View Full Version : Scion tC 1G Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36
  1. my new car...EURO FTW
  2. Exedy Stage 2 Clutch
  3. S/C cold air intake and remapping
  4. gingles' build thread Update april 12
  5. FrozenBoost Water to Air (TW) ***Updated with PICS***
  6. My Treadstone Kit
  7. Tanner Foust Drift TC doing some test runs
  8. Did TRD underrate its supercharger?
  9. TURBO TOYOTAS Install( lots of pics)
  10. im looking for a turbo kit for an 07 A/T
  11. Recommended injectors
  12. AEM Problem Fixed and now ElevationtC's Tuning Thread
  13. elect.? necessary w/ turbo kit running 5lbs? install in bama
  14. Might be a dumb ?
  15. Broken Mount Causing belt slippage???
  16. AEM FIC tuned over the past weekend....
  17. Just got off the dyno 362.1 hp 345.5TQ Mustang dyno
  18. Need an Opinion on Turbo guys!
  19. Oil catch can question
  20. wanting to go boost...wld like advice
  21. Would Tuning be worth it?
  22. QUAIFE LSD
  23. Smell of Burnt Oil from Inside my Turbo
  24. *HELP* AEM/FIC & GAUGE INSTALL. *HELP*
  25. thinking of throwing in some cams
  26. Dezod Street Tune PA
  27. OBDII Software/Cable
  28. Broken Supercharger shaft housing
  29. Say hello to 299WHP and 295WTQ R.S. 3.0 .8 bar now w/VIDEO !
  30. SECRET WEAPON INTAKES for TRD SC
  31. Highest Hp Stock Motor
  32. WHY INDUSTRIES stage 1 turbo kit
  33. A/F ratio with 9.5psi s/c
  34. TURBO TIMERS
  35. Look what i just got
  36. Scion should hire this chic for commericials...*video*
  37. TRD Supercharger HEAT!
  38. HELPP =(
  39. cylinder 1 misfire Help Please
  40. E- MANAGE ULTIMATE
  41. CEL
  42. Base map for F/IC?
  43. Rotrex Supercharger Kit 2.0 ?
  44. what exhaust diameter ???
  45. TRD Supercharger, worn bearings?
  46. Spark Plug removal
  47. AEM TruBoost Gauge Help!
  48. CDI capacitive discharge ignitions
  49. ANYONE HAVE A DUMP TUBE FOR DEZOD S1 kit ?? OR WHERE TO GET?
  50. NEED TO KNOW
  51. Clutch Install
  52. why go to a t3 or bigger?
  53. HAHA! Some of this and some of that........
  54. building a bolt-on intercooler kit for TC trd supercharger
  55. Vortech/TRD design information
  56. Clutch masters stage 7
  57. Did TRD finally redesigned the S/C shaft? 56K NO...
  58. 04' 2AZ-FE out of a Camry
  59. Turbo tC - Turbo D17 - Sprayed VR6 - Buffalo NY - VIDEOS
  60. Dezod tune day update with Dyno Sheet!
  61. @@@~~~HORRIBLE@@@~~~
  62. Tranny is gone !!!!!!!!
  63. FIC Injector Duty Cycle
  64. NST 9.5 PULLEY
  65. Retrofitting supercharger
  66. Intake Mani
  67. BOOST VS. NITROUS. pros and cons.
  68. 700cc = on shelf
  69. Builds Boost but No power WTF
  70. Strange problem, turned out to be alternator...
  71. Boost Control By Gear
  72. Turbo Tc Topeka Style
  73. ** EDIT **
  74. Oil cooler in-line with turbo oil feed line?
  75. $5000 to spend what should I do?
  76. Any tC's in northern Houston????
  77. 110 bpv
  78. question on supercharger???
  79. 07 SCION TC SCAPPOOSE OREGON
  80. Stalling with FIC when coming to a stop? A quick fix!
  81. Olympic Motorsports SouthFL WE TUNE!
  82. lock
  83. turbo project 3
  84. Dezod AEM EMS for the tC updates
  85. Dezod AEM EMS A/c Fix NO FREEZE of Compressor
  86. question bout 6psi untuned
  87. Hello All!
  88. ZIP TIEING MY LICENSE PLATE TO MY FMIC?
  89. ARP Main Studs
  90. Working with the 2AZ-FE
  91. nst 9.5 lbs./ crank pulley questions
  92. nst 9.5 lbs./ crank pulley questions
  93. maf sensor placement
  94. Dezod s1 - Virginia Tech Style!!
  95. Aem Fic problem
  96. im a noob, i know
  97. Custum turbo Setup:Ft Myers Style: Pics of new exhaust up!
  98. I believe another TRD Supercharger Bites the Dust
  99. PTUNING: Red Line Time Attack 09 Season (Takes 1st place at RTA in E-town, NJ)
  100. is NST still around
  101. Turbo Question
  102. AEM EMS START UP PROBLEM, WONT START, ANY TIPS?
  103. Where are people mounting their Dezod Vacuum Mani's?
  104. aem fic pnp harness
  105. What are the signs of a bad TRD Supercharger?
  106. what kind of oil are you using when you are boosted?
  107. FINALLY MORE ROOM FOR TURBO CARS NEW PRODUCT
  108. Injen Intake Users
  109. S1 5 Speed Kits
  110. AEM F/IC PnP Harness Problem
  111. hawgs74 Boosted
  112. Thin Battery.
  113. Turboing suggestions???
  114. another turbo kit question.
  115. quick question about turbo set up.
  116. NEED DUMP TUBE CUSTOM MADE FOR A S1 KIT PLEASE ASAP!!
  117. question about masterpower turbos
  118. Help Removing Driver Axle!
  119. Tunage and Boostage
  120. exhaust with s/c question?
  121. mod please lock
  122. cruise control question...tuner gurus please chime in
  123. Greddy to HKS BOV Adapter
  124. Has anyone plugged there intank Fuel Pressure Regulator.
  125. Well the time has come...
  126. Clutch?
  127. Looking for a good tuner in eastern pa
  128. Round 2
  129. Some Formula D Scion tC pictures
  130. Its ALIVE!
  131. Camry Block with Scion Engine Bay
  132. Help with S/C noises
  133. Where do I tap coolant for a turbo water jacket?
  134. Launch Control/2 Step
  135. Sleeve or no sleeve
  136. Amount of oil for turbo setup?
  137. It's that time for me :)
  138. Montage of my old cars transition to boost...56kohya
  139. New Toy
  140. Need help with greddy ultimate software
  141. not sure what this noise is?
  142. S/C with SOME normal gas and some premium gas
  143. TRD Supercharger/Weapon R intake/NST Pulleys/computer tune
  144. 91 vs 93 Octane
  145. First Problem in years (white smoke of doom)
  146. THROTTLE RESPONSE
  147. Dyno dynamics = Heartbreaker
  148. Has anyone actually bought one of those chips from ebay?
  149. CEL CODE 0172
  150. ahhhh misfire again....some chime in please
  151. HELP PLEASE! HAVING ISSUES WITH A/F AFTER TUNE (Resolved)
  152. supercharger rebuild
  153. Does anyone have a map for AEM FIC w/ Greddy Turbo Kit
  154. ecko04 - Bye-Bye tC - Trading in soon
  155. Crankshaft Pulley Bolt
  156. Big Problem...any ideas???
  157. I need emanage ultimate datalogs from people
  158. just installed turbo.. need some help!!!
  159. Safc II Question
  160. Turbo upgrade
  161. Need help ASAP not turbo related but im turbo'd :D
  162. Does anyone else smoke???
  163. Greddy BOV Recirc Fitting
  164. SUPERCHARGER HELP!!!!!!
  165. 05-06 FI Dezod Sale
  166. 07+ supercharger on an 06 need help ASAP
  167. blow thru maf people chime in....intake temp sensor prob....
  168. HKS TURBO TIMER..DIY PLZ?
  169. Guy on CSTC claims 426whp on 12.5 lbs...
  170. SuperCharger Noise (Link Fixed)
  171. Dezod S1 turbo kit
  172. Treadstone Kit?
  173. weapon-r intake manifold
  174. Bosch 110 bpv owners
  175. knock gauge exp.
  176. supercharger i need help!!!!!! please
  177. Tial 38mm Wastegate MV-S
  178. Looking for help with TRD Superchager & FIC set up probl
  179. 2007 Scion TC TRD Supercharger removal?
  180. Mikes (ElevationTC) Forced Induction PhotoShoot 56k DIE
  181. 20tCDude05's 500WHP Build
  182. So me and two passangers and my car almost died
  183. So i just relized!
  184. Stage 2 Cams possible problem
  185. Boost gauge flucuation
  186. tC 160* Thermostat
  187. problem with blitz turbo timer. help
  188. spark plugs
  189. Thinking of moving on! GOOD BYE TC :( SOLD
  190. another succesfull install day
  191. trying to get rid of my wastage.
  192. A little teaser. 2 Step video.
  193. open dump question
  194. Heat shield help
  195. Boost Creep possible solutions
  196. Supercharger Warranty only 1yr/12000miles
  197. Golden rule: "Dont boost on a budget." but....
  198. Wanna purchase the TRD S/C but got close to 50000 miles!
  199. Valve cover leak :/
  200. k1 rod help....need to know which side faces front of motor.
  201. Seibon VS2 hood
  202. s/c compression test
  203. vortech downgraded v5 psi rating?
  204. Problem Tuning E-Manage Blue
  205. S/C Questions
  206. Custom Turbo Kit : So Cal Chick Style
  207. HELP PLZ w/ Dezod S1 and AEM FIC
  208. SoFloTC updated Pictures :D dyno Coming soon
  209. Video i found online from BOTI
  210. Just got my Dezod S1 Turbo kit
  211. Q/A: Boosted MPG Thread!
  212. Boosted tc Overheat at idle
  213. Aem UEGO Wide Band Questions
  214. Help w/ E-manage PnP Harness
  215. Greddy Emanage U or AEM FIC ?
  216. Difference between a starter turbo kit and turbo kit?
  217. Ugliest turbo manifold.
  218. AEM FIC software
  219. TC owners some help please
  220. My New Turbo Build
  221. WHAT THE HELL IS RADO THINKING!!!!
  222. turbonetics kit...... help
  223. FRP question
  224. Apexi AVCR
  225. New Engine Management (long time coming....)
  226. Stock Fuel Injector Clips
  227. Trouble Codes on T-Netics TC
  228. Pleas lock
  229. AEM EMS MAP NEEDED FOR COMPARISON
  230. nitrous 75 shot
  231. help please!!!
  232. PRJCT SCIKO TURBO ( 117 pix on pg 1 )
  233. greddy e mangement blue
  234. aem fic
  235. Lookin for a Gator for my '07 S/C tC
  236. S/C idler pulley fail
  237. Question About Removing S/C
  238. Help finding replacment for Dezod S1 Turbocharger
  239. think I popped my engine. help diagnose
  240. The ART of the BLOWN ENGINE (all opinions welcome)
  241. CAI questions, hydrolocking, filter location
  242. Track results from today (6-7-09) updated video
  243. s/c bearing grease fitting
  244. SoFloTC destroyed manifold FIXED lol.
  245. ENGINE MANAGEMENT QUESTION??? HELP
  246. 45 minute head disasembly.
  247. TECH: Downpipe install kit is essential. Why? Look inside.
  248. Swaping AEM fic's
  249. I need a favor from someone!
  250. Injector Lag Time?
