- Motor Damage Due to Overboosting (w/pics)
- Tuning F/IC - Crank / Start Cylcle?
- Gauge brands, what's good?
- Turbo break in period or Immediate Dyno Tune?
- Got my used DEZOD AEM EMS today have a problem.
- Non Boosted Map for Aem EMS
- New Hardware... Need Advise
- header install with s/c
- AEM FIC maybe multi-stage boost controller...
- [url]www.DESCENDANT-racing.com[/url]
- Hydra Owners chime in please
- tc bulid list
- Dyno APP'S
- PTUNING: Adjustable Front License Plate Mount Kit - NEW!
- BOV on a supercharger?
- How to Replace T-netics Raptor BOV for Greddy Type RS BOV
- manifold quick fix
- small shaft play... normal?
- Quick Question: TRD Supercharger Oil TEE
- is the turbo bad? just got it rebuilt...
- TT 09 2.1 updates with pricing
- upstate new york tuner ?
- Friend just bought my other block
- Anyone Heard of these Gauges?
- Final decision on obx lsd?
- DIY S/C rebuild kit
- bit of trouble...
- WORLD Racing 2009 off season
- Most amount of power from TRD
- Phantom Grip VS OBX LSD
- Took my s/c apart, In your face trd.
- AEM FI/C Base map for S/C
- Question for you turbo guys around Dallas
- s-pipe to close to oil pan
- fuel pressure regulator
- trouble making power up top...help!?
- WARNING!!!!!!!! vacuum coupling failure
- white smoke out the breather and tailpipe
- wrapping my minfold and downpipe
- S/C issues
- greddy e-manage ultimate?
- i went to ASR engineering the other day and saw some goodnes
- turbo kit ?
- Supercharger or turbo?
- What if Dezod made a top-mounted intercoolor kit O_o
- My turboz is better than ur turbozz
- EBC install, couple questions
- Hydra 2.5 VS. Hydra 2.6
- new clutch in, but a hitch...
- Got a quote from the shop, would like to hear some opinions!
- Lets see some aftermarket Gauge Setups
- WHP estimate? *NEED HELP ASAP*
- Supercharger Project
- before putting in the supercharger...
- 07 block 05 head...few questions
- The tC non-turbo'd...
- Officially UnNaturally Aspirated! w/ Pics pg. 2 !!
- Boost @ 70K ???
- hand polishing turbo mani ?
- WORLD Racing 2009 AWD tC
- Turbo Toyotas: Rican Style. Update!!! now with Dyno pg 1
- Turbo basemap for FIC.
- p-tuning 3" turbo back on dezod kit?
- Polishing or Ceramic Coating a SC
- Stock cams + Springs/retainers.. Where to raise redline?
- Dezod Turbo kit - Ocean State Style: Updated 3-9-09
- switched power source in engine bay to tap meth switch?
- what do you guys think about this ebay turbo kit
- tuned greddy kit number with emanage ultimate anyone?
- What BOV is this?
- i need a lil help with my turbo
- TRD Supercharger question.
- no boost indicacion on my gauge
- no boost indication on gauge
- Shaft Play
- DOH!! I need Help with AEM Wideband!!!
- My new journey
- Bad turbo seal? Please help
- lightweight pulleys with turbo?
- stage 8 manifold bolts
- Turbo results with 2011 boxer 2.0-liter engine?
- Anyone ever use one of these?
- sc'er pulley removal?
- 2008 turbo kits
- INTAKE MANIFOLD
- What to look for after blown engine
- Dezod Turbo back Exhaust Install/ With Pics/Video update
- Can Hydra pass OBDII inspection?
- Great WIDE wheel for FI tCs!
- ECU SWAPS
- custom exhaust work.
- emanage help on intake temp sensor
- built motor break in process
- Dezod AEM Standalone Came In Today
- Emanage Blue 7psi map
- 2005 tc weak block - or false info?
- AEM FIC Base Map
- cv shafts
- how much boost should i go for?
- The best catback exhaust for a SC'ed scion tc 08???
- Warning: Fake Greddy RS BOVs
- supercharged or turboed?
- Charge Pipe
- ** EDIT **
- AEM Dry Flow Filter for 5speed 06 TC
- how long will a stock clutch for the tC hold with 12psi?
- will my trd intake work with my trd supercharger
- turbo kit partout update PG 2
- Dezod Housekeeping...website, turbo kits & Aplha kit
- torque value on s/c idler pulley?
- What manifold is this?
- Dezod AEM EMS Race Box 4 T W
- ZPI stage 0 turbo kit map
- 05-06 TRD SUPERCHARGER KIT on 07 TC w/ pics YES it will fit!
- ZPI owners.
- What turbos are everyone running?
- re-flashed ecu
- IDLE A/F ratio 10.0 please help
- Anyone use a bando brand belt for their s/c?
- E85 in a TC
- CANT BUY TRD supercharger ANY MORE!!!!!!!!!
- Limp Mode - Removed Side Airbags - Did it cause Limp Mode?
- Help with AEM listing
- best turbo kit
- Looking for pre map running 550 cc injectors greddy turbo
- how good is the greddy kit
- HELP car is running lean at idle
- scion tc fog light install help
- TRD Supercharger Air Box "trumpet" diffuser
- glowshift oil pressure gauge question
- DIY: modify your factor FPR to achieve pressures above 50psi
- driving untuned with internals safe?
- Trying to keep the turbo sleeping?
- ABS and BRAKE light problem ... need some help
- does this kit come with EVERYthing I need?
- Building an Exhaust Manifold.... Help Needed
- combustion chamber volume ? ? ?
- buying used turbo....
- Turbo for automatic??
- 2az short block build - turbotoyota - whyindustries
- New one guys...When do you upgrade intercooler?
- My Build
- Perfect intercooler for bigger HP?
- leftover oil in cat or something wrong?
- TRD SC Owners, NST 65mm SC Pulley Group Buy!
- A-Pillar Pod Install
- ** EDIT **
- Finally Boosted!!!... Big Thanks to SL... Update and Dyno Pg. 117
- ProSport oil pressure set up HELP ! NOW ASAP
- Question!
- no more trd supercharger??
- installing cold air intake
- HELP!! Yet another s/c bites the dust...
- Water/Meth Injection
- Ebay Intercooler
- The Long Road
- S/C upgrades
- making it nice and pretty.
- M=tuned Turbo kit : little update for now
- FIXED can delete :)
- Supercharger install needed on TC. I'm in south OH.
- Stock and Aftermarket parts trying to get rid of..
- Turbo + open down pipe video
- Throttle position and RPM wire tapping...
- some left over turbo parts im sellin'
- ERL Performance engines specs/pricing
- power steering pulley problems
- tc not running right after installing s/c
- racing headers and S/C
- Boost issues
- 07/08/09 FIC Wiring Diagram
- Help guys ! Install DEFI gauges pre turbo???
- ARP head stud tourqe specs
- AUTO tc putting down 261WHP big pics inside [Video update]!
- ? 07-08-09 Harness.. In a pinch
- Turbo kit or Supercharger kit?
- need drive shaft for trd supercharger
- trd S/C replaced oem clamps w/ T-bolt clamps ADDED BOOST
- Going stock to 400whp or 500whp, how?
- tt water lines
- trd s/c problem. noise in cabin. HELP/ ADVICE
- temporary blue smoke from exhaust...
- HELP! BPV chattering at idle! (not stuck, details inside)
- JVT or DC headers for the TC with S/C
- Slapshift??
- Can this be done?
- Got Fuel? Golden Eagle, Aeromotive, Walbro, PVM - PICS
- still cant decide on the header weapon r nice and PRICEY to.
- help im in need
- all4degame's unboosted and needs a srs a-pillar HELP!
- TRD S/C Question
- fic map
- TT slim fan part#
- install thoughts
- black smoke from exhaust need some help!
- Oil pressure gauge tapped off the block
- Dezod Intercooler Piping Question
- turbo down pipe with midpipe
- Stalling issues at a stop...
- match up with borla exhaust
- question about boost controller.
- AEM FI/C help
- AEM base map for stock injectors
- Engine building resources
- Western Pa.. Dezod Tune Day!
- Finally got out to the track
- Turbo Oil Pan
- question on boost and tune
- Primary Front 02 Oxygen Sensor - Will it work? NOT UNIVERSAL
- Oil catch question
- Any one need a PP harness for emanage blue?
- Answer to the "How do I clock my turbo?" Question
- Greddy Emanage Ultimate Limp Mode
- low maint. turbo
- Greddy Turbo
- Supercharged tc questions
- BOV
- is this real
- anyone heard of them
- Paul(dezod) id like to concede to an argument we had
- who is using an unsprung clutch on the street?
- are these the correct plugs from ptuning?
- 06 ecu swap with 08....?
- supercharger question
- TRD Supercharger Bracket
- (DEZOD EMS ONLY) Has it been done right? "AC" its
- S/C.....management or reflash....?
- Lethal Injection Motorsports Turbo Charged Scion tC
- A/T Transmission scion tc, with boost?
- Need a good eye to look at your base map????
- cams for s/c
- taking block to machine shop
- Bored .20 over, how much boost before i need sleeves?
- New LSD for the tC
- Greddy Turbo Air Filter Replacement
- Dezod now offers Essential OEM parts....
- Can CEL fix adapter mess up my AFR's ?
- Can someone please burn me a copy of Ultimate Software?
- Edit
- fic maps
- TRD SC on different engine
- fuel pump wiring
- kikcaffeine's bearings SUCK - Supercharger is ____ED
- possible wastegate issues??
- turbo timer help!!!!!!!!!!!!!!!!!!
- Parts for days son!
- Supercharger Install...tomorrow
- Aeromotive fuel pump.. Dont bother
- Looking for an 05-08 TRD supercharger bracket with bolts
