View Full Version : Scion tC 1G Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35
  1. NA AFR Readings
  2. CXRacing
  3. help with dezod s1 kit
  4. selling my car
  5. Bearing sound
  6. PTUNING: Spec-SS Turbo Kit (Automatic Scion tC) - Updated Pics!
  7. WPC Treatment (Tranny)
  8. cburglb34 test run 6psi stock exhaust
  9. need some help car acting funny
  10. OBD II data logger suggestion
  11. New location, new phone number, no heat yet!
  12. Intake Manifold & Throttle Body Flange
  13. Has anyone switched to E85 on a supercharger?
  14. too good to be true?
  15. Clutch Time
  16. cold weather idle
  17. etd?
  18. FASTEST SFWD Drag Race Scion tC
  19. The TC and more power
  20. cburglb34 dyno sheet
  21. M=Tuned!! , Thanks Justin and Mike
  22. Greddy Turbo
  23. Some Darton MID 2AZ sleeve stuff...
  24. What exhaust system are you using?
  25. BACK AT PTUNING (290 or bust) 3-9-10
  26. vacuum line size
  27. CEL post turbo install-Now a different code....
  28. PTUNING: Spec-SS Turbo Kit SPECIAL (1 week only - exp. 01/18/10)
  29. OS GIKEN LSD owners
  30. aem injector size change?
  31. AEM F/IC MAF Clamp
  32. 2.5" TuRbo Back exhaust or 3" Turbo Back exhaust
  33. so i've got "trust"
  34. Help!! Stripped Head Bolts 2.4L 2AZ-FE
  35. Emanage blue maps
  36. hp rating stock connecting rods
  37. Boost Works Turbo tC Build TRACK VIDEO
  38. assembly order...
  39. The new pro EFI computer system
  40. re-threading oil pan bolts
  41. boost controller
  42. Version 1 and 2 Pressure sensor?
  43. Not getting full boost???
  44. Vacuum Manifold setup
  45. HKS GT Supercharger....
  46. Need help plz code p2237
  47. ProEFI information
  48. running AEM FI/C with stock car
  49. Dezod Short Block Information
  50. oil pan tapping
  51. If you own a TRD SC read this, another horror story
  52. Normal Oil Pressure + Balance Shaft Delete
  53. Need help installing aem ems ASAP! please
  54. traction stuffs
  55. ProEFI Flex Fuel Video MUST SEE !
  56. boost with no gauges
  57. Turbo Fitting
  58. ptuning automatic kit yay
  59. The future looks bright for us Check out G's boosted FT-86
  60. dezod+ kaminari hood= fail?
  61. help me out here
  62. tC won't start
  63. Engine management advice needed
  64. To Someone With A Automatic Dezod Turbo Kit
  65. 6 speed swap
  66. **CBURGLB34 build thread ** UPDATE AT PTUNING 1-20-2010
  67. Stock fuel pump and fuel rail with 440cc injector
  68. Help on white smoke coming from exhaust...
  69. question about turbo timer
  70. Any other superchargers!
  71. My turbo build finally about to start!
  72. AEM Uego to Emanage Ultimate
  73. Next Gauge...
  74. treadstone turbo injectors size?
  75. wish me luck guys... UPDATE PG 3
  76. FIC ?: intercept or tap?
  77. Import face off 1/24/10 gainesville fl
  78. Anyone not using a hood liner on an oem hood?
  79. C&C tuned tc
  80. Turbo Question
  81. FML low oil pressure
  82. *UPDATE* Dyno posted New awesome numbers
  83. has anyone had any experience with customcarscentral.com
  84. wastegate spring size?
  85. white smoke from dip stick
  86. s/c feels bogged
  87. slim fan's
  88. lots of work ahead of me starting friday..
  89. TU Track day Recap @ NSS *Video update 1/28*
  90. EGT Placement?
  91. Cool new AEM monitoring/tuning products!
  92. turbo to na
  93. PTUNING Billet Aluminum Vacuum Manifold
  94. PTUNING: Turbo Manifolds v.1 for DIY (Slightly Used)
  95. Adjust FPR with Car Off and Walbro
  96. Whats the diff between 05-06an07-08 S/C
  97. i hate blown turbos...lol
  98. What type of oil is best for a turbo tc
  99. aem fic or greddy ult. better?
  100. Just an idea - Additional Injector
  101. 2AZFE Fuel Rail //Dezod Motorsports//
  102. Cars shutting off..
  103. TrackMasters app on the Droid *Video*
  104. Turbo Set UP
  105. Built motor not cranking. Help!
  106. blitz japan supercharger
  107. proefi
  108. 2az-fe uk
  109. help please?
  110. another reason why BLOW THRU FTW!!!
  111. turbo tc, the lowdown b4 the teardown
  112. Upper Oil Pan Removal and Oil Filter Hex Size???
  113. P-tuning kit hits the streets of Delaware Pics inside
  114. MAP FOR AEM EMS
  115. Head Gasket
  116. What Exactly Is A "Conservative" Boost?
  117. s/c tc going to dealer for engine noise
  118. top secret
  119. Greddy Emange Blue
  120. oil drain line
  121. What will they think of next...
  122. Custom Stage 0
  123. Don't pay hundred's to get ur motor mount's pressed in !!!
  124. FIC/6 Beta software version 3.06 available
  125. Radio Noise Suppressor Location
  126. Help...........How to test stock BOV/BPV
  127. Picking away at my install....
  128. HELP! aem fic problem!
  129. HELP...!! Going way too lean under load!
  130. gauge reading questions
  131. aem fic-now with 2step launch control!!! DIY up first page
  132. Engine Swap and LSD Install!!
  133. Considering BOV change...need advice
  134. Turbo Tc going back to stock...
  135. white smoke coming out!!!
  136. Anyone contemplated a GT3082R (GT3040)?
  137. 1000cc pnp injectors
  138. cleaning a turbo
  139. DEZOD????
  140. MOST POWER OUT OF AEM FIC
  141. greddy turbo kit
  142. emanage vs. emanage ult.
  143. Clutch Masters
  144. The Standalone/Piggyback ECU List
  145. What would you guys like to see offered?
  146. Dezod or Descendant
  147. Question about superchager pulley
  148. anyone else in vegas runin numbers
  149. AEM FIC 3.05 question
  150. Exhaust Manifold polishing
  151. JUSTIN (BLOWNXA) spotted! lol
  152. Tranny Slipping...Need opinions...
  153. Nitrous Tank CO2 compatability
  154. S/c Belt/Idler Pulley ( Need Help Asap)
  155. Couple questions
  156. greddy turbo=ball bearing???
  157. Watercooler turbo
  158. triple din gauge and cd player replacement, need some help.
  159. Gauge install
  160. Long overdue: APR Power In-line ECU Release (Screen shots PG7)
  161. s/c Belt issue
  162. Turbo Rebuild
  163. Vacuum manifold questions
  164. Does anyone have an 05-06 tc maf sensor around they can measure?
  165. edit
  166. Break Boostin 102....lol
  167. Gas pedal or Drive-by-wire issue??
  168. Braided Pressure Gauge Line
  169. Turbonetics Turbo Kit Question
  170. ahhh headache help please
  171. What's next???
  172. question about maf senser
  173. Anybody have a reflashed ecu F/S
  174. FIC / Built Motor / Stalling during decel
  175. Greddy Emange Blue
  176. FMU Engine Managment Unit - Would it work?
  177. Guess my WHP
  178. Automatic TC, already turbo'd, looking to add HP
  179. best turbo for A/T
  180. kaminari reverse cowl hood + t'netics turbo = ?
  181. SAFC on a/t tc?
  182. TurboToyotas FMIC Size?
  183. P0335?
  184. Another TurboToyotas Question...
  185. V-Manage
  186. aj (dyltone) at the track...
  187. ugh i got to figure out this traction thing
  188. Turbo Kits? Built Internals? Help Please!
  189. Going boost, could use some advice..
  190. ecu plug order
  191. turboo?
  192. 16g clocking ?'s
  193. Advice please
  194. S1 FUEL UPDATE
  195. cost for turbo kit removal
  196. base map car wont start....
  197. Turbo Help
  198. PTUNING: Spec-RS Competition V-band Manifold Turbo Kit (updated pics page 1)
  199. Kenny Strickler from ZPI & turbochargers.com
  200. Wanted : Info Regarding Kenny Strickler from ZPI
  201. help emange blue
  202. car Rotisserie ?s
  203. DEZOD MOTORSPORTS: ALPHA SERIES V-band Manifold Installed (Page 21)
  204. scionlife, help me piece together a turbo kit
  205. Ptuning VS Dezod S1
  206. Not reaching full boost
  207. greddy and turbonetics spearco intercooler dimensions
  208. Missing Threads? ▲▲ LOOK UP! ▲▲
  209. car wont start
  210. any DIY on AAM return fuel system?
  211. Turbo burning under hood liner
  212. s/c & shredded belt
  213. EMS
  214. Treadstone MAF adapter?
  215. MBC on Tial wastegate
  216. Completely stumped on tuning this thing...
  217. emanage ultimate Questions
  218. "J Pipe"
  219. Upgrading fuel injectors
  220. Need advice fast. Going built motor route in 2 weeks
  221. Greddy 20g turbo on a Scion Tc
  222. Any recommendations for a high-flow cat?
  223. aem fic part #'s
  224. Dezod Motorsports Return Fuel System
  225. Whats the difference...
  226. Going boosted next month
  227. looking to buy used SuperCharger for 07 TC..What should I watch out for?
  228. built head
  229. Can you anyone tell me if these are PNP fuel injectors?
  230. HELP! car is messed up
  231. 2010 WORLD Racing Episode #1
  232. engine damper or engine limiter?
  233. *Chris Rado / Continental Tires Scion tC Battle Wagon Video*
  234. Going for 10's...(NEW PB, 11.38@126.53!!! pg. 23, VIDS pg. 24)
  235. PNP Adapters for RC and other EV1 connector injectors
  236. OK... DYNO question?
  237. *NASA Pro Racing* WORLD Racing Scion tC Mar 12th-14th Fontana, CA @ AutoClub Speedway
  238. After 2 years, finally running my car tonight at the drag strip!
  239. doing some mantenance....
  240. F1 car engine break-in
  241. WORLD-racing.com presents "Go Fast or Go Home" by CHRIS RADO
  242. New DESCENDANT BOV replacement for Bosch BPV
  243. DESCENDANT Ver2.0 Scion tC Turbo Kit
  244. Fueling options
  245. problems need help bad
  246. back from track! 13.6 @ 104
  247. What do you guys think of these? Okada Projects Plasma Direct Ignition Coils
  248. Why did Scion quit offering the supercharger
  249. Need some help
  250. short block problems need help BAADD!!!
