View Full Version : Scion xB 2nd-Gen Suspension & Handling
Pages : 1 2 [3]
  1. TRD Sway Bar Bushing Install
  2. Just got a new xB...looking to drop it a little
  3. Rear Toe
  4. Rear tower bars?
  5. Tein Coilovers vs. Ksport coilovers in ride quality
  6. Stupid here -- anyone have initial alignment results with Eibach Prokit springs?
  7. Brake options
  8. DF210's or NF210's??
  9. TRD springs fading/rusting?
  10. 2nd gen xB stage 2 brake kit
  11. Shopping for Shocks -Tokico HP??
  12. H Tech of NF
  13. Shocks and springs?
  14. Hit curb, now noise at 68 MPH
  15. Anybody had any luck with home camber measurement?
  16. Tanabe strut tower bar
  17. HOTCHKIS rear sway bar broken.
  18. Upgrade
  19. Spring ride height?
  20. ksport
  21. ghetto air ride?
  22. Nurspec brake lines
  23. Installing coilovers...
  24. Camber bolts.
  25. Standard [STD] coilovers.
  26. tenzo r lowerin springs
  27. Tein coilovers
  28. A little change in ride height
  29. Shorter endlinks
  30. Drivers or Mechanics view ????
  31. Eibach Sport Lines on the Way
  32. Tein basic coilover vs k-sport gt pro damper
  33. AZ's first HTM Gen 2 on EasyStreet. *** New pics added ***
  34. Alignment After Drop
  35. Ksports installed
  36. Are rear shocks covered under standard warranty?
  37. What to do What to do...
  38. rear tires feathering
  39. 09 Stingray Xb, Hellatuck!
  40. I tried searching...tire size/drop question
  41. Another set of springs for the xB2 By K-Sport
  42. banging issue NEW failed steering rack
  43. Camber and New Rims - Teaser
  44. RS*R BEST*I coilovers
  45. rear wheel feathering
  46. Clunking Noise on Rear Passenger Side
  47. Want to slam it but curious about cargo
  48. Lifting the xB2, part 2.
  49. More brake options from Dezod for the xB2
  50. I Need an Alignment but Low w/Five Axis Kit
  51. BC Racing coilovers
  52. Can I get info on airbag suspension?
  53. Keep your Spare tire and have your air installed in your trunk
  54. Sprint Springs
  55. people with coilovers help me outt!@#$%
  56. Air tank question
  57. ...so i went ahead and dropped the front some.
  58. '10 xB RSB
  59. xb2 tenzo r lowering springs
  60. tanabe nf210 on 2010 xb
  61. Any specific retailer for Eibach Sportline or Sprint springs?
  62. springs vs air suspe.
  63. Spring install
  64. DF210 or Sportlines? 2011 (pics)
  65. Camber kits
  66. Air suspension setup :Show Off Thread:
  67. 08 bcm on air with 19'shere are some pics of our xb after air install
  68. TRD Shocks and Struts... Worth it?
  69. Alignment in Las Vegas
  70. engine damper and strut bar together?
  71. front end noise again
  72. Brakes already?!?!?
  73. what coilovers are you running?
  74. TEIN Coilovers installed
  75. Ksports for Hotchkis Stage1 TVS setup
  76. Stainless steel brake lines for xb2?
  77. MY BUILD THREAD!
  78. Air ride options,( just the front)
  79. Brembo Deal??
  80. DIY: 2nd Gen NST Shifter Bushings
  81. Clunking noise?
  82. New rotors and pads, strange noise?
  83. KSport Coils + Alignment = Frustration! HELP!!
  84. Suspension and wheel setup advice needed.
  85. D2 Coilovers and Hotchkis Sway Bar
  86. Handling
  87. Please recommend a snow tire setup...
  88. Raceland Coils for us xb2 guys
  89. Question?! Yes!
  90. Another NF210 Question
  91. Forjworks 2011 Scion XB Air ride systems front struts.
  92. 2nd gen xb bagged on 22's
  93. Air ride.
  94. "Thunk" noise coming from front suspension
  95. Is this low enough?
  96. Camber question
  97. Alignment in Spec But Still Getting Tire Wear
  98. Recommendations for new pads and rotors? where?
  99. Ksport GT Springs Or Tanabe DF210 Springs
  100. Blown CV Axle Boot
  101. DIY for changing rotors and pads?
  102. Hotchkis rear springs question?
  103. KSport coilover gurus!!!
  104. Anyone lowered on springs, come inside!
  105. Randode sienna bushings...
  106. How can I make XB feel like luxury sedan?
  107. Air Suspension ???
  108. Pricing and progression on full suspension rebuild
  109. Wheel Hub Assembly Part # for Rear
  110. What size crowsfoot for xB2 tie rod removal?
  111. Eibach Pro-Kit Springs or sportline on 19's
  112. Ksport adjustment
  113. TRD Sportivo
  114. S-techs installed on my 2011
  115. scionpro coilovers
  116. Forjworks AccuAir Suspension systems
  117. TRD Brake Pad and Brake lines
  118. xB2 Ride Height
  119. Coilovers?
  120. B&G Springs on my 2011
  121. rear hub replacement
  122. Strut Tower Brace Time
  123. Finally posting some pics of air ride setup.
  124. For those who d.i.y suspension
  125. void the warranty?
  126. DIY lowering the box! and calipers
  127. sienna shocks for air ride.
  128. Good shop in SoCal (LA/OC) to install suspension?
  129. BC coilovers and metallic blue rattle can hubcaps FTW!!
  130. Dual 380c fuse issue (easystreet kit)
  131. No Disrespect at all...
  132. Sway Bars and Springs on 20s?
  133. HELP! Will I Rub?
  134. XB Bagged Questions/Needs
  135. Forjworks AirREX Air Suspension Systems.
  136. EBC
  137. Tanabe DF210 in stock no wait
  138. Springs vs Air vs Coilovers?
  139. Ingalls Camber Bolts
  140. Adjusting ride height without removing coilover from car.
  141. Scionpro Kit Air Ride Installation Video
  142. Engine Torque Damper
  143. Tanabe Sustec Pro S-0C Coilovers Upgrade
  144. just finished installing my Forjworks air ride
  145. Which EBC brake pads?
  146. Kido Coilovers?
  147. Noise: Click/tick from baljoints maybe??
  148. Rear toe alignment needed?
  149. Adjustable shock/strut for xb2?
  150. Anyone running coilovers for mild drops?
  151. rear brake diagram?
  152. Jacking up car Question
  153. Hotchkis Sport sway bars or TRD rear sway bar only?
  154. AMR Engineering coilovers
  155. KW for 2nd gen?
  156. BC coilovers
  157. Lowering Springs 2012
  158. torque specs please...
  159. Ahh... can't hold it in anymore!
  160. just picked up some Hotchkis springs and f/r sway bars
  161. Xb2 weight distribution?
  162. TRD lowering springs
  163. Rear Disc Brake disassembly???
  164. Help fast please
  165. Rear tire cupping. Need help!
  166. Ksport vs Hotchkis springs, ride quality?
  167. coils vs springs.
  168. vibration at certain speed
  169. Looking for a Xb owner for trunk brace!
  170. FREE PARTS for a lucky Xb owner!
  171. BLACK AND YELLOW XB GETING AIRREX SUSPENSION w/ STAGE 3 DIGITAL
  172. Help me improve ride quality
  173. Help With H-Techs.
  174. Back for a little bit....need some info.
  175. Pulled the Trigger, FBSS Installed!
  176. static drop gen 2 xb(whos lowest) post your pics
  177. xB2 aggressive fitment thread.
  178. TRD BBK Rotor Specs
  179. DC Sports strut brace
  180. Coilover NOISE/CLUNKING
  181. Will 08-09 Hotchkis Sways Work On A 10
  182. Ksport GT Lowering Springs
  183. New wheels and tires, xb isn't as "sharp"?
  184. Brakes ???
  185. Few questions about Air Ride for xB2
  186. df210s to kports coilovers to air
