View Full Version : Scion tC 1G Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36
  1. Annual florida evo & DSM meet
  2. PTUNING: 3" S-Back & Turbo-Back - NOW BACK IN STOCK!
  3. evo dsm 3
  4. s/c belt slipping? i have the solution.
  5. 2jz swap Pics in the engine bay! with naz
  6. 2AZ-FE PCV thread size?
  7. Scion Wins First Professional Road Race at World Challenge Season Finale
  8. 4psi on stock tuning
  9. rainy day photo shoot...
  10. **Thanks Ptuning** Car is back running and tuned!!
  11. ^^*P-Tuning*^^ Motor, Installed.. page 3 turbo installed page 7
  12. Turbo not the way to go?
  13. 400whp clutch???
  14. little help with afr plz
  15. PTUNING 3" S-Back Exhaust Raffle $5.00/ ticket CLICK HERE! (drawing Nov. 16th)
  16. cracked crank pulley WTF?
  17. getting a short block for $130
  18. stock injector limit?
  19. Anyone tried this?
  20. anyone try this???
  21. P-tuning pron!
  22. Turbo sizing
  23. Welp its been fun......
  24. help me!
  25. Car done, back and tuned by Ptuning **Dyno sheet inside**
  26. Whos Boostflow streetboost kit?
  27. "SYSTEM TOO RICH" help diagnose..
  28. real quick injector question
  29. Allen Bolts - TRD Supercharger Kit
  30. Exhaust Rasp and Turbos
  31. great deal!
  32. PTUNING Spec-SS Competition Return-Style Fuel System (pics and pricing)
  33. AEM EMS stuff
  34. EL tubular manifold
  35. AEM Meth Injection wiring?
  36. Ignition Modules
  37. s/c
  38. Slowboy Racing 2AZ-FE Race Blocks
  39. Aem fic maps
  40. built motor but misfireing..updated with tune still same
  41. aem fic tune or MAF clamp?
  42. Cruising afr?
  43. M-Tuning Turbonetics TC Vids
  44. Descendant Fuel Rail advantages
  45. Jessicas comp 67mm goes back to dyno sunday!! Details inside!
  46. scangauge2
  47. Squeeking from steering
  48. Dezod vs. Turbonetics
  49. WORLD-Racing's 2010 Unlimited AWD Time Attack Scion tC
  50. 6psi untuned...everyone read
  51. SAFC tuning question
  52. HOW TO WIRE A SAFC(07-08)ecu
  53. FINALLY....building my motor.
  54. Apexi turbo timer functions?
  55. Looking to trade s/c ecu for n/a
  56. $500.00 Military Discount on DESCENDANT Scion tC Turbo Kit
  57. oil return line
  58. FIC trouble, 25 psia at idle???
  59. TRD injector question (size and color)
  60. unichip for TRD supercharger
  61. injector questions
  62. turbonetics wastegate
  63. do I need injectors???
  64. AEM TRUboost
  65. Max Boost
  66. AEM FIC
  67. Speedo stuck at zero ?
  68. Boost leak central
  69. Need Info
  70. Transition AFR's
  71. BYPASS CLOSED LOOP(open loop tuning) questions
  72. DEZOD AEM EMS COLD START, AMAZING DRIVABILITY, VIDEO'S (compared to stock ecu) *LOOK*
  73. "shift" NFS
  74. Calling all UNTUNED turbo setups
  75. Off and on into the wild blue yonder.......
  76. turbo help/header
  77. My Ride...With the Decedant Racing Manifold
  78. "system too rich" fixed*UPDATE*
  79. exhaust
  80. 07+ turbo intake
  81. what do u guys think ill make? ?
  82. boosted brotha down
  83. FIC CPS problems, seeking help
  84. What gap should I be on with a turbo TC?
  85. blow thru maf question..*UPDATE*
  86. 662 whp dyno @ 29.5 psi, jessicas 67mm tc again**crazy tourqe and curve**
  87. P-Tuning Kit With "MONSTER" Precision SC6265
  88. You know you got some power when....
  89. PTUNING: TA tC - Wins 2009 Redline Time Attack Mod FWD Championship (nice vid pg. 4)
  90. 3" downpipe for Dezod turbo kit
  91. Descendant or weapon r intake manifold??
  92. SEMA Week special!
  93. PTUNING: 400whp Ptuning spec-ss turbokit @ 20 psi, 91 octane w/WMI 3" catted exhaust
  94. ATI Super Damper Harmonic Balancer
  95. Need Greddy Ultimate N/A base map Plz
  96. Not sure what is causing this?
  97. wastegate source COMPRESSOR, or BRAKE BOOSTER..
  98. Injector response time
  99. Tuning question?
  100. checking CEL's without a scanner....? jump port?
  101. Help needed urgent!
  102. SEMA 2009 Sony / Gran Turismo "Best of Show" Asian Import
  103. This is why you need FUEL RETURN SETUP!
  104. I need a break....
  105. which ems
  106. TURBO LIST
  107. Can i Make 350whp on 91 octane?
  108. Aem Fic For 2005 TC?
  109. Taping stock fuel rail for return line
  110. Stock Block/Stock Head +7PSI, E85, NO TUNE+Wire Tuck+ABS Relocate (01/17/11)
  111. can this be done...
  112. difference in 2 psi
  113. Clutch Masters Stage 5
  114. this is why nitrous oxide has a bad reputation
  115. A warning to all my boosted brethren (pcv fail)
  116. My venture with greddy ultimate.
  117. little help installing boost gauge
  118. FIC current draw?
  119. scion_andrew official turbo thread
  120. lock it up!!!!
  121. Help with emanage ult. a/f output afr
  122. Balance Shaft Removal - Socket Size?
  123. clutch install
  124. Why has Hieu been gone you ask?
  125. f/ic maps
  126. SoFloTC - MTuned PAGE 3!
  127. ATTN: Dezod Customers
  128. Great prices on short blocks and other scion parts
  129. Gompka build - Running great!
  130. Need a base map to get to the tuners
  131. ?RS-232 port?
  132. K1 Rod with OEM Pistons? Thoughts Please!
  133. injector clip wiring question
  134. WRX 02-05 injectors on a tc?
  135. need help bad and quick
  136. Mishimoto intercoolers? What ya think
  137. my issues with detonation at 6psi...help
  138. kind of wondering
  139. Engine Hone Cylinders Nikasil or What?
  140. custom exhaust questions
  141. to UN-supercharge the TC
  142. Nitrous
  143. zpi 16g turbo manifold.....need help
  144. hks/greddy BOV adapter for trd supercharger NEW VIDEO pg 2
  145. need 08 ecu pinout
  146. M=tuned offical theme song.video
  147. do we have fuel cut?
  148. replacing hard fuel line
  149. Soflo: M-tuned
  150. High rpm = P0335 (crk position sensor failure)
  151. What intercooler pipes for a turbo toyotas v2.1 kit ?
  152. Turbo timer question
  153. DRAG racings first 6 second FWD pass
  154. TRD Supercharger '05 TC Failure
  155. Ti manifold.....
  156. BOV problem???
  157. Descendant Head Studs 05+
  158. NSCRA Season Finals
  159. PLEASE! help with street tuning the aem fic w/700cc
  160. just a tip
  161. boosted + hard driving = Thrashed Tranny lolz
  162. PTUNING: Early Holiday Specials (lots of parts for FI Scion tC) - exp. 11/30/09
  163. car wont start
  164. what could this be???
  165. great FML misterious oil
  166. Greddy turbo upgrade to external wastegate
  167. Injector O rings
  168. What is are max perfomance on stock block.
  169. meth injection questions...
  170. Issues with car idle at start
  171. 400whp Clutch? Recommendations Please.
  172. ** EDIT **
  173. ?.. an another question!
  174. TURBO!!!!!!!!!!!!!!!!!!!!!!!!!!!
  175. Boosting in Spring of 2010...However I have some issues.
  176. can you help and share??
  177. aftermarket FPR on returnLESS system?
  178. Best DD Clutch for 300whp
  179. If you could build your transmission....
  180. TRD reflash + aem fic = :(
  181. how to get trd reflash?
  182. Dezod mani problems w/ custom 3" exhaust/downpipe??
  183. what spring to get in BOV?
  184. need a 2008 tc aem fic base tune
  185. NEED BOOST ELECTRONICS help
  186. Return Fuel Line - For who?
  187. AEM FIC TUNING QUESTION?
  188. HELP!!! nasty CELs keep coming and going away...
  189. Random multiple cylinder misfire detected
  190. Another problem... This time Tranny related.
  191. Coolant Lines?
  192. Dezod Sleeved Short Block + Dezod Head
  193. *VERY IMPORTANT before installing new head!* 2AZFE Valve Clearance Procedure for DL
  194. Boosting and super lean
  195. Buddy Club Racing Spec Digi Meter Exhaust Temp
  196. Tuned a car today, Then had a race!
  197. adjustable fuel psi regulator need some pointers
  198. Exhaust Piping for a Turbo?
  199. Tuned by Church dyno sheet!!car pics up
  200. Turbo broke my windshield strip! lolz
  201. 650cc tune with 630cc injectors
  202. for those who think their tune is conservative....
  203. turboed car maintance
  204. Anyone running the fic along with bc f/i cams?
  205. "Mastertech86" Dyno
  206. im back, wtfs with the new site.
  207. 60-1, Built Motor, Dyno Sheet UPDATE!
  208. Turbo doesn't line up
  209. Dezod is moving!
  210. calling all people with turbonetics kit
  211. wastegate fitting
  212. All Greddy Ultimate guys.. quick question? And one more added!
  213. blah problems
  214. FIC to log knock.. THEORY.. Test tommrow
  215. 2005-2006 "AEM BASE MAP" Plus Tuning GUIDES
  216. Revamped Tech Notes (V2.0)
  217. Making Your life easier when using AEMLOG WITH FIC
  218. Boost at 70k
  219. need a map to get me to the tuners
  220. Fuel Pressure
  221. Intake Manifolds: Descendant Racing vs Weapon R
  222. brake light malfunction?????
  223. Mmm check out my bearings
  224. Max HP Based on CC's/PSI/Duty
  225. 08_Scion_tC Build/Pic Thread
  226. Greddy ultimate jumper settings.
  227. Swapping a TRD reflashed ecu
  228. $700 OEM TRD Supercharger
  229. ACT clutch disc question
  230. Final numbers with dyno vids
  231. TCKID631's build thread
  232. 300whp + stock clutch = going no were
  233. Cheaper shipping FTW
  234. HELP, Supercharger drive pulley stuck
  235. wrx turbo?
  236. Ebay turbo kits.. At all time worst!
  237. greddy ultimate vets
  238. emanage blue usb cable?
  239. Ptuning SS Fuel Return System review & Install Pics
  240. DONT GET BOV WET!!!
  241. Oil pan removal need advice.
  242. DESCENDANT powered tC 314WHP @ 9psi *video & pics*
  243. Tuner in Washington State or Oregon
  244. Dezod Black Box over 16 psi
  245. TRD SC sound changed
  246. supercharger f'ed
  247. Well, It's Been 3 Years - ALL NEW STUFF, Doesn't End How You Think.
  248. toeveryhour + turbo = incredibly awesome + DYNO SHEET = finally
  249. Draw-thru vs blow-thru MAF setup?
  250. Installing S1 Dezod kit. Couple quick ones...
