- SUPERCHARGER...?
- MAX BOOST ON A TURBO tC with 3" DP BACK EXHAUST ???
- Need my turbo installed and tuned.
- The Magic Smoke: I'm Letting it Out
- Weird Idle Problem
- T/C
- Turbocharge Auto-Trans
- best performance
- Turbo kits
- TD04 turbo 13g
- Should I jump on this turbo kit? What would you suggest?
- Dezod/APR X1, who's got one?
- VSV boost leak?
- Built motor questions
- NOOB Boost Gauge Question
- HELP!!! I need to shed some light on this issue.
- I need a definite answer PLZ!
- SC boost problem
- reinspired!!!
- ECU ground location
- I <3 APR In-Line ECU
- automatic turbo.....where to start?
- what turbo is this
- Walbro 255, boost, and no tune ?
- painting an intercooler
- weapon r oil catch tank
- Cam Position Sensor
- Where did you get your Boomslang from?
- Greddy E-Manage Ult. Jumpers....HELP!
- Hydra owners...Need some help
- RC injector O-ring leak
- Turbonetic's turbo kit !!!!!!!!!!!!
- CF_KC_WIDETC is Finally Boosted and Tuned w/dyno results!!!!
- has anyone else seen this?
- HELP!! How much is just this worth? i need to know ASAP
- N/A Shake down 1/4 mile passes
- DESCENDANT Tuner Friendly Build update
- 05_ScionTC's build thread- Few questions on last page, need insight!!
- 05/06 ecu and harness on a 08 car
- Greddy E Manage Ultimate Trouble!!! PLZ HELP!!
- For those running E85...
- F/IC Issues TSB?
- removing intake manifold
- 10w40 In my Greddy Turbo Kit?? Thickerr Oiler?
- High Oil Pressure
- AEM FIC running rich when i stop
- 06 greddy kit fit a 09?
- Help with turbo decision
- RDX 410cc Injector PNP Scion tC????
- trd supercharger
- turbo tC at a track day: Epic fail
- DESCENDANT 3" S.S. Exhaust System
- just a quick question
- Precision Fuel Injectors?
- Tc supercharger problem!!!!!!
- help! anyone that may know paul @ dezods number
- Split Second: Fuel Enrichment Tool
- Lol another problem.
- Trd Reflash + intake = lean?
- WORLD Racing Episode #5
- removing turbo kit. help.
- Boost Controller information
- Help
- Customer feed back on Dezod/APR X1 inline ECU
- Dan Gardner Poly Motor Mounts
- Stock Fuel Pump
- Dezod Motorsports: Engine management writeup
- 2010 Full Dezod Alpha Series build... !!UPDATE!! NEW PIX
- Ideas for better cooling
- Oil Feed Fittings
- punctured the A/C condenser - Need inputs please
- Quick scangauge question
- Hydra Question
- Watercooled Wastegate
- boost gauge not reading boost
- Garrett turbochargers + Dezod Motorsports = WIN!
- Built motor roll call...
- Has anyone beefed up an auto tranny?
- Question about S/C Kit, >'<
- Just some random turbo tc vids for viewing pleasure!
- Prosport Gauge Issues
- can some one help me? im trying to upload my map from my aem ems. but i dont know how
- Guaging Intrest in a turbo kit. Need some insight
- 2010 Modified Tuner Shoot-Out
- Official WORLD Racing & DESCENDANT video thread **AWD BUILD**
- AEM Software Download?
- longest running stock motor turbo tc??
- Greddy Turbo Questions
- Couplers blowing off turbo, ideas??
- 07+ Emanage blue help
- AWD tC debut @ RedLine Time Attack Aug. 14-15th Sebring Intl Raceway *FREE TIX*
- will an 07 and up intake mani fit a 05?
- E85
- Descendant Turbo video
- NEED HELP! s/c belt diagram
- Custom Turbo Kit: Doggy Style! Round 2!!!! Pics and Dyno
- Turbo not boosting
- AEM F/IC Mounting Locations
- s/c + unichip = CEL
- where do i buy this shirt
- PVC thread size and pitch?
- Needing turbo help- first timer
- Throwing Code P0420.. Help?
- 10psi t/3 t/4 50trim
- To all you roll racers out there..
- Nitrous help
- RODS K1 OR BRODS??
- Dezod & AEM Fuel Rail ?
- Ken Gushi's RWD tc vs Ptuning tc drag race vid
- Return Fuel System Basic ?'s
- Top 10 power rating list.
- turbo tc not getting into gears
- TRD Supercharger issues
- turning up the boost
- Nst 9.5 psi belt Question
- trd reflash back to stock ecu
- 60-1 Turbo 465 whp stock 2AZ-FE E85 (Updated!!!)
- Is your computer smarter than the WOT box?
- Turbo upgrade time!
- 2009 scion tc with issues,
- help please: turbo troubleshooting
- can someone identify this IC piping
- 05 tC turbo build...HELP!
- replacing my head today
- AEM EMS
- My Dyno Sheet Tunes
- MAF Before of After the Turbo
- To those with hard pressure plates!!!
- I'M BAAAACCCCKKKKKK!
- Peak Boost Mani..
- Down the track!
- boosted tcs in jax fl area
- How many peeps used sleeves in their build?
- RC 550cc injector response time
- Future Turbo tc questions.
- Hot side gasket
- Tuning Basics
- PTUNING: Testing our twin-wastegate RS VBand Manifold w/GT35R @ the dragstrip (VIDEO)
- omg
- hey supercharger guys what size exhaust are you running?
- BDYER666 TC BUILD
- GREDDY KIT BASE MAP??
- Do TC axles bust pretty easy?
- DESCENDENT Turbo Install in my RS 2.0
- Dezod APR X1 Inline ECU Tuning Q&A
- greddy e-mange question
- RC injector clips
- WORLD Racing AWD Scion tC...finally unveiled
- FIC Tuning Issue / IAT Question
- Tune?
- aem boost gauge failure
- ATP turbo kit ??
- long time scion owner signing off...:(
- Car Runs And Quits??? Leaning Out
- low RPM
- Cometic Vs. OEM Headgasket
- Two BOV?
- Need a good catch can
- Turbos used for 15k+ miles then sold?
- article about scion tc (Last paragraph)
- Spraying the intercooler?
- To trust or not to trust?
- good or no good
- TRD Supercharger
- PSI and MAF - Clamp? What is it?
- ** EDIT **
- Phone problems
- AWD Scion tC **Build Video Added**
- No engine management @6psi: Safe or Unsafe?
- aem fic basemap for dezod s1 kit?
- Melting Vacuum Lines
- Boosted AT shift issues
- Random Studder , Now Permanent?
- Emanage Blue Map for 9.5 lb Supercharger Setup
- VSV/Evap? Vacuum line location?
- Want to turbo my tc and other upgrades, budget 10k
- Scions have another new home!
- Different wg spring or boost controller
- DIY ECU PnP Harness
- turbo question
- Ptuning Turbo kit at work! (339WHP@12psi)
- Turbo w/ stock ecu
- Looking to purchase a Turbo Kit NewBie Needs Help
- PTUNING: New Turbosmart Comp-Gate40 40mm v-band wastegate
- T3/04E, 11psi, and e85 - how much fuel?
- New New New Stuff....
- Turbos is CA
- awesome tune at PSI!
- Iac valve?
- Dezod S2 Kit Catted or Catless?
- D-Sport Magazine Cover Oct. 2010
- turbo set-up
- Looking For A Dyno Tune On My E-Manage
- simple kit turbo question
- BOOST PROBLEM PLEASE HELP!
- looking for interest
- SAFC II???
- MAF plate?
- Can i hit 450+/-??
- Low Impedance Injectors with stock ECU/FIC
- I need a good tuner in NJ
- Crazy FIC Tuning Issue
- turbo or supercharger?
- Guys w/ ACT Clutches (Specifically TY4-HDMM)
- Clutch Issue UPDATE PG 3. HELP!
- Boosted Video
- I need your help!
- Injectors: Sizing for your needs!
- DESCENDANT intake manifold gaskets?
- Tuner/Installer Colorado?
- EXHAUST
- Bogging/stumbling and check engine light flashed three times.
- Can it be rebuilt?
- This is kinda cool!
- Custom Exhaust
- Need Help ASAP on ARP head studs
- Noob to Turbo question.
- HELP... Returning S/C tC to N/A
- 700cc Injectors & OEM Fuel Rail
- E85 Timing
- help is needed.
- FX600 Twin Disc Clutch
- Oil filter sandwich plate adapters....
- flywheel for boost..
- Issue Starting Car
- Perferred intercooler
- New Engine Start Up and Break-In
- how long will boost last?!?!?!?!?!?!?!?
- How to reset stft and ltft?
- DG Spec & Scion Clinches World Challenge!
- Turbo tC Engine bays... lets see 'em!
- vs. the World updated 9/21 w/*HD video loaded pg2*
- Need turbo help PLEASE!!
- turbo
- Calling all supercharger owners!!!!
- Turbo Heat Blanket
- Need Help On Supercharger
- AWD Scion tC 2-Step Test
- E85 Injectors
- What do you think about this kit
- Supercharger Question
- New Build Part2
- Understanding the ECU
- Back, Need fueling opinions
- Rich cruising A/F ratio
- Hot lap video's of both the WORLD Racing Scion tC's
- My license plate is faster than yours!!
- BLACK MAMBA Boosted*pics inside*
- Whats your favorite FI tC clutch?
- Too rich under boost
