View Full Version : Scion xB 2nd-Gen Drivetrain & Power
Pages : 1 2 [3] 4
  1. Getting a CEL from an intake change.
  2. my goal
  3. headers...
  4. Throttle Body Port and Polish DIY (56K friendly)
  5. How difficult is a CAI install?
  6. T R D C A I
  7. Dealer Options
  8. trd sparks
  9. DYNO AGAIN INJEN PULLEY AND HEADER
  10. 5speed vs Auto
  11. Already burning oil?
  12. strup headers vs weapon x header
  13. Inside fuse box location for 2008 xB?
  14. AEM CAI Installed!
  15. A question about driving with an automatic...
  16. 209 Scion XB AEM Intake
  17. Transmission cooler installation?
  18. V8 scion xb
  19. Help with a problem im having
  20. Custom Exhaust Issues, HALP!
  21. Does anyone having this problem??
  22. Weapon R Header Install
  23. Ebay Exhaust
  24. GReddy SE!!
  25. Custom Exhaust Opinions please
  26. Fujita intake pipe?
  27. xB 2.4 turbo kit: 5psi for 200hp usistock fuel and ignition.
  28. Question For Anyone Who Has the TRD Exhaust Option
  29. induction help
  30. Brake Rotor Question
  31. Brake Hoses
  32. Anyone got reference to Brake Rotor and Pad Installs
  33. WHEN TO REPLACE TIMING BELT?
  34. From "D" to "S", always start from 3?
  35. Can I lock the doors, using the key, with DOORS STILL OPEN?
  36. Custom Five Axis Kit Exhaust
  37. if i switch out the sucba tank
  38. Shell Nitrogen vs BP Invigorate Fuels - Results
  39. Looking for a smooth bore TB spacer for tC/xB2 (2AZ-FE)!
  40. New clutch = 'VSC OFF' & CEL
  41. HELP! Air trapped in cooling system?
  42. Ingles Stiffy
  43. Exhaust Opinion & Poll w/ pics & video clips
  44. S pipe question
  45. universal 80mm throttle body
  46. Radiator Hoses
  47. New member...
  48. Weapon R Header & downpipe + TSUDO FIREBALL CATBACK EXHA
  49. Anyone thought to use a cooler radiator thermostat?
  50. Tenzo R or Weapon R CAI? I need help
  51. Radiator Diversion Panel
  52. Long Overdue, but performance is finally here!
  53. TRD short shifter
  54. Volo Performance Chip?
  55. scuba delete, and originality
  56. What kind of engine oil you use?
  57. Sluggish poorly responsive auto trans...
  58. OBDII scan tool discussion thread
  59. Weapon R Race Sheet Metal Intake Manifold 2003-07 Scion XB
  60. New Release 08-09 Neo Titanium treatment Weapon R intake manifold
  61. 5 Speed problem anyone have this happen?
  62. Weapon R Header and test pipe for SCION XB 08-09
  63. ERZ performance Stock TSUDO Now
  64. Top speed of stock xb?
  65. WS Tranny Fluid Question
  66. universal headers?
  67. Your pick, what do i buy next?
  68. front o2 sensor?
  69. Which muffler sounds better?
  70. Pulleys
  71. Spark Plug Duration
  72. Need new clutch @ 45k Miles
  73. Performance Plan
  74. 2010 xb auto trans fluid checking
  75. Throttle Delay, Rough Idle... MAF sensor?
  76. Down to 3 exhaust...
  77. Ordered My CXR Header!
  78. First oil change
  79. Gen 2 Stock Airbox Question?
  80. NEW FROM NST: Scion xB2 Short Shift Kit!
  81. Cxr header installed
  82. Cleaning the intake
  83. Not happy with exhaust, next step, scuba delete?
  84. ** EDIT **
  85. THINKING about machining STS's
  86. Why does the intake tube make a loopty loop?
  87. Will a TRD tC exhaust work with the XB's?
  88. Tenzo R- CAI INTAKE VIDEO THREAD!
  89. Check Engine & VSC light on.. need some help
  90. AEM Bypass Valve
  91. tenzo r intake
  92. Remove charcoal filter on TRD CAI?
  93. TRD Cold Air Intake Write-up with (lots of) pictures & video
  94. Engine noise on 2010 xB
  95. Borla Axle Back Install with Pictures and Video
  96. Anyone try the Unichip yet?
  97. AEM Intake
  98. VSC OFF and ABS came on at same time
  99. PCV Valve Location
  100. Anyone hear of this noise?
  101. What is a good cold air intake?
  102. dual exhaust 2010 xb
  103. CAI. Vs Short ram air
  104. Dual Exhaust for RS6.0 with 5 Axis Kit
  105. Axxtion STS SoCal Test Fit for FREE
  106. Tosted clutch = New mods
  107. Shifting in a Manual XB2
  108. Is the 2010 xb going to be included in gas pedal recall?
  109. Oil level too high?
  110. questions about camshafts
  111. Which mod next?
  112. TRD CAI and Rain
  113. Broken Synchro: SCION will not warranty repair
  114. front wheel drive/traction control
  115. Ebay Exhaust
  116. current exhaust standings
  117. Electric steering power steering issue when below 32F.
  118. Auto Tranny Shifting
  119. Why was the tranny post locked???
  120. Where is the radiator cap on 2010 xb
  121. TRD sport exhaust
  122. K&N Intake Install on xB2
  123. Replacing Plugs
  124. Lame Tranny
  125. Does our 2.4L have a knock sensor?
  126. NA
  127. side exhaust
  128. Strup exhust and headers?
  129. Brian Crower Cams
  130. All at once....
  131. Post up pics of your xB2 engine!
  132. Help! Where's a Hot Wire??
  133. TRANSMISSION QUESTION,HELP
  134. Center Exhaust NOT on a RS7.0
  135. Scion xB lower motor mount
  136. Headers? Throttle body spacer?
  137. What good power mods are there?
  138. Valvetrain for XB
  139. customer dual exhaust
  140. True 2.5" full exhaust?
  141. Gude Performance 2AZFE Cylinder Head Package: Scion tC / xB 2.4L
  142. 2008 Weapon R 2.5 S-Pipe?
  143. fujitsubo exhaust
  144. Engine Cover: Same for xB and tC?
  145. Clutch DIY?
  146. TRD CAI & exhaust installed. Happy camper here
  147. Motor
  148. xB1 & xB2 Intake
  149. Upgrading the auto tranny
  150. Strup Header
  151. parts
  152. DC Sports Race Header??
  153. New Clutch Question
  154. Borla Dual Exhaust with Five Axis Kit
  155. Link for site that shows ethanol free gas stations
  156. headers
  157. Gauging Interest: Adjustable Throttle Controller Group Buy
  158. Manual Transmission issues
  159. Feeler...cat back exhausts
  160. new carbon fiber engine cover needs new nuts to screw it down!
  161. towing
  162. Anyone have an AFE intake for the xb2?
  163. Scangauge 87 vs 93?
  164. Ordered Unichip today
  165. Clutch pedal squeaking
  166. RE: MT clutch pedal position (DIY in post #7)
  167. Torque Damper
  168. Switching to eneos?
  169. New Exhaust Mounts
  170. OBX LSD any good?
  171. Surge Chip for 2011
  172. XB performance parts.. made my xb quicker
  173. Reducing MT shift throw (shortened shift lever)
  174. 2 gen xb bolt on parts
  175. Clutch feels different after driving for an extended time?
  176. DC Sports Exhaust
  177. Clutch squeek?
  178. TRD short shift kit
  179. Does the strup cat-back have drone?
  180. clarification anybody?
  181. Anyone have dealer change WS auto tranny fluid early?
  182. TRD (xB2) CAI Installation Order
  183. 0W20 to 5w20..horrible mpg?
  184. 2011 Scion xB Injen Cold Air Intake Install!!
  185. spark plugs
  186. 2009 Scion XB (4 Cylinder) 0-60
  187. Thicker 2AZ-FE head gasket?
  188. RE: MT shift cable bushings (my impressions and a DIY)!
  189. Scuba tank options?
  190. NonStopTuning 20% Underdrive Pulley Install Thread
  191. Crank Pulley Bolt Torque Recommendation
  192. About to help a friend install his header...got a question.
  193. Partially tuned N/A xB2 with NICE results
  194. Another Catback Possibility Feeler
  195. Shifter Cable problem Need help please!
  196. An observation about VSC
  197. High Flow Cats...
  198. Tsudo V2 dual exhaust for 5 Axis kit?
  199. TRD Supercharger questions. Plus Dyno graphs.
  200. Scion xb, rumion awd conversion
  201. help me justify a reason to buy/not buy a weapon R intake manifold...
  202. Shortened Manual Shift Lever (followup)
  203. has anyone else had any similar drivetrain problems?
  204. TRD or Strup exhaust??
  205. Magnetic oil Plug need on XB2
  206. New: DC Sports Cold Air Intakes
  207. 2005 Scion XB A/C Clutch Test
  208. Anyone wanna trade a TRD bumper vent for the OEM?
  209. How much oil do you usually drain?
  210. Tanabe exhaust install...
  211. Forjworks Billet Coil Pack Cover
  212. Weapon-R Secret Weapon Intake Installed
  213. Redline?
  214. Strup headers and CEL delete?
  215. The Ultimate CEL Eliminator?
  216. Insulate your CAI?
  217. 2Qt's oil in 5500 miles
  218. New To Scion... but love to go fast.
  219. Header Hiss?
  220. Intake
  221. 12.5 to 1 compression pistons
  222. where to find carbon fiber valve cover?
  223. Crank Pulley
  224. Remote engine start deal!
  225. Resonator Delete.
  226. Weird Engine Sound
  227. 2011 AWD xB
  228. Cold Air Intake, Which one?
  229. XB2 Exhaust
  230. flywheel
  231. ebay intakes
  232. Battery wire guage.
  233. SELLING: 08-10 xB TRD Cold Air Intake
  234. Rich AFR after filling gas tank?
  235. Rough idle after shorting battery terminals
  236. Engine Oil
  237. Cold Air Intake
  238. Rattling Noise When in "D" or "R"?
  239. tenzo r cai
  240. coupler hose
  241. speedo
  242. Fujita Intake =]
  243. rear brake squeal upon releasing the pedal
  244. Mishimoto xB2 Aluminum Bolt-In Radiator
  245. Play in the shifter...
  246. xB2 Short shifter D.I.Y.
  247. Ruff idle
  248. xb2 auto trans fluid change diy
  249. Shift kit for auto transmission
  250. short shifter
