View Full Version : Scion tC 1G Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36
  1. Greddy Turbo Kit with e-manage Ultimate - Won't start.
  2. Post your tuner shop reviews in the sticky thread!
  3. 07 tc with an Mr2 CT20 turbo?
  4. Just got back from the track
  5. This is what happens when you get a bad throw out bearing!!!
  6. Dezod and Turbonetics turbo kit upgrades available
  7. Help with my maps for a greddy e-mamage
  8. wtf well todds done it again!
  9. Wanted: 05-06 Dezod S1 owner with E-manage, Ultimate or AFC Neo
  10. I'm in Falls Church on business, calling VA peps!
  11. what is the best turbo kit?
  12. New Here!!
  13. need help with code p0441
  14. The hits just keep on coming.
  15. P-Tuning CLUTCH raffle 5.00 TICKETS CLICK HERE! LAst DAY HURRY! Ends at 2PM EST
  16. 06 Scion TC AEM FI/C Help
  17. Darton Engine Sleeve?
  18. emanage blue
  19. Turbonetics has a sale going
  20. PTUNING: Motor Carnage from RTA in Carolina Motorsport Park
  21. Draining Fuel and Fuel Pump Question
  22. AEM F/IC Issue
  23. Sound Performance kit (after turbo rebuild) video!
  24. 2AZ-fe flow rate?
  25. automatic with nitrous
  26. major problem.... need some advice car is f..ed up
  27. Flashing CEL P0130
  28. Time to finally do my clutch.
  29. Ptuning at the track
  30. bov question
  31. Belt length for NST 9.5lb pulley
  32. 2AZFE block question
  33. Need base map for 07 AEM F/IC dezod
  34. k1 rods tq spec..
  35. N2MB WOT box problems
  36. Can p-tuning main studs and head studs be reused
  37. Dezod kit
  38. Bouncing boost
  39. Intake Manifold/Vacuum Issue
  40. Ultimate Map
  41. Stft,ltft & timing.
  42. Back from ptuning and everything went great!!!!!!!!
  43. DESCENDANT SCION tC TURBO KIT
  44. Need Base Map
  45. didnt know....
  46. stage 0 turbo questions
  47. Clutch out Pic up!
  48. Need a new Turbo, help me decide which one would fit Dezod S1 directly !!
  49. California State Referee help!!
  50. question about blow thru maf guys....gurus chime in
  51. cost of tuning piggyback
  52. Review: OS Giken on Dezod S1 @ 12 PSI
  53. Show intercooler or hide intercooler ????
  54. i'm getting a new s/c charger
  55. 2010 Auto TC
  56. BOOST?
  57. Supercharger Guru
  58. I need help with my greddy emanage ultmate asap!
  59. noob ? here so be gentle
  60. Question about e-manage blue
  61. i'm getting a turrrrrbo!
  62. oil clearance on rods and main cap..
  63. New Turbo.. Holy batman! update pg3.. WOW
  64. Got my s1 kit installed! but help!
  65. best/most recommended spark plugs for f/i
  66. BOV help
  67. boost controller
  68. Block Balance?? Engine Build 2azfe
  69. Increasing A/F mixture
  70. Engine Assembley Bolt Block to Head
  71. BOV
  72. Modified Mag, Dyno COmparison! GREAT INFO
  73. AEM F/IC TC Tuning
  74. descendent turbokit question
  75. Turbochargers and Information
  76. Ok soooo
  77. Case of The TB!
  78. ** EDIT **
  79. Descendant intake manifold
  80. Rear PCV Fail
  81. piston ring end gap for wiseco/ clearnace
  82. Which Turbo Kit???
  83. descendant intake mani
  84. E-manage base map.
  85. EDIT!!
  86. my dezod turbo manifold cracked
  87. M-Tuning is D-Best
  88. Redline Time Attack Round #4 **video**
  89. wastegate spring size
  90. ptuning....turbo kit, etc.... DYNO SHEET pg.39
  91. TRD supercharged Scion tC verus P-Tuning Turbocharged tC @ Scion Show of Champions!
  92. Help with motor build please!!!
  93. YAY yet another CC fail
  94. wiseco piston
  95. Cooling upgrades, koyo rad, turbo blanket, etc
  96. back in action
  97. Dezod downpipe using stock bracing question, see if you guys can help??! Thanks!
  98. 3" Downpipe Pics Wantedd
  99. Tonight at cfrc in orlando
  100. turbotoytas simple kit+GT3071R (vid p 12, final results p 31)
  101. burning oil still. Dezod Turbo Help!!!!!!!!!!!!!
  102. Turbo Cooling.
  103. B&M tranny cooler
  104. Block Sleeves
  105. Any FI TC's in Illinois area?
  106. rebuild
  107. Maxxed out stock fuel pump with 550s :(
  108. Turbo Tc maf issues
  109. ptuning turbo FTW!!!!!
  110. DIY: How To Install AEM CAI on 2005-07 tC
  111. WORLD-Racing Scion tC ***PSCA @ Cali Speedway in Fontana, CA ***
  112. Tune problems. Update !
  113. Scion Racing & Dan Gardner WIN championship again
  114. hai gaiz! turbo Q.
  115. F/IC High Level Drive O2
  116. Dezod Performance Short Blocks
  117. Dezod Performance BIG RED 850cc PNP Injectors
  118. More engine building parts available too
  119. building a turbo set up (it has begun!!) pic on page 7!
  120. Help me decide on what clutch to get.
  121. A new standalone system for the tc, Proefi.
  122. Engine Managment List
  123. AEM fuel/ignition controller and 2009 tC?
  124. 61mm tc versus 2004 R1
  125. Motors delivered to p-tuning!!!!! The count down starts!
  126. Problem Found! need help!
  127. Everyheard?
  128. PTUNING Enkei Wheels (used) raffle $5.00/ ticket CLICK HERE!
  129. Ptuning at the track with Mtuning tune!!
  130. Need help! Car leans out!
  131. fuel solonoid got stuck open
  132. BREAKING NEWS (i think) OF TURBO TOYOTAS
  133. arp head stud install and hand tight
  134. What do you guys think of this setup? Worth it?
  135. Jessicas comp 67mm DYNO VID / .63ar TBB dyno 527 WHP DEZOD KIT, AEM EMS
  136. Noob oil line questions...
  137. Thinking about turbos....
  138. Help!!! Cel p2102 with aem f/ic tuned with dezod pnp harness
  139. wrong post
  140. TurboChargers.com has my Car...Total FAIL! I'm Crush Tuned now FTMFW!
  141. Descendent or Dezod Turbo Kit?
  142. DIY: Emanage Ultimate 2-step setup
  143. fuel return system
  144. Is Secondary o2 Necessary?
  145. 550CC Injector Max Boost - Compressor A/R.50 - Turbine A/R.63
  146. Jessicas 67mm Turbo Scion TC PICTURES!!! 56K lockup
  147. Electronic Supercharger???
  148. Boost Activated Cutouts!
  149. Limp mode, quick question.
  150. vacuum manifold
  151. Drool....GT35R pimptasticness
  152. What is your turbo tc drag wheel and tire setup??
  153. Manual swap done but 1 issue--- need help so bad!!!!!
  154. lock this
  155. Partial Throttle tune goes BESERK!
  156. sikky manufacturing turbo kit
  157. stock ECU capabilities
  158. Difference 05-06 / 07/08 Head Studs
  159. HELP Please
  160. J3st3r's Setup(s)
  161. Subaru turbo on a tC?
  162. AEM FIC dezod base map needed pleasee!!
  163. Need new FIC base maps!!!
  164. Problem code P2118
  165. cburglb34's new turbo project(56k beware)
  166. ** EDIT **
  167. New mod, 15whp!
  168. Full 3" mandrel exhaust built for greddy turbo'd TC
  169. So the tC is done...Pics
  170. Emanage Blue Help please!!
  171. Help with Wot Box settings (Fixed)
  172. Turbonetic's guy's with unichip!
  173. DESCENDANT tC hitting the streets of L.A.
  174. TRD Supercharger Balancing
  175. Questions regarding built motor and emanage
  176. ebay bov
  177. Back to stock but running rich
  178. My Manifold Cracked once again....
  179. The turbo route is looking good for me..
  180. Unichip tuners in NY?
  181. max hp?
  182. vacuum line routing
  183. Turbo help plz!!!
  184. So....Genesis Turbo Coupe < Turbo tC
  185. In need of Idler pulley hardware kit asap!!
  186. GReddy E-Manage Ultimate Tune and/or Trade
  187. What's our oil TEMP at normal operating temp?
  188. going boost in california a good idea?
  189. # of superchargers
  190. Wat is this?
  191. Scion tC burn out...
  192. Turbonetics intake not fitting?
  193. Has anyone talked to todd recently?
  194. Turbonetics - SS Oil Return Line: I need one
  195. Twin Plate Clutch
  196. Turbonetics kit help
  197. Quick Garret question.
  198. which fmc or standalone
  199. 3 inch exhaust picture thread.
  200. Turbonetics kit on E85 w/ Hydra EMS
  201. PTuning Orlando Style 2! Pic of new manifold on page 1
  202. High Miles
  203. Jessicas Turbo Scion TC, NEW setup IN-CAR vid WG spring pressure
  204. my new turbo setup(pics page 2)
  205. Stupid Q... How do I save FI/C Tunes to PC?
  206. Help with nitrous kit.
  207. help a boosted tc with a tranny problem
  208. WORLD-Racing @ Phoenix International Raceway
  209. supercharger custom intake's
  210. AEM FI/C help
  211. Turbo Toyotas Simple Kit NEEDS a T3/TO4B??
  212. oil feed and drain lines
  213. some supercharger questions
  214. turbo toyotas urban dictionary
  215. New tires+burnout+500whp+lsd= a lot of smoke
  216. Scion tC w/ DESCENDANT Turbo Kit *DYNO*
  217. The 100 Dollar Manifold! PICS installed
  218. Turbonetics Kit on Stock Airbox Mod
  219. aem 19 channel gauge?
  220. Another Competition Clutch Fail
  221. 617 WHP @ 26.4 PSI SPINNING ,JESSICAS 67mm w/ PTUNING KIT/ DEZOD AEM EMS
  222. M-tuning Dedication
  223. anyone wanna guess what this set up will make?
  224. Jessicas custom 67mm w/ptuning 617 WHP DYNO VID SPINNING!!!
  225. help! slim FANS
  226. ACT CLutch
  227. Anyone use this combo? House Of Billet?
  228. Race for the Championship Party
  229. D.i.y hks turbo timer type 1 install
  230. WORLD-Racing Scion tC @ NASA Time Attack Phoenix Intl Raceway
  231. CEL O2 STUCK LEAN! "aimed at shops"chime in
  232. get my car to DE
  233. FIC or ULTIMATE??????
  234. new turbo kit on market
  235. Help! Selection of Correct Turbo Size and Brand
  236. Jackson-Dawson and Scion Up the Ante to Race in SPEED World Challenge Series
  237. Need Assistance with Turbocharger
  238. my turbo is smoking
  239. built motor cranks but no start!! its running..
  240. AEM FIC + LED = SHIFT LIGHT (short diy)
  241. car trouble question.
  242. So....who wants to make some serious turbo power
  243. I made a mistake. Plz delete.
  244. Does anyone no where i can get replacement piping
  245. Blow through Maf Measurements!
  246. TRD supercharger help...
  247. Turbonetics check engine light need your help.
  248. High Hp TURBO Tc guys CLICK HERE
  249. 07 tc reflash back to stock problem
  250. going e85
