Extending cathode wiring
Old May 3, 2007 | 02:16 AM
burstaneurysm's Avatar
Default Extending cathode wiring
So I attempted extending the wiring for two cathodes tonight. I soldered the splice and made sure that the polarity was right. However, when I connected the pigtail to the transformer and they are about half of the brightness that they should be. Plus, the light doesn't go all the way across the cathode, it stops about an inch from the end of the tube. I used 20ga hookup wiring. What did I do wrong?
Old May 3, 2007 | 02:23 AM
g35drift's Avatar
it will always do that lol
i extended mine and they did the same thing :/
you could try to shorten the wire some more? but i dunno
Old May 3, 2007 | 02:57 AM
bufdaddy76's Avatar
crap i need to do the same thing is there no way to exstend them
I realy dont want to spend another 30 bucks on two more kits
Old May 3, 2007 | 05:12 AM
Archngl's Avatar
the wires cannot be extended... says so on oznium's website.
sorry folks.
Old May 3, 2007 | 01:41 PM
UV7's Avatar
UV7
Extending the wire adds more resistance, which the transformer and cathode don't seem to like. I was able to extend mine by a few inches without the dimming, but I have seen what you are talking about. How far are you trying to extend the wires?
Old May 3, 2007 | 04:09 PM
I really need the pigtail to be 2ft. I have the transformer mounted near the grille on the radiator supports. I have two running in the grille, and I want to strap the other two to my strut bar. So, if I want it to look remotely clean, I need to run the wiring along the fender well and under the core support.
Old May 3, 2007 | 04:27 PM
UV7's Avatar
UV7
You could try using larger gauge wire with a higher thread count, but I doubt that would alleviate enough resistance to allow you to stretch the 2 ft. you are hoping for. Have you tried contacting Oznium to see what they have to offer as a solution? Maybe they can shed some light on the subject.
Old May 3, 2007 | 04:35 PM
dudehitt's Avatar
I extended mine about 4-5" with no dimming, but I also used #16 wire. If your lights need to be 5 ft. apart (6" wire + 2 ft. extension + 2 ft. extension + 6" wire) then you should just add another transformer. You can usually buy them separately and they are really cheap.
Old May 3, 2007 | 08:58 PM
Yea, I just checked Oznium. I'll just tap off of the existing wiring. I have the randode underhood kit. I'm pretty sure it's tapping 12v in the cabin, do you know how many cathodes can be run off of his harness?
Old May 3, 2007 | 09:26 PM
dudehitt's Avatar
I don't know, but I can't imagine those inverters use a lot of current.
Old May 3, 2007 | 09:35 PM
I wouldn't think so... I just don't want to burn anything out.
Old May 3, 2007 | 09:43 PM
dudehitt's Avatar
I don't actually have Randy's kit so I don't know what size wire he uses, but you should have no problem as long as you have a fuse.
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
NewBox06
Feb 3, 2015 04:02 AM
Kodokan_4
11
Dec 4, 2004 01:34 AM
randode
44
Jun 29, 2004 04:19 PM
