help...Lighter outlet not working
Old May 6, 2007 | 05:43 PM
marx_tc602's Avatar
Default help...Lighter outlet not working
The problem is that i keep pressing it, but it wont stay in, it will always keep on popping out. It won't even warm up! Anyone know what the problem is?
Old May 6, 2007 | 05:48 PM
sciontcnj's Avatar
only thing i could say would be to check to see if the wires are properly hooked up...take the socket itself out and check the wires..otherwise idk if there is much else you could do. good luck
Old May 6, 2007 | 05:53 PM
marx_tc602's Avatar
ill check up on that. i guess if that isnt a problem, gotta make another trip to the dealer.
Old May 6, 2007 | 05:57 PM
SquallLHeart's Avatar
there's also a fuse you can check
Old May 6, 2007 | 06:07 PM
marx_tc602's Avatar
ah, that could possibly be the main cause.
Old May 6, 2007 | 06:43 PM
ScionJim23's Avatar
mine did this too. I dont smoke but use it to charge my cell phone but my reason was that my fuse blew. I just replaced it and it works fine
Old May 6, 2007 | 06:56 PM
marx_tc602's Avatar
thanks this helps a lot.
Old May 6, 2007 | 10:33 PM
neworldOZ's Avatar
ya my fuse blew a few times wiring leds to it =p
damn tc's with there mini fuses, i had to go to a scion dealership to buy them, anyone know another store that carrys them??
Old May 6, 2007 | 11:52 PM
marx_tc602's Avatar
i have no idea how i blew my fuse. maybe cause i use the power inverter too much, or i smoke too much.
anyway, how much do the mini fuses run for?
Old May 7, 2007 | 04:37 AM
neworldOZ's Avatar
um i believe it was like a doller 50 for 1 fuse, i blew 3 trying to wire a toggle switch with some led's, it didnt work to well so i gave up for the time being =P
the reguler fuses work fine, if u are just trying to work something out like i was doing, but u just cant close the fuse box cuz there to big, so u need a mini fuse,
xBSciontist
Jun 18, 2019 03:06 PM
helloninja
Mar 19, 2018 04:50 AM
missing_image
Feb 7, 2015 07:18 PM
cid_mcdp
Jan 5, 2015 02:45 PM
mdhyre
Dec 7, 2014 12:52 AM
