View Full Version : Scion tC 1G Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Misfiring w/ FIC
  2. 2006 TRD S/C tC down...
  3. wide band reading
  4. 07 Shortblock "Oilers" **PICS INSIDE**
  5. Pistons have come about.....
  6. opps i Slipped!!
  7. AEM F/IC Setup
  8. Stock Head Bolt Removal **ANSWER INSIDE**
  9. Upgraded Radiator for automatics?
  10. Question about SPA Turbo manifold
  11. bov to bpv? simple?
  12. vince is back baby!!
  13. |Dezod| Race Radiator
  14. AEM x300.hex
  15. Break in Methods
  16. My turbo car is throwing cel light code PO300 and 301
  17. Need help please!!!
  18. TurboToyotas ..... Borg Warner Style!!!
  19. wat gauges i need
  20. difference in boost gauges?
  21. 5 32oz Old English down da hatch...(updated)
  22. Maps for Greddy Emanage-U
  23. TURBO, SUPERCHARGER... OR BOTH???
  24. Need parts help
  25. hooking up aem wideband
  26. need some help
  27. Getting AFR reading on computer?
  28. PureVision Built's Turbo Tc Video Update 3/1/09
  29. How much boost?
  30. BLOW THRU MAF questions HELP
  31. Turbo size suggestions for dd
  32. HELP PLEASE SOMEONE NEED HELP INSTALLING
  33. problems with my new turbo
  34. engine has some rod knock
  35. where are the superchargers at???
  36. blue w/ pnp harness for 07 FOUND PLZ LOCK
  37. is there anyone with a roots type s/c??
  38. trd sc just came in today
  39. Backfire? Misfire? Loose Coil Pack - Changed Plugs
  40. wastegate spring question.
  41. News and updates (wheels, intakes & meth)
  42. Trying economic times, we know....Discounts are here.
  43. MAF In front of turbo inlet
  44. water temp sensor in radiator drain plug
  45. GI: GB on AEM EMS Standalone for the tC
  46. 6 Check engine lights codes!
  47. Help me pickout a clutch PWEEEZ :D
  48. Engine Removal
  49. TT "SIMPLE" kit updates with picts
  50. OBDII Database
  51. ECU help
  52. Resetting long term fuel trim in ECU?
  53. ticket for BOV??
  54. Turbo use diverter valve
  55. sc air box problem
  56. k&n drop in air filter for sc?
  57. which split second PSC1?!
  58. S/C Hoses covered in Oil *pics*
  59. aem wideband gauge question
  60. The super hieuman turbocharged tC is no longer
  61. dezod doens't sell the megan manifold anymore?
  62. quick update on the car.
  63. How many have a Knock Light?
  64. 5bolt dp for treadstone mani
  65. Dezod Tuned AEM Vids!!
  66. how many are using .42 ar t3?
  67. help with emanage ultimate
  68. Multi-Scramble Intelligent Boost Controller
  69. Turbonetics Kit
  70. The truth about the code p0171
  71. Vi-PEC engine managment
  72. cant take it anymore!!!!!!!!!!!!!!!
  73. wtf?
  74. any diy guages for supercharger?
  75. 2005 ecu and 2008 ecu
  76. Red E-Brake Light comes on when under boost
  77. help with the s/c
  78. AEM f/ic installation
  79. all owners chime in- tensioner shock failure~
  80. AEM Standalone Map needed asap!
  81. which electronic boost controller ?
  82. EVAP VSV Purge Valve - Tick/Tap/Noise Delete and Remove
  83. New 3'' Ebay exhaust
  84. Problem w/ FIC
  85. supercharger rs3 ?
  86. my new BOV w/video
  87. what oil?????
  88. bov
  89. Supercharger + Intercooler, ANY INFO? PICS?
  90. Supercharger PSI levels, whats normal?
  91. forced induction w/ insurance
  92. How Do You Tell If You Have An Airleak
  93. Damaged Spark Plugs - Piston Hit!
  94. PTUNING: PnP Water/Methanol Injection Kit now available!
  95. DIY Walbro Intank Fuel Pump Install
  96. Emanage Ultimate owners
  97. Start up fuel trim, F/IC
  98. HOW MUCH TIMING
  99. do s/c really shorten the life of a car??
  100. DIY AEM F/IC Harness Resistor Mod
  101. bigger fuel pump question
  102. Balance Shaft Delete Kit - Pros/Cons - No Delete Kit Yet???
  103. Golden Eagle fuel rail vs. stock rail
  104. 2008 S/C Question
  105. Daily driven with no Balance shafts
  106. Choice of Valve springs & Retainers?
  107. FIC Problems and CEL codes
  108. shop peen? stock rods?
  109. Move DIY to tech or sticky them here?
  110. New DIY parts!
  111. Jet Hot Prices...
  112. Blew my engine today... # mystery wires
  113. BOOSTFLOW RAMHORN TURBO MANIFOLD ? ? ?
  114. where can i buy a set of piston rings?
  115. what size are the piston rings for the 2008 tC?
  116. Launch Control **Un-Advertised E-Ultimate feature**
  117. question about air-air/water-air
  118. zpi stage 1 tune??
  119. how much did the dealer charge you do to TRD S/C flash?
  120. supercharger owners please look and let me know what u think
  121. Engine Build Estimate - Block + Head + Clutch Cost
  122. is the tc supercharger software module same for 05-06 and 07
  123. quick e-ult question
  124. ELEVATIONTCs Oooo N AAA XTC! New pics NOW! jun 21
  125. need opinoin about a GT35R turbo
  126. boost spike leads 2 rebuild process, update pg5.
  127. Backpressure and Superchargers I need a question answered
  128. Scion TC parts/wiring schematics
  129. Problems buying a used turbo
  130. 2AZFE Differences from 05-06------07-08 Block/Head
  131. pics of megan manifold
  132. Has anyone installed 05-06 trd supercharger on their 07+ TC?
  133. eclipse turbo on a tc?
  134. BOOST....but which direction?(UPDATED)
  135. New Boosting Clutch Options from ACT!
  136. PTUNING: TA tC 500+WHP dynorun (vid and dynosheet)
  137. greddy ultimate or aem fic? help please
  138. Paint or Powder Coat IC piping
  139. TRD Supercharger Key Tool
  140. How long has your TC trd supercharger lasted?
  141. custom felxible downpipe?
  142. Muh Snail...
  143. New! Dezod Exhaust Manifold Gasket (in stock now!)
  144. BELT for A/C delete w/NST 12 psi TRD s/c pulley
  145. crappy tune or just my paranoia?
  146. Cam timing issue - engine builders please read - urgent
  147. Main Bearing Caps for Crankshaft 2005
  148. Anyone have the GReddy Profec E-O1 Boost Controller?
  149. Engine Code PO031
  150. Turbocharger, need info
  151. 08 scion tc turbonetics kit advice and questions.
  152. OK, The Piggyback VS Standalone thread!!
  153. Black Box Install/Cable Issue
  154. holset hx30 ? hx35 ? hx40 ?
  155. A new intake Idea - Induction esque?
  156. whats the highest psi S/c pully available.
  157. Magnaflow Catback Exhaust
  158. PTP Turbo Blanket - Installed 2/3/09 w/pics
  159. PCM processor fault
  160. Help me spend this money/Build a Turbo kit
  161. Going to be Boosting the Car Soon; Need Advice
  162. PTUNING Time Attack tC in Modified Magazine
  163. Car majorly hesitated+smoke out the exhaust onWOT*(UPDATE!)*
  164. whats the downfall?
  165. Anyone running Prosport Boost Gauge?
  166. Ignition tid bits
  167. Hi Guys Im New from Cali
  168. question about dezod oil feed..
  169. quick question
  170. TRD SUPERCHARGER
  171. Stock Piston - WHP Threshold
  172. found a 3'' exhaust, anyone have it yet?
  173. just a few questions
  174. i plan on going turbo in the future
  175. How will the stock motor hold up?
  176. NOS+s/c
  177. NEW WR INTAKE MANIFOLD.. FINAL VERSION..
  178. What is line bored?
  179. Turbo Toyotas & Pro Clean Auto's Project Car
  180. Main Gasket
  181. anyone running the camry transmission?
  182. New engine build (HELP NEEDED)
  183. TRD DISCONTINUES SCION SUPERCHARGERS!!
  184. please lock; found the thread i was looking for.
  185. The lengths we go
  186. Turbo question, custom "stage 0"
  187. here's something to watch SC VS TC
  188. //Dezod// Tuner Series Intercooler Pipes
  189. Emanage Ultimate Support Tool
  190. Which belt is best on S/C TC @ 12 psi?
  191. How can I Test my Plug N Play Harness??
  192. Which greddy exhaust?
  193. Warm Weather Projects/Advice
  194. dezod downpipe and stock spipe?
  195. need advice about buying a turbo, please help!
  196. **Vulcan Turbo** Turbo Manifold SALE!
  197. Greddy E-Manage ultimate Jumper switches
  198. 5 Bolt Flange Question
  199. Anyone interested in new kinds of bezels for your gauges?
  200. lol me & my car got on local tV
  201. Belt Question we have been asked a few times....
  202. custom turbo-kit: MO-CO style
  203. AEM F/IC Tuning: o2 "High level drive"
  204. Greddy turbo kit users
  205. zpi exhaust manifold temps???
  206. lost cruise control after injector install
  207. Greddy Touch
  208. NST 12.5 psi pulley install and dyno yesterday!
  209. open loop 3 folks chime in....problem with idle
  210. wastegate fail or not
  211. Cold air vs. K&N
  212. New fuel setup.
  213. car tuned with FIC have some issues
  214. DYNO RESULTS WR INTAKE MANIFOLD FOR TC.
  215. can an intercooler be cut and welded?
  216. Will this work?? YUP!!!(updated)
  217. need help with emanage blie hardwire install + software
  218. Engine Management Suggestions for SC
  219. Fuel Return Alternative? need opinions on this.
  220. Masters program - Auto-X / time attack driver input needed
  221. My boosted tc on forza 2 is faster then yours :)
  222. GI: Dezod Motorsports Fully Built Motors
  223. im tryin to turbo my tc.
  224. another s/c question
  225. is it okay to drive an untuned turbo at 5psi?
  226. increasing redline on 07+ with ultimate?
  227. which boost controller?
  228. cracked my thermostat housing???
  229. How is my 101 HP honda faster than my Turbo Tc?
  230. f/i turbo question
  231. fuel pump challenge
  232. dyno chart.. and "Questions"
  233. s/c question
  234. Is the ebay turbo good?
  235. Supercharger short ram intake idea......
  236. The Official " Is a Ebay Turbo Kit Good" Thread
  237. Replace lens on Boost Gauge ?
  238. Question about T-netics 05-06 kits
  239. stage 0 turbo kit
  240. PTUNING: Competition Return-Style Fuel System
  241. 2.5" or 3" exhaust with 2.5"downpipe & s-
  242. intake temp sensor and emanage ultimate
  243. Low-Profile Intercooler
  244. Need some F/I guidance real quick
  245. Pocket Dyno?!
  246. Stalling with FIC on DFCO?
  247. TRD S/C response needed
  248. How to: Customize to fit 05-06 s/c on 07? possible?
  249. Cant hit full boost
  250. anyone have the ACT street clutch?
