- Cyber Monday
- Complete Manifold back exhaust.
- CX Racing exhaust questions
- Inexplicable problem...
- WTB - xB S/C Parts
- Converting my Trans
- 2011 Xb CEL & Traction Light... No Power
- ECU Tuners?
- xB3 power?
- Does anyone use this scan tool program?
- 2008-2011 xB2 Tanabe Sustec-Pro Under Brace
- loosing engine oil
- Throttle body spacer
- Exhaust for power..
- '08 XB, VSC OFF light on... HELP
- Engine torque damper
- Thought I was burning oil, but might be a leak.
- Headers
- xB Dyno!
- What's the effect of removing the noise baffle from the OE intake hose?
- Manual Trans
- questions about an lsd?
- Auto Transmission + - M
- 2AR-FE motor swap in with 6 speed auto
- Ebay CAI
- WTB: 2010 Scion xB Manual Transmission
- Valve cover question..
- Idle Adjustment Screw?
- Xb2 highway rpm...manual vs auto?
- Auto trans, anyone else have a decent thud going into reverse+drive?
- Need to add some coolant -- trying Peak Global
- Valve cover: paint or polish?
- Ebay: a review.
- Borla Dual Exhaust With Hitch
- DC Sports SHR4403 Header (anyone have it yet?)
- leaking timing chain cover?
- Power steering fluid reservoir location
- Need new clutch
- Anyone running the Weapon R s-pipe?
- eRam Supercharger anyone? An interesting read!
- My eBay header project :)! (Includes DIY info)
- Any 'S' pipe alternatives that don't cost an arm and a leg?
- So, what do you experts make of this piece of ...!
- Fuel Injectors
- Best Exhaust size?
- Louder?
- Valve cover deal!
- NST short shifter?
- straight pipe?
- 'S'-Pipe upgrade to complement my new header
- Strup or HKS?
- TC Steel Braided Clutch Line?
- New performance parts?
- Strup or HKS?!?!?!
- Greddy SE Spectrum Elite Exhaust
- RS 7.0 center exit exhaust?
- 3rd Bad Ignition Coil
- Poping sound
- So I went to Capitol Raceway tonight and...
- 2007 TC valve cover on a 2009 XB
- 2009 xb with bad coils
- Camshaft Timing Oil Control Valve
- Installed Tsudo Fireball exhaust
- Looking to get a new Exhaust system...
- xB on the Dyno I/H/E Auto
- Drain Plug Torque 2008 xB
- Flap - Oil Filter
- cars dead
- Magnaflow catback installed
- need complete exhaust
- 2009 xB2 clutch chatter
- Adjusting idle?
- Weighing my options on radiator fans
- Clutch issue!
- xb exhaust help
- How long did your original battery last?
- intake help
- How to clear a fixed CEL w/o battery disconnect?
- My Homebrew CAI Version II :)!
- 2 bad coil packs, guess what the dealership said??!!
- Short of turbo or head porting, what else can be done?
- Occasional rough idle, low power, engine bogs
- Noisey clutch pedal
- 2008 XB + Fastscions.com Turbo + Level Ten Trans---(lots of pics!)
- ticket
- Header wrap on stainless steel header?
- Exhuast question?
- Adjustable exhaust cam gear?
- 2011 xB TRD CAI
- Transmission fitment question?
- Stock Toyota/xB2/TC2 differential reliability?
- New to Scionlife.com
- Injen's xB Intake system
- Weapon R throttle controller and Unichip work together?
- Throwin' Codes
- Engine just shut off on highway and now won't start
- Lighter fly wheels yes or no
- Exhaust Leak
- New battery vibrations / Alternator Replacement
- Convert back to CAI?
- Click, or snap from front tranny/axels?? anyone?
- glasspacks anyone?
- Has Anyone With A RS7 Removed The Resonator And Kept The TRD Exhaust????????
- Intake ?'s
- Exhaust Question
- Low cost source for xB2 coil-pack?
- 2012 xB, Borla Dual or TRD single
- 1st 2012 Mods / CAI & Borla Duals
- Bosch Iridium Spark Plugs
- Yes, another header thread. Any help will be really apreciated.
- My unichip review
- Transmission change?
- Lightweight flywheel chatter?
- narrowed it down to 3. just needing advice
- aftermarket CAI, void factory warranty?
- idles high
- strup
- TRD vs ACT clutch?
- Custom Dual Exhaust
- Why spend so much money?
- Exhaust sizing info
- Exhaust issues
- tc weapon r intake in a 2012 xb
- CAI Fitment on 2012xb
- LSD install price?!?
- Crank Sensor Plug Replacement?
- OB2 II
- Low oil levels
- Plastic Burning Type Smell
- Auto --> Manual Trans Swap.
- Oil consumption
- What is the best "tame" exhaust?
- TRD Exhuast Question ???
- Level 10 transmission
- PCV valve replacement
- Pic request
- 3rd gear shifting problems
- 2UR-GSE Into A XB
- Check engine lights anybody?
- tC valve cover on xB2...
- QTP on a 2gen Xb
- Help!!!a/c working random
- Exhaust help
- Up Date *4-26-12*Gaugeing interest For Tsudo Exhaust Company Scuba direct replacment.
- Valve Clearances for 09 engine
- Auto/manual trans mounts?
- Weapon R Header + S Pipe help
- P0607 Code, check eng went on then off?
- advice on buying an E351 trans
- Water Pump Failure Poll
- HPS intake feedback
- 2011 xb injen CAI also a SRI?
- New Header & CAI
- Walbro Pump install 2008 Scion XB -- finished
- Correct maf readings?
- Water pump leaking
- 3rd Gear
- Questions about n/a vs boost power
- Fuel link need help.......
- Replacing scuba
- NST Alternator Pulley
- 2010 xb engine pulses & drags
- New Tsudo Parts To Come.....
- !Aftermarket Clutch Flywheel help!
- intake
- 08-up GReddy SE Exhaust
- WTB 2008 xb engine
