View Full Version : Scion tC 1G Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36
  1. Car smoking on decel
  2. At what hp range should u look into a return system ?
  3. Pre-tune checklist
  4. do anyone have a 700cc injectors basemap that i can use
  5. Boomslang PnP harness for Emanage Ultimate
  6. Gaskets and hardware
  7. FX 500 Twin Disc
  8. Exhaust manifold stud length?
  9. Boosted back to stock?
  10. o2 sensor wiring issues
  11. Comp Test Results after 60K boosted miles
  12. Inquiry about switching to blow thru maf
  13. Watch it Live
  14. aem fic will not connect
  15. installing greddy ultimate harness
  16. i need help with harness
  17. Getting ready for dyno tune tomorrow!!!
  18. GTX30R VS. GTX35R
  19. 2006 Scion Tc
  20. heating issue
  21. custom intercooler piping
  22. Water meth nozzle placement ?
  23. Can I run 630s
  24. Possible fix for P0102 with p0113
  25. Pre-tuned?
  26. idle after tune help help help
  27. Serious question...
  28. Need some help - Lean after header install
  29. Stalling Issue
  30. Unusual issue today
  31. Gotech Pro X?
  32. tc not allowing boost?!?!?!
  33. tbs
  34. supercharger boost issue
  35. turbo oil return line flange bolts
  36. what could be causing this
  37. DG Spec is getting it done! Another 1st place enduro finish
  38. stupid question about afr's under boost
  39. help! replacing auto transmission
  40. Ptuning and dezod?
  41. SC pulley what is on my car
  42. need some turbo help
  43. Lets see what ur workin with
  44. Apexi AVC-R
  45. Boost Leak Test Thumper
  46. s/c bad bearing?
  47. Aftermarket header with SC heatshield
  48. Draw through or blow through MAF mounting that is the question!!!
  49. Turbo oil return line question
  50. The boost veterans may be needed on this one
  51. Leak down test
  52. Easier Alpha....
  53. AEM EMS for Scion tC
  54. How to install HKS SSQV with 05 TRD S/C???
  55. Fuel Help
  56. cylinder #4 no compression
  57. throwing codes?!?! help!
  58. oil consumption with turbo
  59. How much to ship engine??
  60. Who sells a TRD S/C adapter for HKS BOV?
  61. just remove intercooler pipes and find oil helppp
  62. SC Question
  63. PTuning Equipped tC's turn heads @ track
  64. Some Turbo Shots
  65. Oil catch cans with TRD S/C questions!
  66. Rebuilt Turbos
  67. Scion TC 440cc Injector problem.
  68. Boostit06's Build thread... UPDATE 12/15/11 More Power!! Page 3
  69. p0037 wont go away
  70. New DW301 Fitment for MY05+ tC!
  71. Cranking but no start
  72. Turbo Life Video New!!!
  73. Blown Head gasket
  74. Help AEM FIC 55mm pulley TUNE
  75. hard starting
  76. plug gapping
  77. Intercooler install help
  78. News and updates from Dezod.
  79. ECU "long term memory"?
  80. cut out at WOT!!!!
  81. fic turbonetics 440cc 8 psi/wastegate ?
  82. vacuum line size
  83. uni chip or aem fic???
  84. Cant get rid of turbo flutter/comp surges Help
  85. What else do I need?
  86. external wastegate or internal wastegate
  87. Count down to ALPHA! (UPDATE FINALLY!)
  88. Spark plug suggestions for S/C TC
  89. Looking for scion tc gauges!
  90. Tune
  91. Blown Head Gasket
  92. Cryo/REM Treatment
  93. Non-Sleeved Short Blocks & Ported, Built Heads
  94. not building boost
  95. Exhaust Size for 300hp Range
  96. Synapse bov question
  97. *EDIT*
  98. Where can I get these parts to my turbo?
  99. DG-Spec and Scion Racing Ready for Three Hour WERC Endurance Race
  100. Teaser
  101. Reflashed ecu??
  102. Supercharge 2008 Tc
  103. Supercharger suddenly rough idle louder rattle noises. Why? Bad?
  104. Engine Assembly - RTV ?
  105. BOV Flange Question
  106. help help help.....af/r inside
  107. Tial mv- r 44mm coolant passages
  108. The finest in fuel injection is here at Dezod...
  109. Calling all supercharged Tc's!
  110. T3 bolts too short for downpipe flange, help??
  111. Battery Relocation
  112. twin 38mm wastegates
  113. Primary o2 delete
  114. 400LPH in-tank pump now here!
  115. Updated pics 10/21 - 05 Supercharger rebuild/repair questions, pictures, progress...
  116. loud clacking noise
  117. VIDEO Can anybody tell if this noise from supercharger is normal?
  118. Calling S/C owners, how did you guys get these bolts off???
  119. Throttle Body Connections
  120. Supercharger orange rust
  121. Throat of the dragon
  122. best kit for my money
  123. Trd Supercharger ??
  124. balance shaft oil passage
  125. 07 engine to 06 engine...
  126. 06 supercharger fits 08? and supercharger questions
  127. Warm Start problem
  128. [VIDEOS] S/C guys, have good ears?? Anyone try 928 Motorsports s/c rebuild???
  129. Supercharged Scion TC with 9.0:1 Pistons
  130. LET THE BUILD BEGIN!!!
  131. turboed need new clutch?!?!?!
  132. Chip choices for 06 tc?
  133. Feeler: OS Giken LSD Group Buy?
  134. High-volume fuel pump = increased fuel pressure?
  135. 80k miles
  136. TUNE help needed
  137. Greddy SCC Speed Cut Controller
  138. Quick ??
  139. Looking for feedback
  140. Boost Gauge
  141. New aem hawtness to be released!
  142. TRD S/C Idler Pulley Replacement
  143. My Build List
  144. Need a place to install and tune!
  145. journey back to stock
  146. SOmeone with ptuning water injection kit help me please
  147. S/C 2010?
  148. I need couplers.
  149. Head studs...
  150. 09 Turbo concerns
  151. 2.5in or 3in exhaust ?
  152. Injectors for supercharger
  153. Looking for a Block.
  154. aem fic on 2007 with turbonetics
  155. bored and have a question
  156. Anybody out there rebuild S/C shafts?
  157. future ptuning products
  158. Upgrades to supercharger
  159. CM fx500 vs CC Stage 5
  160. Mechanical Oil Pressure Gauge Setup
  161. in need of s/c parts
  162. turbo size
  163. e351 tranny
  164. longest auto tc lasted????
  165. Guess how much our Display case weighs, get a free AEM wideband
  166. Supercharger Sparkplug Gap
  167. ZPI mani Problem
  168. K0rupt's Progress over this year
  169. oil cooler.. Is it worth it?
  170. ZPI Kit swap to TT mitzu manifold Update
  171. Wideband Bung on header?
  172. DG Spec places 3rd in 25 Hours of Thunderhill
  173. Camry 2.4L 2azfe
  174. Need info/suggestions with gauges....
  175. APR X-1 getting p0500 code
  176. Piston Ring Failure :(
  177. Stock motor 60-1 or gt35
  178. More ARP goods for the 2AZ....
  179. open dump or recirculating
  180. Warranty
  181. TRD Flash Question
  182. About to go turbo
  183. help with Fuel return system
  184. Auto TC Turbo FIC Battery Drain Fix
  185. car stalled now rough idle (any advice)
  186. home made or kit
  187. Base map
  188. ? for people running 550's w a 255walboro w/ fic
  189. Godspeed wastegates and BOVs
  190. Big Thanks to Lethal Injection Motorsports!
  191. WillUpdate Pictures Soon** - FINALLY AFTER TWO YEARS OF TALK - My 05 build
  192. Merry Christmas!! now what did you get for your car
  193. High Velocity (CFM) Radiator Fans
  194. P0304 & P0300 Code....Need Advice
  195. Car still smoking need help!!
  196. Apexi SAFC2 Turbo Tune
  197. IF you could REDO your build
  198. Codes on a Turboed tC
  199. Supercharger upper radiator Hose part#?
  200. Need help identify these fans.
  201. The *REAL* Stock tC Injector Size (310cc/320cc/370cc)
  202. I'm looking for a zpi turbo manifold. Please help!
  203. Low oil pressure - SPEAK UP 2AZ GURUS!!
  204. Vacuum box?
  205. is this turbo kit good?
  206. aem fic base tune (yea i know)
  207. got to love turbo TC's
  208. turbo install question
  209. supercharger/turbo swap
  210. aem fic & 2 step
  211. stock internals? or replace?
  212. Turbo ?
  213. MAF delete - emanage ultimate
  214. Turbo Timer Problems...Please Help.
  215. S/C oil change help
  216. BOOSTED!
  217. FIC Tuning Help
  218. Oil Plate Sandwich Adapter/oil cooler?
  219. VIDEO: WORLD Racing unboxes Innovate Motorsports MTX-L air-fuel ratio guage
  220. Built engine vacuum please post yours
  221. blow through question
  222. I need help with installing synapse bov???
  223. Turbo/downpipe/spipe not lining up??
  224. Just got refereed here in good ol' california
  225. Help: Need Hydra Basemap
  226. Plans for 2012
  227. WORLD-Motorsports PNP AEM EMS2
  228. ID 1000s
  229. 05-06 & 07+ MAF Bolts diff but what about Harness Clip?
  230. Reflash ECU
  231. Turbo melting fan housing
  232. 2007 tc maf code
  233. aem fic harness
  234. 2006 Scion Tc Supercharger AT
  235. Turbo
  236. Racing Spark Plugs
  237. NST FEELER THREAD: Anyone Need TRD SC IDLER Pulleys?
  238. *EDIT*
  239. WORLD-Motorsports Build Short Block
  240. vacuum block
  241. TRD supercharger parts
  242. Need advice
  243. ordered my aem fic harness from dezod now install time
  244. Can someone help me replace SC shaft bearings?
  245. finally boosted
  246. spark plug question
  247. 2AZ-FE Removal?
  248. Post up your drag slick and wheel set-ups.
  249. Will I need slim fans (fitment/clearance question)
  250. Bouncing idle (after tune)
