcom Be Used For Tuning A Turbo?
- Dezod West overhaul - Going digital!
- best location for maf sensor!
- Yourhotcar.com Turbo Kit?
- car stalls out at low idle
- what kind of clutch is on tc
- Car part out commence! custom kit part out...random parts
- Sc help
- Fastest TC on pump gas.
- delete
- TRD air filter VS. K&N air filter.
- supercharger impeller seal
- Clutch/ flywheel installed
- thinking about going f/i
- retard timing with nitrous
- supercharger HELP!!!
- How long did your clutch last?
- Dezod S1 Installed...finally.
- Need help installing the gates belt.asap(Nevermind i got it)
- why do my afrs no matter what stay high
- Need help with oil feed and return and other turbo stuff
- Cheapest place to buy trd supercharger kit?
- Supercharger help!
- gt35r set up?
- Who has the lowest psi with the most power?
- How did you pay for your turbo or supercharger..?
- The 500whp Build (hopefully!)
- Need a clutch for your T-tC or S/C? (look no more!)
- Heatwrap
- All of these numbers and all of these cars...
- Introducing new oil line options for the Dezod kits.
- Ripp Mods for t3h win
- How would you install this catch can???
- ARK N2 Exhaust for turbo...
- Dezod Stage 1.5 w/AEM EMS 2 Step (Updated Link)
- a lesson for all you SC'd tCs
- Who Sells the Snap rings and rubber o rings for hks bovs ?
- How to re-flash the ecm back to factory after removing s/c
- Finally summers & boost is coming, teaser pic.....
- Header Spipe and Axle-back with OEM Midpipe?
- TURBO TOYOTAS EXTREME TUNE!
- Vids on upgraded BPV on superchargers?
- Turbo Toyotas FTW...... If he said it, its gospel!
- Anyone running the Greddy Kit w/ Fic?
- Who makes Injectors? Company names
- Supercharger help if possible
- Well, today was certainly fun.
- For the peeps with the TurboXS Type25 BPV...
- supercharger help
- Intercooler Size??
- Where to get Tuned?
- AEM UEGO WideBand Gauge wont turn on...
- Anyone with 4th or 5th gear pull videos of their turbo tC?
- crappy nitrous video
- Who makes the best supercharger?
- copper plug part number
- 08 guage pillar pod
- who makes the best turbo kit??
- HP Forumula
- AEM F/IC wiring for the automatic
- GT3076R too big?
